Powerful
processor
21 days
of battery life
Military
grade durability
Full-featured
sports watch
Accurate
GPS and navigation
Handcrafted
in Finland
Refurbished Suunto 9 Peak Pro
Titanium Sand
Il nostro più potente e performante orologio GPS multisport mai realizzato fino ad ora. Ultrasottile e resistente.
Choose your Color
Powerful
processor
21 days
of battery life
Military
grade durability
Full-featured
sports watch
Accurate
GPS and navigation
Durability and looks,combined
Suunto 9 Peak Pro is a powerful multisport watch with extended battery life and
military-grade durability.
The ultra thin and timeless design makes it beautiful on the outside, too.
Enjoy the smooth interface
New
processor
Thanks to the updated chipset architecture, Suunto 9 Peak Pro is one of the most powerful watch Suunto has ever made.
Fast
user interface
The redesigned user interface looks sleek and is fast to use. Features such as exercise start are now quicker to access.
Great
readability
The new font is easier to read. Bigger numbers and contrasting colors make checking the information a breeze, even when on the go.
Best-in-class battery life and improved GPS
40 hrs
battery life with the best GPS mode
21 days
battery life in daily use
Fast
charging
Suunto 9 Peak Pro is extremely fast in charging. It charges in 1 hour from empty to full and with 10 minutes charging you get enough battery for 10 hours training.
Extremely tough. Extremely elegant.
100 m
waterproof
Suunto 9 Peak Pro is waterproof up to 100 meters. It can measure underwater depth up to 10 meters.
Tested
according to military standards
Suunto 9 Peak Pro has gone through tests against temperature shocks, drops, pressure, sand, ice and salt. It is tested according to the highest military standard of toughness (*MIL-STD-810H).
10.8 mm
thin body
Made for adventures, from trails to underwater
What’s your exercise of choice? With presets for more than 95 sport modes, you’re good to go whether you’re at the gym or climbing a mountain. Receive personalized feedback on your training load, progress and recovery, calculated based on heart rate variability (HRV). For more information, follow your efforts in Training Zone on Suunto App or coaching tools such as TrainingPeaks.
With a dedicated snorkeling mode, Suunto 9 Peak Pro is ready to accompany you on your underwater adventures.
115+ sport modes
24/7
companion
Suunto 9 Peak Pro tracks your fitness level, fitness age, blood oxygen, calories, steps and more. Sleep, stress and recovery tracking help you form a basis for holistic well-being. It also connects to your phone with music controls, notifications and other useful features.
Navigation
features
Navigation and staying on the right path has always been part of the Suunto DNA. Together with Suunto app, Suunto 9 Peak Pro offers maps and route planning for all sports needs and adventuring purposes.
Enhance your experience with Suunto app and SuuntoPlus™
Suunto app helps you plan, analyse and share your routes, workouts and activity data. You can connect to over 200 partner apps, such as Strava, komoot and TrainingPeaks. Discover Suunto app.
Within the app, you'll find the SuuntoPlus™ Store, where you can customize your watch even further with new features and connected devices. Make it yours!
Discover SuuntoPlus™.
SPECIFICHE
Misure43 x 43 x 10.8 mm / 1.69 x 1.69 x 0.43 "
Peso55 g / 1.94 oz
Materiale della lunettaTitanium Grade 5
Materiale del vetroSapphire crystal
Materiale della cassaGlass fibre reinforced polyamide
Materiale del cinturinoSilicone
Contenuto della confezioneSuunto 9 Peak Pro Titanium Sand, charging cable, printed user documentation
Paese di produzioneCN
Specyfikacja techniczna
OGÓLNE
Peso55 g / 1.94 oz
Dimensioni del polso125-175 mm o 125-200 mm a seconda del modello (cinturini accessori -215 mm)
Larghezza del cinturino22 mm
Frequenza cardiaca al polso integrata✔
Quadranti personalizzabili✔
Blocco dello schermo tattile✔
Display touch✔
Display a colori✔
Avviso con vibrazione✔
Resistenza all’acqua100 m
Tipo di batterialitio-ioni ricaricabile
Firmware aggiornabile✔
Ora, data✔
Sveglia✔
Doppio orario✔
Sincronizzazione automatica dell’ora✔
Timer per il conto alla rovescia✔
Cronometro✔
LinguaEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Il cinese è disponibile unicamente negli orologi della China edition.
