Suunto Run Lime
Lightweight sports watch designed for runners
- Just 36g for all-day comfort
- Dual-band GPS for precise pace and distance
- Up to 12 days battery life, 20 hours in training
- Run-specific tools like interval workouts and Ghost Runner
- Vivid AMOLED with easy crown navigation
- Tracks your recovery, sleep, and training load
- Music controls, notifications, app syncing
Choose your Color
Designed for runners
From solo morning jogs to the finish line of a race, Suunto Run supports every runner on their journey. Combining dedicated running features and all you need to see progress, win yourself and others, it’s designed to keep up and go the distance with you.
Suunto Run - Run your story.
So light, you'll forget it's there
Run longer, charge less
Keep your eyes on your training goals, not your battery percentage. Suunto Run delivers up to 12 days’ battery life while tracking daily activity and sleep and up to 20 hours of training time with high-accuracy location tracking. A watch that’s ready to go the distance, day after day.
Training, continuous tracking
Up to 20 hours
Performance mode, best GPS accuracy (dual-band)
Up to 40 hours
Power saving mode
Up to 12 days
Daily heart rate on, display wakes on wrist-raise
Dedicated tools for any run (and beyond)
Train smarter and recover stronger with tailored insights
Your companion for runs - and everything else
Designed to go the distance
Suunto outdoor watches are built for reliability and long-term use. To support greater transparency, we’ve calculated a category-specific carbon footprint for our outdoor watches. The footprint represents an average product in this category, helping you better understand the environmental impact of your watch. With its durable and repairable design, Suunto Run is made to stay with you for the long run.
ХАРАКТЕРИСТИКИ
Размеры46 x 46 x 11.5 mm / 1.81 x 1.81 x 0.45 "
Вес36 g / 1.27 oz
Материал безеля:Stainless steel
Материал стекла:Gorilla glass
Материал корпуса:Glass fibre reinforced polyamide
Материал ремешка:Nylon textile
КомплектацияSuunto Run, charging cable, printed user documentation
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляStainless steel
Материал стеклаGorilla glass
Материал корпусаGlass fibre reinforced polyamide
Материал ремешкаNylon textile
Вес36 g / 1.27 oz
Автоматические беспроводное обновление прошивки✔
Насыщение крови кислородом✔
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-20° C to +55° C / -5° F to +130° F
Температура хранения-20° C to +55° C / -5° F to +130° F
Рекомендуемая температура зарядки0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Intelligent charge reminders✔
Daily use: Smartwatch modeup to 12 days
Daily use: Standby time mode onlyup to 20 days
Training: All-Systems GNSS mode + Multi-Bandup to 20h
Training: All-Systems GNSS mode + Single-Bandup to 30h
Training: All battery modes battery promises20h / 30h / 40h
Training: Power saving GNSS modesup to 40h
КОМПАС
Цифровой компас✔
Компенсация склонения✔
Коррекция склонения✔
Шкала направленияdegrees / mils
Стрелкаnorth indicator
Точность компаса5°
Дискретность компаса1°
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Возможности подключения (между устройствами)Bluetooth
Совместимо с приложением Suunto✔
Уведомления телефона на часах✔
Управление мультимедиа на часах✔
Отправка заранее заданных ответов на входящие сообщения с часовAndroid only
Поддержка спортивных онлайн-сообществStrava, TrainingPeaks and more
Обновление ПО часов из облака✔
Автоматическое обновление программного обеспечения по беспроводной сети✔
Совместимость со смартфонамиMost common models supported
МУЗЫКА
Управляйте музыкой с часов✔
Offline music with watch4GB
24/7
ОТСЛЕЖИВАНИЕ АКТИВНОСТИ
Счетчик шагов✔
Количество сожженных калорий✔
Цели активностиsteps, calories
История занятий✔
Скорость сжигания калорий и частота сердцебиения во время повседневных активностей✔
Отслеживание дневной минимальной ЧСС✔
ОТСЛЕЖИВАНИЕ СНА
Продолжительность сна✔
Время сна✔
Время бодрствования✔
Глубокий сон✔
Средняя и минимальная частота пульса во время сна✔
Легкий сон✔
БДГ✔
HRV во сне✔
