1 / 8
Suunto Vertical 2 Black
1/8
Photos
Video
Money-back guarantee
30-Days Return
Global Support
SKU: SS051204000
Suunto Vertical 2
Black
Prezzo di vendita€477,29
Ultimate adventure watch for outdoor expeditions and training — improved
  • Bright 1.5'' AMOLED display
  • Up to 65 hours battery
  • 115+ sport modes
  • Integrated LED flashlight
  • Improved heart rate tracking
Choose Your Color
Quantità
30-Days Return
Global Support
€477,29
Aggiungi
Bright 1.5” AMOLED display
115+ sport modes
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Rugged design in titanium or steel
Secure fit silicone straps
Designed and tested in Finland
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
115+ sport modes
Training Zone with AI Coach
Workout planning
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
Route planning with heatmaps
Climb Guidance planning tool
Dual-band GPS system
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
300+ partner apps
Growing app ecosystem
Faster hardware, more memory
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Learn more
SPECIFICHE
  • Misure
    48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
  • Peso
    87g
  • Materiale della lunetta
    Stainless steel
  • Materiale del vetro
    Sapphire crystal
  • Materiale della cassa
  • Materiale del cinturino
    Silicone
  • Paese di produzione
    CN
Specyfikacja techniczna
OGÓLNE
    Stainless steel
    Sapphire crystal
    Silicone
  • Peso
    87g
  • Dimensioni del polso
    125-175 mm
  • Larghezza del cinturino
    22 mm
  • Frequenza cardiaca al polso integrata
  • Quadranti personalizzabili
  • Blocco dello schermo tattile
  • Display touch
  • Display a colori
  • Avviso con vibrazione
  • Resistenza all’acqua
    100 m
  • Tipo di batteria
    rechargeable lithium-ion
  • Firmware aggiornabile
  • Ora, data
  • Sveglia
  • Doppio orario
  • Sincronizzazione automatica dell’ora
  • Timer per il conto alla rovescia
  • Cronometro
  • Lingua
  • Retroilluminazione
    LTPO AMOLED
  • Retroilluminazione configurabile
    automatic brightness
  • Blocco dei pulsanti
    during exercise
  • Dimensione del display
    1,5"
  • Tipo di display
    matrix
  • Risoluzione del display
    466 x 466
  • Unità metriche e imperiali
  • Ora legale automatica
  • Indicatore della batteria
    percentage / icon
  • Ossigeno nel sangue
  • Display sempre acceso
SPECIFICHE FISICHE
  • Temperatura operativa
  • Temperatura di conservazione
  • Temperatura batteria in carica:
    0° C to +45° C / +32° F to +110° F
DURATA DELLA BATTERIA
  • Promemoria carica intelligenti
  • Uso quotidiano: modalità smartwatch
    up to 20 days
  • Uso quotidiano: solo modalità standby
    up to 40 days
  • Allenamento: modalità GNSS tutti i sistemi + multi-banda
    up to 65h (AOD 60h)
  • Allenamento: modalità GNSS tutti i sistemi + banda singola
    up to 75h (AOD 70h)
  • Allenamento: promesse di batteria per tutte le modalità
    65h / 75h / 110h / 250h
  • Allenamento: modalità GNSS a risparmio energetico
    up to 250h
BUSSOLA
  • Bussola digitale
  • Compensazione inclinazione
  • Correzione della declinazione
  • Scala direzione
    degrees / mils
  • Taratura
    north indicator
  • Precisione della bussola
  • Risoluzione della bussola
CONNETTIVITÀ
  • Connettività (tra dispositivi)
    Bluetooth
  • Suunto app compatibile
  • Le notifiche del telefono sull'orologio
  • Comandi multimediali sull'orologio
  • Invio di risposte precompilate dall'orologio ai messaggi in arrivo
    Android only
  • Compatibile con le comunità sportive online
  • Aggiornamenti del software dell'orologio dal cloud
  • Aggiornamenti software over-the-air automatici
  • Compatibilità con smartphone
    Most common models supported, check here for detailed compatibility list
24/7
MONITORAGGIO DELLE ATTIVITÀ
  • Contapassi
  • Calorie bruciate
  • Obiettivi delle attività
    steps, calories
  • Cronologia attività
  • Conteggio delle calorie bruciate e frequenza cardiaca durante le attività quotidiane
  • Monitoraggio quotidiano della frequenza cardiaca minima
MONITORAGGIO DEL SONNO
  • Durata del sonno
  • Ora in cui ci si va a letto
  • Orario sveglia
  • Sonno profondo
  • Frequenza cardiaca media e minima durante il sonno
  • Sonno leggero
  • REM
  • HRV da sonno
  • Qualità del sonno
STRESS E RECUPERO
  • Livello di risorse giornaliero
  • Stato dello stress e del recupero
  • Misurazione HRV
FUNZIONI ALL'APERTO
MONITORAGGIO E NAVIGAZIONE GPS
  • Mappe offline sull'orologio
  • Sistemi satellitari
  • Supporto frequenza GNSS
    Dual band (L1+L5)
  • Sistemi satellitari simultanei
    4
