SUUNTO WING 2
Safety & Regulatory information Download PDF
SAFETY
Safety
Types of safety precautions
WARNING:
- is used in connection with a procedure or situation that may result in serious injury or death.
CAUTION:
- is used in connection with a procedure or situation that will result in damage to the product.
- is used to emphasize important information.
- is used for extra tips on how to utilize the features and functions of the device.
Safety precautions
WARNING:
Keep the device away from medical devices such as pacemakers, as well as key cards, credit cards and similar items. The device includes a strong magnet which may interfere with the operation of medical or other electronic devices and items with magnetically stored data.
WARNING:
Allergic reactions or skin irritations may occur when the product is in contact with skin, even though our products comply with industry standards. In such event, stop use immediately and consult a doctor.
WARNING:
Always consult your doctor before beginning an exercise program. Overexertion may cause serious injury.
WARNING:
Suunto products and services are intended for recreational use only and are not meant for medical purposes of any kind.
WARNING:
The LED lights on the side of the product do not replace any professional protective or rescue equipment. Always make sure that you use the appropriate safety gear for your specific activity.
WARNING:
Wearing headphones may impact your ability to hear your surroundings. Use your headphones responsibly and prioritize safety.
WARNING:
Before charging, ensure that the charging port of the headphones is free from any residual liquid. Liquid on the charging port damages the headphones’ circuit.
WARNING:
Do not use the product during thunderstorms. Thunderstorms can cause abnormal device operation and increase the risk of electric shock.
WARNING:
Even if your headphones are waterproof, do not charge them while wet. Charging wet headphones can lead to fire or electrical shock. Make sure that the charging cable and the headphones are dry before charging the headphones.
CAUTION:
Do not apply solvent of any kind to the product, as it may damage the surface.
CAUTION:
Do not apply insect repellent on the product, as it may damage the surface.
CAUTION:
Do not knock or drop the product, as it may get damaged.
Do not throw the product away, but treat it as electronic waste to preserve the environment.
Always comply with the local laws and regulations when using the product outdoors and when using it among people.
Make sure you fully understand how to use your headphones and what their limitations are by reading all the printed documentation and the online user manual. Always remember that you are responsible for your own safety.
Getting started
Getting started
Buttons
Suunto Wing 2 has three buttons you can use to switch song, adjust volume and answer or end phone calls.
- multifunction button
- and power button
- button
Switching on/off the device
- keep the button pressed for 3 seconds to switch the device on or off
Listening to audio
press the multifunction button once to start or stop playing the audio
press the multifunction button twice to skip to the next track
press the multifunction button three times to return to the previous track
press the button to increase volume
press the button to decrease volume
keep the multifunction button and the button pressed simultaneously for 3 seconds to switch sound mode
Making a phone call
press the multifunction button once to answer or end a call
Adjusting settings when the device is on
keep the button pressed for 3 seconds to switch the LED lights on
keep the button pressed again for 3 seconds to switch between 5 light modes
keep the multifunction button and the button pressed simultaneously for 3 seconds to enable Head Movement Control
in pairing mode, keep the multifunction button and the button pressed simultaneously for 3 seconds to enable dual device connection
Buttons
- and power button
- button
Listening to audio
Making a phone call
Microphone
Your Suunto Wing 2 comes with dual microphone and environmental noise cancellation (ENC) technology. These features guarantee good voice quality of your phone calls even in noisy or windy conditions.
You find the microphones on the right side of the headphones:
- dual microphone
CAUTION:
Do not wash the microphone holes directly with water or volatile liquids, as they may affect the performance of the microphone.
Bluetooth connectivity
Your Suunto Wing 2 headphones communicate with the compatible devices via Bluetooth. You can pair the product with any Bluetooth devices capable of playing audio, such as mobile phones, smart watches, tablets, etc. For information on how to pair the headphones with a compatible device, see Pairing.
You can connect your headphones to two Bluetooth devices at the same time. See Dual device connection.
If you want to disconnect the headphones and the compatible device, you can do so in the Bluetooth settings of the paired device. You have two options. To keep the headphones on the Bluetooth list of the paired device and ensure quick reconnection, simply disconnect the devices. If you want to completely remove the headphones from the Bluetooth list of the paired device, delete the headphones from the list of Bluetooth connections. In this case, if you want to use the headphones and the Bluetooth device again, you have to start pairing from the beginning.
