SUUNTO SPARTAN ULTRA
Download PDF
SAFETY
SAFETY
Types of safety precautions
WARNING:
- is used in connection with a procedure or situation that may result in serious injury or death.
CAUTION:
- is used in connection with a procedure or situation that will result in damage to the product.
- is used to emphasize important information.
- is used for extra tips on how to utilize the features and functions of the device.
Safety precautions
WARNING:
Keep the USB cable away from medical devices such as pacemakers, as well as key cards, credit cards and similar items. The USB cable device connector includes a strong magnet which may interfere with the operation of medical or other electronic devices and items with magnetically stored data.
WARNING:
Allergic reactions or skin irritations may occur when the product is in contact with skin, even though our products comply with industry standards. In such event, stop use immediately and consult a doctor.
WARNING:
Always consult your doctor before beginning an exercise program. Overexertion may cause serious injury.
WARNING:
Only for recreational use.
WARNING:
Do not entirely rely on the GPS or battery lifetime of the product. Always use maps and other backup material to ensure your safety.
CAUTION:
Do not apply solvent of any kind to the product, as it may damage the surface.
CAUTION:
Do not apply insect repellent on the product, as it may damage the surface.
CAUTION:
Do not throw the product away, but treat it as electronic waste to preserve the environment.
CAUTION:
Do not knock or drop the product, as it may get damaged.
At Suunto we use advanced sensors and algorithms to generate metrics that can help you in your activities and adventures. We strive to be as accurate as possible. However, none of the data our products and services collect is perfectly reliable, nor are the metrics they generate absolutely precise. Calories, heart rate, location, movement detection, shot recognition, physical stress indicators and other measurements may not match the real world. Suunto products and services are intended for recreational use only and are not meant for medical purposes of any kind.
GETTING STARTED
SuuntoLink
Download and install SuuntoLink on your PC or Mac to update your watch software.
We strongly recommend updating your watch when a new software release is available. If an update is available, you are notified via SuuntoLink as well as the Suunto app.
Visit SuuntoLink for further information.
To update your watch software:
- Plug your watch into the computer with the supplied USB cable.
 - Start SuuntoLink if it is not already running.
 - Click the update button in SuuntoLink.
Software updates
Software updates for your watch bring new features and important improvements. We strongly recommend updating your watch as soon as an update is available.
If an update is available, you are notified via SuuntoLink and Suunto app (when you have the watch connected).
Suunto app
With the Suunto app, you can further enrich your Suunto Spartan Ultra experience. Pair your watch with the mobile app to sync your activities, get mobile notifications, customize your watch, get training insights and more.
With any exercise that is stored in Suunto app, you can add pictures as well as create Relive movies of your training sessions.
You cannot pair anything if airplane mode is on. Turn off airplane mode before pairing.
To pair your watch with Suunto app:
- Ensure your watch Bluetooth is on. Under the settings menu, go to Connectivity » Discovery and enable it if it is not already.
 - Download and install Suunto app on your compatible mobile device from the iTunes App Store, Google Play in addition to several popular app stores in China.
 - Start Suunto app and turn on Bluetooth if it is not on already.
 - Tap the watch icon in the upper-left of the app screen and then tap PAIR to pair your watch.
 - Verify the pairing by typing the code that is displayed on your watch in the app.
Some features require an internet connection over Wi-Fi or mobile network. Carrier data connection fees may apply.
Touch screen and buttons
Suunto Spartan Ultra has a touch screen and three buttons you can use to navigate through displays and features.
Swipe and tap
- swipe up or down to move in displays and menus
 - swipe right and left to backwards and forwards in displays
 - swipe left or right to see additional displays and details
 - tap to select an item
 - tap the display to view alternate information
 - tap and hold to open in-context options menu
 - double-tap to return to time display from other displays
Upper button
- press to move up in views and menus
Middle button
- press to select an item
 - press to press to change displays
 - keep pressed to got back in settings menu
 - keep pressed to open in-context options menu
Lower button
- press to move down in views and menus
While recording an exercise:
Upper button
- press to pause or resume recording
 - keep pressed to change activity
Middle button
- press to change displays
Lower button
- press to mark a lap
 - keep pressed to lock and unlock buttons
Icons
Suunto Spartan Ultra uses the following icons:
| Airplane mode | |
| Altitude | |
| Altitude difference | |
| Ascent | |
| Back; go back in menu | |
| Button lock | |
| Cadence | |
| Calibrate (compass) | |
| Calories | |
| Current location (navigation) | |
| Charging | |
| Descent | |
| Distance | |
| Duration | |
| EPOC | |
| Estimated VO2 | |
| Exercise | |
| Failure | |
| Flat time | |
| GPS acquired | |
| Heading (navigation) | |
| Heart rate | |
| HR sensor signal acquired | |
| HR signal from HR sensor acquired | |
| Incoming call | |
| Logbook | |
| Low battery | |
| Message/notification | |
| Missed call | |
| Navigation | |
| Pace | |
| POD signal acquired | |
| Power POD signal acquired | |
| Peak Training Effect | |
| Recovery time | |
| Steps | |
| Stopwatch | |
| Stroke rate (swimming) | |
| Success | |
| SWOLF | |
| Syncing | |
| Settings | |
| Training | |
| Temperature | |
| Storm alarm | |
| Barometer |
Adjusting settings
You can adjust all watch settings directly in the watch.
To adjust a setting:
- Swipe down until you see the settings icon and tap the icon.
- Scroll through the settings menu by swiping up or down or by pressing the upper or lower buttons.
- Select a setting by tapping the setting name or pressing the middle button when the setting is highlighted. Go back in the menu by swiping right or selecting Back .
 - For settings with a value range, change the value by swiping up or down or by pressing the upper or lower button.
- For settings with just two values, such as on or off, change the value by tapping the setting or pressing the middle button.
You can also access general settings from the watch face by tapping and holding your finger on the screen to open the in-context menu.
FEATURES
Activity monitoring
Your watch keeps track of your overall activity level throughout the day. This is an important factor whether you just aim to be fit and healthy or you are training for an upcoming competition.
It is good to be active, but when training hard, you need to have proper rest days with low activity.
The activity counter automatically resets at midnight every day. At the end of the week (Sunday), the watch provides a summary of your activity showing your average for the week and daily totals.
From the watch face display, swipe up or press the lower button to see your total steps for the day.
Your watch counts steps using an accelerometer. The total step count accumulates 24/7, also while recording training sessions and other activities. However, with some specific sports, such as swimming and cycling, steps are not counted.
In addition to steps, you can tap on the display to see estimated calories for the day.
The large number in the center of the display is the estimated amount of active calories you have burned so far during the day. Below this you see the total calories burned. The total includes both active calories and your Basal Metabolic Rate (see below).
The ring in both displays indicates how close you are to your daily activity goals. These targets can be adjusted to your personal preferences (see below)
You can also check your steps over the last seven days with a swipe to the left. Swipe left or press the middle button again to see calories consumption.
Swipe up to check your activity over the last seven days in numbers instead of a graph.
Activity goals
You can adjust your daily goals for both steps and calories. While in the activity display, tap and hold your finger on the screen or keep the middle button pressed to open the activity goal settings.
When setting your steps goal, you define the total number of steps for the day.
The total calories you burn per day is based on two factors: your Basal Metabolic Rate (BMR) and your physical activity.
Your BMR is the amount of calories your body burns while at rest. These are the calories your body needs to stay warm and perform basic function like blink your eyes or beat your heart. This number is based on your personal profile, including factors such as age and gender.
