Suunto 9 Peak Pro
All Black
Pro version of multisport watch for smaller wrists.
- Sapphire touchscreen and stainless steel bezel
- 10.8 mm thin sport watch body
- Powerful processor and redesigned user interface
- 4 satellite systems for best positioning accuracy
- 40 hours of battery life in the best GPS mode
- Advanced training metrics with 100+ sport modes
Choose Your Color
Durability and looks,
combined
Suunto 9 Peak Pro is a powerful multisport watch with extended battery life and military-grade durability.
The ultra thin and timeless design makes it beautiful on the outside, too.
Enjoy the smooth interface
In sports, every second counts. Thanks to the powerful chipset, Suunto 9 Peak Pro reacts faster to your touch than ever before.
We also completely redesigned the user interface, making it even more intuitive to use and easier to read.
Best-in-class battery life and improved GPS
Even on longer adventures, Suunto 9 Peak Pro is a reliable companion. It features the best battery life of similar-sized sports watches: up to 40 hours in the best GPS mode.
The superior GPS allows you to see your location, pace and distance with greater accuracy, even in challenging environments.
Battery life
With Suunto 9 Peak Pro, you can push your limits without worrying about running out of power. Performance mode is activated by default at the start of exercise. If you need to keep going longer, you can change the mode in the watch settings.
Training, continuous tracking
Up to 40 hours
Performance mode, best GPS accuracy (single-band)
Up to 300 hours
Up to 21 days
Daily heart rate on, display wakes on wrist-raise
Up to 30 days
Extremely tough.Extremely elegant.
The robustness of the Suunto 9 Peak Pro was tested according to US military standards. Waterproof up to 100 meters, it is built from the highest quality materials, such as sapphire glass, stainless steel and titanium in selected versions.
Toughness can still look elegant. Together with its predecessors, the Suunto 9 Peak Pro is the thinnest GPS multisport watch on the market.
Made for adventures, from trails to underwater
What’s your exercise of choice? With presets for more than 95 sport modes, you’re good to go whether you’re at the gym or climbing a mountain. Receive personalized feedback on your training load, progress and recovery, calculated based on heart rate variability (HRV). For more information, follow your efforts in Training Zone on Suunto App or coaching tools such as TrainingPeaks.
With a dedicated snorkeling mode, Suunto 9 Peak Pro is ready to accompany you on your underwater adventures.
Designed to go the distance
Enhance your experience with Suunto app and SuuntoPlus™
Suunto app helps you plan, analyse and share your routes, workouts and activity data. You can connect to over 200 partner apps, such as Strava, komoot and TrainingPeaks.
Within the app, you'll find the SuuntoPlus™ Store, where you can customize your watch even further with new features and connected devices. Make it yours!
ХАРАКТЕРИСТИКИ
Размеры43 x 43 x 10.8 mm / 1.69 x 1.69 x 0.43 "
Вес64 g / 2.26 oz
Материал безеля:Stainless steel
Материал стекла:Sapphire crystal
Материал корпуса:Glass fibre reinforced polyamide
Материал ремешка:Silicone
КомплектацияSuunto 9 Peak Pro All Black, charging cable, printed user documentation
Страна производстваCN
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляStainless steel
Материал стеклаSapphire crystal
Материал корпусаGlass fibre reinforced polyamide
Материал ремешкаSilicone
Вес64 g / 2.26 oz
Обхват запястья125-175 mm or 125-200 mm depending on the model (accessory straps -215 mm)
Ширина ремешка22 mm
Встроенный наручный пульсометр✔
Настраиваемые экраны✔
Блокировка сенсорного экрана✔
Сенсорный дисплей✔
Цветной экран✔
Виброоповещение✔
Водостойкий100 m
Тип батареиrechargeable lithium-ion
Обновляемое встроенное ПО✔
Время, дата✔
Будильник✔
Время для двух часовых поясов✔
Автоматический хронометраж✔
Таймер обратного отсчета✔
Секундомер✔
ЯзыкиEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Chinese language is only available in the China edition watches.
