Suunto Vertical 2
Canyon
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
SPÉCIFICATIONS
Mesures48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
Poids87g
Matériau de la lunetteStainless steel
Matériau du verreSapphire crystal
Matériau du boîtierGlass fibre reinforced polyamide
Matériau du braceletSilicone
Pays de fabricationCN
TECHNICAL SPECIFICATIONS
GÉNÉRAL
Poids87g
Tailles de poignet125 à 175 mm
Largeur du bracelet22 mm
Fréquence cardiaque au poignet intégrée✔
Cadrans personnalisables✔
Verrouillage de l’écran tactile✔
Écran tactile✔
Écran couleur✔
Alerte par vibration✔
Résistance à l’eau100 m
Type de batteriebatterie lithium-ion rechargeable
Mise à jour du firmware✔
Heure, date✔
Réveil✔
Double fuseau horaire✔
Horodatage automatique✔
Minuteur✔
Chronomètre✔
LangueCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
RétroéclairageLTPO AMOLED
Rétroéclairage configurableluminosité automatique
Verrouillage des boutonspendant l'exercice
Taille de l’écran1,5 po
Type d’écranmatrice
Résolution de l’écran466 x 466
Unités métriques et impériales✔
Heure d’été automatique✔
Indicateur de batteriepourcentage / icône
Oxygène sanguin✔
Affichage permanent✔
CARACTÉRISTIQUES PHYSIQUES
Température de fonctionnement-20 à +55 °C/-5 à +130 °F
Température de stockage-20 à +55 °C/-5 à +130 °F
Température de mise en charge recommandée0 °C à +45 °C / +32 °F à +110 °F
AUTONOMIE
Rappels de charge intelligents✔
Utilisation quotidienne : mode montre connectéejusqu’à 20 jours
Utilisation quotidienne : Mode veille uniquementjusqu'à 40 jours
Entraînement : Mode GNSS tous systèmes + Multi-Band(jusqu’à 65 h (AOD 60 h)
Entraînement : Mode GNSS tous systèmes + Single-Band75 h maximum (AOD 70 h)
Entraînement : Promesses de batterie pour tous les modes65 h / 75 h / 110 h / 250 h
Entraînement : modes GNSS d'économie d'énergiejusqu'à 250 h
BOUSSOLE
Boussole numérique✔
Compensation de l'inclinaison✔
Correction de déclinaison✔
Échelle de directiondegrés / millièmes
Aiguilleindicateur du nord
Précision de la boussole5°
Résolution de la boussole1°
CONNECTIVITÉ
Connectivité (entre appareils)Bluetooth
Compatible avec l'application Suunto✔
Affichage des notifications du téléphone sur la montre✔
Contrôle des médias depuis la montre✔
Envoi de réponses prédéfinies aux messages entrants depuis la montreAndroid seulement
Compatible avec les différentes communautés sportives en ligneStrava, TrainingPeaks et plus encore
Mises à jour logicielles de la montre depuis le cloud✔
Mises à jour logicielles sans fil automatiques✔
Compatibilité avec les smartphonesLa plupart des modèles les plus courants sont pris en charge, consultez la liste détaillée de compatibilité ici.
24/7
SUIVI D'ACTIVITÉ
Compteur de pas✔
Calories brûlées✔
Objectifs d'activité physiquepas, calories
Historique des activités✔
TCalories dépensées et fréquence cardiaque au cours des activités quotidiennes✔
Suivi de la fréquence cardiaque journalière minimale✔
SUIVI DU SOMMEIL
Durée du sommeil✔
Heures de coucher✔
Temps éveillé✔
Sommeil profond✔
Fréquence cardiaque moyenne et minimum pendant le sommeil✔
Sommeil léger✔
REM✔
VFC du sommeil✔
Qualité du sommeil✔
STRESS ET RÉCUPÉRATION
Niveau des ressources journalières✔
État de stress et récupération✔
Mesure de la VFC✔
SUIVI GPS & NAVIGATION
Cartes hors ligne sur la montre✔
Systèmes par satelliteGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDouble bande (L1 + L5)
Systèmes satellites simultanés4
Nombre maximum de satellites connectés32
Modes batterie intelligentsPerformance, Endurance, Ultra, Tour, Personnalisé
Fréquence d'enregistrement GPSMeilleure, Bonne, OK, Faible
Navigation par points de passage et itinéraire visuel✔
Niveaux de zoom dans la navigation✔
Zoom auto basé sur la forme de l'itinéraire✔
Création de trace en temps réel (« Petit Poucet »)✔
Planification d'itinéraire avec profil d'altitude✔
Cartes topographiques et cartes satellite✔
Cartes de fréquentation du monde entier pour 20 sports✔
Planification d'itinéraire avec les cartes de chaleur✔
