SUUNTO CORE
Download PDF
SAFETY
SAFETY
Types of safety precautions:
WARNING:
- is used in connection with a procedure or situation that may result in serious injury or death.
CAUTION:
- is used in connection with a procedure or situation that will result in damage to the product.
- is used to emphasize important information.
Safety precautions:
WARNING:
DO NOT USE FOR SCUBA DIVING.
WARNING:
ALLERGIC REACTIONS OR SKIN IRRITATIONS MAY OCCUR WHEN PRODUCT IS IN CONTACT WITH SKIN, EVEN THOUGH OUR PRODUCTS COMPLY WITH INDUSTRY STANDARDS. IN SUCH EVENT, STOP USE IMMEDIATELY AND CONSULT A DOCTOR.
CAUTION:
DO NOT EXPOSE TO RAPID TEMPERATURE CHANGES.
CAUTION:
DO NOT APPLY SOLVENT OF ANY KIND.
CAUTION:
DO NOT APPLY INSECT REPELLENT.
CAUTION:
TREAT AS ELECTRONIC WASTE.
CAUTION:
DO NOT KNOCK OR DROP.
WELCOME
Welcome
“For nearly 80 years Suunto has provided accurate, reliable information to people in need of it. Our instruments enable our users to reach their goals more effectively and get more out of their sports experience. Our products are often very critical to the user. Therefore we at Suunto take pride in maintaining highest quality standards for our products.”
Founded in 1936, Suunto is the world leader in precision compasses, dive computers and wristop altimeters. Trusted by climbers, divers and explorers on every continent, Suunto Outdoor instruments deliver legendary design, accuracy and dependability. In 1987, Suunto pioneered the first dive computer, followed by the first Altimeter-Barometer-Compass watch in 1998. Suunto remains the foremost choice of today's outdoor professional. To learn more about Suunto products and the people who use them, visit apac.suunto.com .
INTRODUCTION
Introduction
Suunto Core brings together an altimeter, barometer and an electronic compass in one package. It also has clock, stopwatch and calendar functions.
This User Guide explains the features, how they work, and how you access them. In addition, we have included examples of how you can use them in real life situations.
Each main chapter explains a mode and its views. It also gives you information on how to set and use these views.
Suunto Core gives you readings on time, barometric pressure and altitude. Additional information is given for every reading so that you can make the most of your favorite outdoor activities.
GETTING STARTED
Getting started
Basic settings
Press any button and your Suunto Core will activate. You are then prompted to set the language, units (imperial or metric), time and date. Use the upper right button and lower right button to change the settings. Accept and move to the next menu item by pressing the right middle button. You can always return to the preceding menu item by pressing the lower left button. When the settings are set as you want, you can start using the basic time features of your Suunto Core .
You need to set the altimeter, barometer and compass to get correct readings. Please refer to the User Guide for detailed information on setting these properly.
Modes
Your Suunto Core has three modes: time , ALTI & BARO and Compass . These modes are explained in detail in the User Guide. The enabled mode is indicated by a rectangle around the mode name. You switch between the main modes with the right middle button. Try it!
Views
Each mode has a set of views that you access with the lower left button. Views are presented in the lower part of the display. Views contain supplementary information about the enabled mode, for example, viewing seconds as supplementary information in the time mode. Some views are also interactive.
Suunto Core has four interactive views:
- Stopwatch ( time mode)
- Countdown timer ( time mode)
- Log recorder ( ALTI & BARO mode)
- Altitude difference measurer ( ALTI & BARO mode)
When interactive views are enabled, you can start, stop and restart them with the upper left button and reset them by keeping the upper right button pressed. Enter the stopwatch in time mode and try it out!
Menu
In Menu you can change values, change the general settings and units, or view logs stored in the logbook. To enter Menu , keep the middle right button pressed while in the time , ALTI & BARO or Compass mode. The segments in the outer part of the display indicate your transition time. Exit Menu by pressing the upper left button. Whenever an exit option is available in Menu , this is indicated with an “X” on the screen next to the button. Get familiar with entering and exiting Menu !