When you set a calorie goal, you define how many calories you want to burn in addition to your BMR. These are your so-called active calories. The ring around the activity display advances according to how many active calories you burn during the day compared to your goal.
Airplane mode
Activate airplane mode when needed to turn off wireless transmissions. You can activate or deactivate airplane mode from the settings under Connectivity .
To pair anything with your device, you need to first turn off airplane mode if you have it on.
Altimeter
Suunto Spartan Ultra uses barometric pressure to measure altitude. To get accurate readings, you need to define an altitude reference point. This can be your current elevation if you know the exact value. Alternatively, you can use FusedAlti (see FusedAlti) to set your reference point automatically.
Set your reference point from the settings under Outdoor .
FusedAlti
FusedAlti
By default, altitude is measured with FusedAlti during exercises that use GPS and during navigation. When GPS is switched off, altitude is measured with the barometric sensor.
Autopause
Autopause pauses the recording of your exercise when your speed is less than 2 km/h (1.2 mph). When your speed increases to more than 3 km/h (1.9 mph), the recording continues automatically.
You can turn autopause on/off for each sport mode the sport mode settings in the watch before you start your exercise recording.
If autopause is on during a recording, a pop-up notifies you when the recording is paused automatically.
Tap the resume pop-up to see and switch between the current distance, HR, time, battery level.
You can let the recording resume automatically when you start moving again, or manually resume from the pop-up screen by pressing the upper button.
Backlight
The backlight has two modes: automatic and toggle. In automatic mode, the backlight comes on with any screen touch or button press.
If the watch been idle for 60 seconds or more, the backlight can only be activated by a button press.
In toggle mode, you turn the backlight on with a two-finger tap. The backlight stays on until you tap with two fingers again.
By default, the backlight is in automatic mode. You can change the backlight mode as well as the backlight brightness from the settings under General » Backlight .
Backlight brightness affects battery life. The brighter the backlight is, the quicker the battery drains.
Standby backlight
When you are not actively using the watch by touching the screen or pressing buttons, the watch goes into a standby mode after one minute. The display is on, but in some low-light conditions, the screen might not be easily readable.
To improve readability in low-light conditions, you can use the standby backlight. This is a low-brightness backlight that is on all the time.
You can toggle the standby backlight on or off from the settings under General » Backlight » Standby .
Even though the standby backlight brightness is quite low, it decreases overall battery life because it is on all the time.
Bluetooth connectivity
Suunto Spartan Ultra uses Bluetooth technology to send and receive information from your mobile device when you have paired your watch with the Suunto app. Same technology is also used when pairing PODs and sensors.
However, if you do not want your watch to be visible for Bluetooth scanners, you can activate or deactivate the discovery setting from the settings under Connectivity » Discovery .
The Bluetooth can also be completely turned off by activating airplane mode, see Airplane mode.
Button and screen lock
While recording an exercise you can lock the buttons by keeping the lower right button pressed. Once locked, you cannot perform any actions that requires button interaction (create laps, pause/end exercise etc.) but it is possible to scroll the display views and you can turn on the backlight with any button press if the backlight is in automatic mode.
To unlock everything, keep the lower right button pressed again.
When you are not recording an exercise, the screen locks and dims after one minute of inactivity. To activate the screen, press any button.
The screen also goes to sleep (blank) after a period of inactivity. Any movement turns the screen on again.
Compass
Suunto Spartan Ultra has a digital compass that allows you to orient yourself in relation to magnetic north. The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
You can access the compass from the launcher under Navigation » Compass .
The compass display includes the following information:
- Arrow pointing to magnetic north
 - Heading cardinal
 - Heading in degrees
 - Time of day (local time) or battery level; tap on screen to change views
To exit the compass, swipe right or keep the middle button pressed.
While you are in the compass display, you can swipe up from the bottom of the screen or press the lower button to open a list of shortcuts. The shortcuts give you quick access to navigation actions such as checking the coordinates of your current location or selecting a route to navigate.
Swipe down or press the upper button to exit the list of shortcuts.
Calibrating compass
If the compass is not calibrated, you are prompted to calibrate the compass when you enter the compass display.
If you want to re-calibrate the compass, you can start the calibration again from the settings under Navigation » Navigation settings » Calibrate compass .
Setting declination
To ensure correct compass readings, set an accurate declination value.
Paper maps point to true north. Compasses, however, point to magnetic north – a region above the Earth where the Earth’s magnetic fields pull. Because magnetic North and true North are not at the same location, you must set the declination on your compass. The angle in between magnetic and true north is your declination.
The declination value appears on most maps. The location of magnetic north changes yearly, so the most accurate and up-to-date declination value can be found from websites such as www.magnetic-declination.com ).
Orienteering maps, however, are drawn in relation to magnetic north. If you are using an orienteering map, you need to turn the declination correction off by setting the declination value to 0 degrees.
You can set your declination value from the settings under Navigation » Navigation settings » Declination .
Device info
You can check details of your watch software and hardware from the settings under General » About .
Display theme
To increase the readability of your watch screen while exercising or navigating, you can change between light and dark themes.
With the light theme, the display background is light and the numbers dark.
With the dark theme, the contrast is reverse, with the background dark and the numbers light.
The theme is a global setting that you can change in your watch from any of your sport mode options.
To change display theme in sport mode options:
- Go to any sport mode and swipe up or press the lower button to open the sport mode options.
 - Scroll down to Theme and press the middle button.
 - Switch between Light and Dark by swiping up or down or by pressing the upper and lower buttons, and accept with the middle button.
 - Scroll back up to exit the sport mode options, and start (or exit) the sport mode.
Do Not Disturb mode
The Do Not Disturb mode is a setting that mutes all sounds and vibrations and dims the screen, making it a very useful option when wearing the watch in, for example, a theater or any environment where you want the watch to operate as usual, but silently.
To turn on/off the Do Not Disturb mode:
- From the watch face, keep the middle button pressed to open the shortcuts menu.
 - Swipe up or press the lower button to scroll down to the Do Not Disturb mode.
 - Tap the screen or press the middle button to confirm your selection.
If you have an alarm set, it sounds as normal and disables Do Not Disturb mode unless you snooze the alarm.
Feeling
If you are training regularly, following how you feel after each session is an important indicator of your overall physical condition. A coach or personal trainer can also use your feeling trend to track your progress over time.
There are five degrees of feeling to choose from:
- Poor
 - Average
 - Good
 - Very good
 - Excellent
What these options mean exactly are up to you (and your coach) to decide. The important thing is that you use them consistently.
For each training session, you can record how you felt in the watch directly after stopping the recording by answering the ' How was it? ' question.
You can skip answering the question by pressing the middle button.
Find back
If you are using GPS when recording an activity, Suunto Spartan Ultra automatically saves the starting point of your exercise. With Find back, Suunto Spartan Ultra can guide you directly back to your starting point.
To start Find back:
- Start an exercise with GPS.
 - Swipe left or press the middle button until you have reached the navigation display.
 - Swipe up or press the lower button to open the shortcut menu.
Scroll to Find back and tap the screen or press the middle button to select.
The navigation guidance is shown as the last display on the selected sport mode.
To view additional details about your current position:
- From the Find back view, swipe up or press the lower button to open the shortcut menu.
Select Details .
Swipe up or press the lower button to scroll through the list.
Swipe right or press the middle button to exit the details view.
