If there is more history information available than
                          can be shown in a single screen, you can scroll
                          through the additional information with the upper and
                          lower buttons.
                          In Suunto app you can create new or edit existing dive
                          modes, modify screen layouts, change helium and
                          multi-gas settings, and change dive type (OC/CC). You
                          can activate CCR (closed circuit rebreather) dive
                          support in Suunto app.
                          The decompression algorithm used in
                            Suunto EON Core
                          is Suunto Fused™ RGBM 2. For more information about
                          the algorithm, see
                            Decompression algorithm
                          By default, Air/Nitrox mode is for diving with regular
                          air and diving with oxygen enriched gas mixtures.
                          Diving with nitrox gas mixture allows you to increase
                          bottom times or reduce the risk of decompression
                          illness.
                            Suunto EON Core
                          provides you with information to adjust your dive and
                          stay within safe limits.
                          When diving with nitrox gas mixture, both the
                          percentage of oxygen in your tank and the oxygen
                          partial pressure limit must be entered into
                            Suunto EON Core
                          . This ensures correct nitrogen and oxygen
                          calculations and the correct maximum operating depth
                          (MOD), which is based on your entered values. The
                          default oxygen percentage (O
                            2
                          %) setting is 21% (air) and oxygen partial pressure
                          (pO
                            2
                          ) setting is 1.6 bar (23 psi).
                          After customizing in Suunto app, two other views are
                          available:
                          The timer in the top right of the display shows dive
                          time in minutes and seconds and can be activated and
                          stopped by short pressing the upper button. Keep the
                          upper button pressed to reset the timer.
                          Gauge mode is a bottom timer only. It does not use any
                          decompression algorithm, thus it does not include
                          decompression information or calculations.
                          A third view is visible after customizing in Suunto
                          app:
                            Locked time is set back to 48 hours if you start a
                            new dive while your device is locked.
                          Dive planner
                            The dive planner in
                              Suunto EON Core
                            helps you to quickly plan your next dive. The
                            planner displays available no decompression time and
                            gas times for your dive based on depth, tank size
                            and gas consumption set.
                            The dive planner can also help you plan dives in
                            series, taking into account the residual nitrogen
                            from your previous dive(s) based on the planned
                            surface time you enter.
                              It is important to adjust tank size, tank pressure
                              and personal gas consumption to get the gas
                              calculations right.
                            See
                              How to plan a dive using the Dive planner
                            for details on planning your dives.
                          Flip display
                            You can flip the display of
                              Suunto EON Core
                            to have the buttons on either the left or right side
                            of the dive computer, making it easier to wear on
                            either arm.
                            Change the button orientation under
                            General
                              Device settings
                              Flip display
                            Select
                              Buttons right
                            to have the buttons on the right-hand side or
                              Buttons left
                            to have them on the left-hand side.
                          Gas consumption
                            Gas consumption refers to your real-time consumption
                            rate of gas during a dive. In other words, it is the
                            amount of gas a diver would use in one minute on the
                            surface. This is commonly known as your surface air
                            consumption or SAC rate.
                            Gas consumption rate is measured in liters per
                            minute (cubic feet per minute). This is an optional
                            field and needs to be added to your custom dive mode
                            views in Suunto app. In the classic view below, gas
                            consumption rate is in the bottom right corner.
                            For enabling gas consumption metering, see
                              How to enable gas consumption metering
                          Gas mixtures
                            By default,
                              Suunto EON Core
                            has only one gas (air) available. The default oxygen
                            percentage (O
                              2
                            (pO
                              2
                            ) setting is 1.6 bar (23 psi). You can modify O
                              2
                            percentage and pO
                              2
                            settings in
                            Gases
                            menu.
                              When diving with a nitrox gas mixture, Suunto
                              recommends changing the partial pressure to 1.4
                              bar (20 psi).
                            If you are diving with only one gas, ensure you have
                            only that one gas in the
                            Gases
                            menu. Otherwise,
                              Suunto EON Core
                            expects you to use all gases in the list and
                            notifies you to change gases during the dive.
                            If you need more than one gas, activate multi-gas
                            option in your device. Go to
                              Dive settings
                            Parameters
                            and turn on
                              Multiple gases
                            option.
