Suunto Nautic
Elastic Textile Strap
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Explore more with the Suunto app
SPEZIFIKATIONEN
Maße101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
Gewicht227g (with bungee strap) , 232g (with elastic textile strap)
Lünettenmaterial:Fiber reinforced polymer
Glasmaterial:Panda glass (PANDA-MN228 high alumina silicon glass)
Gehäusematerial:Glass fibre reinforced polyamide
Armbandmaterial:Bungee cord / Elastic textile
HerstellungslandFI
Technische Daten
ALLGEMEIN
LünettenmaterialFiber reinforced polymer
GlasmaterialPanda glass (PANDA-MN228 high alumina silicon glass)
GehäusematerialGlass fibre reinforced polyamide
ArmbandmaterialBungee cord / Elastic textile
Farbdisplay✔
Vibrationsalarm✔
Wasserbeständigkeit200 m
Batterietyprechargeable lithium-ion
Firmware aktualisierbar✔
Zeit, Datum✔
Stoppuhr-Timer✔
SpracheCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
HintergrundbeleuchtungAMOLED
Konfigurierbare Hintergrundbeleuchtungautomatic brightness
Tastensperre✔
Displaygröße3,26"
Displaytypmatrix
Displayauflösung720x382
Metrische und imperiale Einheiten✔
Automatische Sommerzeit✔
Batterieanzeigepercentage / icon
Always-on-Display✔
ÄUSSERE MERKMALE
Betriebstemperatur-20° C to +55° C / -5° F to +130° F
Operating temperature in dive mode0° C to +40° C / +32° F to +104° F
Aufbewahrungstemperatur-20° C to +55° C / -5° F to +130° F
Empfohlene Batterieladetemperatur0° C to +35° C / +32° F to +95° F
BATTERIELEBENSDAUER
Intelligente Ladeerinnerungen✔
Batterielebensdauer (Tauchen)80-190h
KOMPASS
Digitaler Kompass✔
Digitaler Kompass beim Tauchen✔
Neigungskompensation✔
Neigungskorrektur✔
Richtungsskala✔
Nadel✔
Genauigkeit5°
Skaleneinteilung1°
KONNEKTIVITÄT
Konnektivität (zwischen Geräten)Bluetooth
Kompatibel mit der Suunto App✔
Uhrensoftware-Updates über die Cloud✔
Automatische Over-the-Air-Software-Updates✔
Smartphone-KompatibilitätMost common models supported, check here for detailed compatibility list
OUTDOOR-FUNKTIONEN
GPS TRACKING UND NAVIGATION
Offline-Karten auf der Uhr✔
SatellitensystemeGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Offline map storage size32 GB
Simultane Nutzung von Satellitensystemen4
Max. verbundene Satelliten32
GPS-AufzeichnungsrateBest, Good, OK, Low
Vergrößerungsstufen in der Navigation✔
Echtzeit-Darstellung der Strecke✔
Outdoor-Gelände- und Satellitenkarten✔
Globale Heatmaps für 20 Sportarten✔
Navigation mit Points of Interest (POI)✔
GPS-Routenanalyse✔
Aufzeichnen, Anzeigen und Teilen der Wegstrecke✔
WETTER
Sonnenaufgangs-/Sonnenuntergangszeiten✔
Temperatur✔
Temperaturanzeigebereich-20° C to +55° C / -5° F to +130° F
Genauigkeit der Temperaturanzeige1° C / 1.5° F
TRAININGSFUNKTIONEN
HERZFREQUENZ
Herzfrequenzgurt-KompatibilitätBluetooth HR belts
KOMPETENZ IN SPORTARTEN
SPORTMODI
Anpassbare Sportmodi und AnzeigenCustomizable dive
Grafische Anzeigen in SportmodiIn dive
Vorgefertigte Sportmodi auf der UhrDive modes
Geeignet für SportartenScubadive
TAUCHFUNKTIONEN
GRUNDLAGEN
Anpassen von Höhen-0 - 300 m / 300 -1500 m / 1500 - 3000 m
Anzeige Aufstiegzeit✔
CNS/OTU (OLF) Berechnungen✔
Benutzerdefinierte Tauchmodi und Anzeige✔
DekompressionsmodellsSuunto Bühlmann 16 GF
Dekompressions Profil Optionencontinuous and stepped
Tauchhistorielifetime
Tauchzeit✔
Der Gasverbrauch in Echtzeit✔
Gas max pO₂manual 1.0 - 1.6
Gaswechsel✔
Gas zeit✔
Gaseup to 5 gases (Oxygen 21 - 100%)
Messgerät✔
Maximale Betriebstiefe200m
Nitrox (und Luft)✔
Flugverbotszeit✔
Dekompressionsfreier Planer✔
Persönliche AnpassungGradient factors low (10-100) and high (50-100)
Sicherheitsstopps✔
Oberflächenzeit✔
Timer✔
Drahtlose Luftintegration✔
Drahtlose Gasintegration✔
Deco planner✔
Helium✔
TAUCHALARME UND BENACHRICHTIGUNGEN
CNS/OTU (OLF) 80% / 100%✔
Dekompressionsgrenzen-Verletzung✔
Tauchzeit✔
Gaszeit✔
Hoher pO2 (hyperoxisch)✔
Niedriger pO2 (hypoxisch)✔
Maximale Tiefe✔
Nullzeitgrenze (NDL)✔
Gaswechsel (besseres Gas verfügbar)✔
Flaschendruck✔
Zu schneller Aufstieg✔
FREITAUCHEN
Tiefenalarm✔
Tauchzeitalarm✔