Backlight
You can activate the backlight in any mode by pressing the lower right button. The backlight turns off automatically after 5 seconds. If you want to see the backlight when you are in Menu , you need to activate it in the time , ALTI & BARO or Compass mode before entering Menu . The backlight will return to normal when you return to a mode.
Button lock
You can activate and deactivate the button lock by keeping the lower right button pressed.
You can change views and use the backlight when the button lock is activated.
Changing values
To change a setting, you have to be in Menu . To enter Menu , keep the right middle button pressed down in the time , ALTI&BARO or Compass mode. Any changes you make in Menu take effect immediately. For example, if you enter TIME-DATE in Menu and change the time from 12:30 to 11:30 and exit. The time will be set to 11:30.
GENERAL SETTINGS
GENERAL SETTINGS
Before you start to use your Suunto Core, it's a good idea to set the measurement units and general settings according to your preferences. General settings are changed in Menu.
Changing units
In units you select the measurement units, including:
- time : 24h/12h
- date : dd.mm/mm.dd
- temperature : °C/°F (Celsius/Fahrenheit)
- air pressure : hPa/inHg
- altitude : meters/feet
To enter units in Menu :
- Enter Menu by keeping pressed in the Time , Alti & Baro or Compass mode.
- Scroll down to units using .
- Enter with .
To change units:
- In units , scroll between the list items using and .
- Enter with .
- Change the values using and , accept with .
- Exit Menu with .
Changing general settings
In General you set the general settings, including:
- button tone : on/off
- tone guide : on/off
- backlight : light button/any button
- language : English, French, Spanish, German
To enter General in Menu :
- Scroll down to General using .
- Enter with .
Button tone
In Button tone you turn the button tone on or off. A button tone is emitted every time a button is pressed, confirming an action.
- In General , select Button tone .
- Switch the button tone on or off with and .
Tone guides
In tone guide you turn the tone guides on or off. You will hear tone guides when:
- You change a setting value
- You set the altitude reference value
- You start or stop the log recorder
- You mark an altitude point while you are recording logs
- You start or stop the stopwatch
- The device switches between the altimeter and Barometer profile when you are using the automatic profile.
To turn tone guides on or off:
- In General , select Tone guides .
- Switch the tone guides on or off with and .
Backlight
In Backlight you switch between two different light features: any button and light button.
To set the backlight to normal or night use:
- In General , select Backlight .
- Switch the backlight between light button and any button with and .
When light button has been selected, you can activate the backlight with . The backlight is turned off automatically after 5 seconds. If you want to see the backlight when you are in the Menu , you need to activate it in the Time , Alti & Baro or Compass mode before entering the Menu . The backlight will then be activated until you exit Menu .
When any button has been selected, the backlight is activated every time you push a button.
Language
In Language you choose the language of your Suunto Core user interface (English, German, French or Spanish).
To choose a language:
- In General , select Language .
- Select a language from the list with and .
Activating button lock
You can activate and deactivate the button lock by keeping pressed down. When the button lock is activated, it is indicated with a lock symbol
USING TIME MODE
Changing time settings
You change the time settings in Menu .
To enter time settings in Menu :
- Enter Menu by keeping pressed down.
- Scroll down to Time-Date using .
- Enter with .
Setting time
In Time you set the time.
To set the time:
- In Time-Date , select Time .
- Change the hour, minute and second values with and .
Setting date
In Date you set the month, day and year.
To set the date:
- In Time-Date , select Date .
- Change the year, month and day values with and .
To change the format in which the time is displayed, see Changing units .
Setting dual time
In dual time you can set the time for a location in a different time zone.
To set dual time:
- In Time-Date , select dual time .
We recommend that you set the current time at your current location as the main time because the alarm clock emits alarms according to the main time.