                            You need to define all gas mixtures intended to use
                            during the dive in the
                            Gases
                            menu because during your dive the decompression
                            algorithm calculates ascent time using all gases
                            available in the
                            Gases
                            menu.
                            If you want to use trimix gas mixtures (with helium
                            activated), you need to turn helium on under
                              Dive settings
                            Parameters
                            . When this is done, you can change helium
                            percentage (He%) for the selected gas in the
                            Gases
                            menu.
                            You can activate multi-gas diving and helium,
                            configure dive modes and change gas settings using
                            Suunto app, too.
                          Changing gas during a dive
                            It is important to understand how your
                              Suunto EON Core
                            device works when you dive with multiple gases. For
                            example, you may have the following gases when
                            diving to 55 m (180.5 ft):
                              tx18/45, MOD 62.2 m (pO
                                2
                              1.3)
                              tx50/10, MOD 22 m (pO
                                2
                              1.6)
                            - Nx99, MOD 6 m
                            While ascending, you are notified to change gas at
                            22 m (72 ft) and 6 m (20 ft) according to the
                            maximum operating depth (MOD) of the gas. To take a
                            better gas into use, you need to change gas manually
                            by completing the following steps:
                              Press any button to acknowledge the gas change
                              notification.
                              Long press the middle button to see gas options.
                              Scroll with the upper or lower button to the
                              desired gas.
                              Press the middle button to confirm gas selection.
                              If you press any button while
                                Change gas
                              notification is visible on the device screen, the
                              notification disappears. By pressing a button, you
                              only confirm the notification, but gas is not
                              changed automatically. You should always change
                              gas manually. To change gas, you must follow the
                              above listed steps.
                              When you select CCR, gas mixtures are divided to
                              open-circuit and closed-circuit gases. See
                                Rebreather diving
                          Modifying gases during a dive
                            Modifying the gas list in your device is for
                            emergency cases only. For example, due to unforeseen
                            events, you might lose a gas mixture, in which case
                            you could adjust to the situation by deleting that
                            gas mixture from the gas list of
                              Suunto EON Core
                            . This allows you to continue diving and get correct
                            decompression information calculated by the dive
                            computer.
                            In another case, if for some reason you run out of
                            gas and need to use a gas mixture from a dive buddy,
                            it is possible to adapt
                              Suunto EON Core
                            to the situation by adding the new gas mixture to
                            the list.
                              Suunto EON Core
                            re-calculates decompression and shows the correct
                            information.
                              This feature is not enabled by default, it must be
                              activated and it creates an additional step to the
                              gas menu during the dive. It is only available if
                              multiple gases are selected for the dive mode.
                            To enable modifying gases, turn the feature on in
                            the settings menu under
                              Dive settings
                            Parameters
                              Modify gases
                            When enabled, during a multi-gas dive, you can add a
                            new gas as well as select an existing gas from the
                            gas list to remove it.
                              You cannot modify or remove the gas currently in
                              use (active gas).
                            When
                              Modify gases
                            is turned on, you can remove gases which are not in
                            use from the gas list, add new gases to the list,
                            and modify parameters (O
                              2
                            , He, pO
                              2
                            ) of nonactive gases.
                          Isobaric counterdiffusion (ICD)
                            Isobaric counterdiffusion (ICD) occurs when
                            different inert gases (such as nitrogen and helium)
                            diffuse in different directions during a dive. In
                            other words, one gas is being absorbed by the body
                            while the other is being released. ICD is a risk
                            when diving with trimix mixtures.
                            This may happen during a dive, for example, when
                            trimix gas is switched to nitrox or light trimix.
                            When the switch is made, helium and nitrogen rapidly
                            diffuse in opposite directions. This produces a
                            transient increase in total inert gas pressure which
                            can lead to decompression sickness (DCS).
                            Currently there are no algorithms that can address
                            ICD. Therefore, you need to take it into account
                            when planning trimix dives.
                            You can use
                              Suunto EON Core
                            to plan your trimix usage safely. Under the
                            Gases
                            menu, you can adjust oxygen (O
                              2
                            ) and helium (He) percentages to see the change in
                            partial pressure of nitrogen (ppN2) and the partial
                            pressure of helium (ppHe) values.
