Suunto Nautic S
An easy-to-use dive computer with interchangeable straps that fit your style. Made in Finland.
Choose Your Color
Designed for every dive
Suunto Nautic S is built for divers and freedivers who embrace every underwater moment. Compact yet powerful, it combines performance, style and reliability in a design that fits perfectly on your wrist - from first dives to advanced adventures.
With a bright AMOLED display, intuitive controls and trusted Suunto craftsmanship, Nautic S brings together the best of diving technology and everyday usability.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Compact design, made to endure
Reliability is everything underwater. Suunto Nautic S is engineered to perform in demanding conditions, dive after dive.
Its durable, pressure-resistant build and bright AMOLED display ensure clear visibility and confidence on each dive. The new elastic textile strap offers superior comfort and flexibility, adapting to every exposure suit and diving condition.
Whether you’re exploring reefs, practicing freediving, or preparing for your next adventure, Nautic S is designed to keep up wherever your dive takes you.
Power that lasts beyond the surface
When your adventure extends across multiple dives, endurance matters. Suunto Nautic S delivers up to 60 hours of dive time on a single charge - more than enough for a long dive weekend or a remote expedition.
Made for every dive and every diver
From your first open-water course to advanced adventures, Suunto Nautic S grows with you and your diving hobby.
It supports single- and multi-gas modes, sidemount configurations and customizable dive views letting you see exactly what you need, when you need it.
Easy to use yet powerful, Nautic S keeps you in control and lets you focus on what diving is truly about: freedom underwater.
Real-time awareness, wireless precision
Stay informed every moment. Wireless tank pressure support provides real-time gas readings directly on your wrist.
Dual transmitter support enables sidemount divers to follow both tanks with ease, while clear, color-coded visuals keep you instantly aware throughout the dive.
Awareness below and above the surface
Built-in GPS, offline maps, tide- and weather data with sunrise / sunset times help you prepare for your dives and transitions. Together with the digital compass, these tools keep you oriented in all conditions.
Smarter connection, deeper reflection
After each dive, Suunto app extends your experience. Sync your logs automatically, review detailed data, and relive every underwater route with notes, buddy info and conditions.
From dive planning to sharing your best moments, Nautic S keeps every adventure part of a bigger story: yours.
Explore more with the Suunto app
SPECIFICHE
Misure49.9 x 49.9 x 13.3 mm / 1.96 x 1.96 x 0.52 "
Peso81g
Materiale della lunettaStainless steel
Materiale del vetroSapphire crystal
Materiale della cassaGlass fibre reinforced polyamide
Materiale del cinturinoElastic textile
Paese di produzioneFI
Specyfikacja techniczna
OGÓLNE
Peso81g
Larghezza del cinturino22 mm
Quadranti personalizzabili✔
Blocco dello schermo tattile✔
Display touch✔
Display a colori✔
Avviso con vibrazione✔
Resistenza all’acqua100 m
Tipo di batteriarechargeable lithium-ion
Firmware aggiornabile✔
Ora, data✔
Sveglia✔
Doppio orario✔
Timer per il conto alla rovescia✔
Cronometro✔
LinguaCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
RetroilluminazioneAMOLED
Retroilluminazione configurabileautomatic brightness
Blocco dei pulsanti✔
Dimensione del display1,43''
Tipo di displaymatrix
Risoluzione del display466 x 466
Unità metriche e imperiali✔
Ora legale automatica✔
Indicatore della batteriapercentage / icon