RetroilluminazioneLED
Retroilluminazione configurabileluminosità automatica
Blocco dei pulsantidurante l'attività fisica
Dimensione del display1,2"
Tipo di displaya matrice
Risoluzione del display240 x 240
Unità metriche e imperiali✔
Ora legale automatica✔
Aggiornamenti automatici del firmware OTA✔
Indicatore della batteriapercentuale / icona
Ossigeno nel sangue✔
Display sempre acceso✔
SPECIFICHE FISICHE
Temperatura operativa-20° C to +55° C / -5° F to +130° F
Temperatura di conservazione-20° C to +55° C / -5° F to +130° F
Temperatura batteria in carica:0° C to +35° C / +32° F to +95° F
DURATA DELLA BATTERIA
Promemoria carica intelligenti✔
Uso quotidiano: modalità smartwatchup to 21 days
Uso quotidiano: solo modalità standbyup to 30 days
Allenamento: modalità GNSS tutti i sistemi + banda singolaup to 40h
Allenamento: promesse di batteria per tutte le modalità40h / 70h / 300h
Allenamento: modalità GNSS a risparmio energeticoup to 300h
BUSSOLA
Bussola digitale✔
Compensazione inclinazione✔
Correzione della declinazione✔
Scala direzionedegrees / mils
Taraturanorth indicator
Precisione della bussola5°
Risoluzione della bussola1°
CONNETTIVITÀ
Connettività (tra dispositivi)Bluetooth
Suunto app compatibile✔
Le notifiche del telefono sull'orologio✔
Comandi multimediali sull'orologio✔
Invio di risposte precompilate dall'orologio ai messaggi in arrivoAndroid only
Compatibile con le comunità sportive online✔
Aggiornamenti del software dell'orologio dal cloud✔
Aggiornamenti software over-the-air automatici✔
Compatibilità con smartphoneMost common models supported
MUZYKA
Kontroluj swoją muzykę za pomocą zegarka✔
24/7
MONITORAGGIO DELLE ATTIVITÀ
Contapassi✔
Calorie bruciate✔
Obiettivi delle attività✔
Cronologia attività✔
Conteggio delle calorie bruciate e frequenza cardiaca durante le attività quotidiane✔
Monitoraggio quotidiano della frequenza cardiaca minima✔
MONITORAGGIO DEL SONNO
Durata del sonno✔
Ora in cui ci si va a letto✔
Orario sveglia✔
Sonno profondo✔
Frequenza cardiaca media e minima durante il sonno✔
Sonno leggero✔
HRV da sonno✔
Qualità del sonno✔
STRESS E RECUPERO
Livello di risorse giornaliero✔
Stato dello stress e del recupero✔
Misurazione HRV✔
FUNZIONI ALL'APERTO
MONITORAGGIO E NAVIGAZIONE GPS
Sistemi satellitariGPS, GLONASS, GALILEO, QZSS, BEIDOU
Supporto frequenza GNSSL1
Sistemi satellitari simultanei4
Satelliti max. collegati32
Modalità batteria intelligentiPerformance, Endurance, Tour, Custom
Frequenza registrazione GPSBest, OK, Low
Tappe intermedie (waypoint) e navigazione grafica itinerari✔
Livelli di zoom nella navigazione✔
Zoom automatico basato sulla conformazione dell'itinerario✔
Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale✔
Pianificazione itinerari con profilo altitudine✔
Mappe terreni outdoor e satellitari✔
Mappe di calore globali per 20 sport✔
Pianificazione del percorso con mappe di calore✔
Libreria personale itinerari nel Web sincronizzata con l'orologio✔
Segui percorso✔
Navigazione punti di interesse (PDI)✔
ETA (estimated time of arrival, ora di arrivo prevista), distanza residua✔
Analisi percorsi GPS✔
Registrazione, visualizzazione e condivisione percorsi✔
ETA (ora di arrivo prevista)✔
Navigazione rotta✔
Mappe outdoor da satellite, terreno e topografia sul Web tramite Mapbox, Google Maps e Android✔
ALTIMETRO
Altitudine barometrica✔
Altitudine GPS✔
Combinazione altitudine GPS e barometrica (FusedAlti™)✔
Altitudine in modalità giornaliera✔
Acclimatamento all'altitudine con la funzione di saturazione ossigeno✔
