Activity monitoring
              Suunto Traverse
              measures your daily steps and estimates calories burned during the
              day based on your personal settings.
              Your approximate daily step count is available as a default view
              in the time display. Press
              VIEW
              to change to the step counter view. The step count is updated
              every 60 seconds.
              Daily step count and calories burned are displayed under
              DISPLAYS
              Steps
              . The values are reset daily at midnight.
                Activity monitoring is based on your movement as measured by
                sensors in the watch. The values provided by activity monitoring
                are estimations and not intended for medical diagnostics of any
                kind.
            Step history
              Suunto Traverse
              provides a complete history of your step count. The step display
              shows your daily steps, as well as an overview of weekly, monthly
              and yearly trends. You can show/hide the step display from the
              start menu under
              DISPLAYS
              Steps
              . When activated, you can view your step history by pressing
              NEXT
              to scroll through active displays.
              While in the steps display, you can press
              VIEW
              to see your 7-day, 30-day and yearly trends.
            Alti-Baro
              Suunto Traverse
              continuously measures absolute air pressure using the built-in
              pressure sensor. Based on this measurement and reference values,
              it calculates altitude or sea level air pressure.
              Three profiles are available:
              Automatic
              Altimeter
              and
              Barometer
              . For information on setting profiles, see
              Matching profile to activity.
              To view alti-baro information, press
              NEXT
              while in the time display or activate the alti-baro display from
              the display menu.
              You can change to different views by pressing
              VIEW
            In altimeter profile, you can see:
              - altitude + temperature
              - altitude + sunrise/sunset
              - altitude + reference point
              - 12h altitude graph + altitude
            In barometer profile, you get the corresponding views:
              - barometric pressure + temperature
              - barometric pressure + sunrise/sunset
              - barometric pressure + reference point
              - 24h barometric pressure graph + barometric pressure
              Sunrise and sunset time views are available when GPS has been
              activated. If GPS is not active, sunrise and sunset times are
              based on the last recorded GPS data.
            You can show/hide the alti-baro display under the start menu.
              To hide the alti-baro display:
                While in the time display, press
                START
                Scroll to
                DISPLAYS
                with
                LIGHT
                and press
                NEXT
                Scroll to
                End Alti-Baro
                and press
                NEXT
                Keep
                NEXT
                pressed to exit.
              Repeat the procedure and select
              Alti-Baro
              to show the display again.
                If you are wearing your
                Suunto Traverse
                on your wrist, you will need to take it off in order to get an
                accurate temperature reading because your body temperature will
                affect the initial reading.
            Getting correct readings
              If your outdoor activity requires accurate sea level air pressure
              or altitude, you need to calibrate your
              Suunto Traverse
              by entering either your current altitude or the current sea level
              air pressure.
                Absolute air pressure and known altitude reference = sea level
                air pressure. Absolute air pressure and known sea level air
                pressure = altitude.
              The altitude of your location can be found from most topographic
              maps or Google Earth. A sea level air pressure reference for your
              location can be found using the websites of national weather
              services.
              CAUTION:
                Keep the area around the sensor free of dirt and sand. Never
                insert any objects into the sensor openings.
              If
              FusedAlti
              is activated, the altitude reading is corrected automatically
              using
              FusedAlti
              together with altitude and sea level pressure calibration. For
              more information, see
              FusedAlti.
              Changes in local weather conditions affect altitude readings. If
              local weather changes often, it is advisable to reset the current
              altitude reference value frequently, preferably before starting
              your journey when the reference values are available. As long as
              the local weather stays stable, you do not need to set reference
              values.
                To set the sea level pressure and altitude reference values:
                Keep
                NEXT
                pressed to enter the options menu.
                Scroll to
                ALTI-BARO
                with
                LIGHT
                and enter with
                NEXT
                Press
                NEXT
                to enter
                Reference
                  The following setting options are available:
                FusedAlti: GPS is switched on and the watch starts calculating
                altitude based on FusedAlti.
                Altitude
                : Set your altitude manually.
                Sea level pressure
                : Set the sea level pressure reference value manually.
                Set the reference value using
                START
                and
                LIGHT
                . Accept the setting with
                NEXT
                When not recording an activity, press
                START
                in the alti-baro display to get directly to the
                ALTI-BARO
                menu.
            Use example: Setting the altitude reference value
              You’re on the second day of your two-day hike. You realize that
              you forgot to switch from the barometer profile to the altimeter
              profile when you started in the morning.You know that the current
              altitude readings of your
              Suunto Traverse
              are wrong.
              So, you hike to the nearest location shown on your topographic map
              for which an altitude reference value is provided. You correct
              your
              Suunto Traverse
              altitude reference value accordingly and switch to the altimeter
              profile. Your altitude readings are correct again.
              The altimeter profile should be selected when your outdoor
              activity involves changes in altitude (such as hiking in the
              mountains).
              The barometer profile should be selected when your outdoor
              activity does not involve changes in altitude (such as canoeing).
              To get correct readings, you need to match the profile to your
              activity. You can either let
              Suunto Traverse
              decide a suitable profile for the activity using the automatic
              profile, or choose a profile yourself.
            To set the alti-baro profile:
                Keep
                NEXT
                Scroll to
                ALTI-BARO
                with
                LIGHT
                and enter with
                NEXT
                Scroll to
                Profile
                with
                START
                and enter with
                NEXT
                Change the profile with
                START
                or
                LIGHT
                and confirm your selection with
                NEXT
                Keep
                NEXT
                pressed to exit.
            Incorrect readings
              If the altimeter profile is on for an extended period of time with
              the device in a fixed location while the local weather changes,
              the device will give incorrect altitude readings.
              If you use the altimeter profile and the weather changes
              frequently while you climb in altitude or go down in altitude, the
              device will give you incorrect readings.