                            An increase in partial pressure is indicated by a
                            positive number, and a decrease by a negative
                            number. The changes in ppN2 and ppHe are displayed
                            next to each gas mixture that you want to switch to.
                            Maximum operating depth (MOD) of a breathing gas is
                            the depth at which the partial pressure of oxygen
                            (pO
                              2
                            ) of the gas mix exceeds a safe limit. You can
                            define pO
                              2
                            limit for the gas.
                          An ICD warning is generated when:
                              Gas switch depth is greater than 10 m (33 ft).
                              Geometric mean of the partial pressure change of
                              N2 and partial pressure change of He is bigger
                              than 0.35 bar.
                            If these limits are exceeded with a gas switch,
                              Suunto EON Core
                            indicates the risk of ICD as shown below:
                            In this example, the available gas mixtures for a
                            deep trimix dive are:
                              Trimix 15/55, MOD 76.7 m (pO
                                2
                              1.3)
                              Trimix 35/15, MOD 27.1 m (pO
                                2
                              1.3)
                              Trimix 50/10, MOD 22 m (pO
                                2
                              1.6)
                            - Oxygen, MOD 6 m
                              Suunto EON Core
                            highlights the dangerous ICD condition when the gas
                            mixture switches from 15/55 to 35/15 at a depth of
                            27.1 m.
                            If this gas switch is made, the change in ppN2 and
                            ppHe are far beyond the safe limits.
                            One way to avoid the ICD risk is to increase helium
                            content in the first decompression gas mixture
                            (trimix 35/15) to get a 35/32 trimix mixture. Due to
                            this change, the second decompression gas (trimix
                            50/10) needs more helium to avoid ICD risk. The
                            second decompression gas mixture should be trimix
                            50/12. These modifications would keep the changes in
                            partial pressure at a safe level and remove the
                            danger of sudden ICD.
                          Gas time
                            Gas time refers to remaining air (gas) left with
                            current gas mixture, measured in minutes. The time
                            is based on the tank pressure value and your current
                            breathing rate.
                            Gas time is also highly dependent on your current
                            depth. For example, all other factors being the
                            same, including breathing rate, tank pressure and
                            tank size, depth affects gas time as follows:
                              At 10 m (33 ft, surrounding pressure 2 bar), gas
                              time is 40 minutes.
                              At 30 m (99 ft, surrounding pressure 4 bar), gas
                              time is 20 minutes.
                              At 70 m (230 ft, surrounding pressure 8 bar), gas
                              time is 10 minutes.
                            Gas time information is not visible by default.
                            After customization in Suunto app, the information
                            will be visible in the bottom right corner of the
                            screen. If you have not paired a Suunto Tank POD,
                            the gas time field shows n/a. If you have paired a
                            POD but there is no data being received, the field
                            shows - -. This may be because the POD is not in
                            range, the tank is closed, or the POD battery is
                            low.
                              calculations right. Find these options under
                                Dive planner
                              in the device menu.
                              Language and unit system
                              You can change the device language and unit system
                              any time when you are not diving.
                                Suunto EON Core
                              refreshes immediately to reflect the changes.
                              To set these values, see
                                How to set language and unit
                            Logbook
                              Dive logs can be found under
                              Logs
                              . They are listed by date and time, and each entry
                              listing shows the max. depth and dive time of the
                              log.
                              Dive log details and profile can be browsed by
                              scrolling through the logs with the upper or the
                              lower button and selecting a log with the middle
                              button.
                              Each dive log contains data samples with fixed
                              10-second intervals. The dive profile includes a
                              cursor for browsing the logged data, scrollable
                              with upper and lower buttons. A blue line
                              indicates depth, and a white line shows
                              temperature. If you dive with Tank POD, tank
                              pressure and gas consumption graphs become also
                              visible.
                              The last page of the logbook contains further
                              data. Press the middle button to find average
                              depth, CNS percentage, and OTU value.
                              For more detailed log analyses, upload the dive(s)
                              to the Suunto app.
                              When the logbook memory gets full, the oldest
                              dives are deleted to make space for new ones.
                                If you surface and then dive again within five
                                minutes,
                                  Suunto EON Core
                                counts it as one dive.
