Suunto Vertical 2
Arctic Gray
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
SPECIFICHE
Misure48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
Peso87g
Materiale della lunettaStainless steel
Materiale del vetroSapphire crystal
Materiale della cassaGlass fibre reinforced polyamide
Materiale del cinturinoSilicone
Paese di produzioneCN
Specyfikacja techniczna
OGÓLNE
Peso87g
Dimensioni del polso125-175 mm
Larghezza del cinturino22 mm
Frequenza cardiaca al polso integrata✔
Quadranti personalizzabili✔
Blocco dello schermo tattile✔
Display touch✔
Display a colori✔
Avviso con vibrazione✔
Resistenza all’acqua100 m
Tipo di batteriarechargeable lithium-ion
Firmware aggiornabile✔
Ora, data✔
Sveglia✔
Doppio orario✔
Sincronizzazione automatica dell’ora✔
Timer per il conto alla rovescia✔
Cronometro✔
LinguaCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
RetroilluminazioneLTPO AMOLED
Retroilluminazione configurabileautomatic brightness
Blocco dei pulsantiduring exercise
Dimensione del display1,5"
Tipo di displaymatrix
Risoluzione del display466 x 466
Unità metriche e imperiali✔
Ora legale automatica✔
Indicatore della batteriapercentage / icon
Ossigeno nel sangue✔
Display sempre acceso✔
SPECIFICHE FISICHE
Temperatura operativa-20° C to +55° C / -5° F to +130° F
Temperatura di conservazione-20° C to +55° C / -5° F to +130° F
Temperatura batteria in carica:0° C to +45° C / +32° F to +110° F
DURATA DELLA BATTERIA
Promemoria carica intelligenti✔
Uso quotidiano: modalità smartwatchup to 20 days
Uso quotidiano: solo modalità standbyup to 40 days
Allenamento: modalità GNSS tutti i sistemi + multi-bandaup to 65h (AOD 60h)
Allenamento: modalità GNSS tutti i sistemi + banda singolaup to 75h (AOD 70h)
Allenamento: promesse di batteria per tutte le modalità65h / 75h / 110h / 250h
Allenamento: modalità GNSS a risparmio energeticoup to 250h
BUSSOLA
Bussola digitale✔
Compensazione inclinazione✔
Correzione della declinazione✔
Scala direzionedegrees / mils
Taraturanorth indicator
Precisione della bussola5°
Risoluzione della bussola1°
CONNETTIVITÀ
Connettività (tra dispositivi)Bluetooth
Suunto app compatibile✔
Le notifiche del telefono sull'orologio✔
Comandi multimediali sull'orologio✔
Invio di risposte precompilate dall'orologio ai messaggi in arrivoAndroid only
Compatibile con le comunità sportive onlineStrava, TrainingPeaks and more
Aggiornamenti del software dell'orologio dal cloud✔
Aggiornamenti software over-the-air automatici✔
Compatibilità con smartphoneMost common models supported, check here for detailed compatibility list
24/7
MONITORAGGIO DELLE ATTIVITÀ
Contapassi✔
Calorie bruciate✔
Obiettivi delle attivitàsteps, calories
Cronologia attività✔
Conteggio delle calorie bruciate e frequenza cardiaca durante le attività quotidiane✔
Monitoraggio quotidiano della frequenza cardiaca minima✔
MONITORAGGIO DEL SONNO
Durata del sonno✔
Ora in cui ci si va a letto✔
Orario sveglia✔
Sonno profondo✔
Frequenza cardiaca media e minima durante il sonno✔
Sonno leggero✔
REM✔
HRV da sonno✔
Qualità del sonno✔
STRESS E RECUPERO
Livello di risorse giornaliero✔
Stato dello stress e del recupero✔
Misurazione HRV✔
FUNZIONI ALL'APERTO
MONITORAGGIO E NAVIGAZIONE GPS
Mappe offline sull'orologio✔
Sistemi satellitariGPS, GLONASS, GALILEO, QZSS, BEIDOU
Supporto frequenza GNSSDual band (L1+L5)
Sistemi satellitari simultanei4
Satelliti max. collegati32
Modalità batteria intelligentiPerformance, Endurance, Ultra, Tour, Custom
Frequenza registrazione GPSBest, Good, OK, Low
Tappe intermedie (waypoint) e navigazione grafica itinerari✔
Livelli di zoom nella navigazione✔
Zoom automatico basato sulla conformazione dell'itinerario✔
Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale✔
Pianificazione itinerari con profilo altitudine✔
Mappe terreni outdoor e satellitari✔
Mappe di calore globali per 20 sport✔