              If you use the barometer profile for an extended period of time as
              you climb in altitude or go down in altitude, the device assumes
              that you are standing still and interprets your changes in
              altitude as changes in sea level air pressure. It will therefore
              give you incorrect sea level air pressure readings.
            Using altimeter profile
              The altimeter profile calculates altitude based on reference
              values. The reference value can either be sea level air pressure
              or altitude. When the altimeter profile is activated, the
              altimeter icon is shown at the top of the alti-baro display.
            Using barometer profile
              The barometer profile shows the current sea level air pressure.
              This is based on the reference values and the constantly measured
              absolute air pressure.
              When the barometer profile is activated, the barometer icon is
              shown on the display.
            Using automatic profile
              The automatic profile switches between the altimeter and barometer
              profiles according to your movement.
              It is not possible to measure weather and altitude changes at the
              same time, as both cause a change in the surrounding air pressure.
              Suunto Traverse
              senses vertical movement and switches to measuring altitude, when
              needed. When altitude is shown, it is updated with a maximum delay
              of 10 seconds.
              If you are at a constant altitude (less than 5 meters of vertical
              movement within 12 minutes),
              Suunto Traverse
              interprets all pressure changes as weather changes. The
              measurement interval is 10 seconds. The altitude reading remains
              steady and if the weather changes, you will see changes in the sea
              level air pressure reading.
              If you are moving in altitude (more than 5 meters of vertical
              movement within 3 minutes),
              Suunto Traverse
              interprets all pressure changes as movements in altitude.
              Depending on which profile is active, you can access the altimeter
              or barometer in the alti-baro display with
              VIEW
                When you are using the automatic profile, barometer or altimeter
                icons are not shown on the alto-baro display.
              Autopause
                Autopause pauses the recording of your activity when your speed
                is less than 2 km/h (1.2 mph). When your speed increases to more
                than 3 km/h (1.9 mph), the recording continues automatically.
                You can turn autopause on/off for each sport mode in Movescount
                under the advanced settings for the sport mode.
              Backlight
                Pressing
                LIGHT
                activates the backlight.
                By default, the backlight turns on for a few seconds and turns
                off automatically.
              There are four backlight modes:
                  Normal
                  : The backlight turns on for a few seconds when you press
                  LIGHT
                  and when the alarm clock sounds. This is the default setting.
                  Off
                  : The backlight is not switched on by pressing a button or
                  Night
                  : The backlight turns on for a few seconds when you press any
                  button and when the alarm clock sounds.
                  Toggle
                  : The backlight turns on when you press
                  LIGHT
                  and stays on until you press
                  LIGHT
                  again.
                You can change the general backlight setting in the watch
                settings under
                Tones/display
                Backlight
                You can adjust the backlight brightness (in percent), either in
                the watch settings under
                Tones/display
                Backlight
                  When the
                  BACK LAP
                  and
                  START
                  buttons are locked, you can still activate the backlight by
                  pressing
                  LIGHT
              Flashlight
                In addition to normal backlight modes, Traverse has one
                additional mode where the backlight is automatically set to
                maximum brightness and can be used as a flashlight. To activate
                the flashlight, keep
                LIGHT
                pressed.
                The flashlight stays on for about four minutes. You can turn it
                off at any time by pressing
                LIGHT
                or
                BACK LAP
                Keeping
                BACK LAP
                pressed locks and unlocks buttons.
                You can change the button lock behavior in the watch settings
                under
                Tones/display
                Button lock
                Your
                Suunto Traverse
                has two button lock options:
                  Actions only
                  : Start and options menus are locked.
                  All buttons
                  : All buttons are locked. Backlight can be activated in
                  Night
                  mode.
                  Select the
                  Actions only
                  button lock setting to avoid accidentally starting or stopping
                  your log. When the
                  BACK LAP
                  and
                  START
                  buttons are locked, you can still change displays by pressing
                  NEXT
                  and views by pressing
                  VIEW
                Compass
                  Suunto Traverse
                  has a digital compass that allows you to orient yourself in
                  relation to magnetic north. The tilt-compensated compass gives
                  you accurate readings even if the compass is not horizontally
                  level.
                  You can show/hide the compass display from the start menu
                  under
                  DISPLAYS
                  Compass
                  The default compass display includes the following
                  information:
                  - middle row: compass heading in degrees
                    bottom row: press
                    VIEW
                    to see current time, cardinal direction or empty (no value)
                  You can change the compass display information from the
                  options menu under
                  General
                  Formats
                  Compass unit
                  . Select which is the primary value in the center of the
                  compass display: degrees, Mils or cardinals.
                  The compass switches to power saving mode after one minute.
                  Reactivate it with
                  START
                Calibrating compass
                  If you have not used the compass before, you must first
                  calibrate it. Turn and tilt the watch in multiple directions
                  until the watch beeps, indicating calibration is complete.
                  If the calibration is successful, the text
                    Calibration successful
                  is displayed. If the calibration does not succeed, the text
                  Calibration failed
                  is displayed. To retry the calibration, press
                  START
                  If you have already calibrated the compass and want to
                  re-calibrate it, you can manually start the calibration
                  process.
                    To manually start compass calibration:
                    Keep
                    NEXT
                    Scroll to
                    NAVIGATION
                    with
                    START
                    and enter with
                    NEXT
                    Scroll to
                    Settings
                    with
                    LIGHT
                    and select with
                    NEXT
                    Scroll to
                    Compass
                    with
                    LIGHT
                    and select with
                    NEXT
                    Press
                    NEXT
                    to select
                    Calibration
                Setting declination
                  To ensure correct compass readings, set an accurate
                  declination value.
