Suunto Vertical 2
Black
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
Specifikationer
Mått48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
Vikt87g
Material i infattning:Stainless steel
Material i glas:Sapphire crystal
Material i boett:Glass fibre reinforced polyamide
Material i armband:Silicone
TillverkningslandCN
TEKNISKA SPECIFIKATIONER
ALLMÄNT
Bezel materialStainless steel
Glass materialSapphire crystal
Case materialGlass fibre reinforced polyamide
Strap materialSilicone
Weight87g
Handledsmått125-175 mm
Armbandsbredd22 mm
Integrerad pulsmätning på handleden✔
Anpassningsbara urtavlor✔
Lås för pekskärm✔
Pekskärmsdisplay✔
Färgskärm✔
Vibrationsavisering✔
Vattentäthet100 m
Batterityprechargeable lithium-ion
Uppgraderbar programvara✔
Tid, datum✔
Väckarklocka✔
Dubbla tidszoner✔
Automatisk tidtagning✔
Nedräknare✔
Stoppur✔
SpråkCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
BakgrundsbelysningLTPO AMOLED
Justerbar bakgrundsbelysningautomatic brightness
Knapplåsduring exercise
Skärmstorlek1,5"
Visningstypmatrix
Displayupplösning466 x 466
Metriska/brittiska enheter✔
Automatic daylight saving time✔
Batteristatuspercentage / icon
Syremättnad✔
Alltid på-skjerm✔
FYSISKA SPECIFIKATIONER
Driftstemperatur-20° C to +55° C / -5° F to +130° F
Förvaringstemperatur-20° C to +55° C / -5° F to +130° F
Rekommenderad laddningstemperatur0° C to +45° C / +32° F to +110° F
BATTERITID
Intelligenta laddningspåminnelser✔
Daglig användning: Smartwatch-lägeup to 20 days
Daglig användning: Endast standby-lägeup to 40 days
Träning: Alla system GNSS-läge + Multi-Bandup to 65h (AOD 60h)
Träning: Alla system GNSS-läge + Single-Bandup to 75h (AOD 70h)
Träning: Batterilöften för alla lägen65h / 75h / 110h / 250h
Träning: Energisparlägen för GNSSup to 250h
KOMPASS
Digital kompass✔
Lutningskompensation✔
Missvisningskorrektion✔
Riktningsskaladegrees / mils
Nålnorth indicator
Kompassprecision5°
Kompassupplösning1°
ANSLUTNINGSMÖJLIGHETER
Anslutbarhet (mellan enheter)Bluetooth
Kompatibel med Suunto-appen✔
Phone notifications on the watch✔
Mediakontroller på klockan✔
Skicka fördefinierade svar på inkommande meddelanden direkt från klockanAndroid only
Kompatibel med sportforum onlineStrava, TrainingPeaks and more
Uppdateringar av programvara för klocka från molnet✔
Automatiska over the air-uppdateringar✔
Smartphone compatibilityMost common models supported, check here for detailed compatibility list
DYGNET RUNT
AKTIVITETSREGISTRERING
Stegräknare✔
Kaloriförbrukning✔
Aktivitetsmålsteps, calories
Aktivitetshistorik✔
Kaloriförbrukning och pulsmätning under dagliga aktiviteter✔
Registrering minsta dagliga puls✔
SÖMNREGISTRERING
Sömntid✔
Sängtider✔
Tid vaken✔
Djupt viloläge✔
Medelvärde och minimivärde för puls under sömn✔
Lätt sömn✔
REM-sömn✔
Pulsvariabilitet (HRV) från sömn✔
Sömnkvalitet✔
STRESS OCH ÅTERHÄMTNING
Daglig resursnivå✔
Stress- och återhämtningsstatus✔
Pulsvariabilitetsmätning✔
FRILUFTSFUNKTIONER
SPÅRNING OCH NAVIGERING MED GPS
Offlinekartor på klockan✔
SatellitsystemGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Simultana satellitsystem4
Max anslutna satelliter32
Intelligenta batterilägenPerformance, Endurance, Ultra, Tour, Custom
GPS-registreringsfrekvensBest, Good, OK, Low
Ruttpunktsnavigering och visuell ruttnavigering✔
Zoomnivåer i navigering✔
