Suunto 9 Baro Titanium
Ultra-endurance GPS watch with exceptional battery life and barometer
Built to last – just like you!
When you have your mind set on a certain goal or adventure, you want to make sure your watch can also go the distance. With up to 7 days of continuous GPS tracking Suunto 9 is built to last – just like you!
Suunto 9 is a multisport GPS watch designed for athletes who demand the best from their sports watch. Intelligent battery life management system with smart reminders ensures your watch will last just as long as you need it to. The robust Suunto 9 is made for long, arduous training and racing and extreme adventures.
HUVUDFUNKTIONER
Väderfunktioner
Suunto 9 blir hela tiden bättre
Uppdatera programvaran för Suunto 9 för att få de senaste funktionerna.
Fördelar
OROA DIG ALDRIG ÖVER ATT BATTERIET SKA TA SLUT
TESTAD UNDER TUFFA FÖRHÅLLANDEN
SUUNTO FUSEDTRACK™ – BÄTTRE PRECISION FÖR SPÅRNING OCH DISTANS
DELA DIN PASSION MED SUUNTO-APPEN
ANSLUT TILL DINA FAVORITAPPAR
Specifikationer
Mått51.5 x 51.5 x 17 mm / 2.03 x 2.03 x 0.67 "
Vikt76 g / 2.68 oz
Material i infattning:Titanium Grade 5
Material i glas:Sapphire crystal
Material i boett:Glass fibre reinforced polyamide
Material i armband:Silicone
InnehållSuunto 9 Baro Titanium, charging cable, Quick Guide, Warranty Leaflet
TillverkningslandFI
TEKNISKA SPECIFIKATIONER
ALLMÄNT
Bezel materialTitanium Grade 5
Glass materialSapphire crystal
Case materialGlass fibre reinforced polyamide
Strap materialSilicone
Weight76 g / 2.68 oz
Handledsmått130-220 mm
Armbandsbredd24 mm
Integrerad pulsmätning på handleden✔
Anpassningsbara urtavlor✔
Lås för pekskärmduring exercise
Pekskärmsdisplay✔
Färgskärm✔
Vibrationsavisering✔
Vattentäthet100 m
Batterityprechargeable lithium-ion
Uppgraderbar programvara✔
Tid, datum✔
Väckarklocka✔
Dubbla tidszoner✔
Automatisk tidtagning✔
Nedräknare✔
Stoppur✔
SpråkEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Chinese language is only available in the China edition watches.
BakgrundsbelysningLED
Justerbar bakgrundsbelysningbrightness / mode
Knapplåsduring exercise
Skärmstorlek1.34"
Visningstypmatrix
Displayupplösning320 x 300
Metriska/brittiska enheter✔
Automatic daylight saving time✔
Batteristatuspercentage / icon
FYSISKA SPECIFIKATIONER
Driftstemperatur-20° C to +55° C / -5° F to +130° F
Förvaringstemperatur-30° C to +55° C / -22° F to +130° F
Rekommenderad laddningstemperatur0° C to +35° C / +32° F to +95° F
BATTERITID
Intelligenta laddningspåminnelser✔
I tidsläget14 days
Med aktivitetsregistrering dygnet runt och mobilaviseringar7 days
Träningsläge med GPS25h / 50h / 120h / 170h
KOMPASS
Digital kompass✔
Lutningskompensation✔
Missvisningskorrektion✔
Riktningsskaladegrees / mils
Nålnorth indicator
Kompassprecision5°
Kompassupplösning1°
ANSLUTNINGSMÖJLIGHETER
Anslutbarhet (mellan enheter)Bluetooth
Kompatibel med Suunto-appen✔
Phone notifications on the watch✔
Mediakontroller på klockan✔
Skicka fördefinierade svar på inkommande meddelanden direkt från klockanAndroid only
Kompatibel med sportforum online✔
Uppdateringar av programvara för klocka från molnet✔
Smartphone compatibilityMost common models supported
DYGNET RUNT
AKTIVITETSREGISTRERING
Stegräknare✔
Kaloriförbrukning✔
Aktivitetsmålsteps, calories
Aktivitetshistorik✔
Kaloriförbrukning och pulsmätning under dagliga aktiviteter✔
Registrering minsta dagliga puls✔
SÖMNREGISTRERING
Sömntid✔
Sängtider✔
Tid vaken✔
Djupt viloläge✔
Sömnkvalitet✔
STRESS OCH ÅTERHÄMTNING
Daglig resursnivå✔
Stress- och återhämtningsstatus✔
FRILUFTSFUNKTIONER
SPÅRNING OCH NAVIGERING MED GPS
SatellitsystemGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportL1
Simultana satellitsystem2
Max anslutna satelliter12
Intelligenta batterilägenPerformance, Endurance, Ultra, Tour, Custom
GPS-registreringsfrekvensBest, Good, OK, Low
Ruttpunktsnavigering och visuell ruttnavigering✔
Zoomnivåer i navigering✔
