Suunto Nautic
Bungee Cord
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Explore more with the Suunto app
SPECIFICHE
Misure101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
Peso227g (with bungee strap) , 232g (with elastic textile strap)
Materiale della lunettaFiber reinforced polymer
Materiale del vetroPanda glass (PANDA-MN228 high alumina silicon glass)
Materiale della cassaGlass fibre reinforced polyamide
Materiale del cinturinoBungee cord / Elastic textile
Paese di produzioneFI
Specyfikacja techniczna
OGÓLNE
Display a colori✔
Avviso con vibrazione✔
Resistenza all’acqua200 m
Tipo di batteriarechargeable lithium-ion
Firmware aggiornabile✔
Ora, data✔
Cronometro✔
LinguaCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
RetroilluminazioneAMOLED
Retroilluminazione configurabileautomatic brightness
Blocco dei pulsanti✔
Dimensione del display3,26"
Tipo di displaymatrix
Risoluzione del display720x382
Unità metriche e imperiali✔
Ora legale automatica✔
Indicatore della batteriapercentage / icon
Display sempre acceso✔
SPECIFICHE FISICHE
Temperatura operativa-20° C to +55° C / -5° F to +130° F
Operating temperature in dive mode0° C to +40° C / +32° F to +104° F
Temperatura di conservazione-20° C to +55° C / -5° F to +130° F
Temperatura batteria in carica:0° C to +35° C / +32° F to +95° F
DURATA DELLA BATTERIA
Promemoria carica intelligenti✔
Durata della batteria (immersione)80-190h
BUSSOLA
Bussola digitale✔
Bussola digitale durante l'immersione subacquea✔
Compensazione inclinazione✔
Correzione della declinazione✔
Scala direzione✔
Taratura✔
Precisione della bussola5°
Risoluzione della bussola1°
CONNETTIVITÀ
Connettività (tra dispositivi)Bluetooth
Suunto app compatibile✔
Aggiornamenti del software dell'orologio dal cloud✔
Aggiornamenti software over-the-air automatici✔
Compatibilità con smartphoneMost common models supported, check here for detailed compatibility list
FUNZIONI ALL'APERTO
MONITORAGGIO E NAVIGAZIONE GPS
Mappe offline sull'orologio✔
Sistemi satellitariGPS, GLONASS, GALILEO, QZSS, BEIDOU
Supporto frequenza GNSSDual band (L1+L5)
Offline map storage size32 GB
Sistemi satellitari simultanei4
Satelliti max. collegati32
Frequenza registrazione GPSBest, Good, OK, Low
Livelli di zoom nella navigazione✔
Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale✔
Mappe terreni outdoor e satellitari✔
Mappe di calore globali per 20 sport✔
Navigazione punti di interesse (PDI)✔
Analisi percorsi GPS✔
Registrazione, visualizzazione e condivisione percorsi✔
METEO
Ora di alba e tramonto✔
Temperatura✔
Intervallo visualizzazione temperatura-20° C to +55° C / -5° F to +130° F
Risoluzione temperatura1° C / 1.5° F
FUNZIONI PER L'ALLENAMENTO
FREQUENZA CARDIACA
Compatibilità fasce cardioBluetooth HR belts
FUNZIONALITÀ SPORTIVE
MODALITÀ SPORTIVE
Modalità sportive e display personalizzabiliCustomizable dive
Display grafici nelle modalità sportiveIn dive
Modalità sportive preinstallate sull'orologioDive modes
Adatto agli sportScubadive
FUNZIONI DI IMMERSIONE
BASICO
Impostazioni altitudine0 - 300 m / 300 -1500 m / 1500 - 3000 m
risalita tempo display✔
CNS/OTU (OLF) Calcoli✔
personalizzate Modalità di immersione display✔
modello di decompressioneSuunto Bühlmann 16 GF
decompressione profilo Opzionicontinuous and stepped
Cronologia delle immersionilifetime
tempo immersioni✔
consumo di gas in tempo reale✔
Gas max pO₂manual 1.0 - 1.6
Cambio gas✔
tempo gas✔
gasup to 5 gases (Oxygen 21 - 100%)
Indicatore✔
Profondità operativa massima200m
Nitrox (e aria)✔
tempo di non volo✔
Pianificatore senza decompressione✔
Regolazione personaleGradient factors low (10-100) and high (50-100)
Soste di sicurezza✔
Intervallo di superficie✔
Timer✔
Integrazione dell'aria wireless✔
Integrazione del gas wireless✔
Deco planner✔
Helium✔
ALLARMI E NOTIFICHE IMMERSIONE
CNS/OTU (OLF) 80% / 100%✔
Violazione del limite di decompressione✔
Tempo di immersione✔
Tempo del gas✔
pO2 alto (iperossico)✔
pO2 basso (ipossico)✔
Profondità massima✔
NDL (tempo di non decompressione)✔
Cambio gas (gas migliore disponibile)✔
Pressione della bombola✔
Risalita troppo veloce✔
APNEA
Allarme di profondità✔
Allarme tempo di immersione✔