Autozoom baserat på ruttens utformning✔
Brödsmulespår i realtid✔
Ruttplanering med höjdprofil✔
Utomhusterräng och satellitkartor✔
Globala värmekartor för 20 sporter✔
Ruttplanering med värmekartor✔
Eget ruttbibliotek synkroniserat för visning✔
Fäst för att skapa en rutt✔
Intressepunktsnavigering✔
Analys av GPS-spårning✔
Spårloggning, visning och delning✔
ETA (beräknad ankomsttid)✔
HÖJDMÄTARE
Höjdmätning med barometer✔
GPS-höjd✔
GPS-korrigerad höjdmätning med barometer (FusedAlti™)✔
Höjd i dagligt läge✔
Höjdacklimatisering med syremättnad✔
Total uppstigning/nedstigning✔
Vertical speed✔
Automatisk växling mellan höjd/baro✔
Loggningsfrekvens1 s
Upplösning1 m
Omfång-500 - 9999 m
VÄDER
Tid för soluppgång/solnedgång✔
Stormvarning✔
Lufttryck vid havsytan✔
Temperatur✔
Temperaturvisning-20° C to +55° C / -5° F to +130° F
Temperaturnoggrannhet1° C / 1.5° F
Tryckupplösning1 hPa
Ett diagram över höjdskillnader visas i träningssammanställningen✔
TRÄNINGSFUNKTIONER
INTERVALLTRÄNING
Intervallinställningar✔
Intervallvägledning under träning✔
Strukturerade intervaller✔
PULS
Pulsmätning från handleden✔
Kompatibilitet med pulsbältenBluetooth HR belts
RR-intervallwith Suunto Smart Sensor
Puls som hjärtslag per minut✔
Registrerar puls vid simning✔
Diagram över puls i realtid✔
Genomsnittlig puls i realtid✔
Kalorier✔
Toppträningseffekt✔
Personliga pulszoner✔
Konditionsnivå (VO2max)✔
Laktattröskeldetektering✔
Återhämtningstid✔
HASTIGHET OCH STRÄCKA
Kadensbaserad hastighet och distans✔
GPS hastighet och sträcka✔
Tidtagning✔
Foot POD-supportBluetooth Foot Pods
Autovarv✔
Manuella varv✔
Analys av takt, hastighetsdiagram och spår på kartan✔
ÅTERHÄMTNING EFTER TRÄNING
Känsla sparas i klockan efter träning✔
Träningsbaserad återhämtningstid✔
TRÄNINGSBELASTNING
Loggbok med träningsinformation✔
Träningsbelastning med resultat per sport✔
Träningsloggbok för långtidsöversikt✔
Träningssammanfattning med varvinformation✔
DELA OCH ÅTERUPPLEV
Dela träningspass i sociala medier✔
Bedöma och kommentera träningspass✔
Följ andra medlemmar och få feedback via aktivitetsströmning✔
SPORTEXPERTIS
SIMNING
Simtakt och distans i bassäng✔
Simavstånd på öppet vatten✔
Simtid efter bassänglängd, mellantid, total✔
Simtagsfrekvens, antal simtag och simstil✔
Simtagseffektivitet (SWOLF)✔
Automatiska intervall✔
Varvtabell för intervaller✔
CYKLING
Cykelhastighet✔
Snitthastighet i realtid✔
Cykel-POD med stöd för hastighet/kadensBluetooth Bike Pods
Stöd för mätare av cykeleffektBluetooth Power meters
Cykeleffekt (W), snitt och max (med effektsensor)Bluetooth Power meters
Cykelvarv och maximal effekt för mellantid (med effektsensor)✔
Varvtabeller i realtid med genomsnittlig puls, effekt och hastighet✔
Intervallvägledning med effekt/hastighet/puls✔
LÖPNING
Löptakt✔
Suunto FusedSpeed™✔
Löpningseffekt✔
SuuntoPlus™ Ghost runner✔
Foot POD-kalibreringautomatic
Varvtabell i klocka och Suunto-app✔
Snitt, max, varvtempo i realtid✔
Intervallvägledning med takt/puls/distans för löpning✔
MULTISPORTER
Ändra sportläge under träning✔
Förkonfigurerade multisportlägen✔
Efteranalys av multisportträning anpassad efter sport✔
Träningssammanställning för multisport i klockan✔
SPORTLÄGEN
Anpassningsbara sportlägen och displayer✔
Grafisk visning i sportlägen✔
Klockans förinställda sportlägen> 90
SuuntoPlus™✔
DYKFUNKTIONER
FRIDYKNING
Djupmätare för snorkling10 m