СТРЕСС И ВОССТАНОВЛЕНИЕ
Вычисление HRV✔
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
Спутниковые системыGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportL1 + L5
Simultaneous satellite systems4
Max connected satellites32
Интеллектуальные режимы работы от батареиPerformance, Endurance, Power saving
Интервал регистрации GPSBest, Good, Low
Навигация по путевым точкам и визуальная навигация по маршруту✔
Масштабирование при навигации✔
Построение обратного маршрута в реальном времени✔
Планирование маршрутов с профилем высот✔
Топография местности и спутниковые карты✔
Глобальные тепловые карты по 20 видам спорта✔
Планирование маршрута с тепловыми картами✔
Личная библиотека маршрутов в Интернете синхронизирована с часами✔
Контроль маршрута✔
Навигация по интересующим пунктам (POI)✔
Анализ маршрута по данным GPS✔
Параметры, просмотр и экспорт маршрутов✔
ETA (расчетное время прибытия)✔
АЛЬТИМЕТР
Барометрический альтиметр✔
Высота по данным GPS✔
Объединение данных GPS с данными барометрического альтиметра (FusedAltiTM)✔
Высота в повседневном режиме✔
Акклиматизация на высоте с контролем уровня насыщения крови кислородом✔
Общий подъем/спуск✔
Вертикальная скорость✔
Автопереключение профиля высотомера и барометра✔
Интервал регистрации в журнале1 s
Дискретность1 m
Диапазон-500 - 9999 m
ПОГОДА
Время восхода/захода солнца✔
Штормовое предупреждение✔
Атмосферное давление✔
Термометр✔
Диапазон отображения температуры-20° C to +55° C / -5° F to +130° F
Дискретность температуры1° C / 1.5° F
Дискретность давления1 hPa
Отображение графика высоты в общих сведениях о тренировке✔
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ИНТЕРВАЛЬНАЯ ТРЕНИРОВКА
Настройка интервалов✔
Подсказки в ходе интервальной тренировки✔
Спланированные интервальные тренировки✔
ЧАСТОТА СЕРДЦЕБИЕНИЯ
Измерение пульса на запястье✔
Совместимость с поясами-кардиодатчикамиBluetooth HR belts
Частота сердцебиения в удаках в минуту✔
Запись сердечного ритма при плавании✔
График частоты сердцебиения в режиме реального времени✔
Информация о средней частоте сердцебиения в режиме реального времени✔
Калории✔
Максимальная эффективность тренировки✔
Личные пульсовые зоны✔
Уровень подготовки (макс. VO2)✔
Распознание лактатного порога✔
Время восстановления✔
СКОРОСТЬ И РАССТОЯНИЕ
Измерение скорости и расстояния по данным датчика каденса✔
Скорость и расстояние по данным GPS✔
Хронограф✔
Поддержка Foot PODBluetooth Smart
Автоэтапы✔
Ручной отсчет этапов✔
Анализ темпа, графики скорости и маршруты на карте✔
ВОССТАНОВЛЕНИЕ ПОСЛЕ ТРЕНИРОВОК
Сохранение ощущения после тренировки на часы✔
НАГРУЗКА ПРИ ТРЕНИРОВКЕ
Журнал с подробностями тренировок✔
Общие сведения о тренировке с подробностями этапов✔
Журнал тренировок для обзора длительных периодов✔
Итоговая тренировочная нагрузка по видам спорта✔
ДЕЛИТЕСЬ И ПЕРЕЖИВАЙТЕ ЗАНОВО
Публикация тренировок в соцсетях✔
Комментарии и оценки к тренировкам✔
Подписывайтесь на других участников и читайте комментарии через ленту активностей✔
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ПЛАВАНИЕ
Темп и расстояние заплыва в бассейне✔
Дистанция плавания в открытой воде✔
Время плавания: длина дорожки, этап, общее✔
Частота гребков, количество и тип✔
Эффективность гребков (SWOLF)✔
Автоматические интервалы✔
Таблица этапов для интервальной тренировки✔
ЕЗДА НА ВЕЛОСИПЕДЕ
Скорость езды✔
Средняя скорость в режиме реального времени✔
Подсказки для интервальных тренировок с мощностью, скоростью и пульсом✔
БЕГ
Темп бега✔
Контроль маршрута✔
Калибровка Foot PODautomatic
Таблица данных кругового хронографа в часах и приложении Suunto✔
Темп: средний, максимальный, этапа — в режиме реального времени✔
Подсказки для интервальных тренировок с темпом бега, пульсом и расстоянием✔
ТРЕНИРОВКИ С НЕСКОЛЬКИМИ ВИДАМИ СПОРТА
Изменение спортивного режима во время тренировки✔
Настроенные режимы для тренировок с несколькими видами спорта✔
Пост-анализ многоборья по видам спорта✔
Общие сведения о тренировке с несколькими видами спорта на часах✔
СПОРТИВНЫЕ РЕЖИМЫ
Настройка спортивных режимов и дисплеев✔
Графические дисплеи в спортивных режимах✔
Предустановленные спортивные режимы в часах> 32