ПодсветкаLED
Настраиваемая подсветкаautomatic brightness
Блокировка кнопокduring exercise
Размер экрана1,2"
Тип дисплеяmatrix
Разрешение дисплея240 x 240
Метрическая и британская системы измерения✔
Автоматические беспроводное обновление прошивки✔
Индикатор заряда батареиpercentage / icon
Насыщение крови кислородом✔
Дисплей всегда вкл.✔
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-20° C to +55° C / -5° F to +130° F
Температура хранения-20° C to +55° C / -5° F to +130° F
Рекомендуемая температура зарядки0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Intelligent charge reminders✔
Daily use: Smartwatch modeup to 21 days
Daily use: Standby time mode onlyup to 30 days
Training: All-Systems GNSS mode + Single-Bandup to 40h
Training: All battery modes battery promises40h / 70h / 300h
Training: Power saving GNSS modesup to 300h
КОМПАС
Цифровой компас✔
Компенсация склонения✔
Коррекция склонения✔
Шкала направленияdegrees / mils
Стрелкаnorth indicator
Точность компаса5°
Дискретность компаса1°
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Возможности подключения (между устройствами)Bluetooth
Совместимо с приложением Suunto✔
Уведомления телефона на часах✔
Управление мультимедиа на часах✔
Отправка заранее заданных ответов на входящие сообщения с часовAndroid only
Поддержка спортивных онлайн-сообществ✔
Обновление ПО часов из облака✔
Автоматическое обновление программного обеспечения по беспроводной сети✔
Совместимость со смартфонамиMost common models supported
МУЗЫКА
Управляйте музыкой с часов✔
24/7
ОТСЛЕЖИВАНИЕ АКТИВНОСТИ
Счетчик шагов✔
Количество сожженных калорий✔
Цели активности✔
История занятий✔
Скорость сжигания калорий и частота сердцебиения во время повседневных активностей✔
Отслеживание дневной минимальной ЧСС✔
ОТСЛЕЖИВАНИЕ СНА
Продолжительность сна✔
Время сна✔
Время бодрствования✔
Глубокий сон✔
Средняя и минимальная частота пульса во время сна✔
Легкий сон✔
HRV во сне✔
Качество сна✔
СТРЕСС И ВОССТАНОВЛЕНИЕ
Уровень дневного ресурса✔
Стресс и восстановление✔
Вычисление HRV✔
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
Спутниковые системыGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportL1
Simultaneous satellite systems4
Max connected satellites32
Интеллектуальные режимы работы от батареиPerformance, Endurance, Tour, Custom
Интервал регистрации GPSBest, OK, Low
Навигация по путевым точкам и визуальная навигация по маршруту✔
Масштабирование при навигации✔
Автомасштабирование в зависимости от формы маршрута✔
Построение обратного маршрута в реальном времени✔
Планирование маршрутов с профилем высот✔
Топография местности и спутниковые карты✔
Глобальные тепловые карты по 20 видам спорта✔
Планирование маршрута с тепловыми картами✔
Личная библиотека маршрутов в Интернете синхронизирована с часами✔
Контроль маршрута✔
Навигация по интересующим пунктам (POI)✔
ETA (расчетное время прибытия), остающееся расстояние✔
Анализ маршрута по данным GPS✔
Параметры, просмотр и экспорт маршрутов✔
ETA (расчетное время прибытия)✔
Bearing navigation✔
Карты местности: спутниковые, физические и топографические от Mapbox, Google Maps и Android✔
АЛЬТИМЕТР
Барометрический альтиметр✔
Высота по данным GPS✔
Объединение данных GPS с данными барометрического альтиметра (FusedAltiTM)✔
Высота в повседневном режиме✔
Акклиматизация на высоте с контролем уровня насыщения крови кислородом✔
Общий подъем/спуск✔
Вертикальная скорость✔
Автопереключение профиля высотомера и барометра✔
Интервал регистрации в журнале1 s
Дискретность1 m
Диапазон-500 - 9999 m
ПОГОДА
Время восхода/захода солнца✔
Штормовое предупреждение✔
Атмосферное давление✔
Термометр✔
