Suunto Nautic
Elastic Textile Strap
Next-generation dive computer for divers who value every moment underwater
Choose your Color
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Explore more with the Suunto app
SPÉCIFICATIONS
Mesures101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
Poids227g (with bungee strap) , 232g (with elastic textile strap)
Matériau de la lunetteFiber reinforced polymer
Matériau du verrePanda glass (PANDA-MN228 high alumina silicon glass)
Matériau du boîtierGlass fibre reinforced polyamide
Matériau du braceletBungee cord / Elastic textile
Pays de fabricationFI
TECHNICAL SPECIFICATIONS
GÉNÉRAL
Écran couleur✔
Alerte par vibration✔
Résistance à l’eau200 m
Type de batterierechargeable lithium-ion
Mise à jour du firmware✔
Heure, date✔
Chronomètre✔
LangueCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
RétroéclairageAMOLED
Rétroéclairage configurableautomatic brightness
Verrouillage des boutons✔
Taille de l’écran3,26"
Type d’écranmatrix
Résolution de l’écran720x382
Unités métriques et impériales✔
Heure d’été automatique✔
Indicateur de batteriepercentage / icon
Affichage permanent✔
CARACTÉRISTIQUES PHYSIQUES
Température de fonctionnement-20° C to +55° C / -5° F to +130° F
Operating temperature in dive mode0° C to +40° C / +32° F to +104° F
Température de stockage-20° C to +55° C / -5° F to +130° F
Température de mise en charge recommandée0° C to +35° C / +32° F to +95° F
AUTONOMIE
Rappels de charge intelligents✔
Autonomie de la batterie (plongée)80-190h
BOUSSOLE
Boussole numérique✔
Boussole numérique en plongée sous-marine✔
Compensation de l'inclinaison✔
Correction de déclinaison✔
Échelle de direction✔
Aiguille✔
Précision de la boussole5°
Résolution de la boussole1°
CONNECTIVITÉ
Connectivité (entre appareils)Bluetooth
Compatible avec l'application Suunto✔
Mises à jour logicielles de la montre depuis le cloud✔
Mises à jour logicielles sans fil automatiques✔
Compatibilité avec les smartphonesMost common models supported, check here for detailed compatibility list
SUIVI GPS & NAVIGATION
Cartes hors ligne sur la montre✔
Systèmes par satelliteGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Offline map storage size32 GB
Systèmes satellites simultanés4
Nombre maximum de satellites connectés32
Fréquence d'enregistrement GPSBest, Good, OK, Low
Niveaux de zoom dans la navigation✔
Création de trace en temps réel (« Petit Poucet »)✔
Cartes topographiques et cartes satellite✔
Cartes de fréquentation du monde entier pour 20 sports✔
Navigation vers un point d'intérêt (POI)✔
Analyse de trace GPS✔
Enregistrement, visualisation et partage des itinéraires✔
MÉTÉO
Heures de lever/coucher du soleil✔
Température✔
Plage d'affichage de température-20° C to +55° C / -5° F to +130° F
Résolution de température1° C / 1.5° F
FRÉQUENCE CARDIAQUE
Compatibilité ceinture de fréquence cardiaqueBluetooth HR belts
L'EXPERTISE DU SPORT
MODES SPORTIFS
Modes sportifs et affichages personnalisablesCustomizable dive
Affichages graphiques dans les modes sportifsIn dive
Modes sportifs préinstallés sur la montreDive modes
Convient aux sportsScubadive
FONCTIONS DE PLONGÉE
BASIQUE
Ajustement l'altitude0 - 300 m / 300 -1500 m / 1500 - 3000 m
remontée temps écran.✔
CNS/OTU (OLF) Calculs✔
personnalisés Modes de plongée écran.✔
modèle de décompressionSuunto Bühlmann 16 GF
décompression profil Optionscontinuous and stepped
Historique de plongéelifetime
temps de plongée✔
La consommation de gaz en temps✔
Gaz max pO₂manual 1.0 - 1.6
Changement de gaz✔
temps de gaz✔
Gazup to 5 gases (Oxygen 21 - 100%)
Jauge✔
Profondeur maximale de fonctionnement200m
Nitrox (et air)✔
Temps d'interdiction de vol✔
Planificateur sans décompression✔
Ajustement personnelGradient factors low (10-100) and high (50-100)
Paliers de sécurité✔
Temps de surface✔
Minuteur✔
Intégration de l'air sans fil✔
Intégration du gaz sans fil✔
Deco planner✔
Helium✔
CNS/OTU (OLF) 80% / 100%✔
Violation du plafond de décompression✔
Temps de plongée✔
Temps de gaz✔
pO2 élevé (hyperoxique)✔
pO2 bas (hypoxique)✔
Profondeur maximale✔
NDL (temps de non-décompression)✔
Changement de gaz (gaz optimal disponible)✔
Pression du réservoir✔
Ascension trop rapide✔
APNÉE
Alarme de profondeur✔
Alarme de temps de plongée✔