                                Oxygen calculations
                                During a dive,
                                  Suunto EON Core
                                calculates partial pressure of oxygen (pO
                                  2
                                ), central nervous system toxicity (CNS%) and
                                pulmonary oxygen toxicity, tracked by oxygen
                                toxicity units (OTU). The oxygen calculations
                                are based on currently accepted exposure time
                                limit tables and principles.
                                By default in Air/Nitrox dive mode, CNS% and OTU
                                values are not displayed until they reach 80% of
                                their recommended limits. When either value
                                reaches 80%,
                                  Suunto EON Core
                                notifies you and the value stays in the view.
                                  You can customize views to always show CNS%
                                  and OTU.
                                  Personal setting
                                  Suunto Fused™ RGBM 2 algorithm provides 5
                                  personal setting options (+2, +1, 0, -1, -2).
                                  These options refer to decompression models.
                                  +2 and +1 can be considered conservative,
                                  while -2 and -1 can be considered aggressive.
                                  0 is the default setting and is neutral, for
                                  ideal conditions. Generally speaking,
                                  conservative means safer. In practice it means
                                  that a dive at a given depth is shorter due to
                                  the decompression obligation (the no
                                  decompression time is short).
                                  Conservative also means that the time the
                                  diver needs to spend on decompression is
                                  longer. For recreational divers, a
                                  conservative model means less time in the
                                  water in order to avoid decompression
                                  requirements. For technical divers, however,
                                  conservative means more time in the water
                                  because of the longer decompression
                                  requirements imposed during ascent.
                                  Aggressive models, on the other hand, increase
                                  the potential health risks of a dive. For
                                  recreational divers, an aggressive model
                                  allows more time at depth, but may
                                  significantly increase the risk of
                                  The default setting for the Suunto Fused™
                                  RGBM and Fused™ RGBM 2 is to use a compromise
                                  (0 setting) between conservative and
                                  aggressive. With the personal setting, you can
                                  select gradually more conservative or more
                                  aggressive calculations.
                                  There are several risk factors that can affect
                                  your susceptibility to DCS like your personal
                                  health and behavior. Such risk factors vary
                                  between divers, as well as from one day to
                                  another.
                                  The personal risk factors which tend to
                                  increase the possibility of DCS include:
                                    exposure to low temperature – water
                                    temperature less than 20 °C (68 °F)
                                  - below average physical fitness level
                                  - age, particularly over the age of 50
                                    fatigue (from over exercising, lack of
                                    sleep, exhausting travel)
                                    dehydration (affects circulation and may
                                    slow down off-gassing)
                                  - stress
                                    tight fitting equipment (may slow down
                                    off-gassing)
                                    obesity (BMI that is considered obese)
                                  - patent foramen ovale (PFO)
                                  - exercise before or after dive
                                    strenuous activity during a dive (increases
                                    bloodflow and brings additional gas to
                                    tissues)
                                  WARNING:
                                    SET THE CORRECT PERSONAL SETTING! Whenever
                                    it is believed that risk factors that tend
                                    to increase the possibility of DCS exist, it
                                    is recommended that you use this option to
                                    make the calculations more conservative.
                                    Failure to select the correct personal
                                    setting will result in erroneous dive and
                                    planning data.
                                  The five-step personal setting can be used to
                                  adjust the algorithm conservatism to fit your
                                  DCS susceptibility. You can find the setting
                                  under
                                    Dive settings
                                    Parameters
                                    Personal
                                      | Personal level |
                                      Explanation |
                                      | More aggressive (-2) |
                                        Ideal conditions, excellent physical
                                        fitness, highly experienced with a lot
                                        of dives in the near past
                                      | Aggressive (-1) |
                                        Ideal conditions, good physical fitness,
                                        well experienced with dives in the near
                                        past
                                      | Default (0) |
                                      Ideal conditions (default value) |
                                      | Conservative (+1) |
                                        Some risk factors or conditions exist
                                      | More conservative (+2) |
                                        Several risk factors or conditions exist
                                  WARNING:
                                    Personal adjustment setting 0, -1 or -2
                                    causes a high risk of DCS, or other personal
                                    injury, and death.