Диапазон отображения температуры-20° C to +55° C / -5° F to +130° F
Дискретность температуры1° C / 1.5° F
Дискретность давления1 hPa
Отображение графика высоты в общих сведениях о тренировке✔
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ИНТЕРВАЛЬНАЯ ТРЕНИРОВКА
Настройка интервалов✔
Подсказки в ходе интервальной тренировки✔
Спланированные интервальные тренировки✔
ЧАСТОТА СЕРДЦЕБИЕНИЯ
Измерение пульса на запястье✔
Совместимость с поясами-кардиодатчикамиBluetooth Smart belts
Интервал RRwith Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Частота сердцебиения в удаках в минуту✔
Запись сердечного ритма при плавании✔
График частоты сердцебиения в режиме реального времени✔
Информация о средней частоте сердцебиения в режиме реального времени✔
Калории✔
Максимальная эффективность тренировки✔
Личные пульсовые зоны✔
Уровень подготовки (макс. VO2)✔
Время восстановления✔
СКОРОСТЬ И РАССТОЯНИЕ
Измерение скорости и расстояния по данным датчика каденса✔
Скорость и расстояние по данным GPS✔
Хронограф✔
Поддержка Foot PODBluetooth Smart
Автоэтапы✔
Ручной отсчет этапов✔
Анализ темпа, графики скорости и маршруты на карте✔
ВОССТАНОВЛЕНИЕ ПОСЛЕ ТРЕНИРОВОК
Сохранение ощущения после тренировки на часы✔
Время восстановления в зависимости от тренировок✔
НАГРУЗКА ПРИ ТРЕНИРОВКЕ
Журнал с подробностями тренировок✔
Сводка из журнала в часах с информацией по этапам✔
Общие сведения о тренировке с подробностями этапов✔
Журнал тренировок для обзора длительных периодов✔
Итоговая тренировочная нагрузка по видам спорта✔
ДЕЛИТЕСЬ И ПЕРЕЖИВАЙТЕ ЗАНОВО
Публикация тренировок в соцсетях✔
Комментарии и оценки к тренировкам✔
Подписывайтесь на других участников и читайте комментарии через ленту активностей✔
АДАПТИВНЫЕ СОВЕТЫ ПО ТРЕНИРОВКАМ
Интенсивность и продолжительность занятия на основании советов в реальном времени✔
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ПЛАВАНИЕ
Темп и расстояние заплыва в бассейне✔
Дистанция плавания в открытой воде✔
Время плавания: длина дорожки, этап, общее✔
Частота гребков, количество и тип✔
Эффективность гребков (SWOLF)✔
Автоматические интервалы✔
Таблица этапов для интервальной тренировки✔
ЕЗДА НА ВЕЛОСИПЕДЕ
Скорость езды✔
Средняя скорость в режиме реального времени✔
Bike POD с поддержкой скорости/частоты вращения педалейBluetooth Smart
Поддержка датчика мощности при езде на велосипедеBluetooth Smart
Мощность езды на велосипеде (Вт), средняя и максимальная (с датчиком мощности)Bluetooth Smart
Bike Lap and Lap Maximum Power (с датчиком мощности)✔
Таблица этапов в реальном времени со средними показателями: частота сердцебиения, мощность и скорость✔
Подсказки для интервальных тренировок с мощностью, скоростью и пульсом✔
БЕГ
Темп бега✔
Suunto FusedSpeed™✔
Контроль маршрута✔
Мощность бегаfrom wrist or with Stryd sensor
SuuntoPlus™ Ghost runner✔
Калибровка Foot PODautomatic
Таблица данных кругового хронографа в часах и приложении Suunto✔
Темп: средний, максимальный, этапа — в режиме реального времени✔
Подсказки для интервальных тренировок с темпом бега, пульсом и расстоянием✔
ТРЕНИРОВКИ С НЕСКОЛЬКИМИ ВИДАМИ СПОРТА
Изменение спортивного режима во время тренировки✔
Настроенные режимы для тренировок с несколькими видами спорта✔
Пост-анализ многоборья по видам спорта✔
Общие сведения о тренировке с несколькими видами спорта на часах✔
СПОРТИВНЫЕ РЕЖИМЫ
Настройка спортивных режимов и дисплеев✔
Графические дисплеи в спортивных режимах✔
Предустановленные спортивные режимы в часах> 95
SuuntoPlus™Yes, check the details from here
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
ФРИДАЙВИНГ
Глубиномер для подводного плавания с трубкой10 m