                  Paper maps point to true north. Compasses, however, point to
                  magnetic north – a region above the Earth where the Earth’s
                  magnetic fields pull. Because magnetic North and true North
                  are not at the same location, you must set the declination on
                  your compass. The angle in between magnetic and true north is
                  your declination.
                  The declination value appears on most maps. The location of
                  magnetic north changes yearly, so the most accurate and
                  up-to-date declination value can be obtained from the internet
                  (for example
                    www.magnetic-declination.com
                  Orienteering maps, however, are drawn in relation to magnetic
                  north. This means that when you are using orienteering maps
                  you need to turn the declination correction off by setting the
                  declination value to 0 degrees.
                  To set the declination value:
                    Keep
                    NEXT
                    Scroll to
                    NAVIGATION
                    with
                    START
                    and enter with
                    NEXT
                    Scroll to
                    Settings
                    with
                    LIGHT
                    and select with
                    NEXT
                    Scroll to
                    Compass
                    with
                    LIGHT
                    and select with
                    NEXT
                    Scroll to
                    Declination
                    with
                    LIGHT
                    and select with
                    NEXT
                    Turn the declination off by selecting
                    , or select
                    W
                    (west) or
                    E
                    (east). Set the declination value with
                    START
                    or
                    LIGHT
                    Press
                    NEXT
                    to accept the setting.
                    You can also access the navigation menu and compass settings
                    by pressing
                    START
                    while navigating.
                Setting bearing lock
                  You can mark the direction to your target in relation to North
                  with the bearing lock feature.
                To lock a bearing:
                    With the compass active, hold the watch in front of you and
                    turn yourself towards your target.
                    Press
                    BACK LAP
                    to lock the current degree displayed on the watch as your
                    bearing.
                    An empty triangle indicates the locked bearing in relation
                    to the North indicator (solid triangle).
                    Press
                    BACK LAP
                    to clear the bearing lock.
                    When using the compass while recording an activity, the
                    BACK LAP
                    button only locks and clears the bearing. Exit the compass
                    view to make a lap with
                    BACK LAP
                  Countdown timer
                    You can set the countdown timer to count down from a preset
                    time to zero. You can show/hide it from the start menu under
                    DISPLAYS
                    Countdown
                    When activated, the countdown timer can be accessed by
                    pressing
                    NEXT
                    until see the display.
                    The default countdown time is five minutes. You can adjust
                    this time by pressing
                    VIEW
                      You can pause/continue the countdown by pressing
                      START
                      Countdown timer is not available while activity recording
                      is ongoing.
                    Displays
                      Your
                        Suunto Traverse
                      comes with several different features, such as compass
                      (see
                      Compass) and stopwatch (see
                      Stopwatch). These are handled as displays that can be
                      viewed by pressing
                      NEXT
                      . Some of them are permanent, others you can show or hide
                      as you like.
                      To show/hide displays:
                        Press
                        START
                        to enter the start menu.
                        Scroll to
                        DISPLAYS
                        by pressing
                        LIGHT
                        and press
                        NEXT
                        In the list of display, toggle any feature on/off by
                        scrolling to it with
                        START
                        or
                        LIGHT
                        and pressing
                        NEXT
                        . Keep
                        NEXT
                        pressed to exit the displays menu if needed.
                      Your sport modes (see
                      Sport modes) also have multiple displays that you can
                      customize to view different information while recording an
                      activity.
                    Adjusting display contrast
                      Increase or decrease the display contrast of your
                        Suunto Traverse
                      in the watch settings.
                        To adjust the display contrast:
                        Keep
                        NEXT
                        Press
                        NEXT
                        to enter the
                        settings.
                        Press
                        NEXT
                        to enter
                        Tones/display
                        Scroll to
                          Display contrast
                        with
                        LIGHT
                        and enter with
                        NEXT
                        Increase the contrast with
                        START
                        , or decrease it with
                        LIGHT
                        Keep
                        NEXT
                        pressed to exit.
                    Inverting display color
                      Change the display between dark and light through the
                      settings in the watch.
                        To invert the display in the watch settings:
                        Keep
                        NEXT
                        Press
                        NEXT
                        to enter the
                        settings.
                        Press
                        NEXT
                        to enter
                        Tones/display
                        Scroll to
                        Invert display
                        with
                        START
                        and invert with
                        NEXT
                    FusedAlti
                      FusedAlti
                      TM
                      provides an altitude reading that is a combination of GPS
                      and barometric altitude. It minimizes the effect of
                      temporary and offset errors in the final altitude reading.
                        By default, altitude is measured with FusedAlti during
                        recordings that use GPS and during navigation. When GPS
                        is switched off, altitude is measured with the
                        barometric sensor.
                      If you do not want to use FusedAlti in altitude
                      measurement, set your reference value with altitude or sea
                      level pressure.
                      You can search for a new reference value with FusedAlti by
                      activating it in the options menu under
                      ALTI-BARO
                      Reference
                      FusedAlti.
                      In good conditions it takes 4-12 minutes for FusedAlti to
                      find a reference value. During that time,
                        Suunto Traverse
                      shows barometric altitude with '~' before the reading to
                      indicate that the altitude may not be correct.
                    Find back
                        Suunto Traverse
                      automatically saves the starting point of your recording
                      if you are using GPS. With Find back,
                        Suunto Traverse
                      can guide you directly back to your starting point (or to
                      the location where the GPS fix was established).
                    To find back:
                        Keep
                        NEXT
                        pressed to access the options menu.
                        Press
                        NEXT
                        to select
                        NAVIGATION
                        Scroll to
                        Find back
                        with
                        START
                        and select with
                        NEXT
                      The navigation guidance is shown as one of the views in
                      the breadcrumb display.
