Suunto Vertical 2
Pine Green
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
SPECYFIKACJE
Wymiary48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
Waga87g
Materiał pierścienia (ramki):Stainless steel
Materiał szkiełka:Sapphire crystal
Materiał koperty:Glass fibre reinforced polyamide
Materiał paska:Silicone
Kraj produkcjiCN
SPECYFIKACJA TECHNICZNA
OGÓLNE
Materiał pierścienia (ramki)Stainless steel
Materiał szkiełkaSapphire crystal
Materiał kopertyGlass fibre reinforced polyamide
Materiał paskaSilicone
Waga87g
Rozmiary nadgarstka125-175 mm
Szerokość paska22 mm
Zintegrowany nadgarstkowy pomiar tętna✔
Konfigurowane ekrany zegarka✔
Blokada ekranu dotykowego✔
Ekran dotykowy✔
Kolorowy wyświetlacz✔
Alarm wibracyjny✔
Wodoszczelność100 m
Typ bateriirechargeable lithium-ion
Oprogramowanie z możliwością aktualizacji✔
Godzina, data✔
Budzik✔
Podawanie godzin w dwóch strefach czasowych✔
Automatyczne śledzenie czasu✔
Minutnik✔
Stoper✔
JęzykiCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
PodświetlenieLTPO AMOLED
Podświetlenie konfigurowaneautomatic brightness
Blokada przyciskówduring exercise
Rozmiar wyświetlacza1,5"
Typ wyświetlaczamatrix
Rozdzielczość wyświetlacza466 x 466
Jednostki metryczne i imperialne✔
Wskaźnik stanu bateriipercentage / icon
Tlen we krwi✔
Zawsze włączony ekran✔
PARAMETRY
Temperatura robocza-20° C to +55° C / -5° F to +130° F
Temperatura przechowywania-20° C to +55° C / -5° F to +130° F
Zalecana temperatura ładowania0° C to +45° C / +32° F to +110° F
CZAS PRACY BATERII
Inteligentne przypomnienia o ładowaniu✔
Codzienne użytkowanie: tryb smartwatchup to 20 days
Codzienne użytkowanie: tryb czuwania tylkoup to 40 days
Trening: tryb GNSS wszystkich systemów + Multi-Bandup to 65h (AOD 60h)
Trening: tryb GNSS wszystkich systemów + Single-Bandup to 75h (AOD 70h)
Trening: obietnice baterii we wszystkich trybach65h / 75h / 110h / 250h
Trening: tryby oszczędzania energii GNSSup to 250h
KOMPAS
Kompas cyfrowy✔
Kompensacja przechylenia✔
Korekcja deklinacji✔
Skala kierunkudegrees / mils
Igłanorth indicator
Dokładność kompasu5°
Rozdzielczość kompasu1°
ŁĄCZNOŚĆ
Łączność (między urządzeniami)Bluetooth
Zgodny z aplikacją Suunto app✔
Powiadomienia telefonu na zegarku✔
Sterowanie multimediami w zegarku✔
Wysyłaj wstępnie zdefiniowane odpowiedzi z zegarka do folderu wiadomości przychodzącychAndroid only
Kompatybilność z internetowymi społecznościami sportowymiStrava, TrainingPeaks and more
Aktualizacje oprogramowania zegarka z chmury✔
Automatyczne bezprzewodowe aktualizacje oprogramowania✔
Zgodność ze smartfonamiMost common models supported, check here for detailed compatibility list
24 GODZINY NA DOBĘ 7 DNI W TYGODNIU
MONITORING AKTYWNOŚCI
Licznik kroków✔
Liczba spalonych kalorii✔
Cele aktywnościsteps, calories
Historia aktywności✔
Tempo spalania kalorii i tętno podczas codziennych czynności✔
Śledzenie codziennego minimalnego tętna✔
MONITORING SNU
Czas trwania snu✔
Pory snu✔
Czas niespania✔
Głębokie uśpienie✔
Średnie i minimalne tętno podczas snu✔
Płytki sen✔
REM✔
HRV związana ze snem✔
Jakość snu✔
OBCIĄŻENIE FIZYCZNE I REGENERACJA
Dzienny poziom zasobów✔
Stan obciążenia fizycznego i regeneracji✔
Pomiar HRV✔
FUNKCJE OUTDOOROWE
ODBIORNIK GPS I NAWIGACJA
Mapy offline na zegarku✔
Systemy satelitarneGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Równocześnie wykorzystywane systemy satelitarne4
Maksymalna liczba połączonych satelit32
Inteligentne tryby bateriiPerformance, Endurance, Ultra, Tour, Custom
Częstotliwość zapisu GPSBest, Good, OK, Low
Nawigacja po wyświetlanej trasie i po waypointach✔
Poziomy powiększenia w nawigacji✔
Automatyczne powiększenie na podstawie kształtu trasy✔
Zapis przebytej trasy w czasie rzeczywistym✔
Planowanie tras z profilem wysokości✔
Teren zewnętrzny i mapy satelitarne✔
Globalne mapy popularności dla 20 sportów✔