If you move outside of the Bluetooth connection range for more than 3 minutes while wearing Suunto Wing 2, the headphones and the paired device disconnect.
When the Bluetooth connection between the headphones and the compatible device is lost for more than one hour, Suunto Wing 2 will automatically power off to save battery. To use the headphones again, you need to turn the device back on.
Pairing
Before you use your Suunto Wing 2 for the first time, you need to pair it with a compatible device.
If Suunto Wing 2 is not switched on:
Keep the button pressed. After 3 seconds, Suunto Wing 2 switches on. Do not release the button.
Keep the button pressed for 2 more seconds to enter pairing mode. When the red LED lights start blinking, the product is ready for pairing.
Make sure Bluetooth is enabled on the device you want to pair your Suunto Wing 2 with.
Under the Bluetooth settings of the compatible device, open the list of nearby devices.
Find Suunto Wing 2 on the list and pair the headphones with the device.
When the pairing is successful, the headphones will play a sound and the LED lights switch off.
Near-field communication (NFC)
Your Suunto Wing 2 can be paired with a compatible mobile phone using NFC.
When the headphones are on, put their left side with the NFC logo close to the part of your mobile phone where the NFC chip is placed. A popup message appears on the screen offering to pair the phone with Suunto Wing 2.
Suunto app
With the Suunto app on your phone, you can further enrich your Suunto Wing 2 experience. Pair your headphones with the mobile app to adjust Head Movement Control, sound mode, light mode and more.
To adjust headphones settings in Suunto app:
- Pair Suunto Wing 2 with the compatible mobile device via Bluetooth. See Pairing.
- Download and install Suunto app on your compatible mobile device from the iTunes App Store, Google Play or several popular app stores in China.
- Start Suunto app on your phone.
- The app automatically connects to your headphones.
- Go to your profile in Suunto app and open the headphones menu to adjust product settings.
Wearing the headphones
Suunto Wing 2 headphones are bone conduction headphones with open-ear style, allowing you to listen to audio and still hear your surroundings during exercises.
For the proper experience, put the headphones to the back of your head, with the hooks on your ears so that the transducers rest in front of your ears. Keep the back of the headphones parallel to the ground.
Whether you are training in the gym or you are out on rugged paths, the headphones stay stable on your head. Thanks to their light weight and the open-ear style, the headphones are comfortable to use for several hours. You can wear Suunto Wing 2 together with a bike helmet or a hat and even under a beanie.
Features
Features
Head Movement Control is a function for convenient, hands-free operation. By nodding and shaking your head, you can switch between audio tracks and answer or decline phone calls.
To use the Head Movement Control, you have to activate the function. You can activate it in the Suunto app or by keeping the multifunction button and the button pressed simultaneously for 3 seconds.
After activating the Head Movement Control, you are able to control the audio playback and phone calls without pressing any buttons. While listening to music, shake your head twice to switch to the next track. When you have an incoming call while wearing the headphones, nod twice to answer the call or shake your head twice to decline it.
Make sure you turn your head at a sufficiently large angle and complete the movements within 1 second.
Take a break of at least 5 seconds between the different operations.
If you use the Head Movement Control function during exercise, it may result in false triggering. We recommend that you familiarize yourself with the behavior of the Head Movement Control function to determine its suitability for your specific activities.
The Head Movement Control accelerates the battery consumption of the headphones, and when turned on, it reduces the battery life by about 15%.
WARNING:
Head Movement Control is intended for auxiliary operation only. Prioritize safety when using this function. Do not solely rely on Head Movement Control for critical actions that require your full attention and manual control.
WARNING:
LED lights
LED lights are designed to enhance your visibility during sports activities in darker conditions. Thanks to the red LED lights on the sides of your Suunto Wing 2, your surroundings can notice you more easily.
You can turn the LED lights on or off and you can select from different light modes: static, blinking, SOS, cadence sync, and turn & brake. Turn the LED lights on or off and switch light modes in the Suunto app or by long pressing the button.
