1 / 8
Suunto Vertical 2 Arctic Gray
1/8
Photos
Video
Money-back guarantee
30-Days Return
Global Support
Art.nr: SS051205000
Suunto Vertical 2
Arctic Gray
Rea-pris6 705 kr
Ultimate adventure watch for outdoor expeditions and training — improved
  • Bright 1.5'' AMOLED display
  • Up to 65 hours battery
  • 115+ sport modes
  • Integrated LED flashlight
  • Improved heart rate tracking
Choose your Color
Antal
30-Days Return
Global Support
6 705 kr
Lägg i varukorgen
Bright 1.5” AMOLED display
115+ sport modes
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Rugged design in titanium or steel
Secure fit silicone straps
Designed and tested in Finland
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
115+ sport modes
Training Zone with AI Coach
Workout planning
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
Route planning with heatmaps
Climb Guidance planning tool
Dual-band GPS system
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
300+ partner apps
Growing app ecosystem
Faster hardware, more memory
0 / 0
Suunto app
Learn More
SuuntoPlus™
Learn More
Partners
Learn More
Specifikationer
  • Mått
    48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
  • Vikt
    87g
  • Material i infattning:
    Stainless steel
  • Material i glas:
    Sapphire crystal
  • Material i boett:
  • Material i armband:
    Silicone
  • Tillverkningsland
    CN
TEKNISKA SPECIFIKATIONER
ALLMÄNT
  • Bezel material
    Stainless steel
  • Glass material
    Sapphire crystal
  • Case material
  • Strap material
    Silicone
  • Weight
    87g
  • Handledsmått
    125-175 mm
  • Armbandsbredd
    22 mm
  • Integrerad pulsmätning på handleden
  • Anpassningsbara urtavlor
  • Lås för pekskärm
  • Pekskärmsdisplay
  • Färgskärm
  • Vibrationsavisering
  • Vattentäthet
    100 m
  • Batterityp
    rechargeable lithium-ion
  • Uppgraderbar programvara
  • Tid, datum
  • Väckarklocka
  • Dubbla tidszoner
  • Automatisk tidtagning
  • Nedräknare
  • Stoppur
  • Språk
  • Bakgrundsbelysning
    LTPO AMOLED
  • Justerbar bakgrundsbelysning
    automatic brightness
  • Knapplås
    during exercise
  • Skärmstorlek
    1,5"
  • Visningstyp
    matrix
  • Displayupplösning
    466 x 466
  • Metriska/brittiska enheter
  • Batteristatus
    percentage / icon
  • Syremättnad
  • Alltid på-skjerm
FYSISKA SPECIFIKATIONER
  • Driftstemperatur
  • Förvaringstemperatur
  • Rekommenderad laddningstemperatur
    0° C to +45° C / +32° F to +110° F
BATTERITID
  • Intelligenta laddningspåminnelser
  • Daglig användning: Smartwatch-läge
    up to 20 days
  • Daglig användning: Endast standby-läge
    up to 40 days
  • Träning: Alla system GNSS-läge + Multi-Band
    up to 65h (AOD 60h)
  • Träning: Alla system GNSS-läge + Single-Band
    up to 75h (AOD 70h)
  • Träning: Batterilöften för alla lägen
    65h / 75h / 110h / 250h
  • Träning: Energisparlägen för GNSS
    up to 250h
KOMPASS
  • Digital kompass
  • Lutningskompensation
  • Missvisningskorrektion
  • Riktningsskala
    degrees / mils
  • Nål
    north indicator
  • Kompassprecision
  • Kompassupplösning
ANSLUTNINGSMÖJLIGHETER
  • Anslutbarhet (mellan enheter)
    Bluetooth
  • Kompatibel med Suunto-appen
  • Mediakontroller på klockan
  • Skicka fördefinierade svar på inkommande meddelanden direkt från klockan
    Android only
  • Kompatibel med sportforum online
  • Uppdateringar av programvara för klocka från molnet