You are traveling abroad and you set the dual time to be the time at home. The main time is the time at your current location. Now you always know the local time and you can quickly check what time it is at home.
Setting sunrise and sunset times
In Sunrise you select a reference city that your Suunto Core uses to give you sunrise and sunset times.
To set sunrise and sunset times:
- In Menu , select Sunrise .
- Scroll through the locations with and .
- Select a location with .
If you want to set the sunrise and sunset times for a location that is not listed in your device, select another reference city from the same time zone. Select the closest city north or south from your location.
You’re hiking in Algonquin, a huge national park north of Toronto. You want to know when the sun sets, so that you know when to start putting up your tent for the night. You choose “Toronto” as your reference sunrise-sunset city. Your now tells you when the sun will set.
Using stopwatch
The stopwatch measures time. Its resolution is 0.1 seconds.
To use the stopwatch:
- In the Time mode, select the stopwatch view.
- Start, stop and restart the stopwatch with .
- Keep pressed to reset the stopwatch.
Your friend is training for a running competition, and needs to know how long it takes him to run the 100 m dash. You start the stopwatch the instant he breaks from the blocks. You stop the stopwatch the instant he crosses the finish line. The result: 11.3 seconds. Not bad!
Using countdown timer
In Countdown you can set the countdown timer to count down from a preset time to zero. It sounds an alarm when zero is reached. The default is 5 minutes.
To change the default countdown time:
- In Menu , select Time-Date .
- Select Countdown .
- Set the timer minutes and seconds (maximum 99 minutes and 59 seconds).
- Accept with .
To start counting down:
- In Time mode, select the countdown timer view.
- Start, stop and restart with .
- Keep pressed to reset the timer.
You’re on a hiking expedition. It’s morning. You wake up, come out of your tent, and start to make breakfast at your campfire. This time, you want 8-minute eggs. You set the countdown timer to 8 minutes with your eggs in the pot and wait for the water to come to a boil. When the water boils, you engage the countdown timer. At the eight-minute point, your gives the alarm. Presto! Perfect 8-minute eggs.
Setting alarm
You can use your Suunto Core as an alarm clock.
To access the alarm clock and set the alarm:
- Select alarm .
- Switch the alarm on or off with and .
- Accept with .
- Use and to set the hours and minutes.
When the alarm is switched on, the alarm symbol
appears on the display.
When the alarm sounds, you can either snooze or turn the alarm off.
If you choose Yes or do nothing, the alarm stops and restarts every 5 minutes until you stop it. You can snooze up to 12 times for a total of 1 hour. If you choose No , the alarm stops and restarts the same time the following day.
When the snooze is turned on, you can deactivate it in the time mode by keeping pressed down.
You want to wake up early tomorrow morning. You set your alarm for 6:30 before you go to bed. The alarm wakes you up at 6:30 the next morning but you want to sleep for another 5 minutes. You choose YesYes when the device asks you if you want to snooze. After 5 minutes the alarm goes off again. This time you get up and happily start preparing for your trip. What a difference five minutes can make!
The alarm symbol is blinking when the snooze is activated. When snooze is deactivated, the alarm symbol stops to blink.
USING ALTI & BARO MODE
How Alti & Baro works
To get the right readings from Alti & Baro , it is important to understand how Suunto Core calculates altitude and sea level air pressure.
Suunto Core constantly measures absolute air pressure. Based on this measurement and reference values, it calculates altitude or sea level air pressure.
CAUTION:
Keep area around sensor free of dirt and sand. Never insert any objects into the sensor openings.
Getting correct readings
If you are engaged in an outdoor activity that requires you to know the air pressure, you need to enter the altitude reference value for your location. This is found on most topographic maps. Your Suunto Core will now give you the correct readings.
To get the correct altitude readings, you need to enter the sea level air pressure reference value. The sea level air pressure reference value relevant to your location can be found in the weather section of the local newspaper or on the websites of national weather services.