FusedSpeed
FusedSpeed
FusedSpeed benefits you the most when you need highly reactive speed readings during training, for example, when running on uneven terrain or during interval training. If you temporarily lose the GPS signal, for example, Suunto Spartan Ultra is able to continue showing accurate speed readings with the help of the GPS calibrated accelerometer.
To get the most accurate readings with FusedSpeed, only glance shortly at the watch when needed. Holding the watch in front of you without moving it reduces the accuracy.
FusedSpeed is automatically enabled for running and other similar types of activities, such as orienteering, floor ball and football (soccer).
GLONASS
GLONASS (Global Navigation Satellite System) is an alternative positioning system to GPS. With GLONASS enabled, your watch may record a more accurate track in certain conditions. Particularly in urban areas with tall buildings, GLONASS can improve track accuracy. In other areas, it is typically best to leave GLONASS disabled. With GLONASS enabled, your watch consumes more battery life.
To toggle GLONASS on/off:
- Select a sport mode that uses GPS.
 - Open the options menu and scroll down until you reach GLONASS.
 - Press the middle button to toggle the setting on or off.
The GLONASS setting is a global setting. When you enable it, GLONASS is activated for all sport modes with GPS.
GPS accuracy and power saving
The GPS fix rate determines the accuracy of your track - the shorter the interval is between fixes, the better the track accuracy is. Each GPS fix is recorded in your log when recording an exercise.
The GPS fix rate also directly affects battery life. By reducing GPS accuracy, you can extend the battery life of your watch.
The GPS accuracy options are:
- Best : ~ 1 sec fix rate with full power
 - Good : ~ 1 sec fix rate with low power
 - OK : ~ 60 sec fix rate with full power
When set to Best , your watch is using GPS at full power all the time. In full power mode, the GPS is able to filter out interference and get the best fix. This results in the best track accuracy, but also use the battery the most.
By using Good , you can still get GPS fix every second, but the accuracy is reduced because the GPS is not in full power mode all the time. Between fixes, the GPS goes into a low power mode for a short time, as illustrated below.
This extends battery life, but it means the GPS has less time to find a good fix and filter out interference. So the resulting track is not as accurate as with Best .
With OK, the GPS fix rate is reduced to once every minute. This significantly increases battery life, but results in a less accurate track.
Whenever you navigate a route or a POI, the GPS accuracy is automatically set to Best .
Heart rate sensor
You can use a Bluetooth® Smart compatible heart rate sensor, such as the Suunto Smart Sensor, with your Suunto Spartan Ultra to get accurate information about your exercise intensity.
If you use the Suunto Smart Sensor, you also have the added advantage of heart rate memory. The sensor memory function buffers data if the connection to your watch is interrupted, for example, when swimming (no transmission under water).
It also means you can even leave your watch behind after starting a recording. For more information, please refer to the Suunto Smart Sensor User Guide.
Without a heart rate sensor, your Suunto Spartan Ultra provides calorie consumption and recovery time for running activities where speed is used to estimate intensity. However, we recommend using a heart rate sensor to get accurate intensity readings.
Refer to the user guide for Suunto Smart Sensor or other Bluetooth® Smart compatible heart rate sensor for additional information.
See Pairing PODs and sensors for instructions on how to pair an HR sensor with your watch.
Intensity zones
Using intensity zones for exercising helps guide your fitness development. Each intensity zone stresses your body in different ways, leading to different effects on your physical fitness. There are five different zones, numbered 1 (lowest) to 5 (highest), defined as percentage ranges based on your maximum heart rate (max HR), pace or power.
It is important to train with intensity in mind and understand how that intensity should feel. And don't forget, regardless of your planned training, that you should always take time to warm up before an exercise.
The five different intensity zones used in Suunto Spartan Ultra are:
Zone 1: Easy
Exercising in zone 1 is relatively easy on your body. When it comes to fitness training, intensity this low is significant mainly in restorative training and improving your basic fitness when you are just beginning to exercise, or after a long break. Everyday exercise – walking, climbing stairs, cycling to work, etc. – is usually performed within this intensity zone.
Zone 2: Moderate
Exercising at zone 2 improves your basic fitness level effectively. Exercising at this intensity feels easy, but workouts with a long duration can have a very high training effect. The majority of cardiovascular conditioning training should be performed within this zone. Improving basic fitness builds a foundation for other exercise and prepares your system for more energetic activity. Long duration workouts at this zone consume a lot of energy, especially from your body’s stored fat.
Zone 3: Hard
Exercising at zone 3 begins to be quite energetic and feels like pretty hard going. It will improve your ability to move quickly and economically. In this zone, lactic acid begins to form in your system, but your body is still able to completely flush it out. You should train at this intensity at most a couple of times per week, as it puts your body under a lot of stress.
Zone 4: Very hard
Exercising at zone 4 will prepare your system for competition type events and high speeds. Workouts in this zone can be performed either at constant speed or as interval training (combinations of shorter training phases with intermittent breaks). High-intensity training develops your fitness level quickly and effectively, but done too often or at too high intensity may lead to overtraining, which may force you to take a long break from your training program.
Zone 5: Maximal
When your heart rate during a workout reaches zone 5, the training will feel extremely hard. Lactic acid will build up in your system much faster than it can be removed, and you will be forced to stop after a few minutes at most. Athletes include these maximum-intensity workouts in their training program in a very controlled manner, fitness enthusiasts do not require them at all.
Heart rate zones
Heart rate zones are defined as percentage ranges based on your maximum heart rate (max HR).
By default, your max HR is calculated using the standard equation: 220 - your age. If you know your exact max HR, you should adjust the default value accordingly.
Suunto Spartan Ultra has default and activity-specific HR zones. The default zones can be used for all activities, but for more advanced training, you can use specific HR zones for running and cycling activities.
Set max HR
Set your maximum HR from the settings under Training » Intensity zones » Default zones .
- Tap the max HR (highest value, bpm) or press the middle button.
 - Select your new max HR by swiping up or down or by pressing the upper right or lower right buttons.
- Tap your selection or press the middle button.
 - To exit the HR zones view, swipe right or keep the middle button pressed.
You can also set your maximum HR from the settings under General » Personal .
Set default HR zones
Set your default HR zones from the settings under Training » Intensity zones » Default zones .
- Scroll up/down and tap or press the middle button when the HR zone you want to change is highlighted.
 - Select your new HR zone by swiping up or down or by pressing the upper right or lower right buttons.
NOTE:Selecting Reset in the HR zones view will reset the HR zones to the default value.
Set activity specific HR zones
Set your activity specific HR zones from the settings under Training » Intensity zones » Advanced zones .
- Tap the activity (running or cycling) that you want to edit or press the middle button when the activity is highlighted.
 - Press the middle button to toggle the HR zones on.
Using HR zones when exercising
When you record an exercise (see Recording an exercise), and have selected heart rate as an intensity target (see Using targets when exercising), an HR zone gauge, divided into five sections, is shown around the outer edge of the sport mode display (for all sport modes that support HR). The gauge indicates in which HR zone you are currently training by lighting up the corresponding section. The small arrow in the gauge indicates where you are within the zone range.
Your watch alerts you when you hit your selected target zone. During your exercise the watch will prompt you to speed up or slow down, if your heart rate is outside the selected target zone.
In addition, there is a dedicated display for HR zones in the sport mode default display. The zone display shows your current HR zone in the middle field, how long you have been in that zone, and how far away you are in beats per minute to the next zones up or down. The background color of the bar also indicates which HR zone you are training in.