                                    Rebreather diving
                                    You can use
                                      Suunto EON Core
                                    for rebreather diving by customizing your
                                    device in Suunto app. Suunto recommends
                                    using classic or graphical style with
                                    rebreather diving. However, you can use
                                    prominent view and customize fields if
                                    desired.
                                    Fixed setpoint calculation enables
                                      Suunto EON Core
                                    to be used as a backup dive computer on
                                    rebreather dives. It does not control or
                                    monitor the rebreather unit in any way.
                                    When you select your custom multi-gas mode
                                    for CCR (closed-circuit rebreather) diving
                                    in the dive mode setting, your device will
                                    have two different gas menus:
                                      CC gases
                                    (closed-circuit gases) and
                                      OC gases
                                    (open-circuit gases).
                                      For rebreather dives,
                                        Suunto EON Core
                                      should be used as a backup device only.
                                      The primary control and monitoring of your
                                      gases should be done through the
                                      rebreather itself.
                                  Closed-circuit gases
                                    On a rebreather dive, you need at minimum
                                    two closed-circuit gases: one is your pure
                                    oxygen tank, and the other is a diluent. You
                                    can define additional diluents as needed.
                                    You can add only diluent(s) to the gas list.
                                    By default,
                                      Suunto EON Core
                                    assumes that oxygen is used, so it is not
                                    shown in the gas list.
                                    The correct oxygen and helium percentages of
                                    the diluent gases in your diluent
                                    cylinder(s) must always be entered into the
                                    dive computer (or through Suunto app) to
                                    ensure correct tissue and oxygen
                                    calculation. Diluent gases used on a
                                    rebreather dive are found under
                                      CC gases
                                    in the main menu.
                                  Open-circuit gases
                                    As with diluents, you must always define the
                                    bailout gases for all your cylinders (and
                                    additional gases) to ensure correct tissue
                                    and oxygen calculation. Bailout gases for a
                                    rebreather dive are defined under
                                      OC gases
                                    in the main menu.
                                  Setpoints
                                    Your custom rebreather dive mode has two
                                    setpoint values, low and high. Both are
                                    configurable:
                                      Low setpoint: 0.4 – 0.9 (default: 0.7)
                                      High setpoint: 1.0 – 1.5 (default: 1.3)
                                    Typically, you do not need to modify the
                                    default setpoint values. However, you can
                                    change them as needed either in Suunto app
                                    or under the main menu.
                                      To change setpoint values in
                                        Suunto EON Core
                                      While in surface state, keep middle button
                                      pressed to enter main menu.
                                      Scroll to
                                        Setpoint
                                      with the upper button and select with the
                                      middle button.
                                      Scroll to
                                        Low setpoint
                                      or
                                        High setpoint
                                      and select with the middle button.
                                      Adjust the setpoint value with the lower
                                      or upper button and accept with the middle
                                      button.
                                      Keep the middle button pressed to exit
                                      menu.
                                  Setpoint switching
                                    Setpoints can be switched automatically
                                    according to depth. By default, the low
                                    setpoint switch depth is 4.5 m (15 ft), and
                                    the high setpoint switch depth is 21 m (70
                                    ft).
                                    The auto setpoint switching is off by
                                    default for the low setpoint and on for the
                                    high setpoint.
                                      To change auto setpoint switching in
                                        Suunto EON Core
                                      Scroll to
                                        Setpoint
                                      middle button.
                                      Scroll to
                                        Switch low
                                      or
                                        Switch high
                                      Adjust the depth value for the setpoint
                                      switch with the lower or upper button and
                                      accept with the middle button.
                                      menu.
                                    Popup notifications indicate when the
                                    setpoint is switched.
                                    During a rebreather dive, you can also
                                    switch to a custom setpoint at any time.
                                      To change to a custom setpoint:
                                      While diving in a rebreather mode, keep
                                      the middle button pressed to enter main
                                      menu.
                                      Scroll to
                                        Custom setpoint
                                      Adjust the setpoint value as needed with
                                      the lower or upper button and accept with
                                      the middle button.
                                    A popup notification confirms the custom
                                    setpoint switch.
                                      When you change to a custom setpoint, the
                                      automatic setpoint switching is turned off
                                      for the remainder of the dive.
                                  Bailouts
                                    If at any point during a rebreather dive you
                                    suspect a malfunction of any sort, you
                                    should switch to a bailout gas and abort the
                                    dive.
