Suunto Ocean
All Black
Dive computer and sports watch in one. For adventures below and above the surface
Choose Your Color
Dive and sports combined
With its modern Finnish design and premium features built for dives, sports, and everything in between, Suunto Ocean is the perfect companion for all your adventures.
Dive with confidence
The magic of diving lies in the unexpected. To get the most out of your underwater experience you need robust equipment you can trust. Bright colourful display, effortless usability, and long-lasting battery keep you informed and in control throughout your dive.
Battery life
Suunto Ocean provides long battery life for extended dives and workouts, so you can enjoy multiple dives a day without worrying about recharging—ideal for your dive holiday or just everyday.
Training & dive
Up to 50 hours
Continuous tracking with best GPS accuracy (multi-band)
Up to 60 hours
Dive and everyday wear
Up to 200 hours
Up to 16 days
Daily heart rate on, display wakes on wrist-raise
Up to 26 days
Stay active in sports and daily life
Finding time for dive trips, daily activities and sports is a challenge. Suunto Ocean helps you to find balance. Track your everyday movement and optimize training, from a park run to a mountain adventure.
Elevate your experience with Suunto app
Suunto app seamlessly gathers all your data in one place. Gain a holistic view of your daily activity, sports, and dive logs – all in a single app.
Sustainable design from Finland
ХАРАКТЕРИСТИКИ
Размеры49.9 x 49.9 x 13.2 mm / 1.96 x 1.96 x 0.52 "
Вес99 g / 3.49 oz
Материал безеля:Stainless steel
Материал стекла:Sapphire crystal
Материал корпуса:Glass fibre reinforced polyamide
Материал ремешка:Silicone
КомплектацияSuunto Ocean, USB charging cable, printed user documentation
Страна производстваFI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляStainless steel
Материал стеклаSapphire crystal
Материал корпусаGlass fibre reinforced polyamide
Материал ремешкаSilicone
Вес99 g / 3.49 oz
Обхват запястья130-215 mm
Ширина ремешка22 mm
Встроенный наручный пульсометр✔
Настраиваемые экраны✔
Блокировка сенсорного экрана✔
Сенсорный дисплей✔
Цветной экран✔
Виброоповещение✔
Водостойкий100 m
Тип батареиrechargeable lithium-ion
Обновляемое встроенное ПО✔
Время, дата✔
Будильник✔
Время для двух часовых поясов✔
Автоматический хронометраж✔
Таймер обратного отсчета✔
Секундомер✔
ЯзыкиEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Chinese language is only available in the China edition watches.
ПодсветкаAMOLED
Настраиваемая подсветкаautomatic brightness
Блокировка кнопокduring exercise
Размер экрана1,43''
Тип дисплеяmatrix
Разрешение дисплея466 x 466
Метрическая и британская системы измерения✔
Автоматические беспроводное обновление прошивки✔
Индикатор заряда батареиpercentage / icon
Дисплей всегда вкл.✔
Хранение офлайн карт для использования на улице32GB
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-20° C to +55° C / -5° F to +130° F
Рабочая температура в режиме погружения0° C to +40° C / +32° F to +104° F
Температура хранения-20° C to +55° C / -5° F to +130° F
Рекомендуемая температура зарядки0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Intelligent charge reminders✔
Daily use: Smartwatch modeup to 16 days
Daily use: Standby time mode onlyup to 26 days
Training: All-Systems GNSS mode + Multi-Bandup to 50h
Training: All-Systems GNSS mode + Single-Bandup to 65h
Training: All battery modes battery promises50h / 65h / 90h / 200h
Training: Power saving GNSS modesup to 200h
Battery life (dive)40 - 60h
КОМПАС
Цифровой компас✔
Компенсация склонения✔
Коррекция склонения✔