In the exercise summary, you get a breakdown of how much time you have spent in each zone.
Pace zones
Pace zones work just like HR zones but the intensity of your training is based on your pace instead of your heart rate. The pace zones are shown either as metric or imperial value depending on your settings.
Suunto Spartan Ultra has five default pace zones that you can use or you can define your own.
Pace zones are available for running and cycling.
Set pace zones
Set your activity specific pace zones from the settings under Training » Intensity zones » Advanced zones .
- Tap Running or Cycling or press the middle button.
 - Swipe or press the lower button and select pace zones.
 - Swipe up/down or press the upper or lower buttons and press the middle button when the pace zone you want to change is highlighted.
Select your new pace zone by swiping up/down or by pressing the upper or lower buttons.
Press the middle button to select the new pace zone value.
 - Swipe right or press and hold the middle button to exit the pace zones view.
Using pace zones when exercising
When you record an exercise (see Recording an exercise ), and have selected pace as an intensity target (see Using targets when exercising ) a pace zone gauge, divided into five sections, is viewed. These five sections are shown around the outer edge of the sport mode display. The gauge indicates the pace zone you have chosen as an intensity target by lighting up the corresponding section. The small arrow in the gauge indicates where you are within the zone range.
Your watch alerts you when you hit your selected target zone. During your exercise the watch will prompt you to speed up or slow down, if your pace is outside the selected target zone.
In addition, there is a dedicated display for pace zones in the sport mode default display. The zone display shows your current pace zone in the middle field, how long you have been in that zone, and how far away you are in pace to the next zones up or down. The middle bar also lights up, indicating that you are training in the correct pace zone.
Power zones
Power meter measures the amount of physical effort needed to perform a certain activity. The effort is measured in watts. The main advantage gained with a power meter is precision. The power meter reveals exactly how hard you really work and how much power you produce. It is also easy to see your progress when analyzing the watts.
Power zones can help you train with the correct power output.
Suunto Spartan Ultra has five default power zones that you can use or you can define your own.
Power zones are available in all default sport modes for cycling, indoor cycling and mountain biking. For running and trail running, you need to use the specific “Power” sport modes to get power zones. If you are using custom sport modes, make sure your mode uses a power POD so that you also get power zones.
Set activity specific power zones
Set your activity specific power zones from the settings under Training » Intensity zones » Advanced zones .
 - Swipe up or press the lower button and select power zones.
 - Swipe up/down or press the upper or lower buttons and select the power zone you want to edit.
Select your new power zone by swiping up/down or by pressing the upper or lower buttons.
Press the middle button to select the new power value.
 - Swipe right or press and hold the middle button to exit the power zones view.
Using power zones when exercising
You need to have a power pod paired with your watch to be able to use power zones when exercising, see Pairing PODs and sensors .
When you record an exercise (see Recording an exercise ), and have selected power as an intensity target (see Using targets when exercising ) a power zone gauge, divided into five sections, is viewed. These five sections are shown around the outer edge of the sport mode display. The gauge indicates the power zone you have chosen as an intensity target by lighting up the corresponding section. The small arrow in the gauge indicates where you are within the zone range.
Your watch alerts you when you hit your selected target zone. During your exercise the watch will pormpt you to speed up or slow down, if your power is outside the selected target zone.
In addition, there is a dedicated display for power zones in the sport mode default display. The zone display shows your current power zone in the middle field, how long you have been in that zone, and how far away you are in power to the next zones up or down. The middle bar also lights up, indicating that you are training in the correct pace zone.
Interval training
Interval workouts are a common form of training consisting of repetitive sets of high and low intensity efforts. With Suunto Spartan Ultra , you can define in the watch your own interval training for each sport mode.
When defining your intervals, you have four items to set:
- Intervals: on/off toggle that enables interval training. When you toggle this on, an interval training display is added to your sport mode.
 - Repetitions: the number of interval + recovery sets you want to do.
 - Interval: the length of your high intensity interval, based on distance or duration.
 - Recovery: the length of your rest period between intervals, based on distance or duration.
Keep in mind that if you use distance to define your intervals, you need to be in a sport mode that measures distance. The measurement can be based on GPS, or from a foot or bike POD, for example.
If you are using intervals, you cannot activate navigation.
To train with intervals:
- Before you start an exercise recording, swipe up or press the lower button to open the sport mode options.
 - Scroll down to Intervals and tap the setting or press the middle button.
Toggle intervals on and adjust the settings described above.
Scroll back up to the start view and start your exercise as normal.
Swipe left or press the middle button until you reach the intervals display and press the upper button when you are ready to start your interval training.
If you want to stop the interval training before you have completed all your repetitions, keep the middle button pressed to open the sport mode options and toggle off Intervals .
While you are in the intervals display, buttons work as normal, for example, pressing the upper button pauses the exercise recording, not just the interval training.
After you have stopped your exercise recording, interval training is automatically toggled off for that sport mode. The other settings, however, are maintained so you can easily start the same workout the next time you use the sport mode.
Language and unit system
You can change your watch language and unit system from the settings under General » Language .
Logbook
You can access the logbook from the launcher or by swiping right when in the training insight display.
Tap on the log entry you want to view and scroll through log by swiping up or down or by pressing the upper right or lower right buttons.
The log icon remains gray until the exercise has been synced with Suunto app.
To exit the log, swipe right or keep the middle button pressed. You can also just double-tap on the screen to return to the watch face.
Moon phases
In addition to sunrise and sunset times, your watch can track moon phases. The moon phase is based on date you have set in your watch.
The moon phase is available as a view in the outdoor style watch face. Tap on the screen to change the lower row until you see the moon icon and percentage.
The phases are presented as an icon with percentage as follows:
Notifications
If you have paired your watch with the Suunto app, you can receive notifications such as in-coming calls and text messages on your watch.
When you pair your watch with the app, notifications are on by default. You can turn them off from the settings under Notifications.
When a notification arrives, a pop-up appears on the watch face.
If the message doesn't fit on the screen, swipe up to scroll through the full text.
Notification history
If you have unread notifications or missed calls on your mobile device, you can view them on your watch.
From the watch face, press the middle button and then press the lower button to scroll through the notification history.
The notification history is cleared when you check the messages on your mobile device.
Outdoor insight
Suunto Spartan Ultra constantly measures absolute air pressure using the built-in pressure sensor. Based on this measurement and your altitude reference value, it calculates altitude or air pressure.
CAUTION:
Keep the area around the air pressure sensor holes on the left-side of your watch free of dirt and sand. Never insert any objects into the holes as this may damage the sensor.
Swipe up or press the lower button to view the current altitude and barometric pressure.
Tap to view the current temperature.
Swipe left or press the middle button to switch between altimeter and barometer trend graphs.
Make sure you have set your altitude reference value correctly (see Altimeter). The altitude of your current location can be read from most topographic maps or major on-line map services such as Google Maps.
Changes in local weather conditions affect altitude readings. If local weather changes often, you should reset the altitude reference value regularly, preferably before starting your next journey.
While in the altitude and barometric pressure view, keep the middle button pressed for quick access to the outdoor settings where you can adjust the reference value.
Automatic alti-baro profile
Weather and altitude changes both cause a change in air pressure. To handle this, Suunto Spartan Ultra automatically switches between interpreting changes in air pressure as altitude or weather changes based on your movement.
If your watch senses vertical movement, it switches to altitude measuring. When you are viewing the altitude graph, it is updated with a maximum delay of 10 seconds.
