Suunto Vertical 2
Arctic Gray
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
TEKNISET TIEDOT
Mitat48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
Paino87g
Kehän materiaali:Stainless steel
Lasin materiaali:Sapphire crystal
Rungon materiaali:Glass fibre reinforced polyamide
Rannekkeen materiaali:Silicone
ValmistusmaaCN
TEKNISET TIEDOT
YLEISET
Kehän materiaaliStainless steel
Lasin materiaaliSapphire crystal
Rungon materiaaliGlass fibre reinforced polyamide
Rannekkeen materiaaliSilicone
Paino87g
Rannekoot125-175 mm
Rannekkeen leveys22 mm
Integroitu rannesykemittaus✔
Mukautettavat kellotaulut✔
Kosketusnäyttölukko✔
Kosketusnäyttö✔
Värinäyttö✔
Värinähälytys✔
Vedenkestävyys100 m
Pariston/akun tyyppirechargeable lithium-ion
Laitteisto päivitettävissä✔
Kello, pvm✔
Herätyskello✔
Kahden kellonajan näyttö✔
Automaattinen ajanotto✔
Lähtölaskenta✔
Ajanottokello✔
KieletCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
TaustavaloLTPO AMOLED
Säädettävä taustavaloautomatic brightness
Näppäinlukkoduring exercise
Näyttökoko1,5"
Näyttötyyppimatrix
Näytön resoluutio466 x 466
Mittayksiköt: metrijärj./brittil.✔
Automaattinen kesäaika✔
Pariston/akun lataustasopercentage / icon
Veren happitaso✔
Aina päällä oleva näyttö✔
FYYSISET OMINAISUUDET
Käyttölämpötila-20° C to +55° C / -5° F to +130° F
Säilytyslämpötila-20° C to +55° C / -5° F to +130° F
Suositeltu latauslämpötila0° C to +45° C / +32° F to +110° F
AKUN KESTO
Älykkäät latausmuistutukset✔
Päivittäinen käyttö: älykellotilaup to 20 days
Päivittäinen käyttö: vain valmiustilaup to 40 days
Harjoittelu: kaikkien järjestelmien GNSS-tila + Multi-Bandup to 65h (AOD 60h)
Harjoittelu: kaikkien järjestelmien GNSS-tila + Single-Bandup to 75h (AOD 70h)
Harjoittelu: kaikkien akkutilojen kestot65h / 75h / 110h / 250h
Harjoittelu: virtaa säästävät GNSS-tilatup to 250h
KOMPASSI
Digitaalinen kompassi✔
Kallistuskompensointi✔
Erannonkorjaus✔
Suuntima-asteikkodegrees / mils
Neulanorth indicator
Kompassin tarkkuus5°
Kompassin erottelukyky1°
LIITETTÄVYYS
Liitettävyys (laitteiden välillä)Bluetooth
Suunto appin kanssa yhteensopiva✔
Puhelinilmoitukset kellossa✔
Mediaohjaimet kellossa✔
Lähetä kellosta ennalta määritettyjä vastauksia saapuviin viesteihinAndroid only
Yhteensopiva urheiluverkkoyhteisöjen kanssaStrava, TrainingPeaks and more
Kellon ohjelmistopäivitykset pilvestä✔
Automaattiset langattomat ohjelmistopäivitykset✔
Yhteensopivuus älypuhelinten kanssaMost common models supported, check here for detailed compatibility list
24/7
AKTIIVISUUSSEURANTA
Askellaskuri✔
Kalorinkulutus✔
Liikuntatavoitteetsteps, calories
Aktiivisuushistoria✔
Kalorien kulutus ja syke päivittäisen liikunnan aikana✔
Päivittäisen vähimmäissykkeen seuranta✔
UNISEURANTA
Unenkesto✔
Nukkumaanmenoajat✔
Aika hereillä✔
Syvä uni✔
Keski- ja minimisyke unen aikana✔
Kevyt uni✔
REM✔
Sykevälivaihtelu (HRV) unen aikana✔
Unen laatu✔
RASITUS JA PALAUTUMINEN
Päivittäinen resurssitaso✔
Rasitus- ja palautumistila✔
Sykevälivaihtelun (HRV) mittaus✔
OUTDOOR-TOIMINNOT
GPS-SEURANTA JA -NAVIGOINTI
Offline-kartat kellossa✔
SatelliittijärjestelmätGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS-taajuustukiDual band (L1+L5)
Samanaikaiset satelliittijärjestelmät4
Satelliittiyhteyksien enimmäismäärä32
Älykkäät akkutilatPerformance, Endurance, Ultra, Tour, Custom
GPS-tallennusväliBest, Good, OK, Low
Reittipiste- ja reittinavigointi✔
Navigoinnin tarkennustasot✔
Reitin muotoon perustuva automaattitarkennus✔