Autozoom baserat på ruttens utformning✔
Brödsmulespår i realtid✔
Ruttplanering med höjdprofil✔
Utomhusterräng och satellitkartor✔
Globala värmekartor för 20 sporter✔
Ruttplanering med värmekartor✔
Eget ruttbibliotek synkroniserat för visning✔
Fäst för att skapa en rutt✔
Intressepunktsnavigering✔
Analys av GPS-spårning✔
Spårloggning, visning och delning✔
ETA (beräknad ankomsttid)✔
Riktningsnavigering✔
Utomhuskartor av typerna satellit, terräng och topografi på webben via Mapbox, Google Maps & Android✔
HÖJDMÄTARE
Höjdmätning med barometer✔
GPS-höjd✔
GPS-korrigerad höjdmätning med barometer (FusedAlti™)✔
Höjd i dagligt läge✔
Total uppstigning/nedstigning✔
Vertical speed✔
Automatisk växling mellan höjd/baro✔
Loggningsfrekvens1 s
Upplösning1 m
Omfång-500 - 9999 m
VÄDER
Tid för soluppgång/solnedgång✔
Stormvarning✔
Lufttryck vid havsytan✔
Temperatur✔
Temperaturvisning-20° C to +55° C / -5° F to +130° F
Temperaturnoggrannhet1° C / 1.5° F
Tryckupplösning1 hPa
Ett diagram över höjdskillnader visas i träningssammanställningen✔
TRÄNINGSFUNKTIONER
INTERVALLTRÄNING
Intervallinställningar✔
Intervallvägledning under träning✔
PULS
Pulsmätning från handleden✔
Kompatibilitet med pulsbältenBluetooth Smart belts
RR-intervallwith Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Puls som hjärtslag per minut✔
Registrerar puls vid simning✔
Diagram över puls i realtid✔
Genomsnittlig puls i realtid✔
Kalorier✔
Toppträningseffekt✔
Personliga pulszoner✔
Konditionsnivå (VO2max)✔
Återhämtningstid✔
HASTIGHET OCH STRÄCKA
Kadensbaserad hastighet och distans✔
GPS hastighet och sträcka✔
Tidtagning✔
Foot POD-supportBluetooth Smart
Autovarv✔
Manuella varv✔
Analys av takt, hastighetsdiagram och spår på kartan✔
ÅTERHÄMTNING EFTER TRÄNING
Känsla sparas i klockan efter träning✔
Träningsbaserad återhämtningstid✔
TRÄNINGSBELASTNING
Loggbok med träningsinformation✔
Träningsbelastning med resultat per sport✔
Träningsloggbok för långtidsöversikt✔
Träningssammanfattning med varvinformation✔
DELA OCH ÅTERUPPLEV
Dela träningspass i sociala medier✔
Bedöma och kommentera träningspass✔
Följ andra medlemmar och få feedback via aktivitetsströmning✔
SPORTEXPERTIS
SIMNING
Simtakt och distans i bassäng✔
Simavstånd på öppet vatten✔
Simtid efter bassänglängd, mellantid, total✔
Simtagsfrekvens, antal simtag och simstil✔
Simtagseffektivitet (SWOLF)✔
Automatiska intervall✔
Varvtabell för intervaller✔
CYKLING
Cykelhastighet✔
Snitthastighet i realtid✔
Cykel-POD med stöd för hastighet/kadensBluetooth Smart
Stöd för mätare av cykeleffektBluetooth Smart
Cykeleffekt (W), snitt och max (med effektsensor)Bluetooth Smart
Cykelvarv och maximal effekt för mellantid (med effektsensor)✔
Varvtabeller i realtid med genomsnittlig puls, effekt och hastighet✔
Intervallvägledning med effekt/hastighet/puls✔
LÖPNING
Löptakt✔
Suunto FusedSpeed™✔
Löpningseffektwith Stryd sensor
SuuntoPlus™ Ghost runner✔
Foot POD-kalibreringautomatic
Varvtabell i klocka och Suunto-app✔
Snitt, max, varvtempo i realtid✔
Intervallvägledning med takt/puls/distans för löpning✔
MULTISPORTER
Ändra sportläge under träning✔
Förkonfigurerade multisportlägen✔
Efteranalys av multisportträning anpassad efter sport✔
Träningssammanställning för multisport i klockan✔
SPORTLÄGEN
Anpassningsbara sportlägen och displayer✔
Grafisk visning i sportlägenheart rate, speed and altitude
Klockans förinställda sportlägen> 80
SuuntoPlus™
Rekommenderade produkter
Videor
*Den faktiska batteritiden kan variera beroende på användning och förhållanden. Om du aktiverar batteriläget Ultra ökar batteritiden, men pulsmätningen på handleden inaktiveras. Batteriläget Tour ger dig den längsta batteritiden, men med lägre GPS-kvalitet. I batteriläget Uthållighet är batteritiden 40 timmar med pulsmätning på handleden och 50 timmar med pulsbälte. Pekskärmen är inaktiverad under träning, men du kan aktivera den i läget för anpassningar.
Läs mer om de bästa sätten att mäta pulsen på handleden.