In cadence sync mode, the light flashes in sync with your cadence. In turn & brake mode, the corresponding side light activates when you turn your head to check traffic, and both side lights illuminate during sudden braking. As these modes may occasionally be triggered unintentionally, we recommend testing them in advance to ensure they suit your activity.
WARNING:
The LED lights do not replace any professional protective or rescue equipment. Always make sure that you use the appropriate safety gear for your specific activity.
WARNING:
The visibility range of the LED lights may be affected by various factors, including weather conditions, ambient brightness, air quality, and other external factors. Always consider these factors before using your headphones.
The LED lights accelerate the battery consumption of the headphones, and when turned on, they reduce the battery life by about 50%.
LED lights have a protective coating that protects the lights during production. Please note that this coating will wear off the product over time. This phenomenon is normal and it does not cause any quality change.
Sound mode
You can choose from different sound modes when wearing your headphones. Your Suunto Wing 2 offers a normal sound mode for everyday use and light exercises and another sound mode for outdoor trainings and noisy conditions. In the outdoor sound mode, the volume is higher. Select the mode that provides the best experience in your given situation.
Noise may occur at high volume levels.
While listening to audio, you can switch sound mode by keeping the multifunction button and the button pressed simultaneously for 3 seconds. If you have Suunto app installed on your phone, you can also change sound mode in the app.
WARNING:
Prolonged use of headphones at high volume levels can lead to hearing damage and sound distortion.
WARNING:
Voice feedback
If you have a voice feedback capable Suunto watch, you can get voice feedback with valuable information during your exercise. The feedback can help you to keep track of your progress and give you useful indicators, depending on what feedback options you have selected. The headphones must be paired with your watch before using this feature.
This feature is available only on Suunto 9 Peak Pro, Suunto Vertical series, Suunto Race series, and Suunto Ocean series.
To connect your headphones with yout Suunto watch, you need to install the Suunto Wing 2 app from the SuuntoPlus™ Store on the watch.
- Switch the Suunto Wing 2 headphones on.
- From the exercise start screen on your watch, scroll down and select SuuntoPlus™.
- Toggle Suunto Wing 2 app on.
- Wait for the watch to automatically connect with the Suunto Wing 2 headphones.
- Go back and press Start.
When multiple headphones are available for your watch to connect, make sure that you connect the intended devices. When connected to the watch, the headphones play a sound.
If both the headphones and the Suunto app are connected to your watch, voice feedback may be played through the app. To ensure the feedback is heard through the headphones, it’s recommended to close the app in the background.
To activate voice feedback on your watch before an exercise:
- Before starting an exercise, scroll down and select Voice feedback.
- Toggle Voice feedback on.
- Scroll down and select which voice feedback you want activated by turning the toggles on/off.
- Make sure your headphones are on and paired with your watch.
- Go back and start your exercise as you normally do.
Your headphones will now bring you various voice feedback during your exercise, depending on which voice feedback you have activated.
To activate voice feedback on your watch during an exercise:
- Long press the lower button to enter Control panel.
- Scroll down and select Voice feedback.
- Go back and resume your exercise.
You can connect your Suunto Wing 2 headphones to two Bluetooth devices at the same time. With the help of the dual device connection function, you can easily switch to your phone and answer a call while listening to music from your computer.
Follow these steps to pair your headphones with two devices:
- If your headphones are switched on, switch them off.
- Keep the button pressed for 5 seconds to switch the headphones on and enter pairing mode.
- While the red LED light is blinking, keep the multifunction button and the button pressed simultaneously for 3 seconds to enable dual device connection. The headphones will play a sound when the function is enabled.
- Under the Bluetooth settings of the first compatible device, open the list of nearby devices.
- Find Suunto Wing 2 in the list and pair the headphones with the first device.
- Switch your headphones off.
- Keep the button pressed for 5 seconds to switch the headphones back on and enter pairing mode.
- Under the Bluetooth settings of the second compatible device, open the list of nearby devices.
- Find Suunto Wing 2 on the list and pair the headphones with the second device.
- When you connect the second device, the first device temporarily disconnects from the headphones. To reconnect the first device, go to the Bluetooth settings of the device or simply restart the headphones.
When the headphones are already paired with a device with Suunto app:
- Enable dual device connection in Suunto app.
