Suunto A-30
SH Metric Compass
A compact, accurate compass for hiking and orienteering, also in poor visibility
Choose your Color
BASEPLATE COMPASS WITH MAGNIFYING LENS FOR BACKPACKERS
Suunto A-30 is a reliable baseplate compass for navigating and surviving in extreme conditions. Depending on the variant, A-30 comes with Metric UTM scales and inch ruler or USGS UTM scales.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
Sustainable design from Finland
Suunto compasses are born from a legacy of Finnish innovation, crafted with precision and reliability that has guided adventurers since 1936. Designed and manufactured in Finland, each compass reflects Suunto’s commitment to quality, durability, and environmental responsibility. Made with 100% renewable energy, our compasses are built to last ensuring they remain a trusted companion for years of exploration.
For greater transparency, we’ve calculated a category-level carbon footprint for selected field compass models, representing the average climate impact of a compass in this category.
Read more about our climate actions and purchased voluntary carbon credits.
SPECIFICATIONS
Measurements114 x 56 x 10 mm / 4.49 x 2.2 x 0.39 "
Weight32 g / 1.13 oz
Bezel material:Plastic
What's in the box?Suunto A-30 SH Metric Compass, lanyard, Quickrelease, Quick Guide
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialPlastic
Metric scalescm, 1:25 000 m, 1:50 000 m
Declination correctionficed scale
Balanced for southern hemisphere✔
Water resistanceinsensitive to water pressure
Battery typeno battery required
Luminous markingsbezel, orienting markings and direction of travel
Lanyard quick release✔
Attachmentlanyard
PHYSICAL SPECIFICATIONS
Operating temperature-30° C to +60° C / -22° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
COMPASS
Direction scaledegrees
Needlehigh grade steel
Bearing lock with orienting indicator✔
Liquid filled and jewel bearing✔
Compass accuracy2.5°
Compass resolution2°
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Magnifying lens✔
