Slutsåld
Suunto Nautic Bungee Cord & Tank Pod
Money-back guarantee
30-Days Return
Global Support
Art.nr: SS051302000
Suunto Nautic
Rea-pris€999
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Coming in December
Antal
30-Days Return
Global Support
€999
Slutsåld
Bright AMOLED display, integrated
LED flashlight
Up to 120 hours on a single charge
Wireless tank
pressure
Multi-gas and sidemount support
GPS and underwater route tracking
Suunto App
connectivity
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Rugged leak-proof construction
Glove-friendly
buttons
Designed and tested
in Finland
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Rechargeable battery.
single charge
Reliable power for
multi-day diving trips
Designed for endurance
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Multi-gas and
sidemount support
Customizable dive
views
Full decompression
planning
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Wireless tank
pressure readings
Dual transmitter
support for
sidemount diving
Color-coded visuals
for instant clarity
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Offline maps and GPS help plan and track your routes, while the built-in digital compass provides precise direction underwater. Tide, weather, and sunrise/sunset data support safe surface intervals and the integrated flashlight brings visibility and convenience when light is scarce. Nautic keeps you aware and in control, both underwater and on the surface.
GPS and offline maps
Digital compass for underwater
navigation
LED flashlight, tide, and weather support
for safety
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Automatic dive log
sync
Route and condition tracking
Share and relive
every dive
Explore more with the Suunto app
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Access additional benefits and services from our 200+ partners.
Learn more
Specifikationer
  • Mått
    101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
  • Vikt
    227g (with bungee strap) , 232g (with elastic textile strap)
  • Material i infattning:
    Fiber reinforced polymer
  • Material i glas:
    Panda glass (PANDA-MN228 high alumina silicon glass)
  • Material i boett:
  • Material i armband:
    Bungee cord / Elastic textile
  • Tillverkningsland
    FI
TEKNISKA SPECIFIKATIONER
ALLMÄNT
  • Bezel material
  • Glass material
  • Case material
  • Strap material
  • Weight
  • Färgskärm
  • Vibrationsavisering
  • Vattentäthet
    200 m
  • Batterityp
    rechargeable lithium-ion
  • Uppgraderbar programvara
  • Tid, datum
  • Stoppur
  • Språk
  • Bakgrundsbelysning
    AMOLED
  • Justerbar bakgrundsbelysning
    automatic brightness
  • Knapplås
  • Skärmstorlek
    3,26"
  • Visningstyp
    matrix
  • Displayupplösning
    720x382
  • Metriska/brittiska enheter
  • Batteristatus
    percentage / icon
  • Alltid på-skjerm
FYSISKA SPECIFIKATIONER
  • Driftstemperatur
  • Driftstemperatur i dykläge
  • Förvaringstemperatur
  • Rekommenderad laddningstemperatur
BATTERITID
  • Intelligenta laddningspåminnelser
  • Batteritid (dykning)
    80-190h
KOMPASS
  • Digital kompass
  • Digital kompass vid dykning
  • Lutningskompensation
  • Missvisningskorrektion
  • Riktningsskala
  • Nål
  • Kompassprecision
  • Kompassupplösning
ANSLUTNINGSMÖJLIGHETER
  • Anslutbarhet (mellan enheter)
    Bluetooth
  • Kompatibel med Suunto-appen
  • Uppdateringar av programvara för klocka från molnet
  • Automatiska over the air-uppdateringar
  • Smartphone compatibility
    Most common models supported, check here for detailed compatibility list
FRILUFTSFUNKTIONER
SPÅRNING OCH NAVIGERING MED GPS
  • Offlinekartor på klockan
  • Satellitsystem
  • GNSS frequency support
    Dual band (L1+L5)
  • Offline map storage size
    32 GB
  • Simultana satellitsystem
    4
  • Max anslutna satelliter
    32
  • GPS-registreringsfrekvens
    Best, Good, OK, Low
  • Zoomnivåer i navigering
  • Brödsmulespår i realtid
  • Utomhusterräng och satellitkartor
  • Globala värmekartor för 20 sporter
  • Intressepunktsnavigering
  • Analys av GPS-spårning
  • Spårloggning, visning och delning
VÄDER
  • Tid för soluppgång/solnedgång
  • Temperatur
  • Temperaturvisning
  • Temperaturnoggrannhet
    1° C / 1.5° F
TRÄNINGSFUNKTIONER
PULS
  • Kompatibilitet med pulsbälten
    Bluetooth HR belts
SPORTEXPERTIS
SPORTLÄGEN
  • Anpassningsbara sportlägen och displayer
    Customizable dive
  • Grafisk visning i sportlägen
    In dive
  • Klockans förinställda sportlägen
    Dive modes
  • Lämplig för olika sporter
    Scubadive
DYKFUNKTIONER
GRUNDLÄGGANDE
  • Höjdjustering
  • Visning av uppstigningstid
  • Beräkning av CNS/OTU (OLF)
  • Anpassningsbara dyklägen och skärmar
  • Dekompressionsmodell
    Suunto Bühlmann 16 GF
  • Alternativ för dekompressionsprofil
    continuous and stepped
  • Dykhistorik
    lifetime
  • Dyktid
  • Gasförbrukning (realtid)
  • Max pO2 för gas
    manual 1.0 - 1.6
  • Gasväxling
  • Gastid
  • Gaser
    up to 5 gases (Oxygen 21 - 100%)
  • Gauge
  • Maximalt användningsdjup (EN 13319)
    200m
  • Nitrox (och luft)
  • Flygförbudstid
  • Planerare för dyk utan dekompression
  • Personlig justering
    Gradient factors low (10-100) and high (50-100)
  • Säkerhetsstopp
  • Yttid
  • Timer
  • Trådlös tryckmätning
  • Trådlös gasintegration
  • Deco planner
  • Helium
DYKLARM OCH MEDDELANDEN
  • CNS/OTU (OLF) 80 % / 100 %
  • Överträdelse av dekompressionstak
  • Dyktid
  • Gastid
  • Högt pO2 (hyperoxiskt)
  • Lågt pO2 (hypoxiskt)
  • Maxdjup
  • NDL
  • Flasktryck
  • Alltför snabb stigning
FRIDYKNING
  • Djuplarm
  • Dyktidslarm
Recommended products
Support for Suunto Nautic
