Venduto
1 / 5
Suunto Nautic Elastic Textile Strap
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS051303000
Suunto Nautic
Prezzo di vendita€725
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Coming in December
Quantità
30-Days Return
Global Support
€725
Venduto
Bright AMOLED display, integrated
LED flashlight
Up to 120 hours on a single charge
Wireless tank
pressure
Multi-gas and sidemount support
GPS and underwater route tracking
Suunto App
connectivity
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Rugged leak-proof construction
Glove-friendly
buttons
Designed and tested
in Finland
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Rechargeable battery.
single charge
Reliable power for
multi-day diving trips
Designed for endurance
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Multi-gas and
sidemount support
Customizable dive
views
Full decompression
planning
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Wireless tank
pressure readings
Dual transmitter
support for
sidemount diving
Color-coded visuals
for instant clarity
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Offline maps and GPS help plan and track your routes, while the built-in digital compass provides precise direction underwater. Tide, weather, and sunrise/sunset data support safe surface intervals and the integrated flashlight brings visibility and convenience when light is scarce. Nautic keeps you aware and in control, both underwater and on the surface.
GPS and offline maps
Digital compass for underwater
navigation
LED flashlight, tide, and weather support
for safety
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Automatic dive log
sync
Route and condition tracking
Share and relive
every dive
Explore more with the Suunto app
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Access additional benefits and services from our 200+ partners.
Learn more
SPECIFICHE
  • Misure
    101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
  • Peso
    227g (with bungee strap) , 232g (with elastic textile strap)
  • Materiale della lunetta
    Fiber reinforced polymer
  • Materiale del vetro
    Panda glass (PANDA-MN228 high alumina silicon glass)
  • Materiale della cassa
  • Materiale del cinturino
    Bungee cord / Elastic textile
  • Paese di produzione
    FI
Specyfikacja techniczna
OGÓLNE
  • Peso
  • Display a colori
  • Avviso con vibrazione
  • Resistenza all’acqua
    200 m
  • Tipo di batteria
    rechargeable lithium-ion
  • Firmware aggiornabile
  • Ora, data
  • Cronometro
  • Lingua
  • Retroilluminazione
    AMOLED
  • Retroilluminazione configurabile
    automatic brightness
  • Blocco dei pulsanti
  • Dimensione del display
    3,26"
  • Tipo di display
    matrix
  • Risoluzione del display
    720x382
  • Unità metriche e imperiali
  • Ora legale automatica
  • Indicatore della batteria
    percentage / icon
  • Display sempre acceso
SPECIFICHE FISICHE
  • Temperatura operativa
  • Operating temperature in dive mode
  • Temperatura di conservazione
  • Temperatura batteria in carica:
DURATA DELLA BATTERIA
  • Promemoria carica intelligenti
  • Durata della batteria (immersione)
    80-190h
BUSSOLA
  • Bussola digitale
  • Bussola digitale durante l'immersione subacquea
  • Compensazione inclinazione
  • Correzione della declinazione
  • Scala direzione
  • Taratura
  • Precisione della bussola
  • Risoluzione della bussola
CONNETTIVITÀ
  • Connettività (tra dispositivi)
    Bluetooth
  • Suunto app compatibile
  • Aggiornamenti del software dell'orologio dal cloud
  • Aggiornamenti software over-the-air automatici
  • Compatibilità con smartphone
    Most common models supported, check here for detailed compatibility list
FUNZIONI ALL'APERTO
MONITORAGGIO E NAVIGAZIONE GPS
  • Mappe offline sull'orologio
  • Sistemi satellitari
  • Supporto frequenza GNSS
    Dual band (L1+L5)
  • Offline map storage size
    32 GB
  • Sistemi satellitari simultanei
    4
  • Satelliti max. collegati
    32
  • Frequenza registrazione GPS
    Best, Good, OK, Low
  • Livelli di zoom nella navigazione
  • Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale
  • Mappe terreni outdoor e satellitari
  • Mappe di calore globali per 20 sport
  • Navigazione punti di interesse (PDI)
  • Analisi percorsi GPS
  • Registrazione, visualizzazione e condivisione percorsi
METEO
  • Ora di alba e tramonto
  • Temperatura
  • Intervallo visualizzazione temperatura
  • Risoluzione temperatura
    1° C / 1.5° F
FUNZIONI PER L'ALLENAMENTO
FREQUENZA CARDIACA
  • Compatibilità fasce cardio
    Bluetooth HR belts
FUNZIONALITÀ SPORTIVE
MODALITÀ SPORTIVE
  • Modalità sportive e display personalizzabili
    Customizable dive
  • Display grafici nelle modalità sportive
    In dive
  • Modalità sportive preinstallate sull'orologio
    Dive modes
  • Adatto agli sport
    Scubadive
FUNZIONI DI IMMERSIONE
BASICO
  • Impostazioni altitudine
  • risalita tempo display
  • CNS/OTU (OLF) Calcoli
  • personalizzate Modalità di immersione display
  • modello di decompressione
    Suunto Bühlmann 16 GF
  • decompressione profilo Opzioni
    continuous and stepped
  • Cronologia delle immersioni
    lifetime
  • tempo immersioni
  • consumo di gas in tempo reale
  • Gas max pO₂
    manual 1.0 - 1.6
  • Cambio gas
  • tempo gas
  • gas
    up to 5 gases (Oxygen 21 - 100%)
  • Indicatore
  • Profondità operativa massima
    200m
  • Nitrox (e aria)
  • tempo di non volo
  • Pianificatore senza decompressione
  • Regolazione personale
    Gradient factors low (10-100) and high (50-100)
  • Soste di sicurezza
  • Intervallo di superficie
  • Timer
  • Integrazione dell'aria wireless
  • Integrazione del gas wireless
  • Deco planner
  • Helium
ALLARMI E NOTIFICHE IMMERSIONE
  • CNS/OTU (OLF) 80% / 100%
  • Violazione del limite di decompressione
  • Tempo di immersione
  • Tempo del gas
  • pO2 alto (iperossico)
  • pO2 basso (ipossico)
  • Profondità massima
  • NDL (tempo di non decompressione)
  • Cambio gas (gas migliore disponibile)
  • Pressione della bombola
  • Risalita troppo veloce
APNEA
  • Allarme di profondità
  • Allarme tempo di immersione
Recommended products
Support for Suunto Nautic
