1 / 5
Suunto EON Steel Black
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS050558000
Suunto EON Steel
Black
Sale price€859,76
Highly durable dive computer equipped with two algorithms, rechargeable battery and wireless mobile connection. Made in Finland.
Choose Your Color
Quantity
30-Days Return
Global Support
€859,76
Add to cart
Freedom of choice
Caves, wrecks or the blue unknown – the choice is yours. Equipped with Suunto Fused™ RGBM 2 and Bühlmann 16 with Gradient Factors dive algorithms, Suunto EON Steel Black is the ultimate dive companion for divers demanding the most. With its extremely durable design, multi-gas and CCR support, customizable features and wireless mobile connectivity with Suunto app, your diving adventure has no limits. Designed and tested by divers, for divers.
KEY FEATURES
MULTIPLE ALGORITHMS
CUSTOMIZABLE
UPDATABLE SOFTWARE
WIRELESS MOBILE CONNECTION
WIRELESS TANK PRESSURE
RECHARGEABLE BATTERY
FOR ALL DIVING
150 M WATER RESISTANT
BENEFITS
Full configurability for all diving
Suunto EON Steel Black is designed to give you the freedom to tailor your dive computer to fit your diving needs. You can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. Intuitive menus and a simple 3-button layout make Suunto EON Steel Black very easy to use despite the many options available.
Equipped with two dive algorithms; Suunto Fused™ RGBM 2 and Bühlmann 16 GF and configurable ascent profiles, you decide what is your decompression profile for today’s dive.
Designed for years to come
Suunto EON Steel Black comes with a stylish brushed stainless steel bezel and a vivid high contrast screen - easy to read even in low light conditions. The long-lasting battery endures even the toughest diving conditions, and with a full charge, provides up to 40 hours of diving.
Put to the test in the toughest diving conditions by Suunto’s internal dive team on hundreds of dives - the Steel Black is functional, accurate, and built to take a beating. The reusable storage case and user updatable software, Suunto EON Steel Black is your trusted diving companion for years to come.
Wireless connection
Transfer your dive logs easily over Bluetooth to your mobile phone. In Suunto app you can relive, and share your diving adventures, build an all-inclusive dive history by enriching your dive logs with photos, comments and dive location. Review and analyze your dive data including dive time, maximum depth, device settings, gas consumption (when using Suunto Tank POD).
Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto EON Steel Black with Suunto Tank POD before diving. You can connect up to 20 PODs.
ХАРАКТЕРИСТИКИ
  • Вес
    347 g / 12.24 oz
  • Материал безеля:
    Stainless steel
  • Материал стекла:
    Xensation Glass
  • Материал корпуса:
    Reinforced composite
  • Материал ремешка:
    Elastomer, Bungee
  • Комплектация
    Suunto EON Steel Black, USB Cable, Quick Guide, Safety and Regulatory leaflet, International warranty leaflet, Protective boot, Display scratch guard sticker, Bungee adapter and extra strap loop, Suunto sticker
  • Страна производства
    FI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
  • Материал безеля
    Stainless steel
  • Материал стекла
    Xensation Glass
  • Материал корпуса
  • Материал ремешка
    Elastomer, Bungee
  • Вес
    347 g / 12.24 oz
  • Поворот дисплея
  • Водостойкий
  • Тип батареи
    rechargeable lithium-ion
  • Обновляемое встроенное ПО
  • Время, дата
  • Будильник
    1 daily alarm
  • Секундомер
  • Языки
  • Подсветка
    LED
  • Настраиваемая подсветка
  • Тип дисплея
    color TFT
  • Разрешение дисплея
    320 x 240
  • Метрическая и британская системы измерения
  • Индикатор заряда батареи
    icon + dive hours remaining
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
  • Рабочая температура
  • Температура хранения
  • Рекомендуемая температура зарядки
КОМПАС
  • Цифровой компас
  • Компенсация склонения
    up to 45°
  • Коррекция склонения
  • Шкала направления
    degrees
  • Стрелка
    compass rose
  • Фиксация азимута с индикатором направления
  • Глобальная балансировка
  • Точность компаса
    +/- 15°
  • Дискретность компаса
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
  • Возможности подключения (между устройствами)
    inductive (up to 20 Tank PODs), Bluetooth Smart
  • Совместимо с приложением Suunto
  • Совместимость с SuuntoLink
  • Совместимость с DM5
  • Передача журнала
    Bluetooth Smart / USB cable
  • Совместимость со смартфонами
    Most common models supported
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
ПОГОДА
  • Термометр
  • Диапазон отображения температуры
  • Дискретность температуры
    1° C / 1.5° F
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
БАЗОВЫЕ ВОЗМОЖНОСТИ
  • Поправка по высоте
  • Отображение времени всплытия
    0 - 999 min ( > after 999)
  • Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения)
  • Custom disНастраиваемые экраны
    4 per dive mode
  • Модель декомпрессии
    Suunto Fused™ RGBM 2 Bühlmann 16 GF
  • Параметры профиля декомпрессии
    continuous and stepped
  • Декомпрессионная остановка
  • Журнал погружений
    lifetime
  • Время погружения
    0 to 999 min
  • Потребление газовой смеси (в реальном времени)
  • Максимальное парциальное давление кислорода (pO2) в дыхательной смеси
    manual 0.5 - 1.6 / fixed 1.6
  • Переключение дыхательных смесей
  • Время по газовой смеси
  • Газовые смеси
    up to 20 gases (Oxygen 5 - 99% / Helium 0 -95%)
  • Gauge (Датчик)
  • Создание ярлыков журнала
  • Память для журнала измерений
  • Изменение интервалов регистрации данных в журнале
    10 s
  • Максимальная глубина погружения (EN 13319)
    150 m
  • Кислородно-азотная смесь (и воздух)
  • Время запрета полетов
  • Планировщик бездекомпрессионного предела
  • Персональная настройка
    P+2, P+1, P0, P-1, P-2Gradient factors low (10-100) and high (50-100)
  • Ребризер замкнутого цикла (CCR), фиксированная концентрация кислорода
  • Остановка безопасности
  • Время на поверхности
    0 to 100 h
  • Таймер
  • Поддержка КАГС (газовая смесь)
  • Визуальный стиль
    Default/Graphical/Prominent
  • Беспроводная интеграция с баллоном
    optional (up to 20 different tanks with Suunto Tank POD)
СИГНАЛЫ И УВЕДОМЛЕНИЯ ПРИ ПОГРУЖЕНИИ
  • Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения) 80% / 100%
  • Выход за верхний декомпрессионный предел
  • Выход за точку глубокой остановки
  • Высокое значение pO2 разжижителя
  • Низкое значение pO2 разжижителя
  • Автоматическое переключение разжижителя
  • Время погружения
  • Высокое парциальное давление pO2 (гипероксия)
  • Предупреждение об ИКД
  • Низкое парциальное давление pO2 (гипоксия)
  • Переключение газовой смеси (на более подходящую, если имеется)
  • Давление в баллоне
  • Слишком быстрое всплытие
РЕБРИЗЕР
  • Разжижители
  • Отработка аварийных случаев
  • Верхние/нижние пределы
  • Пользовательские пределы
  • Ручное/автоматическое переключение пределов
Recommended products
VIDEOS
You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
SUPPORT FOR SUUNTO EON STEEL BLACK