  • Satelliti max. collegati
    32
  • Modalità batteria intelligenti
  • Frequenza registrazione GPS
    Best, Good, OK, Low
  • Tappe intermedie (waypoint) e navigazione grafica itinerari
  • Livelli di zoom nella navigazione
  • Zoom automatico basato sulla conformazione dell'itinerario
  • Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale
  • Pianificazione itinerari con profilo altitudine
  • Mappe terreni outdoor e satellitari
  • Mappe di calore globali per 20 sport
  • Pianificazione del percorso con mappe di calore
  • Libreria personale itinerari nel Web sincronizzata con l'orologio
  • Segui percorso
  • Navigazione punti di interesse (PDI)
  • Analisi percorsi GPS
  • Registrazione, visualizzazione e condivisione percorsi
  • ETA (ora di arrivo prevista)
ALTIMETRO
  • Altitudine barometrica
  • Altitudine GPS
  • Combinazione altitudine GPS e barometrica (FusedAlti™)
  • Altitudine in modalità giornaliera
  • Acclimatamento all'altitudine con la funzione di saturazione ossigeno
  • Ascesa/discesa totale
  • Velocità verticale
  • Profilo alti/baro automatico
  • Frequenza di registrazione
    1 s
  • Risoluzione
    1 m
  • Rilevazione altitudine
    -500 - 9999 m
METEO
  • Ora di alba e tramonto
  • Allarme temporale/tempesta
  • Pressione a livello del mare
  • Temperatura
  • Intervallo visualizzazione temperatura
  • Risoluzione temperatura
    1° C / 1,5° F
  • Risoluzione pressione
    1 hPa
  • Grafico di altitudine visualizzato nel riepilogo dell'attività fisica
FUNZIONI PER L'ALLENAMENTO
ALLENAMENTO A INTERVALLI
  • Configurazione intervalli
  • Indicazioni sugli intervalli durante l'allenamento
  • Intervalli strutturati
FREQUENZA CARDIACA
  • Frequenza cardiaca misurata al polso
  • Compatibilità fasce cardio
    Fasce cardio Bluetooth
  • Intervallo RR
    con Suunto Smart Sensor
  • Frequenza cardiaca in battiti al minuto
  • Registra la frequenza cardiaca durante il nuoto
  • Grafico frequenza cardiaca in tempo reale
  • Frequenza cardiaca media in tempo reale
  • Calorie
  • PTE (Picco effetto allenamento)
  • Zone di frequenza cardiaca personali
  • Livello di fitness (VO2 max)
  • Rilevamento della soglia anaerobica
  • Tempo di recupero
VELOCITÀ E DISTANZA
  • Distanza e velocità basate sulla cadenza
  • Velocità e distanza calcolata tramite GPS
  • Cronografo
  • Supporto per Foot POD
    Bluetooth Foot Pods
  • Giri automatici
  • Giri manuali
  • Analisi dell'andatura, grafici della velocità e percorsi sulla mappa
RECUPERO DELL'ALLENAMENTO
  • Stato d'animo salvato sull'orologio dopo l'allenamento
  • Tempo di recupero in base all'allenamento
CARICO DI LAVORO
  • Registro con dettagli dell'allenamento
  • Carico di allenamento con totali per sport
  • Registro degli allenamenti per panoramiche a lungo termine
  • Riepilogo dell'allenamento con dettagli sui giri
CONDIVIDI E RIVIVI
  • Condivisione dell'allenamento sui social media
  • Valutazione e commenti sull'allenamento
  • Segui gli altri utenti e ottieni feedback tramite il flusso di attività
FUNZIONALITÀ SPORTIVE
NUOTO
  • Andatura e distanza nuoto in vasca
  • Distanza nuoto in acque libere
  • Tempo per vasca, giro (frazione), totale
  • Frequenza, numero e tipo bracciate
  • Efficienza nuotata (SWOLF)
  • Intervalli automatici
  • Tabella giri intervalli
BICICLETTA
  • Velocità bicicletta
  • Velocità media in tempo reale
  • Bike POD con supporto velocità/cadenza
    Bluetooth Bike Pods
  • Supporto misuratore Bike Power
    Bluetooth Power meters
  • Bike Power (potenza pedalata) (W), valore medio e max (con sensore potenza)
  • Giro e potenza max giro (con sensore potenza)
  • Tabella dei giri in tempo reale con frequenza cardiaca, potenza media e velocità media
  • Indicazioni sugli intervalli con potenza/velocità/frequenza cardiaca
CORSA
  • Andatura corsa
  • Suunto FusedSpeed™
  • Segui percorso
  • Potenza della corsa
  • SuuntoPlus™ Ghost runner
  • Calibrazione Foot POD
    automatico
  • Tabella giri nell'orologio e nell'app Suunto
  • Andatura giro in tempo reale, max, media
  • Indicazioni sugli intervalli con andatura corsa/frequenza cardiaca/distanza
MULTISPORT
  • Cambia modalità sportiva durante l'allenamento
  • Modalità multisport preconfigurate
  • Analisi post-esercizio multisport per sport
  • Riepilogo esercizio multisport sull'orologio
MODALITÀ SPORTIVE
  • Modalità sportive e display personalizzabili
  • Display grafici nelle modalità sportive
  • Modalità sportive preinstallate sull'orologio
    > 90
  • SuuntoPlus™
FUNZIONI DI IMMERSIONE
APNEA
  • Profondimetro per snorkeling
    10 m
Recommended Products
SUPPORT FOR SUUNTO VERTICAL 2
