Suunto Nautic
Elastic Textile Strap
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Explore more with the Suunto app
Specifikationer
Mått101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
Vikt227g (with bungee strap) , 232g (with elastic textile strap)
Material i infattning:Fiber reinforced polymer
Material i glas:Panda glass (PANDA-MN228 high alumina silicon glass)
Material i boett:Glass fibre reinforced polyamide
Material i armband:Bungee cord / Elastic textile
TillverkningslandFI
TEKNISKA SPECIFIKATIONER
ALLMÄNT
Bezel materialFiber reinforced polymer
Glass materialPanda glass (PANDA-MN228 high alumina silicon glass)
Case materialGlass fibre reinforced polyamide
Strap materialBungee cord / Elastic textile
Weight227g (with bungee strap) , 232g (with elastic textile strap)
Färgskärm✔
Vibrationsavisering✔
Vattentäthet200 m
Batterityprechargeable lithium-ion
Uppgraderbar programvara✔
Tid, datum✔
Stoppur✔
SpråkCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
BakgrundsbelysningAMOLED
Justerbar bakgrundsbelysningautomatic brightness
Knapplås✔
Skärmstorlek3,26"
Visningstypmatrix
Displayupplösning720x382
Metriska/brittiska enheter✔
Automatic daylight saving time✔
Batteristatuspercentage / icon
Alltid på-skjerm✔
FYSISKA SPECIFIKATIONER
Driftstemperatur-20° C to +55° C / -5° F to +130° F
Driftstemperatur i dykläge0° C to +40° C / +32° F to +104° F
Förvaringstemperatur-20° C to +55° C / -5° F to +130° F
Rekommenderad laddningstemperatur0° C to +35° C / +32° F to +95° F
BATTERITID
Intelligenta laddningspåminnelser✔
Batteritid (dykning)80-190h
KOMPASS
Digital kompass✔
Digital kompass vid dykning✔
Lutningskompensation✔
Missvisningskorrektion✔
Riktningsskala✔
Nål✔
Kompassprecision5°
Kompassupplösning1°
ANSLUTNINGSMÖJLIGHETER
Anslutbarhet (mellan enheter)Bluetooth
Kompatibel med Suunto-appen✔
Uppdateringar av programvara för klocka från molnet✔
Automatiska over the air-uppdateringar✔
Smartphone compatibilityMost common models supported, check here for detailed compatibility list
FRILUFTSFUNKTIONER
SPÅRNING OCH NAVIGERING MED GPS
Offlinekartor på klockan✔
SatellitsystemGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Offline map storage size32 GB
Simultana satellitsystem4
Max anslutna satelliter32
GPS-registreringsfrekvensBest, Good, OK, Low
Zoomnivåer i navigering✔
Brödsmulespår i realtid✔
Utomhusterräng och satellitkartor✔
Globala värmekartor för 20 sporter✔
Intressepunktsnavigering✔
Analys av GPS-spårning✔
Spårloggning, visning och delning✔
VÄDER
Tid för soluppgång/solnedgång✔
Temperatur✔
Temperaturvisning-20° C to +55° C / -5° F to +130° F
Temperaturnoggrannhet1° C / 1.5° F
TRÄNINGSFUNKTIONER
PULS
Kompatibilitet med pulsbältenBluetooth HR belts
SPORTEXPERTIS
SPORTLÄGEN
Anpassningsbara sportlägen och displayerCustomizable dive
Grafisk visning i sportlägenIn dive
Klockans förinställda sportlägenDive modes
Lämplig för olika sporterScubadive
DYKFUNKTIONER
GRUNDLÄGGANDE
Höjdjustering0 - 300 m / 300 -1500 m / 1500 - 3000 m
Visning av uppstigningstid✔
Beräkning av CNS/OTU (OLF)✔
Anpassningsbara dyklägen och skärmar✔
DekompressionsmodellSuunto Bühlmann 16 GF
Alternativ för dekompressionsprofilcontinuous and stepped
Dykhistoriklifetime
Dyktid✔
Gasförbrukning (realtid)✔
Max pO2 för gasmanual 1.0 - 1.6
Gasväxling✔
Gastid✔
Gaserup to 5 gases (Oxygen 21 - 100%)
Gauge✔
Maximalt användningsdjup (EN 13319)200m
Nitrox (och luft)✔
Flygförbudstid✔
Planerare för dyk utan dekompression✔
Personlig justeringGradient factors low (10-100) and high (50-100)
Säkerhetsstopp✔
Yttid✔
Timer✔
Trådlös tryckmätning✔
Trådlös gasintegration✔
Deco planner✔
Helium✔
DYKLARM OCH MEDDELANDEN
CNS/OTU (OLF) 80 % / 100 %✔
Överträdelse av dekompressionstak✔
Dyktid✔
Gastid✔
Högt pO2 (hyperoxiskt)✔
Lågt pO2 (hypoxiskt)✔
Maxdjup✔
NDL✔
Switch gas (better gas is available)✔
Flasktryck✔
Alltför snabb stigning✔
FRIDYKNING
Djuplarm✔
Dyktidslarm✔