                    Icons
                      The following icons are displayed in
                        Suunto Traverse
                          alarm |
                          altimeter |
                          barometer |
                          battery |
                          Bluetooth |
                          button lock |
                          button press indicators |
                          current display |
                          down/decrease |
                          flashlight |
                          GPS signal strength |
                          heart rate |
                          highest point |
                          incoming call |
                          lowest point |
                          message/notification |
                          missed call |
                          next/confirm |
                          pairing |
                          settings |
                          sport mode |
                          storm |
                          sunrise |
                          sunset |
                          up/increase |
                    POI icons
                      The following POI icons are available in
                        Suunto Traverse
                          begin |
                          building/home |
                          camp/camping |
                          car/parking |
                          cave |
                          crossroad |
                          emergency |
                          end |
                          food/restaurant/cafe |
                          forest |
                          geocache |
                          info |
                          lodging/hostel/hotel |
                          meadow |
                          mountain/hill/valley/cliff |
                          road/trail |
                          rock |
                          sight |
                          water/waterfall/river/lake/coast |
                          waypoint |
                    Logbook
                      The logbook stores the logs of your recorded activities.
                      The maximum number of logs and the maximum duration of a
                      single log depends on how much information is recorded in
                      each activity. GPS accuracy (see GPS accuracy and power
                      saving), for example, directly impact the number and
                      duration of logs that can be stored.
                      You can view the log summary of your activity right after
                      you have stopped recording or through the
                      Logbook
                      The information shown in the log summary is dynamic: it
                      changes depending on factors such as sport mode and
                      whether or not you used an heart rate belt or GPS. By
                      default, all logs include at minimum the following
                      information:
                      - sport mode name
                      - time
                      - date
                      - duration
                      - laps
                      If the log includes GPS data, the logbook entry includes a
                      view of the full route track as well as the altitude
                      profile of the track.
                        You can see many more details of your recorded
                        activities in Suunto app.
                        To view log summary after stopping a recording:
                        Keep
                        START
                        pressed to stop and save the recording.
                        Press
                        NEXT
                        to view the log summary.
                      You can also view the summaries of all your recorded
                      sessions(logs) in the logbook. In the logbook recorded
                      sessions are listed according to date and time.
                        To view summary log in the logbook:
                        Press
                        START
                        Scroll to
                        Logbook
                        with
                        LIGHT
                        and enter with
                        NEXT
                        Scroll the logs with
                        START
                        or
                        LIGHT
                        and select a log with
                        NEXT
                        Browse the summary views of the log with
                        NEXT
                      Memory left indicator
                      If more than 50 % of the logbook has not been synchronized
                      with Suunto app,
                        Suunto Traverse
                      displays a reminder when you enter the logbook.
                      The reminder is not displayed once the unsynced memory is
                      full and
                        Suunto Traverse
                      begins overwriting old logs.
                    Movescount
                      Movescount allows you to customize your watch to best meet
                      your needs.
                        Start by installing SuuntoLink:
                        Go to
                          www.suunto.com/suuntolink
                        Download, install and open the latest version of
                        SuuntoLink.
                        Follow the instructions to create your Movescount
                        account.
                        Go to
                          www.movescount.com
                        and log in.
                        The first time your
                          Suunto Traverse
                        is connected to Movescount, the watch settings are
                        transferred from the watch to your Movescount account.
                        The next time you connect your
                          Suunto Traverse
                        to your Movescount account, changes in settings and
                        sport modes you make in Movescount and in the watch are
                        automatically synchronized.
                        Navigating with GPS
                          Suunto Traverse
                        uses the Global Positioning System (GPS) to determine
                        your current position. GPS incorporates a set of
                        satellites that orbit the Earth at an altitude of 20,000
                        km at the speed of 4 km/s.
                        The built-in GPS receiver in
                          Suunto Traverse
                        is optimized for wrist use and receives data from a very
                        wide angle.
                      Getting GPS signal
                          Suunto Traverse
                        activates GPS automatically when you select a sport mode
                        with the GPS functionality, determine your location, or
                        start navigating.
                          When you activate GPS for the first time, or have not
                          used it for a long time, it might take longer than
                          usual to get a GPS fix. Subsequent GPS starts will
                          take less time.
                          To minimize GPS initiation time, hold the watch steady
                          facing up and make sure you are in an open area with a
                          clear view of the sky.
                          Regularly synchronize your
                            Suunto Traverse
                          with Suunto app to get the latest satellite orbit data
                          (GPS optimization). This reduces the time needed to
                          get the GPS fix and improves track accuracy.
                      Troubleshooting: No GPS signal
                          For an optimal signal, point the GPS part of the watch
                          upwards. The best signal can be received in an open
                          area with a clear view of the sky.
                          The GPS receiver usually works well inside tents and
                          other thin covers. However, objects, buildings, dense
                          vegetation or cloudy weather can reduce the GPS signal
                          reception quality.
                          GPS signal does not penetrate any solid constructions
                          or water. Therefore do not try to activate GPS inside
                          buildings, caves or under water.
                      GPS grids and position formats
                        Grids are lines on a map that define the coordinate
                        system used on the map.
                        Position format is the way the GPS receiver's position
                        is displayed on the watch. All the formats relate to the
                        same location, they only express it in a different way.
                        You can change the position format in the watch settings
                        Formats
                        Position format
                          You can select the format from the following grids:
                          latitude/longitude is the most commonly used grid and
                          has three different formats:
                                WGS84 Hd.d°
                                WGS84 Hd°m.m'
                                WGS84 Hd°m's.s
                          UTM
                          (Universal Transverse Mercator) gives a
                          two-dimensional horizontal position presentation.
                          MGRS
                          (Military Grid Reference System) is an extension of
                          UTM and consists of a grid zone designator,
                          100,000-meter square identifier and a numerical
                          location.