You can check the list of the connected devices in Suunto app.
When you use Suunto Wing 2 with two paired devices at the same time, the headphones determine their own priority based on the order of the played content and the tasks. Normally, the first played audio takes precedence over the second, and phone calls take precedence over audio playback. However, the actual operation of different brands and models of the compatible devices may vary.
Settings
Settings
Device info
You can check device info, for example, the software version of your headphones in Suunto app.
Device info
Software updates
Software updates add important improvements to your headphones. For updating the software, the headphones must be connected to Suunto app. Internet connection is required for downloading the update package. For installing the update package, the battery level of the headphones must be at least 20%.
When an update is available, a popup window offers you the update option after opening Suunto app. Keep the headphones connected to your mobile phone during the update process. When the update is complete, the headphones will restart.
You can check the software version of your headphones under the device settings in Suunto app.
Resetting the headphones
In case you want to delete all your settings from Suunto Wing 2, you can reset the product. While Suunto Wing 2 is charging, keep the multifunction button pressed for 5 seconds. When the red LED lights blink twice and the headphones play a sound, the reset is successful.
After the reset, the Bluetooth pairing records are deleted from the headphones. When you want to use the headphones again, you have to start the pairing process from the beginning. See Pairing.
Care and support
Care and support
Handling guidelines
Handle the unit with care, do not knock or drop it. Do not store the headphones below heavy items as the headphones may get deformed.
Although the headphones are resistant to sweat and rain, do not soak them in water for a long time. When the surface of the product is dirty, wipe it clean with a soft dry cloth. Pay special attention to the microphones, buttons, and charger pins.
Under normal circumstances, the headphones do not require servicing.
Use only original Suunto accessories. Damage caused by non-original accessories is not covered by warranty.
Handling guidelines
Battery and charging
The battery performance on a single charge depends on how you use your headphones and in what conditions. Low temperatures, for example, reduce the duration of a single charge. In general, the capacity of rechargeable batteries decreases over time.
The headphones are fully charged in one hour, and you can listen to up to 12 hours of music with one charge.
When the battery level is less than 5%, the headphones play a low battery alarm tone every 5 minutes, and the red LED lights are blinking.
To check the battery status of your headphones, connect the product to Suunto app. You can see the battery status on the headphones' page in the app.
For charging your headphones, you can use the supplied USB cable or the portable powerbank.
USB cable
The USB charging cable is included in the product package. For charging the headphones with the cable, connect the end of the cable to the charging port of the headphones. If the headphones are switched on, they will automatically switch off when the charging starts. While the headphones are charging, the LED lights are on. When the battery is fully charged, the LED lights turn off.
Powerbank
For charging the headphones while on the move, the package of the product contains a portable powerbank, offering extra 24 hours of battery life.
Before using the powerbank, you have to charge it with a USB-C cable. To check the battery status of the powerbank, press the button on the front side. Lights start blinking on the top of the device, each light representing 25% of battery capacity.
To charge your Suunto Wing 2 with the powerbank, insert the headphones into the holes on the top of it. If the headphones are switched on, they will automatically switch off when connected to the powerbank. When the charging starts, the LED lights on the headphones turn on and the lights on the powerbank are blinking for one minute. When the battery is fully charged, the LED lights on the headphones turn off.
When inserting the headphones on the powerbank, make sure that the charging ports are in contact. The charging starts only when you can see the lights of the headphones on and the lights on the powerbank start blinking. If you do not see the lights, move the headphones a bit so that the ports are in contact.
WARNING:
Before charging, ensure that the charging ports of the headphones and the powerbank are free from any residual liquid. Liquid on the charging ports damage the headphones' and the powerbank's circuit.
Disposal
Please dispose of the device in accordance with local regulations for electronic waste. Do not throw it in the garbage. If you wish, you may return the device to your nearest Suunto dealer.
Reference
Reference
Compliance
For compliance related information and detailed technical specifications, see “Product Safety and Regulatory Information” delivered together with your Suunto Wing 2 or available at www.suunto.com/userguides.
Compliance
CE
Hereby, Suunto Oy, declares that the radio equipment type HS251 is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: www.suunto.com/EUconformity.