                                      To change to a bailout gas:
                                      Keep the middle button pressed to enter
                                      the main menu.
                                      Scroll to
                                        OC gases
                                      Scroll to the desired bailout gas and
                                    After a bailout gas is selected, the
                                    setpoint field is replaced with the pO
                                      2
                                    value of the selected open-circuit gas.
                                    If the malfunction is rectified or the dive
                                    situation otherwise normalizes, you can
                                    switch back to a diluent using the same
                                    procedure as described above, but selecting
                                    from
                                      CC gases
                                    Safety stops and deepstops
                                    Safety stop and deepstop ceilings are always
                                    at constant depth when you are at the stop.
                                    Safety stop and deepstop times are counted
                                    down in minutes and seconds.
                                  Safety stop
                                    There are two types of safety stops:
                                    voluntary and mandatory. Safety stop is
                                    mandatory if ascent speed violation happened
                                    during the dive. Mandatory safety stop is
                                    shown in red, while voluntary safety stop is
                                    indicated with yellow.
                                    A three (3) minute safety stop is always
                                    recommended for every dive over 10 m (33
                                    ft).
                                    The time for a safety stop is calculated
                                    when you are between 2.4 and 6 m (7.9 and
                                    19.6 ft). This is presented with up/down
                                    arrows on the left side of the stop depth
                                    value. The safety stop time is shown in
                                    minutes and seconds. The time may exceed
                                    three (3) minutes if you ascend too fast
                                    during dive. If violations happened several
                                    times, the additional stop time is longer.
                                    Safety stops can be set to three (3), four
                                    (4), or five (5) minutes.
                                    Voluntary safety stop is shown in yellow:
                                  Mandatory safety stop is shown in red:
                                  Deepstop
                                    Deepstops activate only when you dive deeper
                                    than 20 m (66 ft). During ascend, deepstops
                                    activate when you are halfway up from your
                                    maximum depth. Deepstops are presented like
                                    safety stops. You are in the deepstop area
                                    when the deepstop depth has up/down arrows
                                    in front of it and deepstop time is running.
                                    The deepstop window is +/- 1.5 m (4.9 ft).
                                    Calculation starts at deepstop target depth
                                    plus 0.5 m (1.6 ft). Calculation ends - 3 m
                                    (- 9.8 ft) away from deepstop depth.
                                    There can be more than one deepstop during
                                    ascend. For example, if you dive to 42 m
                                    (137.8 ft), the first deepstop is prompted
                                    at 21 m (68.9 ft) and the second is at 10.5
                                    m (34.4 ft) The second deepstop is 2 minutes
                                    long.
                                    In the following example the diver dives
                                    down to maximum 30.4 m (99.7 ft) and has a
                                    deepstop at 15.2 m (49.9 ft):
                                    Below 20.0 m (66 ft), deepstop gets
                                    activated. In this case, as the diver
                                    ascends, the deepstop is necessary at
                                    halfway of the maximum depth, so at 15.2 m
                                    (49.9 ft).
                                    If the deepstop depth is 15.2 m (49.9 ft),
                                    the calculation starts at 15.7 m (51.5 ft)
                                    and stops at 12.2 m (40.0 ft). The deepstop
                                    window is +/- 1.5 m (4.9 ft) and when the
                                    diver is within the deepstop window, it is
                                    indicated with two white arrows pointing at
                                    each other on the display.
                                    When the diver ascends above the deepstop
                                    window ceiling - in this case above 14.2 m
                                    (46.5 ft) - a downward pointing yellow arrow
                                    signals that the depth is not optimal, it is
                                    recommended to descend. The deepstop target
                                    depth number also turns yellow.
                                    If the diver keeps ascending, after 0.5 m
                                    (1.6 ft), a downward pointing red arrow and
                                    an alarm notify the diver to descend
                                    immediately. The deepstop calculation keeps
                                    running for another 1.5 m (4.9 ft) up but
                                    stops after that. In the above example it
                                      For safety reasons, you cannot switch off
                                      deepstops if helium (trimix gas mixtures)
                                      is enabled for the dive mode in use. When
                                      helium is not in use, deepstops can be
                                      turned on and off. However, it is
                                      recommended that you turn deepstops on for
                                      all dives. If deepstops are turned on but
                                      omitted during a dive, it will affect your
                                      next dive which will be more conservative.