If you are at a constant altitude (less than 5 meters of vertical movement within 12 minutes), your watch interprets air pressure changes as weather changes and adjusts the barometer graph accordingly.
Pair your watch with Bluetooth Smart PODs and sensors to collect additional information, such as cycling power, when recording an exercise.
Suunto Spartan Ultra supports the following types of PODs and sensors:
- Heart rate
 - Bike
 - Power
 - Foot
You cannot pair anything if airplane mode is on. Turn off airplane mode before pairing. See Airplane mode .
To pair a POD or sensor:
- Go to your watch settings and select Connectivity .
 - Select Pair sensor to get the list of sensor types.
 - Swipe down to see the whole list and tap on the sensor type you want to pair.
- Follow the instructions in the watch to complete pairing (refer to sensor or POD manual if needed), pressing the middle button to advance to the next step.
If the POD has required settings, such as crank length for a power POD, you are prompted to enter a value during the pairing process.
Once the POD or sensor is paired, your watch searches for it as soon as you select a sport mode that uses that sensor type.
You can see the full list of paired devices in your watch from the settings under Connectivity » Paired devices .
From this list, you can remove (unpair) the device if needed. Select the device you want to remove, and tap Forget .
Calibrating bike POD
For bike PODs, you need to set the wheel circumference in your watch. The circumference shall be in millimeters and it is done as a step in the calibration. If you change the wheels (with new circumference) of your bike, the wheel circumference setting in the watch must also be changed.
To change the wheel circumference:
- In settings, go to Connectivity » Paired devices .
 - Select Bike POD .
 - Select the new wheel circumference.
Calibrating foot POD
When you pair a foot POD, your watch automatically calibrates the POD using GPS. We recommend using the automatic calibration, but you can disable it if needed from the POD settings under Connectivity » Paired devices .
For the first calibration with GPS, you should select a sport mode where the foot POD is used and the GPS accuracy is set to Best . Start the recording and run at a steady pace on a level surface, if possible, for at least 15 minutes.
Run at your normal average pace for the initial calibration, and then stop the exercise recording. The next time you use the foot POD, the calibration is ready.
Your watch automatically re-calibrates the foot POD as needed whenever GPS speed is available.
Calibrating power POD
For power PODs (power meters), you need to initiate the calibration from the sport mode options in your watch.
To calibrate a power POD:
- Pair a power POD with your watch if you have not done so already.
 - Select a sport mode that uses a power POD and then open the mode options.
 - Select Calibrate power POD and follow the instructions in the watch.
You should re-calibrate the power POD from time to time.
Points of interest
A point of interest, or POI, is a special location, such as camping spot or vista along a trail, you can save and navigate to later. You can create POIs in Suunto app from a map and do not have to be at the POI location. Creating a POI in your watch is done by saving your current location.
Each POI is defined by:
- POI name
 - POI type
 - Date and time created
 - Latitude
 - Longitude
 - Elevation
You can store up to 250 POIs in your watch.
Adding and deleting POIs
You can add a POI to your watch either with Suunto app or by saving your current location in the watch.
If you are outside with your watch and come across a spot you want to save as a POI, you can add the location directly in your watch.
To add a POI with your watch:
- Swipe down or press the upper button to open the launcher.
 - Scroll to Navigation and tap on the icon or press the middle button.
 - Swipe up or press the lower button to scroll down to Your location and press the middle button.
 - Wait for the watch to activate GPS and find your location.
 - When the watch displays your latitude and longitude, press the upper button to save your location as a POI and select the POI type.
 - By default the POI name is the same as the POI type (with a running number after it). You can edit the name later in Suunto app.
Deleting POIs
You can remove a POI by deleting the POI from the POI list in the watch or removing it in Suunto app.
To delete a POI in your watch:
 - Swipe up or press the lower button to scroll down to POIs and press the middle button.
 - Scroll to the POI you want to remove from the watch and press the middle button.
 - Scroll to the end of the details and select Delete .
When you delete a POI from your watch, the POI is not permanently deleted.
To permanently delete a POI, you need to delete the POI in Suunto app.
Navigating to a POI
You can navigate to any POI that is in your watch POI list.
When navigating to a POI, your watch uses full power GPS.
To navigate to a POI:
 - Scroll to POIs and press the middle button to open your list of POIs.
 - Scroll to the POI you want to navigate to and press the middle button.
 - Press the upper button to start navigating.
 - Press the upper button again at any time to stop navigating.
The POI navigation has two views:
- POI view with direction indicator and distance to the POI
- map view showing your current location relative to the POI and your breadcrumb trail (the track you have traveled)
Swipe left or right, or press the middle button, to switch between views.
While in the POI view, tap on the screen to see additional information in the lower row such as altitude difference between current position and POI and estimated time of arrival (ETA) or en route (ETE).
In the map view, other POIs nearby are shown in gray. Tap on the screen to switch between the overview map and a more detailed view. In the detailed view, you adjust the zoom level by pressing the middle button and then zooming in and out with the upper and lower buttons.
While navigating, you can swipe up from the bottom of the screen or press the lower button to open a list of shortcuts. The shortcuts give you quick access to POI details and actions such as saving your current location or selecting another POI to navigate to, as well as ending navigation.
POI types
The following POI types are available in Suunto Spartan Ultra :
| generic point of interest | |
| Bedding (animal, for hunting) | |
| Begin (start of a route or trail) | |
| Big game (animal, for hunting) | |
| Bird (animal, for hunting) | |
| Building, home | |
| Cafe, food, restaurant | |
| Camp, camping | |
| Car, parking | |
| Cave | |
| Cliff, hill, mountain, valley | |
| Coast, lake, river, water | |
| Crossroad | |
| Emergency | |
| End (end of a route or trail) | |
| Fish, fishing spot | |
| Forest | |
| Geogache | |
| Hostel, hotel, lodging | |
| Info | |
| Meadow | |
| Peak | |
| Prints (animal tracks, for hunting) | |
| Road | |
| Rock | |
| Rub (animal marking, for hunting) | |
| Scrape (animal marking, for hunting) | |
| Shot (for hunting) | |
| Sight | |
| Small game (animal, for hunting) | |
| Stand (for hunting) | |
| Trail | |
| Trail cam (for hunting) | |
| Waterfall |
Position formats
The position format is the way your GPS position is displayed on the watch. All the formats relate to the same location, they only express it in a different way.
You can change the position format in the watch settings under Navigation » Position format .
Latitude/longitude is the most commonly used grid and has three different formats:
- WGS84 Hd.d°
 - WGS84 Hd°m.m'
 - WGS84 Hd°m's.s
Other common position formats available include:
- UTM (Universal Transverse Mercator) gives a two-dimensional horizontal position presentation.
 - MGRS (Military Grid Reference System) is an extension of UTM and consists of a grid zone designator, 100,000-meter square identifier and a numerical location.
Suunto Spartan Ultra also supports the following local position formats:
- BNG (British)
 - ETRS-TM35FIN (Finnish)
 - KKJ (Finnish)
 - IG (Irish)
 - RT90 (Swedish)
 - SWEREF 99 TM (Swedish)
 - CH1903 (Swiss)
 - UTM NAD27 (Alaska)
 - UTM NAD27 Conus
 - UTM NAD83
 - NZTM2000 (New Zealand)
Some position formats cannot be used in the areas north of 84° and south of 80°, or outside the countries that they are intended for. If you are outside the allowed area, your location coordinates cannot be displayed on the watch.