Pianificazione del percorso con mappe di calore✔
Libreria personale itinerari nel Web sincronizzata con l'orologio✔
Segui percorso✔
Navigazione punti di interesse (PDI)✔
Analisi percorsi GPS✔
Registrazione, visualizzazione e condivisione percorsi✔
ETA (ora di arrivo prevista)✔
ALTIMETRO
Altitudine barometrica✔
Altitudine GPS✔
Combinazione altitudine GPS e barometrica (FusedAlti™)✔
Altitudine in modalità giornaliera✔
Acclimatamento all'altitudine con la funzione di saturazione ossigeno✔
Ascesa/discesa totale✔
Velocità verticale✔
Profilo alti/baro automatico✔
Frequenza di registrazione1 s
Risoluzione1 m
Rilevazione altitudine-500 - 9999 m
METEO
Ora di alba e tramonto✔
Allarme temporale/tempesta✔
Pressione a livello del mare✔
Temperatura✔
Intervallo visualizzazione temperatura-20° C a +55° C / -5° F a +130° F
Risoluzione temperatura1° C / 1,5° F
Risoluzione pressione1 hPa
Grafico di altitudine visualizzato nel riepilogo dell'attività fisica✔
FUNZIONI PER L'ALLENAMENTO
ALLENAMENTO A INTERVALLI
Configurazione intervalli✔
Indicazioni sugli intervalli durante l'allenamento✔
Intervalli strutturati✔
FREQUENZA CARDIACA
Frequenza cardiaca misurata al polso✔
Compatibilità fasce cardioFasce cardio Bluetooth
Intervallo RRcon Suunto Smart Sensor
Frequenza cardiaca in battiti al minuto✔
Registra la frequenza cardiaca durante il nuoto✔
Grafico frequenza cardiaca in tempo reale✔
Frequenza cardiaca media in tempo reale✔
Calorie✔
PTE (Picco effetto allenamento)✔
Zone di frequenza cardiaca personali✔
Livello di fitness (VO2 max)✔
Rilevamento della soglia anaerobica✔
Tempo di recupero✔
VELOCITÀ E DISTANZA
Distanza e velocità basate sulla cadenza✔
Velocità e distanza calcolata tramite GPS✔
Cronografo✔
Supporto per Foot PODBluetooth Foot Pods
Giri automatici✔
Giri manuali✔
Analisi dell'andatura, grafici della velocità e percorsi sulla mappa✔
RECUPERO DELL'ALLENAMENTO
Stato d'animo salvato sull'orologio dopo l'allenamento✔
Tempo di recupero in base all'allenamento✔
CARICO DI LAVORO
Registro con dettagli dell'allenamento✔
Carico di allenamento con totali per sport✔
Registro degli allenamenti per panoramiche a lungo termine✔
Riepilogo dell'allenamento con dettagli sui giri✔
CONDIVIDI E RIVIVI
Condivisione dell'allenamento sui social media✔
Valutazione e commenti sull'allenamento✔
Segui gli altri utenti e ottieni feedback tramite il flusso di attività✔
FUNZIONALITÀ SPORTIVE
NUOTO
Andatura e distanza nuoto in vasca✔
Distanza nuoto in acque libere✔
Tempo per vasca, giro (frazione), totale✔
Frequenza, numero e tipo bracciate✔
Efficienza nuotata (SWOLF)✔
Intervalli automatici✔
Tabella giri intervalli✔
BICICLETTA
Velocità bicicletta✔
Velocità media in tempo reale✔
Bike POD con supporto velocità/cadenzaBluetooth Bike Pods
Supporto misuratore Bike PowerBluetooth Power meters
Bike Power (potenza pedalata) (W), valore medio e max (con sensore potenza)Bluetooth Power meters
Giro e potenza max giro (con sensore potenza)✔
Tabella dei giri in tempo reale con frequenza cardiaca, potenza media e velocità media✔
Indicazioni sugli intervalli con potenza/velocità/frequenza cardiaca✔
CORSA
Andatura corsa✔
Suunto FusedSpeed™✔
Segui percorso✔
Potenza della corsa✔
SuuntoPlus™ Ghost runner✔
Calibrazione Foot PODautomatico
Tabella giri nell'orologio e nell'app Suunto✔
Andatura giro in tempo reale, max, media✔
Indicazioni sugli intervalli con andatura corsa/frequenza cardiaca/distanza✔
MULTISPORT
Cambia modalità sportiva durante l'allenamento✔
Modalità multisport preconfigurate✔
Analisi post-esercizio multisport per sport✔
Riepilogo esercizio multisport sull'orologio✔
MODALITÀ SPORTIVE
Modalità sportive e display personalizzabili✔
Display grafici nelle modalità sportive✔
Modalità sportive preinstallate sull'orologio> 90
SuuntoPlus™✔
FUNZIONI DI IMMERSIONE
APNEA
Profondimetro per snorkeling10 m