                                      Sample rate
                                        Suunto EON Core
                                      uses a fixed sample rate of 10 seconds for
                                      all log recordings.
                                      Standby and deep sleep
                                      Standby and deep sleep are two functions
                                      that are designed to prolong battery life.
                                      Standby is an adjustable setting that
                                      turns off the screen after a set amount of
                                      time to save battery if
                                        Suunto EON Core
                                      is not used.
                                        To adjust the standby time:
                                        the menu.
                                        Browse to
                                          General
                                          Device settings
                                          Standby
                                        Press the middle button to enter
                                        Standby.
                                        Scroll up/down to select the desired
                                        standby time in minutes.
                                        Press the middle button to save changes
                                        and return to the Device settings menu.
                                        Keep the middle button pressed to exit.
                                    Deep sleep
                                      Deep sleep is a function that prolongs
                                      battery life when
                                        Suunto EON Core
                                      has not been used for some time. Deep
                                      sleep is activated when two days have
                                      passed since:
                                      - No buttons have been pressed
                                      - Dive calculation has ended
                                        Suunto EON Core
                                      wakes up when it is connected to a
                                      PC/charger, when a button is pressed, or
                                      when the water contact gets wet.
                                      Surface and no-fly time
                                      After a dive,
                                        Suunto EON Core
                                      displays surface time since the previous
                                      dive and a countdown time for the
                                      recommended no-fly time. During the no-fly
                                      time you should avoid flying or traveling
                                      to higher altitude.
                                      No-fly time is the minimum surface time
                                      after a dive which is recommended to wait
                                      before flying with an airplane. It is
                                      always at least 12 hours. For desaturation
                                      times shorter than 75 minutes, no-fly time
                                      is not displayed. Maximum no-fly time is
                                      72 hours.
                                      If decompression is omitted during a dive
                                      and the dive algorithm is locked for 48
                                      hours (see
                                        Algorithm lock
                                      ), the no-fly time is always 48 hours.
                                      Similarly, if dive is done in gauge mode
                                      (bottom timer), the no-fly time is 48
                                      hours.
                                      With Suunto Fused™ RGBM 2, selected
                                      personal setting parameter (-2, -1, 0, +1,
                                      +2) is affecting no-fly time. The more
                                      conservative personal setting you have,
                                      the longer no-fly time values you will
                                      see. More aggressive personal setting will
                                      result in shorter no-fly time values.
                                      Once the no-fly time calculated by your
                                        Suunto EON Core
                                      with Suunto Fused™ RGBM 2 has ended, you
                                      can enter and fly with a normal airplane
                                      which is pressurized up to 3000 m.
                                      WARNING:
                                        YOU ARE ADVISED TO AVOID FLYING ANY TIME
                                        THE COMPUTER COUNTS DOWN THE NO-FLY
                                        TIME. ALWAYS ACTIVATE THE COMPUTER TO
                                        CHECK THE REMAINING NO-FLY TIME PRIOR TO
                                        FLYING! Flying or traveling to a higher
                                        altitude within the no-fly time can
                                        greatly increase the risk of DCS. Review
                                        the recommendations given by Divers
                                        Alert Network (DAN). There can never be
                                        a flying-after-diving rule that is
                                        guaranteed to completely prevent
                                        decompression sickness!
                                        Suunto app
                                        With the Suunto app, you can easily
                                        customize device and dive settings. See
                                          Customizing dive modes with Suunto app
                                        and
                                          How to customize dive modes with
                                          Suunto app
                                        You can also transfer your dive logs
                                        wirelessly to the app where you can
                                        follow and share your diving adventures.
                                          To pair with Suunto app on iOS:
                                          Download and install Suunto app on
                                          your compatible Apple device from the
                                          App Store. The app description
                                          includes the latest compatibility
                                          information.
                                          Start Suunto app and turn on Bluetooth
                                          if it is not on already. Leave the app
                                          running in the foreground.
                                          If you have not yet set up your
                                            Suunto EON Core
                                          , do so now (see
                                            Getting started
                                          Tap the watch icon in the upper left
                                          corner of the screen and tap on the '
                                          + ' icon to add a new device.