Reaaliaikainen paluureitti✔
Reitinsuunnittelu korkeusprofiililla✔
Maasto- ja satelliittikartat✔
20 urheilulajin maailmanlaajuiset lämpökartat✔
Reitin suunnittelu lämpökartoilla✔
Henkilökohtainen kelloon synkronoituva reittikirjasto✔
Kiinnity reittiin✔
KPOI-navigointi✔
GPS-reittianalyysi✔
Reittien tallennus, katselu ja jakaminen✔
ASA (arvioitu saapumisaika)✔
KORKEUS
Barometrinen korkeus✔
GPS-korkeus✔
Yhdistetty GPS- ja barometrinen korkeus (FusedAlti™)✔
Korkeus päivittäistilassa✔
Korkeuteen sopeutumisen seuranta happisaturaatioarvon avulla✔
Kokonaisnousu-/lasku✔
Nousunopeus✔
Automaattinen korkeus/ilmanpaine-profiili✔
Lokin tallennusväli1 s
Resoluutio1 m
Näyttöalue-500 - 9999 m
SÄÄ
Auringonnousu-/laskuajat✔
Myrskyvaroitus✔
Ilmanpaine merenpinnan tasolla✔
Lämpömittari✔
Lämpötilan näyttöalue-20° C to +55° C / -5° F to +130° F
Lämpötilan resoluutio1° C / 1.5° F
Paineen resoluutio1 hPa
Korkeuskäyrä näkyy harjoitusyhteenvedossa✔
HARJOITTELUTOIMINNOT
INTERVALLIHARJOITTELU
Intervalliasetukset✔
Intervalliohjaus harjoituksen aikana✔
Harjoitusintervallit✔
SYKE
Syke mitataan ranteesta✔
Sykevyön yhteensopivuusBluetooth HR belts
Sykeväli (RR)with Suunto Smart Sensor
Syke lyönteinä minuutissa✔
Tallentaa sydämen sykkeen uinnin aikana✔
Reaaliaikainen sykekuvaaja✔
Reaaliaikainen keskisyke✔
Kalorikulutus✔
PTE (Peak Training Effect) -arvo✔
Henkilökohtaiset sykealueet✔
Kuntotaso (VO2max)✔
Anaerobisen kynnyksen tunnistus✔
Palautumisaika✔
NOPEUS JA MATKA
Kadenssiin perustuva nopeus ja matka✔
GPS-nopeus ja -matka✔
Kronometri✔
Foot POD -tukiBluetooth Foot Pods
Automaattikierrokset✔
Manuaaliset kierrokset✔
Vauhtianalyysi, nopeuskuvaajat ja reitit kartalla✔
HARJOITTELUN JÄLKEINEN PALAUTUMINEN
Harjoittelun jälkeisen olon tallennus kelloon✔
Harjoitteluun perustuva palautumisaika✔
HARJOITUSRASITUS
Loki harjoituksen yksityiskohdista✔
Harjoitusrasitus ja yhteismäärät lajeittain✔
Harjoitusloki pitkän aikavälin tarkasteluun✔
Harjoituksen yhteenveto kierrostiedoilla✔
JAA JA KOE UUDELLEEN
Harjoituksen jakaminen sosiaalisessa mediassa✔
Harjoituksen arvostelu ja kommentointi✔
Seuraa muita jäseniä ja saa palautetta toimintasyötteen avulla✔
URHEILUN ASIANTUNTEMUSTA
UINTI
Allasuinnin vauhti ja matka✔
Avovesiuinnin matka✔
Uintiaika allaspituuden ja kierroksen mukaan sekä kokonaisaika✔
Uintivetojen tahti, määrä ja tyyppi✔
Uintivedon tehokkuus (SWOLF)✔
Automaattiset intervallit✔
Intervallikierrostaulukko✔
PYÖRÄILY
Pyöräilynopeus✔
Reaaliaikainen keskinopeus✔
Bike POD nopeus-/kadenssituellaBluetooth Bike Pods
Pyörän tehomittarin tukiBluetooth Power meters
Teho (W), keski ja maksimi (tehoanturin avulla)Bluetooth Power meters
Väliaika ja väliajan huipputeho (tehoanturin avulla)✔
Reaaliaikainen kierrostaulukko, jossa on keskisyke, -teho ja -nopeus✔
Intervalliohjaus – teho/nopeus/syke✔
JUOKSU
Juoksuvauhti✔
Suunto FusedSpeed™✔
Kiinnity reittiin✔
Juoksutehon mittaus✔
Ghost runner✔
Foot POD -kalibrointiautomatic
Kierrostaulukko kellossa ja Suunto-sovelluksessa✔
Reaaliaikainen keski-, maksimi- ja kierrosnopeus✔
Intervalliohjaus – juoksutahti/syke/matka✔
MULTISPORT-TOIMINNOT
Urheilulajin vaihto harjoituksen aikana✔
Valmiiksi asennetut multisport-tilat✔
Moniurheiluharjoitusten lajikohtainen jälkianalyysi✔
Monilaji-harjoitusyhteenveto kellossa✔
URHEILUTILAT
Muokattavat urheilutilat ja näytöt✔
Urheilutilojen graafiset näytöt✔
Kelloon valmiiksi asennetut urheilutilat> 90
SuuntoPlus™✔
SUKELLUSTOIMINNOT
VAPAASUKELLUS
Syvyysmittari snorklaukseen10 m