In addition to 24/7 activity monitoring, you can use your watch to record your training sessions or other activities to get detailed feedback and follow your progress.
To record an exercise:
- Put on a heart rate sensor (optional).
Tap the exercise icon or press the middle button.
Swipe up or down to scroll through the sport modes and tap on the one you want to use. Alternatively, scroll with the upper and lower buttons and select with the middle button.
Above the start indicator, a set of icons appear, depending on what you are using with the sport mode (such as heart rate and connected GPS). The arrow icon (connected GPS) flash gray while searching and turn green once a signal is found. The heart icon (heart rate) flash gray while searching and when once a signal is found, it turns into a colored heart attached to a belt if you are using a heart rate sensor or a colored heart without the belt if you are using the optical heart rate sensor.
If you are using a heart rate sensor but the icon turns green, check that the heart rate sensor is paired, see Pairing PODs and sensors , and select the sport mode again.
You can wait for each icon to turn green or red or start the recording as soon as you like by pressing the middle button.
Once the recording is started, the selected heart rate source is locked and cannot be changed during the ongoing training session.
While recording, you can switch between displays with the middle button or by using the touch screen if it is enabled.
Press the upper button to pause the recording. Stop and save with the lower button or continue with the upper button.
If the sport mode you selected has options, such as setting a duration target, you can adjust them before starting the recording by swiping up or pressing the lower button. You can also adjust sport mode options while recording by keeping the middle button pressed.
During the recording, you can tap on the screen to get a pop-up that shows current time and battery level.
If you are using a multisport mode, switch sports by keeping the upper button pressed.
After you stop the recording, you are asked how you felt. You can answer or skip the question. (See Feeling) Then you get a summary of the activity that you can browse through with the touch screen or buttons.
If you made a recording you don't want to keep, you can delete the log entry by scrolling to the bottom of the summary and tapping the delete button. You can also delete logs in the same way from the logbook.
It is possible to set different targets with your Suunto Spartan Ultra when exercising.
If the sport mode you selected has targets as an option, you can adjust them before starting the recording by swiping up or pressing the lower button.
To exercise with general target:
 - Tap Target or press the middle button.
 - Select Duration or Distance .
 - Select your target.
 - Swipe right to go back to the sport mode options.
When you have general targets activated, a target gauge is visible on every data display showing your progress.
You will also receive a notification when you have reached 50% of your target and when your selected target is fulfilled.
To exercise with intensity target:
 - Tap Intensity zones or press the middle button.
 - Select   HR zones ,   Pace zones   or   Power zones .
(The options depends on selected sport mode and if you have a power pod paired with the watch). - Select your target zone.
Navigating during exercise
You can navigate a route or to a POI while you are recording an exercise.
The sport mode you are using needs to have GPS enabled to be able to access the navigation options. If the sport mode GPS accuracy is OK or Good, when you select a route or POI, the GPS accuracy is changed to Best.
To navigate during exercise:
- Create a route or POI in Suunto app and sync your watch if you haven't done so already.
 - Select a sport mode that uses GPS and then swipe up or press the lower button to open the options. Alternatively, start your recording first, and then keep the middle button pressed to open the sport mode options.
 - Scroll to Navigation and tap the setting or press the middle button.
 - Swipe up and down or press the upper and lower buttons to select a navigation option and press the middle button.
 - Select the route or POI you want to navigate and press the middle button. Then press the upper button to start navigating.
If you have not started the exercise recording yet, the last step takes you back to the sport mode options. Scroll up to the start view and start your recording as normal.
While exercising, swipe right or press the middle button to scroll to the navigation display where you will see the route or POI that you selected. For more information on the navigation display, see Navigating to a POI and Routes.
While in this display you can swipe up or press the lower button to open your navigation options. From the navigation options, you can, for example, select a different route or POI, check your current location coordinates, as well as end navigation by selecting Breadcrumb .
Sport mode power saving options
To extend battery life while using sport modes with GPS, your biggest gains come from adjusting GPS accuracy (see GPS accuracy and power saving). To extend battery life further, you can adjust use the following power saving options:
- Display color: by default, the display uses the full range of colors available. When you enable the Low color option, the display uses fewer colors which reduces the amount of battery power needed.
 - Display timeout: normally, the display is always on during your exercise. When you turn on the display timeout, the display turns off after 10 seconds to save battery power. Press any button to turn the display back on.
To activate power saving options:
 - Scroll down to Power saving and tap the setting or press the middle button.
 - Adjust the power saving options as you want and then swipe right or keep the middle button pressed to exit the power saving options.
 - Scroll back up to the start view and start your exercise as normal.
If the display timeout is on, you can still get mobile notifications as well as sound and vibration alerts. Other visual aids such as the autopause pop-up are not shown.
Recovery time
Recovery time is an estimate in hours of how long your body needs to recuperate after training. The time is based on the duration and intensity of the training session, as well as your overall fatigue.
Recovery time accumulates from all types of exercise. In other words, you accumulate recovery time on long, low intensity training session as well as at high intensity.
The time is cumulative across training sessions, so if you train again before the time has expired, the newly accumulated time is added to the remainder from your previous training session.
To view your recovery time, swipe until you see the training insight display and tap on the screen.
Because recovery time is an estimation only, the accumulated hours count down steadily regardless of your fitness level or other individual factors. If you are very fit, you may recover faster than estimated. On the other hand, if you have the flu, for example, your recovery may be slower than estimated.
Routes
You can use your Suunto Spartan Ultra to navigate routes. Plan your route in Suunto app and transfer it to your watch with the next sync.
To navigate on a route:
- Scroll to Routes and press the middle button to open your list of routes.
- Scroll to the route you want to navigate to and press the middle button.
Tap the screen to switch between the overview map and a more detailed view.
In the detailed view, zoom in and out by tapping the screen or keeping the middle button pressed. Adjust the zoom level with the upper and lower buttons.
While you are in the navigation display, you can swipe up from the bottom of the screen or press the lower button to open a list of shortcuts. The shortcuts give you quick access to navigation actions such as saving your current location or selecting another route to navigate.
All sport modes with GPS also have a route selection option. See Navigating during exercise.
Navigation guidance
As you navigate a route, your watch helps you stay on the correct path by giving you additional notifications as you progress along the route.
For example, if you go more than 100 m (330 ft) off route, the watch notifies you that you are not on the right track, as well as lets you know when you are back on route.
Once you reach a waypoint of POI on the route, you get an informative popup showing you the distance and estimated time en route (ETE) to the next waypoint or POI.
If you navigating a route that crosses itself, such as a figure-8, and you make a wrong turn at the crossing, your watch assumes you are intentionally going in a different on the route. The watch shows the next waypoint based on the current, new direction of travel. So, keep an eye on your breadcrumb trail to ensure you are going the right way when you are navigating a complicated route.
Altitude navigation
If you are navigating a route that has altitude information, you can also navigate based on ascent and descent using the altitude profile display. While in the main navigation display (where you see your route), swipe left or press the middle button to switch to the altitude profile display.
- top: your current altitude
 - center: altitude profile showing your current position
 - bottom: remaining ascent or descent (tap screen to change views)
If you stray too far off from the route while using altitude navigation, your watch will give you an Off route message in the altitude profile display. If you see this message, scroll to the route navigation display to get back on track before continuing with altitude navigation.