Шкала направленияdegrees / mils
Стрелкаnorth indicator
Точность компаса5°
Дискретность компаса1°
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Возможности подключения (между устройствами)Bluetooth
Совместимо с приложением Suunto✔
Уведомления телефона на часах✔
Управление мультимедиа на часах✔
Отправка заранее заданных ответов на входящие сообщения с часовAndroid only
Поддержка спортивных онлайн-сообществStrava, TrainingPeaks and more
Обновление ПО часов из облака✔
Автоматическое обновление программного обеспечения по беспроводной сети✔
Совместимость со смартфонамиMost common models supported
МУЗЫКА
Управляйте музыкой с часов✔
24/7
ОТСЛЕЖИВАНИЕ АКТИВНОСТИ
Счетчик шагов✔
Количество сожженных калорий✔
Цели активностиsteps, calories
История занятий✔
Скорость сжигания калорий и частота сердцебиения во время повседневных активностей✔
Отслеживание дневной минимальной ЧСС✔
ОТСЛЕЖИВАНИЕ СНА
Продолжительность снаDuration, average HR during sleep
Время сна✔
Время бодрствования✔
Глубокий сон✔
Средняя и минимальная частота пульса во время сна✔
Легкий сон✔
БДГ✔
HRV во сне✔
СТРЕСС И ВОССТАНОВЛЕНИЕ
Уровень дневного ресурса✔
Стресс и восстановление✔
Вычисление HRV✔
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
Offline maps on watch✔
Спутниковые системыGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportL1 + L5
Simultaneous satellite systems4
Max connected satellites32
Интеллектуальные режимы работы от батареиPerformance, Endurance, Ultra, Tour
Интервал регистрации GPSBest, Good, OK, Low
Навигация по путевым точкам и визуальная навигация по маршруту✔
Масштабирование при навигации✔
Автомасштабирование в зависимости от формы маршрута✔
Построение обратного маршрута в реальном времени✔
Планирование маршрутов с профилем высот✔
Топография местности и спутниковые карты✔
Глобальные тепловые карты по 20 видам спорта✔
Планирование маршрута с тепловыми картами✔
Личная библиотека маршрутов в Интернете синхронизирована с часами✔
Контроль маршрута✔
Навигация по интересующим пунктам (POI)✔
Анализ маршрута по данным GPS✔
Параметры, просмотр и экспорт маршрутов✔
ETA (расчетное время прибытия)✔
АЛЬТИМЕТР
Барометрический альтиметр✔
Высота по данным GPS✔
Объединение данных GPS с данными барометрического альтиметра (FusedAltiTM)✔
Высота в повседневном режиме✔
Акклиматизация на высоте с контролем уровня насыщения крови кислородом✔
Общий подъем/спуск✔
Вертикальная скорость✔
Автопереключение профиля высотомера и барометра✔
Интервал регистрации в журнале1 s
Дискретность1 m
Диапазон-500 - 9999 m
ПОГОДА
Время восхода/захода солнца✔
Штормовое предупреждение✔
Атмосферное давление✔
Термометр✔
Диапазон отображения температуры-20° C to +55° C / -5° F to +130° F
Дискретность температуры1° C / 1.5° F
Дискретность давления1 hPa
Отображение графика высоты в общих сведениях о тренировке✔
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ИНТЕРВАЛЬНАЯ ТРЕНИРОВКА
Настройка интервалов✔
Подсказки в ходе интервальной тренировки✔
Спланированные интервальные тренировки✔
ЧАСТОТА СЕРДЦЕБИЕНИЯ
Измерение пульса на запястье✔
Совместимость с поясами-кардиодатчикамиBluetooth Smart belts
Интервал RR✔
Частота сердцебиения в удаках в минуту✔
Запись сердечного ритма при плавании✔
График частоты сердцебиения в режиме реального времени✔
Информация о средней частоте сердцебиения в режиме реального времени✔
Калории✔
Максимальная эффективность тренировки✔
Личные пульсовые зоны✔
Уровень подготовки (макс. VO2)✔
Распознание лактатного порога✔
Время восстановления✔
СКОРОСТЬ И РАССТОЯНИЕ
Измерение скорости и расстояния по данным датчика каденса✔
Скорость и расстояние по данным GPS✔
Хронограф✔