                            Suunto Traverse
                          also supports the following local grids:
                          British (BNG)
                            Finnish (ETRS-TM35FIN)
                          Finnish (KKJ)
                          Irish (IG)
                            Swedish (RT90)
                            Swiss (CH1903)
                            UTM NAD27 Alaska
                            UTM NAD27 Conus
                          UTM NAD83
                            NZTM2000
                          (New Zealand)
                          Some grids cannot be used in the areas north of 84°N
                          and south of 80°S, or outside the countries that they
                          are intended for.
                      GPS accuracy and power saving
                        When customizing sport modes, you can define the GPS fix
                        interval using the GPS accuracy setting in Suunto
                        Movescount. The shorter the interval, the better the
                        accuracy during recording.
                        By increasing the interval and lowering the accuracy,
                        you can extend the battery life.
                          The GPS accuracy options are:
                          Best
                          : ~ 1 sec fix interval, highest power consumption
                          Good
                          : ~ 5 sec fix interval, moderate power consumption
                          OK
                          : ~ 60 sec fix interval, lowest power consumption
                          Off
                          : no GPS fix
                        You can adjust the predefined GPS accuracy of the sport
                        mode if needed
                        only
                        during a recording and while navigating. For instance,
                        if you notice you are low on battery, you could adjust
                        the setting to extend battery life.
                        Adjust GPS accuracy in the start menu under
                        NAVIGATION
                        Settings
                        GPS accuracy
                      GPS and GLONASS
                          Suunto Traverse
                        uses a Global Navigation Satellite System (GNSS) to
                        determine your location. The GNSS can use signals from
                        both GPS and GLONASS satellites.
                        By default your watch searches for GPS signals only. In
                        some situations and locations already the world, using
                        GLONASS signals can improve location accuracy. However,
                        keep in mind that using GLONASS consumes more battery
                        than using GPS only.
                        You can activate or deactivate GLONASS at any time, even
                        while recording an activity.
                          The activate or deactivate GLONASS:
                          Keep
                          NEXT
                          Scroll to
                          NAVIGATION
                          with
                          START
                          and enter with
                          NEXT
                          Scroll to
                          Settings
                          with
                          LIGHT
                          and select with
                          NEXT
                          Scroll to
                          GNSS
                          with
                          START
                          and select with
                          NEXT
                          Choose
                          GPS & GLONASS
                          to activate GLONASS. If already active, choose
                          GPS
                          to deactivate GLONASS.
                          Keep
                          NEXT
                          pressed to exit.
                          GLONASS is only used if GPS accuracy is set to best.
                          (See
                          GPS accuracy and power saving).
                        Notifications
                          If you have paired your
                            Suunto Traverse
                          with Suunto app (see
                          Suunto app), you can get call, message and push
                          notifications on the watch.
                            To get notifications on your watch:
                            Keep
                            NEXT
                            Press
                            LIGHT
                            to scroll to
                            CONNECTIVITY
                            and press
                            NEXT
                            Press
                            LIGHT
                            to scroll to
                              Notifications
                            Toggle on/off with
                            LIGHT
                            Exit by keeping
                            NEXT
                            pressed.
                          With notifications on, your
                            Suunto Traverse
                          gives an alert (see
                          Tones and vibration) and displays a notification icon
                          in the bottom row of the time display with each new
                          event.
                            To view notifications on your watch:
                            Press
                            START
                            Scroll to
                            NOTIFICATIONS
                            with
                            START
                            and press
                            NEXT
                            Scroll through the notifications with
                            START
                            or
                            LIGHT
                          Up to 10 notifications can be listed. Notifications
                          remain in your watch until you clear them from your
                          mobile device. However, notifications older than one
                          day are hidden from view in the watch.
                          Recording activities
                          Use sport modes (see
                          Sport modes) to record activities and view various
                          information during your outing.
                          Out of the box,
                            Suunto Traverse
                          has has one sport mode, Hiking. Start a recording by
                          pressing
                          START
                          and then press
                          NEXT
                          to enter
                          RECORD
                          So long as there is only one sport mode in the watch,
                          the recording starts immediately. If you add other
                          sport modes, you need to select the sport mode you
                          want to use and then press
                          NEXT
                          to start the recording.
                            You can also quickly start the recording by keeping
                            START
                            pressed.
                            Pairing heart rate sensor
                            Pairing procedures may vary depending on the heart
                            rate (HR) sensor type. Please refer to the user
                            guide for the device you are pairing with your
                              Suunto Traverse
                            before continuing.
                              To pair a heart rate sensor:
                            - Activate heart rate sensor.
                              Keep
                              NEXT
                              Scroll to
                                CONNECTIVITY
                              with
                              LIGHT
                              and select with
                              NEXT
                              Press
                              NEXT
                              again to enter
                              Pair
                              Scroll to
                              HR belt
                              with
                              LIGHT
                              and press
                              NEXT
                              Hold your
                                Suunto Traverse
                              close to the device you are pairing and wait for
                                Suunto Traverse
                              to notify that pairing was successful.
                            Points of interest
                              Suunto Traverse
                            includes GPS navigation which allows you to navigate
                            to a pre-defined destination stored as a point of
                            interest (POI).
                              You can also start navigating to a POI when you
                              are recording an activity (see
                              Recording activities).
                              To navigate to a POI:
                              Press
                              START
                              Scroll to
                                NAVIGATION
                              with
                              START
                              and press
                              NEXT
                              Scroll to
                                POIs (Points of interest)
                              using
                              LIGHT
                              and press
                              NEXT
                              Scroll to the POI you wish to navigate to with
                              START
                              or
                              LIGHT
                              and select with
                              NEXT
                              Press
                              NEXT
                              again to select
                              Navigate
                              . If you are using the compass for the first time,
                              you need to calibrate it (see
                              Calibrating compass). After activating the
                              compass, the watch starts searching for a GPS
                              signal. All navigating is recorded. If your watch
                              has more than one sport mode, you are prompted to
                              select one.
