Safety
Types of safety precautions
- is used in connection with a procedure or situation that may result in serious injury or death.
- is used in connection with a procedure or situation that will result in damage to the product.
- is used to emphasize important information.
- is used for extra tips on how to utilize the features and functions of the device.
Safety precautions
Keep the device away from medical devices such as pacemakers, as well as key cards, credit cards and similar items. The device includes a strong magnet which may interfere with the operation of medical or other electronic devices and items with magnetically stored data.
Allergic reactions or skin irritations may occur when the product is in contact with skin, even though our products comply with industry standards. In such event, stop use immediately and consult a doctor.
Always consult your doctor before beginning an exercise program. Overexertion may cause serious injury.
Suunto products and services are intended for recreational use only and are not meant for medical purposes of any kind.
The LED lights on the side of the product do not replace any professional protective or rescue equipment. Always make sure that you use the appropriate safety gear for your specific activity.
Wearing headphones may impact your ability to hear your surroundings. Use your headphones responsibly and prioritize safety.
Before charging, ensure that the charging port of the headphones is free from any residual liquid. Liquid on the charging port damages the headphones’ circuit.
Do not use the product during thunderstorms. Thunderstorms can cause abnormal device operation and increase the risk of electric shock.
Even if your headphones are waterproof, do not charge them while wet. Charging wet headphones can lead to fire or electrical shock. Make sure that the charging cable and the headphones are dry before charging the headphones.
Do not apply solvent of any kind to the product, as it may damage the surface.
Do not apply insect repellent on the product, as it may damage the surface.
Do not knock or drop the product, as it may get damaged.
Do not throw the product away, but treat it as electronic waste to preserve the environment.
Always comply with the local laws and regulations when using the product outdoors and when using it among people.
Make sure you fully understand how to use your headphones and what their limitations are by reading all the printed documentation and the online user manual. Always remember that you are responsible for your own safety.
