Suunto Nautic S
An easy-to-use dive computer with interchangeable straps that fit your style. Made in Finland.
Choose Your Color
Designed for every dive
Suunto Nautic S is built for divers and freedivers who embrace every underwater moment. Compact yet powerful, it combines performance, style and reliability in a design that fits perfectly on your wrist - from first dives to advanced adventures.
With a bright AMOLED display, intuitive controls and trusted Suunto craftsmanship, Nautic S brings together the best of diving technology and everyday usability.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Compact design, made to endure
Reliability is everything underwater. Suunto Nautic S is engineered to perform in demanding conditions, dive after dive.
Its durable, pressure-resistant build and bright AMOLED display ensure clear visibility and confidence on each dive. The new elastic textile strap offers superior comfort and flexibility, adapting to every exposure suit and diving condition.
Whether you’re exploring reefs, practicing freediving, or preparing for your next adventure, Nautic S is designed to keep up wherever your dive takes you.
Power that lasts beyond the surface
When your adventure extends across multiple dives, endurance matters. Suunto Nautic S delivers up to 60 hours of dive time on a single charge - more than enough for a long dive weekend or a remote expedition.
Made for every dive and every diver
From your first open-water course to advanced adventures, Suunto Nautic S grows with you and your diving hobby.
It supports single- and multi-gas modes, sidemount configurations and customizable dive views letting you see exactly what you need, when you need it.
Easy to use yet powerful, Nautic S keeps you in control and lets you focus on what diving is truly about: freedom underwater.
Real-time awareness, wireless precision
Stay informed every moment. Wireless tank pressure support provides real-time gas readings directly on your wrist.
Dual transmitter support enables sidemount divers to follow both tanks with ease, while clear, color-coded visuals keep you instantly aware throughout the dive.
Awareness below and above the surface
Built-in GPS, offline maps, tide- and weather data with sunrise / sunset times help you prepare for your dives and transitions. Together with the digital compass, these tools keep you oriented in all conditions.
Smarter connection, deeper reflection
After each dive, Suunto app extends your experience. Sync your logs automatically, review detailed data, and relive every underwater route with notes, buddy info and conditions.
From dive planning to sharing your best moments, Nautic S keeps every adventure part of a bigger story: yours.
Explore more with the Suunto app
Specifikationer
Mått49.9 x 49.9 x 13.3 mm / 1.96 x 1.96 x 0.52 "
Vikt81g
Material i infattning:Stainless steel
Material i glas:Sapphire crystal
Material i boett:Glass fibre reinforced polyamide
Material i armband:Elastic textile
TillverkningslandFI
TEKNISKA SPECIFIKATIONER
ALLMÄNT
Bezel materialStainless steel
Glass materialSapphire crystal
Case materialGlass fibre reinforced polyamide
Strap materialElastic textile
Weight81g
Armbandsbredd22 mm
Anpassningsbara urtavlor✔
Lås för pekskärm✔
Pekskärmsdisplay✔
Färgskärm✔
Vibrationsavisering✔
Vattentäthet100 m
Batterityprechargeable lithium-ion
Uppgraderbar programvara✔
Tid, datum✔
Väckarklocka✔
Dubbla tidszoner✔
Nedräknare✔
Stoppur✔
SpråkCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
BakgrundsbelysningAMOLED
Justerbar bakgrundsbelysningautomatic brightness
Knapplås✔
Skärmstorlek1,43''
Visningstypmatrix
Displayupplösning466 x 466
Metriska/brittiska enheter✔
Automatic daylight saving time✔
Batteristatuspercentage / icon
Alltid på-skjerm✔
FYSISKA SPECIFIKATIONER
Driftstemperatur-20° C to +55° C / -5° F to +130° F
Driftstemperatur i dykläge0° C to +40° C / +32° F to +104° F
Förvaringstemperatur-20° C to +55° C / -5° F to +130° F
Rekommenderad laddningstemperatur0° C to +35° C / +32° F to +95° F
BATTERITID
Intelligenta laddningspåminnelser✔
Daglig användning: Endast standby-lägeup to 26 days
Batteritid (dykning)40 - 60h
KOMPASS
Digital kompass✔
Digital kompass vid dykning✔
Lutningskompensation✔
Missvisningskorrektion✔
Riktningsskala✔
Nål✔
Kompassprecision5°
Kompassupplösning1°
ANSLUTNINGSMÖJLIGHETER
Anslutbarhet (mellan enheter)Bluetooth
Kompatibel med Suunto-appen✔
Phone notifications on the watch✔
Skicka fördefinierade svar på inkommande meddelanden direkt från klockanAndroid only
Uppdateringar av programvara för klocka från molnet✔
Automatiska over the air-uppdateringar✔
Smartphone compatibilityMost common models supported, check here for detailed compatibility list
FRILUFTSFUNKTIONER
SPÅRNING OCH NAVIGERING MED GPS
Offlinekartor på klockan✔
SatellitsystemGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Offline map storage size32 GB
Simultana satellitsystem4
Max anslutna satelliter32
GPS-registreringsfrekvensBest, Good, OK, Low
Zoomnivåer i navigering✔
Brödsmulespår i realtid✔
Utomhusterräng och satellitkartor✔
Globala värmekartor för 20 sporter✔
Ruttplanering med värmekartor✔
Eget ruttbibliotek synkroniserat för visning✔
Fäst för att skapa en rutt✔
Intressepunktsnavigering✔
Analys av GPS-spårning✔
Spårloggning, visning och delning✔
ETA (beräknad ankomsttid)✔
VÄDER
Tid för soluppgång/solnedgång✔
Stormvarning✔
Lufttryck vid havsytan✔
Automatisk växling mellan höjd/baro✔
Temperatur✔
Temperaturvisning-20° C to +55° C / -5° F to +130° F
Temperaturnoggrannhet1° C / 1.5° F
TRÄNINGSFUNKTIONER
PULS
Kompatibilitet med pulsbältenBluetooth HR belts
SPORTEXPERTIS
SPORTLÄGEN
Anpassningsbara sportlägen och displayerCustomizable dive
Grafisk visning i sportlägenIn dive
Klockans förinställda sportlägenDive modes
Lämplig för olika sporterScubadive , Freedive, Snorkeling
DYKFUNKTIONER
GRUNDLÄGGANDE
Höjdjustering0 - 300 m / 300 -1500 m / 1500 - 3000 m
Visning av uppstigningstid✔
Beräkning av CNS/OTU (OLF)✔
Anpassningsbara dyklägen och skärmar✔
DekompressionsmodellSuunto Bühlmann 16 GF
Alternativ för dekompressionsprofilcontinuous and stepped
Dykhistoriklifetime
Dyktid✔
Fridykning✔
Gasförbrukning (realtid)✔
Max pO2 för gasmanual 1.0 - 1.6
Gasväxling✔
Gastid✔
Gaserup to 5 gases (Oxygen 21 - 100%)
Gauge✔
Maximalt användningsdjup (EN 13319)80m
Nitrox (och luft)✔
Flygförbudstid✔
Planerare för dyk utan dekompression✔
Personlig justeringGradient factors low (10-100) and high (50-100)
Säkerhetsstopp✔
Yttid✔
Timer✔
Trådlös tryckmätning✔
Deco planner✔
DYKLARM OCH MEDDELANDEN
CNS/OTU (OLF) 80 % / 100 %✔
Överträdelse av dekompressionstak✔
Dyktid✔
Gastid✔
Högt pO2 (hyperoxiskt)✔
Maxdjup✔
NDL✔
Switch gas (better gas is available)✔
Flasktryck✔
Alltför snabb stigning✔
FRIDYKNING
Djuplarm✔
Meddelande om djup✔
Dyktidslarm✔
Fridykningshistorik per dag✔
Antal fridykningar✔
Total historik för fridykning✔
Meddelande om yttid✔
Depth meter for freedive80m