Display sempre acceso✔
SPECIFICHE FISICHE
Temperatura operativa-20° C to +55° C / -5° F to +130° F
Operating temperature in dive mode0° C to +40° C / +32° F to +104° F
Temperatura di conservazione-20° C to +55° C / -5° F to +130° F
Temperatura batteria in carica:0° C to +35° C / +32° F to +95° F
DURATA DELLA BATTERIA
Promemoria carica intelligenti✔
Uso quotidiano: solo modalità standbyup to 26 days
Durata della batteria (immersione)40 - 60h
BUSSOLA
Bussola digitale✔
Bussola digitale durante l'immersione subacquea✔
Compensazione inclinazione✔
Correzione della declinazione✔
Scala direzione✔
Taratura✔
Precisione della bussola5°
Risoluzione della bussola1°
CONNETTIVITÀ
Connettività (tra dispositivi)Bluetooth
Suunto app compatibile✔
Le notifiche del telefono sull'orologio✔
Invio di risposte precompilate dall'orologio ai messaggi in arrivoAndroid only
Aggiornamenti del software dell'orologio dal cloud✔
Aggiornamenti software over-the-air automatici✔
Compatibilità con smartphoneMost common models supported, check here for detailed compatibility list
FUNZIONI ALL'APERTO
MONITORAGGIO E NAVIGAZIONE GPS
Mappe offline sull'orologio✔
Sistemi satellitariGPS, GLONASS, GALILEO, QZSS, BEIDOU
Supporto frequenza GNSSDual band (L1+L5)
Offline map storage size32 GB
Sistemi satellitari simultanei4
Satelliti max. collegati32
Frequenza registrazione GPSBest, Good, OK, Low
Livelli di zoom nella navigazione✔
Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale✔
Mappe terreni outdoor e satellitari✔
Mappe di calore globali per 20 sport✔
Pianificazione del percorso con mappe di calore✔
Libreria personale itinerari nel Web sincronizzata con l'orologio✔
Segui percorso✔
Navigazione punti di interesse (PDI)✔
Analisi percorsi GPS✔
Registrazione, visualizzazione e condivisione percorsi✔
ETA (ora di arrivo prevista)✔
METEO
Ora di alba e tramonto✔
Allarme temporale/tempesta✔
Pressione a livello del mare✔
Profilo alti/baro automatico✔
Temperatura✔
Intervallo visualizzazione temperatura-20° C to +55° C / -5° F to +130° F
Risoluzione temperatura1° C / 1.5° F
FUNZIONI PER L'ALLENAMENTO
FREQUENZA CARDIACA
Compatibilità fasce cardioBluetooth HR belts
FUNZIONALITÀ SPORTIVE
MODALITÀ SPORTIVE
Modalità sportive e display personalizzabiliCustomizable dive
Display grafici nelle modalità sportiveIn dive
Modalità sportive preinstallate sull'orologioDive modes
Adatto agli sportScubadive , Freedive, Snorkeling
FUNZIONI DI IMMERSIONE
BASICO
Impostazioni altitudine0 - 300 m / 300 -1500 m / 1500 - 3000 m
risalita tempo display✔
CNS/OTU (OLF) Calcoli✔
personalizzate Modalità di immersione display✔
modello di decompressioneSuunto Bühlmann 16 GF
decompressione profilo Opzionicontinuous and stepped
Cronologia delle immersionilifetime
tempo immersioni✔
allenament apnea✔
consumo di gas in tempo reale✔
Gas max pO₂manual 1.0 - 1.6
Cambio gas✔
tempo gas✔
gasup to 5 gases (Oxygen 21 - 100%)
Indicatore✔
Profondità operativa massima80m
Nitrox (e aria)✔
tempo di non volo✔
Pianificatore senza decompressione✔
Regolazione personaleGradient factors low (10-100) and high (50-100)
Soste di sicurezza✔
Intervallo di superficie✔
Timer✔
Integrazione dell'aria wireless✔
Deco planner✔
ALLARMI E NOTIFICHE IMMERSIONE
CNS/OTU (OLF) 80% / 100%✔
Violazione del limite di decompressione✔
Tempo di immersione✔
Tempo del gas✔
pO2 alto (iperossico)✔
Profondità massima✔
NDL (tempo di non decompressione)✔
Cambio gas (gas migliore disponibile)✔
Pressione della bombola✔
Risalita troppo veloce✔
APNEA
Allarme di profondità✔
Notifica di profondità✔
Allarme tempo di immersione✔
Storico giornaliero dell’apnea✔
Numero totale di apnee✔
Storico totale dell’apnea✔
Notifica del tempo in superficie✔
Depth meter for freedive80m