Turn-by-turn navigation powered by Komoot
If you are a Komoot member, you can find or plan routes with Komoot and sync these to your Suunto Spartan Ultra via Suunto app. In addition, your exercises recorded with your watch will automatically be synchronized to Komoot.
When using route navigation with your Suunto Spartan Ultra together with routes from Komoot, your watch will alert you with a sound when it is time to make a turn.
To use turn-by-turn navigation powered by Komoot:
- Register at Komoot.com
 - In Suunto app, select partner services.
 - Select Komoot and connect by using the same credentials you used at the Komoot registration.
All your selected or planned routes (called “tours” in Komoot) in Komoot will automatically synchronize to Suunto app, which you then easily can transfer to your watch.
Follow the instructions in section Routes and select your route from Komoot to get turn-by-turn alerts.
For more information regarding the partnership between Suunto and Komoot, please see http://www.suunto.com/komoot
Komoot is currently not available in China.
Sleep tracking
A good night's sleep is important for a healthy mind and body. You can use your watch to track your sleep and follow how much sleep you are getting on average.
When you wear your watch to bed, Suunto Spartan Ultra tracks your sleep based on accelerometer data.
To track sleep:
- Go to your watch settings, scroll down to Sleep and press the middle button.
Toggle on Sleep tracking .
Set the times for going to bed and waking up according to your normal sleep schedule.
The last step defines your bedtime. Your watch uses that period to determine when you are sleeping (during your bedtime) and reporting all sleep as one session. If you get up for a drink of water during the night, for example, your watch still counts any sleep after that as the same session.
If you go to bed before your bedtime and also wake up after your bedtime, your watch does not count that as a sleep session. You should set your bedtime according to the earliest you may go to bed and the latest you may wake up.
Once you have enabled sleep tracking, you can also set your sleep target. A typical adult needs between 7 and 9 hours of sleep per day, though your ideal amount of sleep may vary from the norms.
Sleep trends
When you wake up, you are greeted with a summary of your sleep. The summary includes, for example, the total duration of your sleep, as well as the estimated time you were awake (moving around) and the time you were in deep sleep (no movement).
In addition to the sleep summary, you can follow your overall sleep trend with the sleep insight. From the watch face, press the lower right button until you see the Sleep display. The first view shows your last sleep compared to your sleep target.
While in the sleep display, you can swipe left to see your average sleep over the last seven days. Swipe up to see your actual sleeping hours for the last seven days.
From the Sleep display, you can keep the middle button pressed to access sleep tracking settings and the latest sleep summary.
All sleep measurements are based on movement only, so they are estimates that may not reflect your actual sleep habits.
Automatic Do Not Disturb mode
You can use the auto Do Not Disturb setting to automatically enable Do Not Disturb mode while you sleep.
Sport modes
Your watch comes with a wide range of pre-defined sport modes. The modes are designed for specific activities and purposes, from a casual walk outside to a triathlon race.
When you record an exercise (see Recording an exercise), you can swipe up and down to see the short list of sport modes. Tap the icon at the end of the short list to view the complete list and see all sport modes.
Each sport mode has a unique set of displays and views. You can edit and customize the information displayed on screen in the Suunto app. You can also shorten the list of sport modes in your watch or add new ones.
Swimming
You can use your Suunto Spartan Ultra for swimming in pools or openwater.
When you use a pool swimming sport mode, the watch relies on the pool length to determine distance. You can change the pool length as needed under the sport mode options before you start swimming
Openwater swimming relies on GPS to calculate distance. Because GPS signals do not travel under water, the watch needs to come out of the water periodically, such as with the freestyle stroke, to get a GPS fix.
These are challenging conditions for GPS, so it is important that you have a strong GPS signal before you jump in the water. To ensure good GPS, you should:
- Sync your watch with SuuntoLink before you go swimming to optimize your GPS with the latest satellite orbit data.
 - After you select an openwater swimming sport mode and a GPS signal is acquired, wait at least three minutes before starting your swim. This gives the GPS time to establish strong positioning.
Storm alarm
A significant drop in barometric pressure typically means a storm is coming and you should take cover. When the storm alarm is active, Suunto Spartan Ultra sounds an alarm and displays a storm symbol when the pressure drops 4 hPa (0.12 inHg) or more during a 3-hour period.
To activate the storm alarm:
- Press the middle button to open the shortcut menu.
 - Scroll down to Alarms and enter by pressing the middle button.
 - Scroll to Storm alarm and toggle on/off by pressing the middle button.
When a storm alarm sounds, pressing any button ends the alarm. If no button is pressed, the alarm notification lasts for one minute. The storm symbol remains on the display until the weather conditions stabilize (pressure drop slows down).
Sunrise and sunset alarms
The sunrise/sunset alarms in your Suunto Spartan Ultra are adaptive alarms based on your location. Instead of setting a fixed time, you set the alarm for how much in advance you want to be alerted before the actual sunrise or sunset.
The sunrise and sunset times are determined via GPS, so your watch relies on the GPS data from the last time you used GPS.
To set sunset/sunrise alarms:
Scroll to the alarm that you want to set and select by pressing the middle button.
 - Set the desired hours prior to sunrise/sunset by scrolling up/down with the upper and lower buttons and confirming with the middle button.
Set minutes in the same way.
 - Press the middle button to confirm and exit.
A watch face is also availalbe that shows sunrise and sunset times.
Sunrise and sunset times and alarms require a GPS fix. The times are blank until GPS data is available.
Time and date
You set time and date during the initial startup of your watch. After this, your watch uses GPS time to correct any offset.
You can manually adjust time and date from the settings under GENERAL » Time/date where you can also change time and date formats.
In addition to the main time, you can use dual time to follow the time at a different location, for example, when you are traveling. Under General » Time/date , tap Dual time to set the time zone by selecting a location.
Alarm clock
Your watch has an alarm clock that can sound once or repeat on specific days. Activate the alarm from the settings under Alarm » Alarm clock .
Besides standard fixed alarms, you will also find an adaptive alarm type based on data for sunrise and sunset. See Sunrise and sunset alarms.
To set a fixed alarm time:
- From the watch face, press the middle button to open the shortcuts menu and scroll to Alarms .
First select how often you want the alarm to sound. The options are:
Once : alarm sounds once in the next 24 hours at the set time Weekdays : alarm sounds at the same time Monday thru Friday Daily : alarm sounds at the same time every day of the week
Set the hour and minutes and then exit the settings.
When the alarm sounds, you can dismiss it to end the alarm, or you can select the snooze option. The snooze time is 10 minutes and can be repeated up to 10 times.
If you let the alarm continue to sound, it will automatically snooze after 30 seconds.
Timers
Your watch includes a stopwatch and countdown timer for basic time measurement. From the watch face, open the launcher and scroll up until you see the timer icon. Tap the icon or press the middle button to open the timer display.
When you first enter the display, it shows the stopwatch. After that, it remembers whatever you used last, stopwatch or countdown timer.
Swipe up or press the lower button to open the Set timer shortcuts menu where you can change the timer settings.
Stopwatch
Start the stopwatch by pressing the middle button.
Stop the stopwatch by pressing the middle button. You can resume by pressing the middle button again. Reset by pressing the lower button.
Exit the timer by swiping right or keeping the middle button pressed.
Countdown timer
In the timer display, swipe up or press the lower button to open the shortcuts menu. From there you can select a pre-defined countdown time or create custom countdown time.
Stop and reset as needed wtih the middle and lower buttons.
Tones and vibration
Tones and vibration alerts are used for notifications, alarms and other key events and actions. Both can be adjusted from the settings under General » Tones .