Absolute air pressure is measured constantly Absolute air pressure + altitude reference = Sea level air pressure
* Absolute air pressure + sea level air pressure reference = Altitude *
Changes in local weather conditions will affect altitude readings. If local weather changes often, it is advisable to reset the current altitude reference value frequently, preferably before starting your journey when the reference values are available. If local weather is stable, you do not need to set reference values.
Getting incorrect readings
Altimeter profile + standing still + weather change
If your altimeter profile is on for an extended period of time with the device in a fixed location while the local weather changes, the device will give incorrect altitude readings.
Altimeter profile + altitude moving + weather change
If your altimeter profile is on and the weather changes frequently while you climb in altitude or go down in altitude, the device will give you incorrect readings.
Barometer profile + altitude moving
If the Barometer profile is on for an extended period of time as you climb in altitude or go down in altitude, the device assumes that you are standing still and interprets your changes in altitude as changes in sea level air pressure. It will therefore give you incorrect sea level air pressure readings.
You’re on the second day of your two-day hike. You realize that you forgot to switch from the BarometerBarometer profile to the altimeterAltimeter profile when you started moving in the morning.You know that the current altitude readings given by your watch are wrong. So, you hike to the nearest location shown on your topographic map for which a altitude reference value is provided. You correct your altitude reference value accordingly. Your altitude readings are correct again.
Setting profiles and reference values
Matching profile to activity
The altimeter profile should be selected when your outdoor activity involves changes in altitude (e.g. hiking in hilly terrain). The Barometer profile should be selected when your outdoor activity does not involve changes in altitude (e.g. surfing, sailing). To get the correct readings, you need to match the profile to the activity. You can either let Suunto Core decide which profile is most suitable for you at the moment, or you can choose a suitable profile yourself.
Setting profiles
To set the profile:
- In Menu , select alti-baro .
- Select Profile .
- Choose a suitable profile.
Alternatively you can set the profile in the Alti & Baro mode by keeping pressed down.
Setting reference values
To set the reference value:
- Select Reference and choose between the altimeter and Sea level .
- Set the known reference value using and .
You’re hiking and take a break when you see a sign with the current altitude. You check your altitude reading and discover a small difference between the two numbers. You set the altitude reference value on your to match that of the sign.
Using weather trend indicator
The weather trend indicator is located on the upper side of the display. It is displayed in the time and alti & baro modes, providing you with quick reference to check upcoming weather conditions. The weather trend indicator is comprised of two lines forming an arrow. Each line represents a 3-hour period. The right line represents the last 3 hours. The left line represents the 3 hours prior to the last 3 hours. So the line can indicate 9 different patterns in the barometric trend.
| Situation 3-6 hours ago | Situation last 3 hours | |
| Dropped heavy (>2 hPa/3hours) | Dropping heavily (>2 hPa/3hours) | |
| Remained stable | Rising heavily (>2 hPa/3hours) | |
| Rose heavy (>2 hPa/3hours) | Dropping heavily (>2 hPa/3hours) |
If the weather trend indicator shows that the air pressure is constantly rising, there is a higher possibility of sunny weather upcoming. Again, if the air pressure is constantly dropping, there is a higher possibility of rainy weather.
Activating storm alarm
The storm alarm notifies you that a pressure drop of 4 hPa / 0.12 inHg or more has occurred during a 3-hour period. Suunto Core will activate an alarm and flash an alarm symbol on the display for 20 seconds. The storm alarm only works when you have activated the barometer profile in the Alti & Baro mode.
To activate the storm alarm:
- Select Storm alarm .
- Switch the storm alarm on or off with and .
You can stop the storm alarm by pressing any button.
You are hiking in a dense forest when your activates the storm alarm. The weather has taken a turn for the worse in the last 3 hours - the sky is getting dark. Good thing your warned you, because you need to find shelter from the hard rain that may soon fall.
Using altimeter profile
The altimeter profile calculates altitude based on the reference values. The reference values can either be sea level air pressure or a previous point of altitude reference value. When the altimeter profile is activated, the word Alti is underlined on the display.