Planowanie trasy z mapami popularności✔
Osobista biblioteka tras w Internecie zsynchronizowana z zegarkiem✔
Przypięcie do trasy✔
Nawigacja według punktów POI✔
Analiza trasy GPS✔
Rejestrowanie, wyświetlanie i udostępnianie trasy✔
ETA (szacowany czas przybycia do celu)✔
WYSOKOŚCIOMIERZ
Wysokość barometryczna✔
Wysokość GPS✔
Zintegrowana wysokość GPS i barometryczna (FusedAlti™)✔
Wysokość w trybie dziennym✔
Aklimatyzacja na wysokości z tlenem we krwi✔
Całkowite zwiększenie lub zmniejszenie wysokości✔
Prędkość pionowa✔
Automatyczny profil wysokościomierza/barometru✔
Częstotliwość zapisu dziennika1 s
Rozdzielczość1 m
Zakres-500 - 9999 m
POGODA
Godziny wschodu i zachodu słońca✔
Alarm burzowy✔
Ciśnienie na poziomie morza✔
Temperatura✔
Zakres wyświetlanych temperatur-20° C to +55° C / -5° F to +130° F
Rozdzielczość pomiaru temperatury1° C / 1.5° F
Rozdzielczość ciśnienia1 hPa
Wykres wysokości w podsumowaniu treningu✔
FUNKCJE TRENINGOWE
TRENING INTERWAŁOWY
Konfiguracja interwałów✔
Wskazówki interwałowe podczas treningu✔
Schematy interwałów✔
TĘTNO
Pomiar tętna na nadgarstku✔
Zgodność z pasem do pomiaru tętnaBluetooth HR belts
Odstęp RRwith Suunto Smart Sensor
Tętno w uderzeniach na minutę✔
Rejestruje tętno podczas pływania✔
Wykres tętna w czasie rzeczywistym✔
Średnie tętno w czasie rzeczywistym✔
Kalorie✔
Szczytowy Efekt Treningowy✔
Osobiste strefy tętna✔
Poziom sprawności (VO2max)✔
Wykrywanie progu mleczanu✔
Czas odpoczynku✔
PRĘDKOŚĆ I ODLEGŁOŚĆ
Prędkość i dystans na podstawie kadencji✔
Prędkość i odległość GPS✔
Chronometr✔
Obsługa czujnika Foot PODBluetooth Foot Pods
Automatyczne „łapane” okrążenia✔
Ręcznie „łapane” okrążenia✔
Analiza tempa, wykresy prędkości i tras na mapie✔
REGENERACJA POTRENINGOWA
Możliwość zapisu w zegarku odczuć po treningu✔
Czas regeneracji na podstawie treningu✔
OBCIĄŻENIE TRENINGOWE
Dziennik treningu z obsługą historii i obrazów✔
Obciążenie treningowe z podsumowaniami według sportów✔
Dziennik treningów z funkcją przeglądów długoterminowych✔
Dziennik ze szczegółami treningu✔
PRZEŻYWAJ NA NOWO I UDOSTĘPNIAJ
Udostępnianie treningów w serwisie społecznościowym✔
Ocena i komentarze treningów✔
Śledź innych członków i uzyskaj opinię za pośrednictwem strumienia aktywności✔
SPORTOWE KOMPETENCJE
PŁYWANIE
Tempo pływania i odległość✔
Odległość pływania na wodach otwartych✔
Czas pływania według długości basenu, okrążenia i łącznie✔
Tempo, liczba i typ pociągnięć ramion podczas pływania✔
Wydajność pociągnięć ramion (SWOLF)✔
Automatyczne interwały✔
Tabela okrążeń interwałowych✔
JAZDA NA ROWERZE
Prędkość pedałowania✔
Średnia prędkość w czasie rzeczywistym✔
Czujnik rowerowy POD z obsługą prędkości/kadencjiBluetooth Bike Pods
Obsługa miernika mocy rowerowejBluetooth Power meters
Funkcja Bike Power (W), wart. średnia i maksymalna (za pomocą czujnika mocy)Bluetooth Power meters
Okrążenie rowerowe, maksymalne zużycie energii podczas okrążenia (za pomocą czujnika mocy)✔
Tabela okrążeń w czasie rzeczywistym ze średnim tętnem, średnią mocą i średnią prędkością✔
Wskazówki interwałowe z mocą/prędkością/tętnem✔
BIEGANIE
Tempo biegu✔
Suunto FusedSpeed™✔
Moc podczas biegania✔
SuuntoPlus™ Ghost runner✔
Kalibracja czujnika Foot PODautomatic
Tabela okrążeń w zegarku i aplikacji Suunto✔
Tempo średnie, maksymalne, okrążenia w czasie rzeczywistym✔
Wskazówki interwałowe z tempem biegu/tętnem/przebytym dystansem✔
SPORTY MULTIDYSCYPLINARNE
Zmiana trybu sportowego podczas treningu✔
Wstępnie skonfigurowane tryby sportów multidyscyplinarnych✔
Analiza treningu multisportowego według dyscypliny✔
Podsumowanie treningów multisportowych w zegarku✔
TRYBY SPORTOWE
Możliwość personalizacji trybów sportowych i ekranów✔
Wyświetlanie graficzne w trybach sportowych✔
Zainstalowane tryby sportowe zegarka> 90
SuuntoPlus™✔
FUNKCJE NURKOWE
NURKOWANIE BEZDECHOWE (FREEDIVING)
Głębokościomierz do nurkowania z fajką10 m