                            - Start navigating to the POI.
                            The watch displays the breadcrumb display, showing
                            your position and the position of the POI.
                            By pressing
                            VIEW
                            you can access additional guidance:
                              distance and direction to POI in straight line
                              distance to POI and estimated time en route based
                              on your current speed,
                              difference between your current altitude and the
                              POI altitude
                            When stationary or moving slowly (<4 km/h), the
                            watch shows you the direction to the POI (or
                            waypoint if navigating a route) based on the compass
                            bearing.
                            While moving (>4 km/h), the watch shows you the
                            direction to the POI (or waypoint if navigating a
                            route) based on GPS.
                            The direction to your target, or bearing, is shown
                            with the empty triangle. Your direction of travel,
                            or heading, is indicated by the solid lines at the
                            top of the display. Aligning these two ensures you
                            are moving in the correct direction.
                          Checking your location
                              Suunto Traverse
                            allows you to check the coordinates of your current
                            location using GPS.
                              To check your location:
                              Press
                              START
                              Scroll to
                                NAVIGATION
                              with
                              START
                              and press
                              NEXT
                              Scroll to
                              Location
                              with
                              LIGHT
                              and press
                              NEXT
                              Press
                              NEXT
                              to select
                              Current
                              The watch starts searching for a GPS signal and
                              displays
                              GPS found
                              after acquiring the signal. After that your
                              current coordinates are shown on the display.
                              You can also check your location while you are
                              recording an activity by keeping
                              NEXT
                              pressed to access
                                NAVIGATION
                              in the options menu or by pressing
                              START
                              while in the breadcrumb display.
                          Adding a POI
                              Suunto Traverse
                            allows you to save your current location or define a
                            location as a POI.
                          You can store up to 250 POIs in the watch.
                            When adding a POI, select a POI type (icon) and POI
                            name from a predefined list.
                          To save a POI:
                              Press
                              START
                              Scroll to
                                NAVIGATION
                              with
                              START
                              and press
                              NEXT
                              Scroll to
                              Location
                              with
                              LIGHT
                              and press
                              NEXT
                              Select
                              Current
                              or select
                              Define
                              to manually change longitude and latitude values.
                              Press
                              START
                              to save the location.
                              Select a suitable name for the location. Scroll
                              through the name options with
                              START
                              or
                              LIGHT
                              . Select a name with
                              NEXT
                              Press
                              START
                              to save the POI.
                              You can quickly save your current location as a
                              POI by keeping
                              VIEW
                              pressed. This can be done from any display.
                          Deleting a POI
                          You can delete a POI directly in the watch.
                            To delete a POI:
                              Press
                              START
                              Scroll to
                                NAVIGATION
                              with
                              START
                              and press
                              NEXT
                              Scroll to
                              with
                              LIGHT
                              and press
                              NEXT
                              Scroll to the POI you wish to delete with
                              START
                              or
                              LIGHT
                              and select with
                              NEXT
                              Scroll to
                              Delete
                              with
                              START
                              and press
                              NEXT
                              Press
                              START
                              to confirm.
                          Routes
                            You can create a route in Movescount, or import a
                            route created with another service.
                          To add a route:
                              Go to
                                www.movescount.com
                              and log in.
                              Sync your
                                Suunto Traverse
                              with Movescount using Suuntolink and the supplied
                              USB cable.
                            Routes could also be deleted through Movescount.
                          Navigating a route
                            You can navigate a route you have transferred to
                            your
                              Suunto Traverse
                            from Movescount (see 3.20 Routes) or from a log in
                            your logbook with GPS data. You get a preview of the
                            route based on the route list or logbook selection.
                            If you are using the compass for the first time, you
                            Calibrating compass). After activating the compass,
                            the watch will begin searching for a GPS signal.
                            After the watch acquires a GPS signal, you can begin
                            to navigate a route.
                            To navigate a route:
                              Press
                              START
                              Scroll to
                                NAVIGATION
                              with
                              START
                              and press
                              NEXT
                              Scroll to
                              Routes
                              or
                                NAVIGATION
                              and press
                              NEXT
                              to enter .
                              Scroll to the route you want to navigate with
                              START
                              or
                              LIGHT
                              and press
                              NEXT
                              Press
                              NEXT
                              to select
                              Navigate
                              . All navigating is recorded. If you watch has
                              select one.
                              Select
                              Forwards
                              or
                              Backwards
                              to chose the direction you want to navigate (from
                              the first waypoint or the last).
                              Start navigating. The watch informs you when you
                              are approaching the beginning of the route.
                              The watch informs you when you have arrived at
                              your destination.
                              You can also start navigating while recording an
                              activity (see
                          During navigation
                            During navigation, press
                            VIEW
                            to scroll the following views:
                            - full track view showing the whole route
                              zoomed-in track view of the route: by default, the
                              zoomed-in view is scaled to a 100 m (0.1 mi)
                              scale; the scale is larger if you are far away
                              from the route
                          Track view
                              The full track view shows you the following
                              information:
                              (1) arrow indicating your location and pointing to
                              the direction of your heading.
                            - (2) the beginning and end of the route
                            - (3) The closest POI is shown as an icon.
                            - (4) scale of the track view
                              In the full track view the north is always up.
                          Map orientation
                            You can change the map orientation in the options
                            menu under
                            NAVIGATION
                            Settings
                            Map
                            Orientation
                                Heading up
                              : Displays the zoomed-in map with the heading
                              pointing up.
                              North up
                              : Displays the zoomed-in map with the north
                              pointing up.
                          Ascent profile view
                            The ascent profile view shows you the following
                            information:
                            - Remaining ascent
                            - Real-time altitude profile graph
                            - Remaining descent
                            If you veer too far off the route track, the profile
                            graph is not updated. Instead, the text
                            Off route
                            is shown below the graph. You need to return to the
                            track to get accurate ascent calculations.
