1 / 8
Suunto Vertical 2 Pine Green
1/8
Photos
Video
Money-back guarantee
30-Days Return
Global Support
SKU : SS051207000
Suunto Vertical 2
Pine Green
Prix de vente€572,75
Ultimate adventure watch for outdoor expeditions and training — improved
  • Bright 1.5'' AMOLED display
  • Up to 65 hours battery
  • 115+ sport modes
  • Integrated LED flashlight
  • Improved heart rate tracking
Choose Your Color
Quantité
30-Days Return
Global Support
€572,75
Ajouter au panier
Bright 1.5” AMOLED display
115+ sport modes
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Rugged design in titanium or steel
Secure fit silicone straps
Designed and tested in Finland
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
115+ sport modes
Training Zone with AI Coach
Workout planning
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
Route planning with heatmaps
Climb Guidance planning tool
Dual-band GPS system
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
300+ partner apps
Growing app ecosystem
Faster hardware, more memory
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Learn more
SPÉCIFICATIONS
  • Mesures
    48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
  • Poids
    87g
  • Matériau de la lunette
    Stainless steel
  • Matériau du verre
    Sapphire crystal
  • Matériau du boîtier
  • Matériau du bracelet
    Silicone
  • Pays de fabrication
    CN
TECHNICAL SPECIFICATIONS
GÉNÉRAL
    Stainless steel
  • Matériau du verre
    Sapphire crystal
    Silicone
  • Poids
    87g
  • Tailles de poignet
    125 à 175 mm
  • Largeur du bracelet
    22 mm
  • Fréquence cardiaque au poignet intégrée
  • Cadrans personnalisables
  • Verrouillage de l’écran tactile
  • Écran tactile
  • Écran couleur
  • Alerte par vibration
  • Résistance à l’eau
    100 m
  • Type de batterie
    batterie lithium-ion rechargeable
  • Mise à jour du firmware
  • Heure, date
  • Réveil
  • Double fuseau horaire
  • Horodatage automatique
  • Minuteur
  • Chronomètre
  • Langue
  • Rétroéclairage
    LTPO AMOLED
  • Rétroéclairage configurable
    luminosité automatique
  • Verrouillage des boutons
    pendant l'exercice
  • Taille de l’écran
    1,5 po
  • Type d’écran
    matrice
  • Résolution de l’écran
    466 x 466
  • Heure d’été automatique
  • Indicateur de batterie
    pourcentage / icône
  • Oxygène sanguin
  • Affichage permanent
CARACTÉRISTIQUES PHYSIQUES
    -20 à +55 °C/-5 à +130 °F
  • Température de stockage
  • Température de mise en charge recommandée
    0 °C à +45 °C / +32 °F à +110 °F
AUTONOMIE
  • Rappels de charge intelligents
  • Utilisation quotidienne : mode montre connectée
    jusqu’à 20 jours
  • Utilisation quotidienne : Mode veille uniquement
    jusqu'à 40 jours
  • Entraînement : Mode GNSS tous systèmes + Multi-Band
    (jusqu’à 65 h (AOD 60 h)
  • Entraînement : Mode GNSS tous systèmes + Single-Band
    75 h maximum (AOD 70 h)
  • Entraînement : Promesses de batterie pour tous les modes
    65 h / 75 h / 110 h / 250 h
  • Entraînement : modes GNSS d'économie d'énergie
    jusqu'à 250 h
BOUSSOLE
  • Boussole numérique
  • Correction de déclinaison
  • Échelle de direction
    degrés / millièmes
  • Aiguille
    indicateur du nord
  • Précision de la boussole
  • Résolution de la boussole
CONNECTIVITÉ
    Bluetooth
  • Compatible avec l'application Suunto
  • Affichage des notifications du téléphone sur la montre
  • Contrôle des médias depuis la montre
  • Envoi de réponses prédéfinies aux messages entrants depuis la montre
    Android seulement
  • Compatible avec les différentes communautés sportives en ligne
    Strava, TrainingPeaks et plus encore
  • Mises à jour logicielles de la montre depuis le cloud
  • Mises à jour logicielles sans fil automatiques
  • Compatibilité avec les smartphones
    La plupart des modèles les plus courants sont pris en charge, consultez la liste détaillée de compatibilité ici.