When the altimeter profile is activated, you can access the following views with :
- Log recorder: records the altitude changes into logs
- Altitude difference measurer: measures the altitude difference from a set point
- Temperature: measures the current temperature
- Empty: no supplementary information
Using altitude difference measurer
The altitude difference measurer shows the difference in altitude between a set point and your current position. This feature is especially useful for mountain climbing, for example when you want to track your progress in terms of altitude climbed.
To use the altitude difference measurer:
- In the Alti & Baro mode, select the altitude difference measurer view.
- Start, stop and restart it with .
- Keep pressed to reset.
You are about to start climbing a mountain that is 3, 280 feet (1000 m) high. You want to be able to check your progress as you climb, so you activate the altitude difference measurer on your Suunto Core . You start climbing, checking your altitude occasionally to see how far you are from the next check point. At some point you start to get tired. You check your altitude, and see that there’s still a lot of climbing ahead. Maybe you need to rethink your next check point.
Recording logs
The log recorder stores all your movements in altitude between the start and stop times. If you are engaged in an activity in which your altitude changes, you can record the altitude changes and view the stored information later.
You can also set altitude marks (laps), allowing you to view the duration and ascent/descent height between your previous mark and current mark. Your marks are stored in memory and you can access them later.
To record a log:
- In the Alti & Baro mode, select the log recorder view.
- When you are recording a log, set laps with .
- Keep pressed to reset (this can only be done when the recorder is stopped).
Log height difference: shows the measured altitude difference between a log starting point and a log finishing point with the following icons:
| In the additional views: | |
| is displayed when your altitude is above the starting point. | |
| is displayed when your altitude is the same as at the starting point. | |
| is displayed when your altitude is below the starting point. | |
| is displayed when you view how much you have ascended from the log start. | |
| is displayed when you view how much you have descended from the log start. |
Altitude points are recorded according to the recording interval you have chosen (see Choosing recording interval ).
To change the recording rate:
- In Menu , select memory .
- Select rec interval .
- Change the recording rate with and .
An estimation of how much time you can record is shown in the lower part of the display when you browse between the recording rates. The actual recording durations may vary slightly depending on your activity during the recording period.
You can access your history of recorded logs, including log details, from logbook in Menu (see Viewing and locking logs ).
When you have stopped the log recorder, you can enter the logbook and view your current recordings before you reset the recorder.
Using barometer profile
The Barometer profile shows the current sea level air pressure. This is based on the reference values given and the constantly measured absolute air pressure. Changes in sea level air pressure are presented graphically in the middle of the display. The display shows the recording of the last 24 hours with a recording interval of 30 minutes.
When the Barometer profile is activated, the word Baro is underlined on the display.
When the Barometer profile is activated, you can access the following views with :
- Log recorder: records the altitude changes in logs
- Altitude reference: shows the altitude reference value
- Time: shows the current time
- Empty: no additional view
If you are wearing your Suunto Core on your wrist, you will need to take it off in order to get an accurate temperature reading because your body temperature will affect the initial reading.
A 7-day log of changes in sea level air pressure can be viewed in alti-baro memory in Menu (see Alti-baro memory ).
You’re still hiking and you’re getting tired. You decide to take a nap and you set up your tent. Since your altitude will stay the same for a while, you activate the BarometerBarometer profile. When you wake up, you will be able to check changes in sea level air pressure with an eye on the weather.
Recording logs
When you are recording logs in the altimeter profile, you can switch to the Barometer profile when you for example take a break during a hike.
The log recorder will continue recording the log, but it will not record changes in air pressure. When the barometer profile is activated, the device assumes you are not moving in altitude, and it will therefore not record any altitude changes. The altitude log will therefore be flat during this period. For information on using the log recorder, see Recording logs .
You can start, stop and reset the altitude measurement while in the Barometer profile.
