Suunto Nautic
Bungee Cord
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Explore more with the Suunto app
ESPECIFICACIONES
Medidas101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
Peso227g (with bungee strap) , 232g (with elastic textile strap)
Material del bisel:Fiber reinforced polymer
Material de la lente:Panda glass (PANDA-MN228 high alumina silicon glass)
Material de la carcasa:Glass fibre reinforced polyamide
Material de la correa:Bungee cord / Elastic textile
País de fabricaciónFI
ESPECIFICACIONES TÉCNICAS
Material de la lentePanda glass (PANDA-MN228 high alumina silicon glass)
Material de la carcasaGlass fibre reinforced polyamide
Material de la correaBungee cord / Elastic textile
Pantalla en color✔
Alerta mediante vibración✔
Sumergibilidad200 m
Tipo de pilarechargeable lithium-ion
Firmware actualizable✔
Hora, fecha✔
Cronómetro✔
IdiomasCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
Luz de fondoAMOLED
Luz de fondo configurableautomatic brightness
Bloqueo de botones✔
Tamaño de pantalla3,26"
Tipo de pantallamatrix
Resolución de pantalla720x382
Unidades métricas e imperiales✔
Control de hora automático✔
Indicador de bateríapercentage / icon
Pantalla siempre activa✔
ESPECIFICACIONES FÍSICAS
Temperatura de funcionamiento-20° C to +55° C / -5° F to +130° F
Temperatura de funcionamiento en modo de buceo0° C to +40° C / +32° F to +104° F
Temperatura de almacenamiento-20° C to +55° C / -5° F to +130° F
Temperatura de carga recomendada0° C to +35° C / +32° F to +95° F
DURACIÓN DE LA BATERÍA
Recordatorios de carga inteligentes✔
Duración de la batería (inmersión)80-190h
BRÚJULA
Brújula digital✔
Brújula digital durante el buceo✔
Compensación de inclinación✔
Corrección de la declinación✔
Escala de dirección✔
Aguja✔
Exactitud de la brújula5°
Resolución de brújula1°
CONECTIVIDAD
Conectividad (entre dispositivos)Bluetooth
Compatible con la Suunto app✔
Actualizaciones del software del reloj desde la nube✔
Actualizaciones de software inalámbricas automáticas✔
Compatibilidad con smartphoneMost common models supported, check here for detailed compatibility list
FUNCIONES PARA AIRE LIBRE
Mapas sin conexión en el reloj✔
Sistemas de satéliteGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Offline map storage size32 GB
Sistemas de satélite simultáneos4
Máximos satélites conectados32
Frecuencia de grabación GPSBest, Good, OK, Low
Niveles de zoom en navegación✔
Sendero de navegación en tiempo real✔
Mapas de terreno y de satélite para aire libre✔
Mapas de calor globales para 20 deportes✔
Navegación de puntos de interés (PDI)✔
Análisis de rutas de GPS✔
Registro, visualización e intercambio de rutas✔
METEOROLOGÍA
Hora de amanecer/puesta de sol✔
Temperatura✔
Intervalo de indicación de temperatura-20° C to +55° C / -5° F to +130° F
Resolución de temperatura1° C / 1.5° F
FUNCIONES DE ENTRENAMIENTO
FRECUENCIA CARDÍACA
Compatibilidad con cinturón de frecuencia cardíacaBluetooth HR belts
CAPACIDADES PARA DEPORTE
MODOS DE DEPORTE
Modos de deporte y pantallas personalizablesCustomizable dive
Pantallas gráficas en modos de deporteIn dive
Modos de deporte preinstalados en el relojDive modes
Apto para deportesScubadive
FUNCIONES DE BUCEO
BÁSICOS
Ajuste de altitud0 - 300 m / 300 -1500 m / 1500 - 3000 m
Pantalla de tiempo de ascenso✔
Cálculo de SNC/UTO (FLO)✔
Modos de buceo y pantallas personalizables✔
Modelo de descompresiónSuunto Bühlmann 16 GF
Opciones de perfil de descompresióncontinuous and stepped
Historial de inmersioneslifetime
Tiempo de inmersión✔
Consumo de gas (en tiempo real)✔
Gas máx. pO2manual 1.0 - 1.6
Cambio de gases✔
Tiempo de gas✔
Gasesup to 5 gases (Oxygen 21 - 100%)
Manómetro✔
Profundidad máxima de funcionamiento (EN 13319)200m
Nítrox (y aire)✔
Tiempo sin vuelo✔
Planificador sin descompresión✔
Ajustes personalesGradient factors low (10-100) and high (50-100)
Parada de seguridad✔
Tiempo en superficie✔
Temporizador✔
Integración de aire inalámbrica✔
Integración de gas inalámbrica✔
Deco planner✔
Helium✔
SNC/UTO (FLO) 80%/100%✔
Violación del techo de descompresión✔
Tiempo de gas✔
pO2 alto (hiperóxico)✔
pO2 bajo (hipóxico)✔
Profundidad máxima✔
NDL✔
Cambio de gas (mejor gas disponible)✔
Presión en la botella✔
Ascenso demasiado rápido✔
INMERSIÓN EN APNEA
Alarma de profundidad✔
Alarma de tiempo de inmersión✔