                                          Select your dive computer from the
                                          list of found devices, tap
                                          PAIR
                                          Enter the passkey shown on your dive
                                          computer display into the pairing
                                          request field on your mobile device.
                                          Tap
                                          PAIR
                                          at the bottom of the request field.
                                          To pair with Suunto app on Android:
                                          your compatible Android device from
                                          Google Play. The app description
                                          information.
                                            Suunto EON Core
                                          , do so now (see
                                            Getting started
                                          Tap the watch icon in the upper right
                                          corner of the screen.
                                          list of found devices and tap
                                          PAIR
                                          Tap
                                          PAIR
                                          You cannot pair any device if airplane
                                          mode is on. Turn off airplane mode
                                          before pairing.
                                      Synchronizing logs and settings
                                        To be able to synchronize logs and
                                        settings, first you need to install
                                        Suunto app.
                                          To download logs from your
                                            Suunto EON Core
                                          and sync settings:
                                          Connect
                                            Suunto EON Core
                                          to your mobile device via Bluetooth.
                                        - Start Suunto app.
                                          Wait for the syncing to complete.
                                        New dive logs appear in your activity
                                        history, sorted by date and time.
                                        SuuntoLink
                                        Use SuuntoLink to update the software of
                                        your
                                          Suunto EON Core
                                        . Download and install SuuntoLink on
                                        your PC or Mac.
                                        We strongly recommend updating your
                                        device when a new software release is
                                        available. If an update is available,
                                        you are notified via SuuntoLink and in
                                        the Suunto app.
                                        Visit
                                          SuuntoLink
                                        for further information.
                                        To update your dive computer software:
                                          Plug your
                                            Suunto EON Core
                                          into the computer with the supplied
                                          USB cable.
                                          Start SuuntoLink if it is not already
                                          running.
                                          Click the update button in SuuntoLink.
                                          To sync your dives, connect the device
                                          to Suunto app before the software
                                          update.
                                          Tank pressure
                                          Your
                                            Suunto EON Core
                                          can be used with the total number of
                                          twenty (20) gases, each of which may
                                          have Suunto Tank POD for wireless tank
                                          pressure transmission.
                                          To install and pair a Suunto Tank POD,
                                          see
                                            How to install and pair a Suunto
                                            Tank POD
                                          In tank pressure view you can see the
                                          below screens.
                                          The following example has the tank
                                          pressure alarm set to 100 bars. The
                                          tank pressure is 75 bars as indicated
                                          in the switch window in the bottom
                                          right corner.
                                          In the switch window, the actual tank
                                          pressure is shown in blue by default.
                                          Tank pressure is shown in yellow when
                                          it is over 50 bars and below the tank
                                          pressure alarm value set by the user:
                                          When the tank pressure drops below 50
                                          bars, the actual tank pressure value
                                          is indicated in red in the switch
                                          window and a mandatory alarm is
                                          triggered:
                                        Timer
                                            Suunto EON Core
                                          has a timer that can be used for
                                          timing specific actions during surface
                                          or dive. The timer is shown in the
                                          bottom right corner as a scrollable
                                          item.
                                            In timer view, the timer is
                                            displayed as an analog watch.
                                            To use the timer:
                                            Press the upper button to start the
                                            timer.
                                            Press the upper button again to
                                            pause the timer.
                                            Keep the upper button pressed to
                                            reset the timer.
                                          Timer start and stop actions are saved
                                          in the dive log.
                                            The water contact is located on the
                                            side of the case near the USB cable
                                            port. When submerged, the water
                                            contact poles are connected by the
                                            conductivity of the water.
                                            Suunto EON Core
                                          switches to dive state when water is
                                          detected. Dive starts
                                            when the water contact is on, at 1.2
                                            m (4 ft), or
                                            when the water contact is not on, at
                                            3.0 m (10 ft)
                                        and ends
                                            when the water contact is on and
                                            your depth is less than 1.2 m (4
                                            ft), or
                                            when the water contact is not on and
                                            your depth is at 3.0 m (10 ft).
                                          When water contact is active, the
                                          color of the depth reading digits
                                          turns white.