You are recording your altitude changes during a hike and decide to take a longer break. You switch to the Barometer profile. Since the altitude recording continues but no altitude changes are occurring, you go to the log recorder view in the Barometer profile and stop the altitude recording.
Using automatic profile
The automatic profile switches between the altimeter and Barometer profiles according to your movements. When the automatic profile is activated, appears on the upper right part of the display. Depending on which profile is activated, you can access the altimeter or barometer profile views with .
When the device is moving 5 meters in altitude within 3 minutes, the altimeter profile is activated. When the device does not move in altitude for 12 minutes, the barometer profile is activated.
The automatic profile should not be activated all the time. Some activities require the barometer profile to be constantly activated even though you might be moving (e.g. surfing). In other words, in certain situations you need to choose a suitable profile manually.
Using depth meter profile
You use the depth meter profile when snorkeling. It shows your current depth and the maximum depth you reached during a snorkeling dive. The maximum depth of the device is 32.8 ft (10m). When the depth meter profile is activated, a wave icon appears on the upper left part of the display.
When the depth meter profile is activated, you can access the following views with :
- Log recorder: records your snorkeling dives
Recording logs in depth meter profile
The log recorder in the depth meter profile works similarly to the log recorder in the altimeter profile, but instead of recording altitude it records the depth of your snorkeling dives.
To record logs in the depth meter profile:
- Start, stop and restart it with . Begin a snorkeling dive.
- When you return to the surface, reset by holding pressed.
CAUTION:
Do not push buttons while the device is under water.
You need to reset your log recorder in the altimeter profile before using the log recorder in the depth meter profile. Otherwise, your maximum depth will stay the same as your current altitude above the surface.
When you have stopped your log recorder, before resetting it, you can enter the logbook and view your current recordings!
USING COMPASS MODE
To ensure correct compass readings while in COMPASS mode: Compass
- calibrate the compass correctly when prompted (see Calibrating compass )
- set the correct declination value
- keep the device level
- keep away from metal (e.g. jewelry) and magnetic fields (e.g. power lines)
Calibrating compass
The device needs to be carefully calibrated during first time use and when the battery is replaced. The device will always prompt you about it when it is needed.
To calibrate the compass:
- Keep the device level, do not tilt it in any directions.
- Slowly rotate the device clockwise (around 15 seconds per round) until the compass is activated.
If you notice deviations in the compass, you can recalibrate it by keeping it level and rotating it slowly clockwise 5-10 times while in compass mode.
Re-calibrate the compass before each use for best possible accuracy.
Setting declination value
Paper maps point to true North. Compasses, however, point to magnetic North – a region above the Earth where the Earth’s magnetic fields pull. Because magnetic North and true North are not at the same location, you must set the declination on your compass. The angle in between magnetic and true north is your declination.
The declination value appears on most maps. The location of magnetic North changes yearly, so the most accurate and up-to-date declination value can be obtained from the internet (for example the National Geophysical Data Center for the USA).
Orienteering maps, however, are drawn in relation to magnetic North. This means that when you are using orienteering maps you need to turn the declination correction off by setting the declination value to 0 degrees.
To set the declination value:
- In Menu , select Compass .
- Turn the declination off or choose W (west) or E (east).
- Set the declination value with and .
Using compass
When you are in the Compass mode, you see two moving segments on the rim of the display. These point towards North. The hairline at 12 o’clock shows your heading and functions as a compass direction arrow. The numerical value of your heading is shown in the center of the display.
In Compass mode you can access the following views with [View]:
- Cardinals: shows the current heading in cardinal directions
- Bearing tracking: shows the direction between the heading and the set bearing
The compass will switch itself to power saving mode after a minute if no buttons are pressed. Reactivate it with .
You can use the compass in two ways: you can use the bezel or the bearing tracking.
Using bearing tracking
In bearing tracking you can lock a bearing (direction) and your Suunto Core compass will guide you along it.
To use the bearing tracking:
- Point the compass direction arrow in the direction you want to travel and press . The bearing is now locked. Your current heading is shown in the middle of the display, and it will change according to your movements.