Поддержка Foot POD✔
Автоэтапы✔
Ручной отсчет этапов✔
Анализ темпа, графики скорости и маршруты на карте✔
ВОССТАНОВЛЕНИЕ ПОСЛЕ ТРЕНИРОВОК
Сохранение ощущения после тренировки на часы✔
НАГРУЗКА ПРИ ТРЕНИРОВКЕ
Журнал с подробностями тренировок✔
Общие сведения о тренировке с подробностями этапов✔
Журнал тренировок для обзора длительных периодов✔
Итоговая тренировочная нагрузка по видам спорта✔
ДЕЛИТЕСЬ И ПЕРЕЖИВАЙТЕ ЗАНОВО
Публикация тренировок в соцсетях✔
Комментарии и оценки к тренировкам✔
Подписывайтесь на других участников и читайте комментарии через ленту активностей✔
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ПЛАВАНИЕ
Темп и расстояние заплыва в бассейне✔
Дистанция плавания в открытой воде✔
Время плавания: длина дорожки, этап, общее✔
Частота гребков, количество и тип✔
Эффективность гребков (SWOLF)✔
Автоматические интервалы✔
Таблица этапов для интервальной тренировки✔
ЕЗДА НА ВЕЛОСИПЕДЕ
Скорость езды✔
Средняя скорость в режиме реального времени✔
Bike POD с поддержкой скорости/частоты вращения педалейBluetooth Smart
Поддержка датчика мощности при езде на велосипедеBluetooth Smart
Мощность езды на велосипеде (Вт), средняя и максимальная (с датчиком мощности)Bluetooth Smart
Bike Lap and Lap Maximum Power (с датчиком мощности)✔
Таблица этапов в реальном времени со средними показателями: частота сердцебиения, мощность и скорость✔
Подсказки для интервальных тренировок с мощностью, скоростью и пульсом✔
БЕГ
Темп бега✔
Suunto FusedSpeed™✔
Контроль маршрута✔
Мощность бегаfrom wrist or with Stryd sensor
SuuntoPlus™ Ghost runner✔
Калибровка Foot PODautomatic
Таблица данных кругового хронографа в часах и приложении Suunto✔
Темп: средний, максимальный, этапа — в режиме реального времени✔
Подсказки для интервальных тренировок с темпом бега, пульсом и расстояниемon watch
ТРЕНИРОВКИ С НЕСКОЛЬКИМИ ВИДАМИ СПОРТА
Изменение спортивного режима во время тренировки✔
Настроенные режимы для тренировок с несколькими видами спорта✔
Пост-анализ многоборья по видам спорта✔
Общие сведения о тренировке с несколькими видами спорта на часах✔
СПОРТИВНЫЕ РЕЖИМЫ
Настройка спортивных режимов и дисплеев✔
Графические дисплеи в спортивных режимах✔
Предустановленные спортивные режимы в часах> 95
SuuntoPlus™✔
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
БАЗОВЫЕ ВОЗМОЖНОСТИ
Поправка по высоте0 - 300 m / 300 -1500 m / 1500 - 3000 m
Отображение времени всплытия✔
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения)✔
Модель декомпрессииSuunto Bühlmann 16 GF
Параметры профиля декомпрессииcontinuous and stepped
Журнал погружений✔
Время погружения✔
Фридайвинг✔
Потребление газовой смеси (в реальном времени)✔
Переключение дыхательных смесей✔
Время по газовой смеси✔
Газовые смесиup to 5 gases (Oxygen 21 - 100%)
Максимальная глубина погружения (EN 13319)60 m (EN 13319)
Кислородно-азотная смесь (и воздух)✔
Время запрета полетов✔
Персональная настройкаGradient factors low (10-100) and high (50-100)
Остановка безопасности✔
Время на поверхности✔
ТаймерFreedive
Беспроводное подключение к системе подачи воздуха✔
СИГНАЛЫ И УВЕДОМЛЕНИЯ ПРИ ПОГРУЖЕНИИ
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения) 80% / 100%✔
Выход за верхний декомпрессионный предел✔
Время погружения✔
Высокое парциальное давление pO2 (гипероксия)✔
Максимальная глубина✔
NDL✔
Переключение газовой смеси (на более подходящую, если имеется)✔
Давление в баллоне✔
Слишком быстрое всплытие✔
ФРИДАЙВИНГ
Оповещение о глубине✔
Глубиномер для подводного плавания с трубкой60 m
Уведомление о глубине✔
Уведомление о времени на поверхности✔
Дневной журнал фридайвинга✔
Количество свободных погружений✔
Общий журнал фридайвинга✔