                            To access the service menu, keep
                            BACK LAP
                            and
                            START
                            pressed simultaneously until the watch enters the
                            service menu.
                              The service menu includes the following items:
                              Info
                                    Air pressure
                                  : shows the current absolute air pressure and
                                  temperature.
                                    Version
                                  : shows the current software and hardware
                                  version.
                                  BLE
                                  : shows the current Bluetooth Smart version.
                              Display
                                    LCD test
                                  : allows you to test that the LCD works
                                  properly.
                              ACTION
                                    Power off
                                  : allows you to put the watch into deep sleep.
                                    GPS reset
                                  : allows you to reset GPS.
                              Power off
                              is a low power state. Follow the normal startup
                              procedure to wake up the device. All settings
                              except time and date are maintained. Just confirm
                              them through the startup wizard.
                              The watch switches to power saving mode when it is
                              static for 10 minutes. The watch re-activates when
                              moved.
                              Service menu content is subject to change without
                              notice during updates.
                          Resetting GPS
                            In case the GPS unit cannot find a signal, you can
                            reset GPS data in the service menu.
                          To reset GPS:
                              In the service menu, scroll to
                              ACTION
                              with
                              LIGHT
                              and enter with
                              NEXT
                              Press
                              LIGHT
                              to scroll to
                              GPS reset
                              and enter with
                              NEXT
                              Press
                              START
                              to confirm GPS reset, or press
                              LIGHT
                              to cancel.
                              Resetting GPS resets GPS data and compass
                              calibration values. Saved logs are not removed.
                            Sport modes
                              Sport modes are your way to customize how
                              activities are recorded. Different information is
                              shown on the displays while recording depending on
                              the sport mode.
                                Suunto Traverse
                              comes with a predefined sport mode for hiking.
                              In Suunto Movescount you can create custom sport
                              modes, edit the predefined sport mode, delete
                              sport modes, or simply hide them so that they are
                              not shown in your
                              RECORD
                              menu (see
                              A custom sport mode can contain up to four
                              displays. You can choose which data appears on
                              each display from a comprehensive list of options.
                              You can transfer up to five sport modes created in
                              Movescount to your
                                Suunto Traverse
                            Stopwatch
                              The stopwatch is a display that can be turned on
                              or off from the start menu.
                                To activate the stopwatch:
                                Press
                                START
                                Scroll to
                                  DISPLAYS
                                with
                                LIGHT
                                and press
                                NEXT
                                Scroll to
                                  Stopwatch
                                with
                                LIGHT
                                and press
                                NEXT
                              When activated, the timer can be accessed by
                              pressing
                              NEXT
                              until the timer appears.
                                The stopwatch is not visible while recording an
                                activity.
                                To use the stopwatch:
                                In the activated stopwatch display, press
                                START
                                to start measuring time.
                                Press
                                BACK LAP
                                to make a lap, or press
                                START
                                to pause the stopwatch. To view the lap times,
                                press
                                BACK LAP
                                when the stopwatch is paused.
                                Press
                                START
                                to continue.
                                To reset the time, keep
                                START
                                pressed when the stopwatch is paused.
                                While the stopwatch is running, you can:
                                press
                                VIEW
                                to switch between the time and lap time shown on
                                the bottom row of the display.
                                switch to Time display with
                                NEXT
                                enter the options menu by keeping
                                NEXT
                                pressed.
                              If you no longer want to see the stopwatch
                              display, deactivate the stopwatch.
                                To hide the stopwatch:
                                Press
                                START
                                Scroll to
                                  DISPLAYS
                                with
                                LIGHT
                                and press
                                NEXT
                                Scroll to
                                  End stopwatch
                                with
                                LIGHT
                                and press
                                NEXT
                            Suunto app
                              With the Suunto app, you can further enrich your
                                Suunto Traverse
                              experience by analyzing and sharing your
                              trainings, connecting to partners and much more.
                              Pair with the mobile app to get notifications on
                              your
                                Suunto Traverse
                                To pair your watch with Suunto app:
                                Download and install Suunto app on your
                                compatible mobile device from the App Store,
                                Google Play in addition to several popular app
                                stores in China.
                                Start Suunto app and turn on Bluetooth if it is
                                not on already.
                                On your watch, keep
                                Next
                                Scroll to
                                PAIR
                                with
                                Light Lock
                                and select with
                                Next
                                Press
                                Next
                                to select
                                MobileApp
                                Return to the app and tap the watch icon in the
                                upper left corner of the screen. When the name
                                of the watch appears, tap PAIR.
                                Enter the passkey shown on your watch display
                                into the paring request field on your mobile
                                device and tap PAIR to finalize the connection.
                                Some features require an internet connection
                                over Wi-Fi or mobile network. Carrier data
                                connection fees may apply.
                            Syncing with mobile app
                                Suunto Traverse
                              with Suunto app, all your new training sessions
                              are automatically synced when the Bluetooth
                              connection is active and in working range. The
                              Bluetooth icon on your
                                Suunto Traverse
                              flashes when data is being synced.
                              If your mobile device has an active data
                              connection and Bluetooth is on, logs are synced
                              with Suunto app when automatic syncing is on. If
                              there is no data connection, syncing is delayed
                              until a connection is available.
                              This default setting can be changed from the
                              options menu if you have paired your watch with
                              the mobile app.
                                To turn off automatic syncing:
                                Keep
                                NEXT
                                Scroll to
                                  CONNECTIVITY
                                with
                                LIGHT
                                and select with
                                NEXT
                                Press
                                NEXT
                                again to enter the
                                  MobileApp sync
                                setting.