- The arrows in the top row of the display point you in the direction you need to take in order to keep to your desired bearing. The
symbol confirms that you are aiming towards the right direction.
Pressing also activates the backlight.
You’re hiking and you’ve just climbed a steep hill. Looking out over the valley below, you see a cabin on another hill. You decide to hike to the cabin through the valley. You point the direction arrow of your compass towards the cabin and lock the bearing. Once you’re in the valley, the arrows in the display’s top row show you where to go. Because the compass is active for only 40 seconds at a time to conserve battery life, now and then you need to re-start the compass to check your heading. Keep an eye on it and you’ll get there soon.
USING MEMORY
Alti-baro memory
alti-baro automatically records changes in altitude or sea level air pressure for the last 7 days. Information will be stored depending on which profile is active at the moment of the recording. Records are stored every 30 minutes.
To view the records of the last 7 days:
- In memory , select alti-baro .
- Use and to browse through the records.
You are camping in the mountains. You want to predict tomorrow’s weather, so you switch your to the Barometer profile for the night. In the morning you check the alti-baro memory and note that the air pressure remained stable for the whole night. Hopefully this will continue during the day.
Logs recorded by the log recorder in the altimeter , Barometer or depth meter profile are stored in logbook . You can store up to 10 logs. A new log always replaces the oldest log in logbook . To save logs, you can lock them.
is shown when a log is locked.You can only lock up to 9 logs.
When entering logbook , you are shown the number of unlocked logs. You can then choose to either view or lock logs.
When you view logs, you are first shown a list of available logs complete with times and dates. You can scroll and then enter each log to view its summary information and details.
Viewing logs
When viewing log summaries, you are shown
- A summary graph, time of recording and highest point
- Total descent, duration of descent, average descent speed
- Total ascent, duration of ascent and average ascent speed
- Altimeter split time (total log duration from start) and lap times (duration since last lap time)
When viewing log details, you are shown:
- A graph of the changes in altitude
- Time of recording
- Altitude/depth at the time of recording
To view the logs:
- In memory , select logbook .
- Choose a log from the list.
- Select View .
- Switch between log summaries with and .
- View log details with .
- Increase and decrease scrolling speed and change direction with and . Stop with .
When scrolling the graph, your current position is in the middle of the graph.
Only altimeter logs include summaries.
Locking and unlocking logs
To lock or unlock the logs:
- Select Lock / Unlock .
- Lock/unlock the log with OR Cancel with ).
You can choose the recording interval in rec interval in Menu .
You can choose between five recording intervals:
- 1 second
- 5 seconds
- 10 seconds
- 30 seconds
60 seconds
When browsing through the intervals, the available recording time is shown in the lower part of the display.
To choose a recording interval:
- In memory , select rec interval .
- Choose a recording interval using and .
Short lasting activities with fast changes in altitude is better to record with faster recording interval (e.g. downhill skiing). Again, long time activities with slower changes in altitude is better to record with slower recording interval (e.g. hiking)
CARE AND SUPPORT
Handling guidelines
Handle your Suunto Core with care. The sensitive internal electronic components may be damaged if the device is dropped or otherwise mishandled.
Do not try to open or repair your Suunto Core by yourself. If you are experiencing problems with the device, please contact your nearest authorized Suunto Service Center.
Remember to register your product at support to get personalized support.
Leather straps
Suunto Core leather straps are made from high quality natural hides. The performance and lifespan of these straps can differ from one strap to the next given the natural variation in the materials.
Usage also has a significant impact on the performance and lifespan of leather straps, much like belts, wallets and other items made from leather. Contact with fresh water, salt water, and perspiration may change the color and odor of the strap, as well as shorten its lifespan.
If you intend to swim, snorkel or participate in strenuous activities with your Suunto Core , we recommend using a synthetic strap.
Cleaning
Regularly clean and dry your Suunto Core with fresh water and a soft cloth, particularly after heavy perspiration or swimming. Avoid getting leather straps wet.
