1 / 5
Suunto Nautic Bungee Cord
1/5
Money-back guarantee
30-Days Return
Global Support
SKU : SS051300000
Suunto Nautic
Bungee Cord
Prix de vente€699
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Quantité
30-Days Return
Global Support
€699
Ajouter au panier
Bright AMOLED display, integrated
LED flashlight
Up to 120 hours on a single charge
Wireless tank
pressure
Multi-gas and sidemount support
GPS and underwater route tracking
Suunto App
connectivity
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Rugged leak-proof construction
Glove-friendly
buttons
Designed and tested
in Finland
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Rechargeable battery.
single charge
Reliable power for
multi-day diving trips
Designed for endurance
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Multi-gas and
sidemount support
Customizable dive
views
Full decompression
planning
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Wireless tank
pressure readings
Dual transmitter
support for
sidemount diving
Color-coded visuals
for instant clarity
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Offline maps and GPS help plan and track your routes, while the built-in digital compass provides precise direction underwater. Tide, weather, and sunrise/sunset data support safe surface intervals and the integrated flashlight brings visibility and convenience when light is scarce. Nautic keeps you aware and in control, both underwater and on the surface.
GPS and offline maps
Digital compass for underwater
navigation
LED flashlight, tide, and weather support
for safety
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Automatic dive log
sync
Route and condition tracking
Share and relive
every dive
Explore more with the Suunto app
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Access additional benefits and services from our 200+ partners.
Learn more
SPÉCIFICATIONS
  • Mesures
    101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
  • Poids
    227g (with bungee strap) , 232g (with elastic textile strap)
  • Matériau de la lunette
    Fiber reinforced polymer
  • Matériau du verre
    Panda glass (PANDA-MN228 high alumina silicon glass)
  • Matériau du boîtier
  • Matériau du bracelet
    Bungee cord / Elastic textile
  • Pays de fabrication
    FI
TECHNICAL SPECIFICATIONS
GÉNÉRAL
  • Matériau du verre
  • Poids
  • Écran couleur
  • Alerte par vibration
  • Résistance à l’eau
    200 m
  • Type de batterie
    rechargeable lithium-ion
  • Mise à jour du firmware
  • Heure, date
  • Chronomètre
  • Langue
  • Rétroéclairage
    AMOLED
  • Rétroéclairage configurable
    automatic brightness
  • Verrouillage des boutons
  • Taille de l’écran
    3,26"
  • Type d’écran
    matrix
  • Résolution de l’écran
    720x382
  • Heure d’été automatique
  • Indicateur de batterie
    percentage / icon
  • Affichage permanent
CARACTÉRISTIQUES PHYSIQUES
  • Operating temperature in dive mode
  • Température de stockage
  • Température de mise en charge recommandée
AUTONOMIE
  • Rappels de charge intelligents
  • Autonomie de la batterie (plongée)
    80-190h
BOUSSOLE
  • Boussole numérique
  • Boussole numérique en plongée sous-marine
  • Correction de déclinaison
  • Échelle de direction
  • Aiguille
  • Précision de la boussole
  • Résolution de la boussole
CONNECTIVITÉ
    Bluetooth
  • Compatible avec l'application Suunto
  • Mises à jour logicielles de la montre depuis le cloud
  • Mises à jour logicielles sans fil automatiques
  • Compatibilité avec les smartphones
    Most common models supported, check here for detailed compatibility list
SUIVI GPS & NAVIGATION
  • Cartes hors ligne sur la montre
  • Systèmes par satellite
  • GNSS frequency support
    Dual band (L1+L5)
  • Offline map storage size
    32 GB
  • Systèmes satellites simultanés
    4
  • Nombre maximum de satellites connectés
    32
  • Fréquence d'enregistrement GPS
    Best, Good, OK, Low
  • Niveaux de zoom dans la navigation
  • Création de trace en temps réel (« Petit Poucet »)
  • Cartes topographiques et cartes satellite
  • Cartes de fréquentation du monde entier pour 20 sports
  • Navigation vers un point d'intérêt (POI)
  • Analyse de trace GPS
  • Enregistrement, visualisation et partage des itinéraires
MÉTÉO
  • Heures de lever/coucher du soleil
  • Température
  • Résolution de température
    1° C / 1.5° F
FRÉQUENCE CARDIAQUE
  • Compatibilité ceinture de fréquence cardiaque
    Bluetooth HR belts
L'EXPERTISE DU SPORT
MODES SPORTIFS
  • Modes sportifs et affichages personnalisables
    Customizable dive
  • Affichages graphiques dans les modes sportifs
    In dive
  • Modes sportifs préinstallés sur la montre
    Dive modes
  • Convient aux sports
    Scubadive
FONCTIONS DE PLONGÉE
BASIQUE
  • Ajustement l'altitude
  • remontée temps écran.
  • CNS/OTU (OLF) Calculs
  • personnalisés Modes de plongée écran.
  • modèle de décompression
    Suunto Bühlmann 16 GF
  • décompression profil Options
    continuous and stepped
  • Historique de plongée
    lifetime
  • temps de plongée
  • La consommation de gaz en temps
  • Gaz max pO₂
    manual 1.0 - 1.6
  • Changement de gaz
  • temps de gaz
  • Gaz
    up to 5 gases (Oxygen 21 - 100%)
  • Jauge
    200m
  • Nitrox (et air)
  • Temps d'interdiction de vol
  • Ajustement personnel
    Gradient factors low (10-100) and high (50-100)
  • Paliers de sécurité
  • Temps de surface
  • Minuteur
  • Intégration de l'air sans fil
  • Intégration du gaz sans fil
  • Deco planner
  • Helium
  • CNS/OTU (OLF) 80% / 100%
  • Temps de plongée
  • Temps de gaz
  • pO2 élevé (hyperoxique)
  • pO2 bas (hypoxique)
  • NDL (temps de non-décompression)
  • Changement de gaz (gaz optimal disponible)
  • Pression du réservoir
  • Ascension trop rapide
APNÉE
  • Alarme de profondeur
  • Alarme de temps de plongée
Recommended products
Support for Suunto Nautic