24/7
SUIVI D'ACTIVITÉ
  • Compteur de pas
  • Calories brûlées
  • Objectifs d'activité physique
    pas, calories
  • Historique des activités
  • TCalories dépensées et fréquence cardiaque au cours des activités quotidiennes
  • Suivi de la fréquence cardiaque journalière minimale
SUIVI DU SOMMEIL
  • Durée du sommeil
  • Heures de coucher
  • Temps éveillé
  • Sommeil profond
  • Fréquence cardiaque moyenne et minimum pendant le sommeil
  • Sommeil léger
  • REM
  • VFC du sommeil
  • Qualité du sommeil
STRESS ET RÉCUPÉRATION
  • Niveau des ressources journalières
  • État de stress et récupération
  • Mesure de la VFC
SUIVI GPS & NAVIGATION
  • Cartes hors ligne sur la montre
  • Systèmes par satellite
  • GNSS frequency support
    Double bande (L1 + L5)
  • Systèmes satellites simultanés
    4
  • Nombre maximum de satellites connectés
    32
  • Modes batterie intelligents
    Performance, Endurance, Ultra, Tour, Personnalisé
  • Fréquence d'enregistrement GPS
    Meilleure, Bonne, OK, Faible
  • Navigation par points de passage et itinéraire visuel
  • Niveaux de zoom dans la navigation
  • Zoom auto basé sur la forme de l'itinéraire
  • Création de trace en temps réel (« Petit Poucet »)
  • Planification d'itinéraire avec profil d'altitude
  • Cartes topographiques et cartes satellite
  • Cartes de fréquentation du monde entier pour 20 sports
  • Planification d'itinéraire avec les cartes de chaleur
  • Bibliothèque personnelle d'itinéraires sur le Web synchronisée avec la montre
  • Passer à l'itinéraire
  • Navigation vers un point d'intérêt (POI)
  • Analyse de trace GPS
  • Enregistrement, visualisation et partage des itinéraires
  • HAE (heure d'arrivée estimée)
ALTIMÈTRE
  • Altitude barométrique
  • Altitude GPS
  • Altitude GPS et barométrique combinée (FusedAlti™)
  • Altitude en mode quotidien
  • Acclimatation à l'altitude avec l'oxygène sanguin
  • Totaux des ascensions/descentes
  • Vitesse verticale
  • Profil altimètre/baromètre automatique
  • Fréquence d'enregistrement du journal
    1 s
  • Résolution
    0,01 atm - 10 atm
  • Portée
    -500 - 9 999 m
MÉTÉO
  • Heures de lever/coucher du soleil
  • Alarme d'orage
  • Pression au niveau de la mer
  • Température
  • Résolution de température
    1 °C / 1,5 °F
  • Résolution de pression
    1 hPa
  • Graphique d'altitude affiché dans le récapitulatif des exercices
ENTRAÎNEMENT FRACTIONNÉ
  • Configuration d'intervalles
  • Assistance pour l'entraînement fractionné pendant la séance
  • Intervalles structurés
FRÉQUENCE CARDIAQUE
  • Fréquence cardiaque mesurée à partir du poignet
  • Compatibilité ceinture de fréquence cardiaque
    Ceintures de FC Bluetooth
  • Intervalle RR
    avec le Suunto Smart Sensor
  • Fréquence cardiaque en battements par minute
  • Enregistre la fréquence cardiaque pendant la natation
  • Graphique de fréquence cardiaque en temps réel
  • Fréquence cardiaque moyenne en temps réel
  • Calories
  • Pic d'effet d'entraînement
  • Zones de fréquence cardiaque personnelles
  • Niveau de forme (VO2max)
  • Détection du seuil de lactate
  • Temps de récupération
VITESSE ET DISTANCE
  • Vitesse et distance basées sur la cadence
  • Vitesse et distance GPS
  • Chrono
  • Compatible avec le capteur de foulée
    Bluetooth Foot Pods
  • Tours automatiques
  • Tours manuels
  • Analyse de l'allure, graphiques de vitesse et traces sur la carte
RÉCUPÉRATION DE L'ENTRAÎNEMENT
  • Sentiment enregistré après l'entraînement sur la montre
  • Temps de récupération selon l'entraînement
CHARGE D'ENTRAÎNEMENT
  • Journal avec détails des exercices
  • Charge d'entraînement avec totaux par sport
  • Journal d'entraînement pour les vues d'ensemble sur le long terme
  • Récapitulatif des exercices avec détails des tours
PARTAGER ET REVIVREZ
  • Partage de l'exercice sur les réseaux sociaux
  • Évaluation et commentaire des exercices
  • Suivez les autres membres et recevez des avis via le flux des activités
L'EXPERTISE DU SPORT
NATATION
  • Rythme de nage en bassin et distance
  • Distance de nage en eau libre
  • Temps de nage par longueur de bassin, tours, total
  • Cadence et type de nage et nombre de mouvements
  • Efficacité des mouvements (SWOLF)
  • Intervalles automatiques
  • Tableau de tours en fractionné
CYCLISME
  • Vitesse cycliste
  • Vitesse moyenne en temps réel
  • Bike POD avec prise en charge de la vitesse et de la cadence
    Capteur Bike Pods Bluetooth
  • Prise en charge des appareils de mesure de puissance cycliste
    Capteurs de puissance Bluetooth
  • Puissance cycliste (W), moyenne et maximum (avec capteur de puissance)
  • Tours en vélo et puissance maximum par tour (avec capteur de puissance)
  • Tableau de tours en temps réel avec FC moyenne, puissance moyenne et vitesse moyenne
  • Assistance pour l'entraînement fractionné avec puissance/vitesse/fréquence cardiaque
COURSE
  • Rythme de course
  • Suunto FusedSpeed™
  • Puissance de course à pied
  • SuuntoPlus™ Ghost runner
  • Étalonnage de capteur de foulée
    automatique
  • Tableau des tours dans la montre et l'appli Suunto
  • Cadence moyenne, maxi., au tour en temps réel
  • Assistance pour l'entraînement fractionné avec allure de course/fréquence cardiaque/distance
MULTISPORTS
  • Changer de mode sportif pendant l'exercice
  • Modes multisports préconfigurés
  • Analyse post-exercice multisport par sport
  • Résumé de l'exercice multisport sur la montre
MODES SPORTIFS
  • Modes sportifs et affichages personnalisables
  • Affichages graphiques dans les modes sportifs
  • Modes sportifs préinstallés sur la montre
    > 90
  • SuuntoPlus™
FONCTIONS DE PLONGÉE
APNÉE
  • Profondimètre pour le snorkeling
    10 m
Recommended Products
SUPPORT FOR SUUNTO VERTICAL 2