Replacing battery
To reduce the risk of fire or burns, do not crush, puncture or dispose of used batteries in fire or water. Recycle or dispose of used batteries properly.
If the threads of the battery compartment cover are damaged, send your device to an authorized Suunto representative for service.
Suunto original battery replacement and strap kits must be used if available for your product. Kits are available at Suunto webshop and some authorized Suunto dealers. Not using these kits and careless battery replacement may void warranty.
SPECIFICATIONS
Icons
The following icons are displayed in Suunto Core :
| alarm | |
| alti-baro mode | |
| automatic profile | |
| back/return | |
| battery low | |
| button indicator | |
| button lock | |
| compass line | |
| compass mode | |
| depth meter profile | |
| down/decrease | |
| forward/accept | |
| quick exit | |
| time mode | |
| up/increase | |
| weather trend indicator |
Technical data
General
- Operating temperature -20°C … +60 °C / -4°F … +140°F
- Storage temperature -30 °C … +60 °C / -22°F … +140°F
- Water resistance: 30 m / 100 ft
- Mineral glass
- User-replaceable battery CR2032
- Battery life-time: ~ 1 year in normal use
Altimeter
- Display range: -500 m … 9000 m / -1640 ft … 32760 ft
- Resolution: 1 m / 3 ft
Barometer
- Display range: 920 … 1080 hPa / 27.13 … 31.85 inHg
- Resolution: 1 hPa / 0.03 inHg
Depth meter
- Depth display range: 0 … 10 m / 0 … 32.8 ft
- Resolution: 0.1 m
Thermometer
- Display range: -20°C … 60°C / -4°F … 140°F
- Resolution: 1°C / 1°F
Compass
- Resolution 1°
Warranty
Warranty Period
The Warranty Period is two (2) years for Watches, Smart Watches, Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive Mechanical Instruments, and Mechanical Precision Instruments unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to Suunto chest straps, watch straps, chargers, cables, rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
This Limited Warranty does not cover:
- normal wear and tear such as scratches, abrasions, or alteration of the color and/or material of non-metallic straps, b) defects caused by rough handling, or c) defects or damage resulting from use contrary to intended or recommended use, improper care, negligence, and accidents such as dropping or crushing;
- printed materials and packaging;
- defects or alleged defects caused by use with any product, accessory, software and/or service not manufactured or supplied by Suunto;
- non-rechargeable batteries.
This Limited Warranty is not enforceable if the Product or accessory:
- has been opened beyond intended use;
- has been repaired using unauthorized spare parts; modified or repaired by unauthorized Service Center;
- serial number has been removed, altered or made illegible in any way, as determined at the sole discretion of Suunto; or
- has been exposed to chemicals including but not limited to sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service, visit apac.suunto.com/warranty , contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
CE
Suunto Oy hereby declares that this product is in compliance with the essential requirements and other relevant provisions of Directive 1999/5/EC.
Patent notice
This product is protected US Patent application serial number 11/152,076 and corresponding patents or patent applications in other countries. Additional patent applications are pending.
Trademark
Suunto Core , its logos, and other Suunto brand trademarks and made names are registered or unregistered trademarks of Suunto Oy. All rights are reserved.
Copyright
Copyright © Suunto Oy. All rights reserved. Suunto, Suunto product names, their logos and other Suunto brand trademarks and names are registered or unregistered trademarks of Suunto Oy. This document and its contents are proprietary to Suunto Oy and are intended solely for the use of clients to obtain knowledge and information regarding the operation of Suunto products. Its contents shall not be used or distributed for any other purpose and/or otherwise communicated, disclosed or reproduced without the prior written consent of Suunto Oy. While we have taken great care to ensure that information contained in this documentation is both comprehensive and accurate, no warranty of accuracy is expressed or implied. This document content is subject to change at any time without notice. The latest version of this documentation can be downloaded at apac.suunto.com .