                                Toggle off with
                                LIGHT
                                and keep
                                NEXT
                                pressed to exit.
                              When automatic syncing is off, you cannot get or
                              view notifications on your watch.
                            Suunto Apps
                              Suunto Apps allow you to further customize your
                                Suunto Traverse
                              . Visit Suunto App Zone under Community in
                              Movescount.com to find Apps, such as various
                              timers and counters, available for your use. If
                              you cannot find what you need, create your own App
                              with Suunto App Designer. You can create Apps, for
                              example, for calculating your estimated marathon
                              result, or the slope grade of your skiing route.
                                Suunto Apps in Movescount refers to apps you can
                                use in your watch. Not to be confused with
                                Suunto app which is a mobile app used for
                                analyzing and sharing your trainings, connecting
                                To add Suunto Apps to your
                                  Suunto Traverse
                                Go to the
                                App zone
                                section in Movescount community to browse
                                existing Suunto Apps. To create your own App,
                                select
                                App Designer
                                Add Suunto App to a sport mode. Connect your
                                  Suunto Traverse
                                to your Movescount account to synchronize Suunto
                                App to the watch. The added Suunto App will show
                                the result of its calculation while you
                                exercise.
                                You can add up to five Suunto Apps to each sport
                                mode.
                              Time
                                The time display on your
                                  Suunto Traverse
                                shows the following information:
                                - top row: date
                                - middle row: time
                                  bottom row: change with
                                  VIEW
                                  to show additional information such as
                                  sunrise/sunset, altitude and battery level.
                                In the options menu under
                                  Time/date
                                , you can set the following:
                                - Dual time
                                - Alarm
                                - Time and date
                              Alarm clock
                                You can use your
                                  Suunto Traverse
                                as an alarm clock. Turn the alarm on/off and set
                                the alarm time in the options menu under
                                  Time/date
                                Alarm
                                When the alarm is switched on, the alarm symbol
                                is shown on most of the displays.
                                  When the alarm sounds, you can:
                                  Snooze by pressing
                                  LIGHT
                                  . The alarm stops and restarts every five
                                  minutes until you stop it. You can snooze up
                                  to 12 times for a total of one hour.
                                  Stop by pressing
                                  START
                                  . The alarm stops and restarts the same time
                                  the following day, unless you switch the alarm
                                  off in the options menu.
                                  When snoozing, the alarm icon blinks in the
                                  time display.
                              Time syncing
                                Your
                                  Suunto Traverse
                                time can be updated through your mobile phone,
                                computer (Suuntolink) or GPS time.
                                When you connect your watch to the computer with
                                the USB cable, Suuntolink by default updates
                                your watch time and date according to the
                                computer clock.
                              GPS time
                                GPS time corrects the offset between your
                                  Suunto Traverse
                                and the GPS time. GPS time checks and corrects
                                the time whenever a GPS fix is found (for
                                example when recording an activity, or saving a
                                POI).
                                GPS time is on by default. You can turn it off
                                  Time/date
                                  Time & date
                              Daylight Saving Time
                                  Suunto Traverse
                                supports Daylight Saving Time (DST) time
                                adjustments if GPS time is on
                                You can adjust the Daylight Saving Time setting
                                  Time/date
                                  Time & date
                              There are three settings available:
                                    Automatic
                                  – automatic DST adjustment based on GPS
                                  location
                                    Winter time
                                  – always winter time (no DST)
                                    Summer time
                                  – always summer time
                                Tones and vibration
                                Tones and vibration alerts are used for
                                notifications, alarms and other key events. Both
                                can be adjusted separately in the options menu
                                under
                                  Tones/display
                                Tones
                                or
                                  Vibration
                                For each alert type, you can select from the
                                following options:
                                    All on
                                  : all events trigger tones/vibration
                                    All off
                                  : no events trigger tones/vibration
                                    Buttons off
                                  : all events other than pushing buttons
                              Track back
                                With
                                  Suunto Traverse
                                you can retrace your route any time during a
                                recording with the help of the breadcrumb
                                display.
                                You can also navigate a track from the logbook
                                with recorded activities that include GPS data.
                                Follow the same procedure as in
                                Navigating a route. Scroll to
                                Logbook
                                instead of
                                Routes
                                , and select a log to start navigating.
                                Weather indicators
                                In addition to the barometer graph (see
                                Using barometer profile),
                                  Suunto Traverse
                                has two weather indicators: weather trend and
                                storm alarm.
                                The weather trend indicator is displayed as a
                                view in the time display, providing you a quick
                                way to check weather changes.
                                The weather trend indicator is comprised of two
                                lines forming an arrow. Each line represents a
                                3-hour period. A change in barometric pressure
                                greater than 2 hPa (0.59 inHg) over three hours
                                triggers a change the direction of the arrow.
                                For example:
                                      pressure dropping heavily over the last
                                      six hours
                                      pressure was steady, but rising heavily
                                      over the last three hours
                                      pressure was rising heavily, but dropping
                                      heavily over the last three hours
                              Storm alarm
                                A significant drop in barometric pressure
                                typically means a storm is coming and you should
                                take cover. When the storm alarm is active,
                                  Suunto Traverse
                                sounds an alarm and flashes a storm symbol when
                                the pressure drops 4 hPa (0.12 inHg) or more
                                during a 3-hour period.
                                The storm alarm is off by default. You can turn
                                it on in the options menu under
                                Alerts
                                  Storm alarm
                                  The storm alarm does not work if you have
                                  altimeter profile activated.
                                When a storm alarm sounds, pressing any button
                                ends the alarm. If no button is pressed, the
                                alarm repeats once after five minutes. The storm
                                symbol remains on the display until the weather
                                conditions stabilize (pressure drop slows down).
                                A special lap (called 'storm alarm') is
                                generated when a storm alarm occurs while