Under General » Tones » General , you can select from the following options:
- All on : all events trigger an alert
 - All off : no events trigger alerts
 - Buttons off : all events other than pushing buttons trigger alerts.
Under General » Tones » Alarms you can switch vibrations on and off.
You can select from the following options:
- Vibration : vibration alert
 - Tones : sound alert
 - Both : both vibration and sound alert.
Training insight
Your watch provides an overview of your training activity.
Swipe up or press the lower button to scroll to the training insight view
Swipe left or press the middle button twice to see a graph with all your activities for the last 3 weeks and the average duration. Tap the screen to toggle between the different activities you have done for the last 3 weeks.
Swipe up or press the lower right button to see a summary of your current week. The summary includes duration and calories. Swiping up when a specific activity is chosen will show details of that activity.
Watch faces
Suunto Spartan Ultra comes with several watch faces to choose from, both digital and analog styles.
To change the watch face:
- From your current watch face view, keep the middle button pressed to open the shortcuts menu.
 - Scroll to Watch face and tap or press the middle button to enter.
- Swipe up and down to scroll through the watch face previews and tap on the one you want to use.
 - Swipe up and down to scroll through the color options and tap on the one you want to use.
Each watch face has additional information, such as date or dual time. Tap the display to switch between views.
 Activity monitoring   Airplane mode   Altimeter   Autopause   Backlight   Bluetooth connectivity   Button and screen lock   Compass   Device info   Display theme   Do Not Disturb mode   Feeling   Find back   FusedSpeed   GLONASS   GPS accuracy and power saving   Heart rate sensor   Intensity zones   Interval training   Language and unit system   Logbook   Moon phases   Notifications   Outdoor insight   Pairing PODs and sensors   Points of interest   Position formats   Recording an exercise   Recovery time   Routes   Turn-by-turn navigation powered by Komoot   Sleep tracking   Sport modes   Storm alarm   Sunrise and sunset alarms   Time and date   Timers   Tones and vibration   Training insight   Watch faces
CARE AND SUPPORT
Handling guidelines
Handle the unit with care – do not knock or drop it.
Under normal circumstances, the watch does not require servicing. On a regular basis, rinse it with fresh water, mild soap, and carefully clean the housing with a moist, soft cloth or chamois.
Battery
The duration on a single charge depends on how you use your watch and in what conditions. Low temperatures, for example, reduce the duration of a single charge. In general, the capacity of rechargeable batteries decreases over time.
In case of abnormal capacity decrease due to defective battery, Suunto covers battery replacement for one year or maximum 300 charging times, whichever comes first.
When the battery charge level is less than 20% and later 5%, your watch displays a low battery icon. If the charge level gets very low, your watch goes into a low power mode and display a charge icon.
Use the supplied USB cable to charge your watch. Once the battery level is high enough, the watch wakes up from lower power mode.
Disposal
Please dispose of the device in accordance with local regulations for electronic waste. Do not throw it in the garbage. If you wish, you may return the device to your nearest Suunto dealer.
REFERENCE
Technical specifications
General
- Operating temperature: -20° C to +60° C/-5° F to +140° F
 - Battery charging temperature: 0° C to +35° C/+32° F to +95° F
 - Storage temperature: -30° C to +60° C/-22° F to +140° F
 - Water resistance: 100 m/328 ft
 - Battery type: rechargeable lithium-ion battery
 - Battery life: 18-140 hours with GPS, depending on conditions and settings
Radio transceiver
- Bluetooth® Smart compatible
 - Communication frequency: 2402-2480 MHz
 - Maximum transmission power: <4 dBm
 - Range: ~3 m/9.8 ft
Altimeter
- Display range: -500 m to 9999 m/-1640 ft to 32805 ft
 - Resolution: 1 m/3 ft
Compass
- Resolution: 1 degree/18 mils
GPS
- Technology: SiRF star V
 - Frequency band: 1575.42 MHz
Manufacturer
Suunto Oy
Tammiston kauppatie 7 A
FI-01510 Vantaa
FINLAND
Date of manufacture
The manufacturing date can be determined from your device’s serial number. The serial number is always 12 characters long: YYWWXXXXXXXX.
In the serial number, the first two digits (YY) are the year and the following two digits (WW) are the week within the year when the device was manufactured.
Compliance
CE
Hereby, Suunto Oy, declares that the radio equipment type OW161 is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: www.suunto.com/EUconformity .
FCC compliance
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) this device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation. This product has been tested to comply with FCC standards and is intended for home or office use.
Changes or modifications not expressly approved by Suunto could void your authority to operate this device under FCC regulations.
NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
- Reorient or relocate the receiving antenna.
 - Increase the separation between the equipment and receiver.
 - Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
 - Consult the dealer or an experienced radio/TV technician for help.
Amer Sports United States
2030 Lincoln Avenue
84401 Ogden
United States
+1 855 258 0900
ISED REGULATORY COMPLIANCE
This device contains licence-exempt transmitter(s) that comply with Innovation, Science and Economic Development Canada’s licence-exempt RSS(s).
(1) this device may not cause interference, and
(2) this device must accept any interference, including interference that may cause undesired operation of the device.
NOM-121-SCT1-2009
Trademark
Suunto Spartan Ultra , its logos, and other Suunto brand trademarks and made names are registered or unregistered trademarks of Suunto Oy. All rights are reserved.
Patent notice
This product is protected by pending patent applications and their corresponding national rights: FI 20155573, US 7,324,002, US 7,271,774, US 13/744,493, US 13/794,468, US 13/833,755, US 13/827,418, US 14/195,670, US 14/331,268, US 14/839,928, US 14/882,487.
Additional patent applications have been filed.
International Limited Warranty
Warranty Period
The Warranty Period is two (2) years for Watches, Smart Watches, Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive Mechanical Instruments, and Mechanical Precision Instruments unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to Suunto chest straps, watch straps, chargers, cables, rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
- normal wear and tear such as scratches, abrasions, or alteration of the color and/or material of non-metallic straps, b) defects caused by rough handling, or c) defects or damage resulting from use contrary to intended or recommended use, improper care, negligence, and accidents such as dropping or crushing;
 - printed materials and packaging;
 - defects or alleged defects caused by use with any product, accessory, software and/or service not manufactured or supplied by Suunto;
 - non-rechargeable batteries.
- has been opened beyond intended use;
 - has been repaired using unauthorized spare parts; modified or repaired by unauthorized Service Center;
 - serial number has been removed, altered or made illegible in any way, as determined at the sole discretion of Suunto; or
 - has been exposed to chemicals including but not limited to sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty service. You must also register your product online at www.suunto.com/register to receive international warranty services globally. For instructions how to obtain warranty service, visit www.suunto.com/warranty , contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
Copyright
© Suunto Oy 7/2016. All rights reserved. Suunto, Suunto product names, their logos and other Suunto brand trademarks and names are registered or unregistered trademarks of Suunto Oy. This document and its contents are proprietary to Suunto Oy and are intended solely for the use of clients to obtain knowledge and information regarding the operation of Suunto products. Its contents shall not be used or distributed for any other purpose and/or otherwise communicated, disclosed or reproduced without the prior written consent of Suunto Oy. While we have taken great care to ensure that information contained in this documentation is both comprehensive and accurate, no warranty of accuracy is expressed or implied. This document content is subject to change at any time without notice. The latest version of this documentation can be downloaded at www.suunto.com .