Bibliothèque personnelle d'itinéraires sur le Web synchronisée avec la montre✔
Passer à l'itinéraire✔
Navigation vers un point d'intérêt (POI)✔
Analyse de trace GPS✔
Enregistrement, visualisation et partage des itinéraires✔
HAE (heure d'arrivée estimée)✔
ALTIMÈTRE
Altitude barométrique✔
Altitude GPS✔
Altitude GPS et barométrique combinée (FusedAlti™)✔
Altitude en mode quotidien✔
Acclimatation à l'altitude avec l'oxygène sanguin✔
Totaux des ascensions/descentes✔
Vitesse verticale✔
Profil altimètre/baromètre automatique✔
Fréquence d'enregistrement du journal1 s
Résolution0,01 atm - 10 atm
Portée-500 - 9 999 m
MÉTÉO
Heures de lever/coucher du soleil✔
Alarme d'orage✔
Pression au niveau de la mer✔
Température✔
Plage d'affichage de température-20 à +55 °C/-5 à +130 °F
Résolution de température1 °C / 1,5 °F
Résolution de pression1 hPa
Graphique d'altitude affiché dans le récapitulatif des exercices✔
ENTRAÎNEMENT FRACTIONNÉ
Configuration d'intervalles✔
Assistance pour l'entraînement fractionné pendant la séance✔
Intervalles structurés✔
FRÉQUENCE CARDIAQUE
Fréquence cardiaque mesurée à partir du poignet✔
Compatibilité ceinture de fréquence cardiaqueCeintures de FC Bluetooth
Intervalle RRavec le Suunto Smart Sensor
Fréquence cardiaque en battements par minute✔
Enregistre la fréquence cardiaque pendant la natation✔
Graphique de fréquence cardiaque en temps réel✔
Fréquence cardiaque moyenne en temps réel✔
Calories✔
Pic d'effet d'entraînement✔
Zones de fréquence cardiaque personnelles✔
Niveau de forme (VO2max)✔
Détection du seuil de lactate✔
Temps de récupération✔
VITESSE ET DISTANCE
Vitesse et distance basées sur la cadence✔
Vitesse et distance GPS✔
Chrono✔
Compatible avec le capteur de fouléeBluetooth Foot Pods
Tours automatiques✔
Tours manuels✔
Analyse de l'allure, graphiques de vitesse et traces sur la carte✔
RÉCUPÉRATION DE L'ENTRAÎNEMENT
Sentiment enregistré après l'entraînement sur la montre✔
Temps de récupération selon l'entraînement✔
CHARGE D'ENTRAÎNEMENT
Journal avec détails des exercices✔
Charge d'entraînement avec totaux par sport✔
Journal d'entraînement pour les vues d'ensemble sur le long terme✔
Récapitulatif des exercices avec détails des tours✔
PARTAGER ET REVIVREZ
Partage de l'exercice sur les réseaux sociaux✔
Évaluation et commentaire des exercices✔
Suivez les autres membres et recevez des avis via le flux des activités✔
L'EXPERTISE DU SPORT
NATATION
Rythme de nage en bassin et distance✔
Distance de nage en eau libre✔
Temps de nage par longueur de bassin, tours, total✔
Cadence et type de nage et nombre de mouvements✔
Efficacité des mouvements (SWOLF)✔
Intervalles automatiques✔
Tableau de tours en fractionné✔
CYCLISME
Vitesse cycliste✔
Vitesse moyenne en temps réel✔
Bike POD avec prise en charge de la vitesse et de la cadenceCapteur Bike Pods Bluetooth
Prise en charge des appareils de mesure de puissance cyclisteCapteurs de puissance Bluetooth
Puissance cycliste (W), moyenne et maximum (avec capteur de puissance)Capteurs de puissance Bluetooth
Tours en vélo et puissance maximum par tour (avec capteur de puissance)✔
Tableau de tours en temps réel avec FC moyenne, puissance moyenne et vitesse moyenne✔
Assistance pour l'entraînement fractionné avec puissance/vitesse/fréquence cardiaque✔
COURSE
Rythme de course✔
Suunto FusedSpeed™✔
Puissance de course à pied✔
SuuntoPlus™ Ghost runner✔
Étalonnage de capteur de fouléeautomatique
Tableau des tours dans la montre et l'appli Suunto✔
Cadence moyenne, maxi., au tour en temps réel✔
Assistance pour l'entraînement fractionné avec allure de course/fréquence cardiaque/distance✔
MULTISPORTS
Changer de mode sportif pendant l'exercice✔
Modes multisports préconfigurés✔
Analyse post-exercice multisport par sport✔
Résumé de l'exercice multisport sur la montre✔
MODES SPORTIFS
Modes sportifs et affichages personnalisables✔
Affichages graphiques dans les modes sportifs✔
Modes sportifs préinstallés sur la montre> 90
SuuntoPlus™✔
FONCTIONS DE PLONGÉE
APNÉE
Profondimètre pour le snorkeling10 m