Ascesa/discesa totale✔
Velocità verticale✔
Profilo alti/baro automatico✔
Frequenza di registrazione1 s
Risoluzione1 m
Rilevazione altitudine-500 - 9999 m
METEO
Ora di alba e tramonto✔
Allarme temporale/tempesta✔
Pressione a livello del mare✔
Temperatura✔
Intervallo visualizzazione temperatura-20° C to +55° C / -5° F to +130° F
Risoluzione temperatura1° C / 1.5° F
Risoluzione pressione1 hPa
Grafico di altitudine visualizzato nel riepilogo dell'attività fisica✔
FUNZIONI PER L'ALLENAMENTO
ALLENAMENTO A INTERVALLI
Configurazione intervalli✔
Indicazioni sugli intervalli durante l'allenamento✔
Intervalli strutturati✔
FREQUENZA CARDIACA
Frequenza cardiaca misurata al polso✔
Compatibilità fasce cardioBluetooth Smart belts
Intervallo RRwith Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Frequenza cardiaca in battiti al minuto✔
Registra la frequenza cardiaca durante il nuoto✔
Grafico frequenza cardiaca in tempo reale✔
Frequenza cardiaca media in tempo reale✔
Calorie✔
PTE (Picco effetto allenamento)✔
Zone di frequenza cardiaca personali✔
Livello di fitness (VO2 max)✔
Tempo di recupero✔
VELOCITÀ E DISTANZA
Distanza e velocità basate sulla cadenza✔
Velocità e distanza calcolata tramite GPS✔
Cronografo✔
Supporto per Foot PODBluetooth Smart
Giri automatici✔
Giri manuali✔
Analisi dell'andatura, grafici della velocità e percorsi sulla mappa✔
RECUPERO DELL'ALLENAMENTO
Stato d'animo salvato sull'orologio dopo l'allenamento✔
Tempo di recupero in base all'allenamento✔
CARICO DI LAVORO
Registro con dettagli dell'allenamento✔
Riepilogo registri sull'orologio con dettagli sui giri✔
Carico di allenamento con totali per sport✔
Registro degli allenamenti per panoramiche a lungo termine✔
Riepilogo dell'allenamento con dettagli sui giri✔
CONDIVIDI E RIVIVI
Condivisione dell'allenamento sui social media✔
Valutazione e commenti sull'allenamento✔
Segui gli altri utenti e ottieni feedback tramite il flusso di attività✔
ALLENAMENTO GUIDATO CON ADATTAMENTO AUTOMATICO
Allenamento guidato in tempo reale basato su intensità e durata✔
FUNZIONALITÀ SPORTIVE
NUOTO
Andatura e distanza nuoto in vasca✔
Distanza nuoto in acque libere✔
Tempo per vasca, giro (frazione), totale✔
Frequenza, numero e tipo bracciate✔
Efficienza nuotata (SWOLF)✔
Intervalli automatici✔
Tabella giri intervalli✔
BICICLETTA
Velocità bicicletta✔
Velocità media in tempo reale✔
Bike POD con supporto velocità/cadenzaBluetooth Smart
Supporto misuratore Bike PowerBluetooth Smart
Bike Power (potenza pedalata) (W), valore medio e max (con sensore potenza)Bluetooth Smart
Giro e potenza max giro (con sensore potenza)✔
Tabella dei giri in tempo reale con frequenza cardiaca, potenza media e velocità media✔
Indicazioni sugli intervalli con potenza/velocità/frequenza cardiaca✔
CORSA
Andatura corsa✔
Suunto FusedSpeed™✔
Segui percorso✔
Potenza della corsafrom wrist or with Stryd sensor
SuuntoPlus™ Ghost runner✔
Calibrazione Foot PODautomatic
Tabella giri nell'orologio e nell'app Suunto✔
Andatura giro in tempo reale, max, media✔
Indicazioni sugli intervalli con andatura corsa/frequenza cardiaca/distanza✔
MULTISPORT
Cambia modalità sportiva durante l'allenamento✔
Modalità multisport preconfigurate✔
Analisi post-esercizio multisport per sport✔
Riepilogo esercizio multisport sull'orologio✔
MODALITÀ SPORTIVE
Modalità sportive e display personalizzabili✔
Display grafici nelle modalità sportive✔
Modalità sportive preinstallate sull'orologio> 95
SuuntoPlus™
FUNZIONI DI IMMERSIONE
APNEA
Profondimetro per snorkeling10 m
