Suunto Wing 2
Coral Orange
Premium bone-conduction headphones with powerbank. Designed for safe adventuring - every day, in any weather.
- Open-ear comfort and safety
- Stable & lightweight
- Head Movement Control
- IP66 sweat- & waterproof
- Up to 12 hours of battery + 24 hours with powerbank
- Real-time performance feedback from Suunto watch
Choose Your Color
Quantity
€134,66
Stay aware, stay ahead
Experience the confidence of total situational awareness. The open-ear design of the Suunto Wing 2 allows you to anticipate an approaching vehicle, hear a fellow runner or cyclist, or just enjoy the birdsong. You get motivation from your music and the peace of mind that comes from never being cut off from your environment.
Music that moves with you
The Suunto Wing 2 design delivers rich, high-quality audio that turns tough climbs into epic moments and long runs into moving meditations. The robust mic is designed for better protection and wind noise cancelation up to 30 km/h so that you can enjoy calls on the go.
Sweatproof, dustproof, adventure-proof
Push your limits without worrying about your gear. Suunto Wing 2 is engineered to be a reliable partner in any condition, shrugging off the sweat, rain, or dust from your toughest efforts. It’s the freedom to train how you want, knowing your headphones are built to endure.
Charge less, move more
With enough power for multi-day trips and ultra-endurance events, Suunto Wing 2 is designed to keep going as long as you do. You can plan that epic adventure knowing that your audio will also go the distance. And for charging you can use the same USB-C charger as for other modern devices.
Smarter light for safer activities
The Wing 2’s intelligent LED lights ensure you stay visible to others. These lights react to your movement — pulsing with your running cadence or flashing when you check for traffic — for an extra layer of safety.
Sound that follows your lead
Never break your stride. When your hands are busy, the intuitive hands-free controls let you manage calls and music without fumbling for a button. A simple nod is all it takes to stay in the zone, maintain momentum, and keep your focus locked on the journey ahead.
Unlock the full potential of your headphones with the Suunto app
Connect your Suunto Wing 2 to Suunto app to fully personalize your experience. You can fine-tune your audio settings, customize the intelligent LED light modes for your sport of choice, and install the latest software updates. Plus, connect to your Suunto watch for real-time performance feedback delivered directly to your ears. This text-to-speech feature lets you track metrics like lap time, total distance and duration, and average speed.
Device controls
SPECIFICATIONS
Measurements103 x 126 x 47.6mm
Weight35 g / 1.23 oz
Case material:Silicone + Titanium Alloy
What's in the box?Suunto Wing 2 headphones, charging cable, Powerbank, Suunto storage bag, Printed user quick guide, International warranty leaflet, Safety leaflet
Country of manufactureCN
TECHNICAL SPECIFICATIONS
Case materialSilicone + Titanium Alloy
Water resistanceIP66
Battery typerechargeable lithium-ion
Battery Charge TimeHeadphones:≤1h,Powerbank:≤1.5h
Firmware upgradable✔
Music only play time≧10H, Used with powerbank: ≧30H (60% volume, using SBC format to play 'Hotel California')
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-20° C to +60° C / -5° F to +140° F
Recommended charging temperature0° C to +45° C / +32° F to +113° F
CONNECTIVITY
Compatible with Suunto app✔
Software updates from cloud✔
Bluetooth5.3
Bluetooth Range> 10m
Supported Audio FormatsA2DP, AVRCP, HFP, HSP
Supported Audio codecSBC
Dual device connection✔
Smartphone compatibilityMost common models supported
SPEAKER
SizeL24.2mm*W15.1mm*H6.2mm
Impedance6Ω±15%
Frequencyrange20Hz~20kHz
Sensitivity117dB@1kHz -10dBFS
MICROPHONE
Sensitivity-38dB(1kHz)
Frequencyrange100Hz~10KHz
S/N Ratio62.5dB