  • Automatiska over the air-uppdateringar
  • Smartphone compatibility
    Most common models supported, check here for detailed compatibility list
DYGNET RUNT
AKTIVITETSREGISTRERING
  • Stegräknare
  • Kaloriförbrukning
  • Aktivitetsmål
    steps, calories
  • Aktivitetshistorik
  • Kaloriförbrukning och pulsmätning under dagliga aktiviteter
  • Registrering minsta dagliga puls
SÖMNREGISTRERING
  • Sömntid
  • Sängtider
  • Tid vaken
  • Djupt viloläge
  • Medelvärde och minimivärde för puls under sömn
  • Lätt sömn
  • REM-sömn
  • Pulsvariabilitet (HRV) från sömn
  • Sömnkvalitet
STRESS OCH ÅTERHÄMTNING
  • Daglig resursnivå
  • Stress- och återhämtningsstatus
  • Pulsvariabilitetsmätning
FRILUFTSFUNKTIONER
SPÅRNING OCH NAVIGERING MED GPS
  • Offlinekartor på klockan
  • Satellitsystem
  • GNSS frequency support
    Dual band (L1+L5)
  • Simultana satellitsystem
    4
  • Max anslutna satelliter
    32
  • Intelligenta batterilägen
  • GPS-registreringsfrekvens
    Best, Good, OK, Low
  • Ruttpunktsnavigering och visuell ruttnavigering
  • Zoomnivåer i navigering
  • Autozoom baserat på ruttens utformning
  • Brödsmulespår i realtid
  • Ruttplanering med höjdprofil
  • Utomhusterräng och satellitkartor
  • Globala värmekartor för 20 sporter
  • Ruttplanering med värmekartor
  • Eget ruttbibliotek synkroniserat för visning
  • Fäst för att skapa en rutt
  • Intressepunktsnavigering
  • Analys av GPS-spårning
  • Spårloggning, visning och delning
  • ETA (beräknad ankomsttid)
HÖJDMÄTARE
  • Höjdmätning med barometer
  • GPS-höjd
  • GPS-korrigerad höjdmätning med barometer (FusedAlti™)
  • Höjd i dagligt läge
  • Höjdacklimatisering med syremättnad
  • Total uppstigning/nedstigning
  • Vertical speed
  • Automatisk växling mellan höjd/baro
  • Loggningsfrekvens
    1 s
  • Upplösning
    1 m
  • Omfång
    -500 - 9999 m
VÄDER
  • Tid för soluppgång/solnedgång
  • Stormvarning
  • Lufttryck vid havsytan
  • Temperatur
  • Temperaturvisning
  • Temperaturnoggrannhet
    1° C / 1.5° F
  • Tryckupplösning
    1 hPa
  • Ett diagram över höjdskillnader visas i träningssammanställningen
TRÄNINGSFUNKTIONER
INTERVALLTRÄNING
  • Intervallinställningar
  • Intervallvägledning under träning
  • Strukturerade intervaller
PULS
  • Pulsmätning från handleden
  • Kompatibilitet med pulsbälten
    Bluetooth HR belts
  • RR-intervall
    with Suunto Smart Sensor
  • Puls som hjärtslag per minut
  • Registrerar puls vid simning
  • Diagram över puls i realtid
  • Genomsnittlig puls i realtid
  • Kalorier
  • Toppträningseffekt
  • Personliga pulszoner
  • Konditionsnivå (VO2max)
  • Laktattröskeldetektering
  • Återhämtningstid
HASTIGHET OCH STRÄCKA
  • Kadensbaserad hastighet och distans
  • GPS hastighet och sträcka
  • Tidtagning
  • Foot POD-support
    Bluetooth Foot Pods
  • Autovarv
  • Manuella varv
  • Analys av takt, hastighetsdiagram och spår på kartan
ÅTERHÄMTNING EFTER TRÄNING
  • Känsla sparas i klockan efter träning
  • Träningsbaserad återhämtningstid
TRÄNINGSBELASTNING
  • Loggbok med träningsinformation
  • Träningsbelastning med resultat per sport
  • Träningsloggbok för långtidsöversikt
  • Träningssammanfattning med varvinformation
DELA OCH ÅTERUPPLEV
  • Dela träningspass i sociala medier
  • Bedöma och kommentera träningspass
  • Följ andra medlemmar och få feedback via aktivitetsströmning
SPORTEXPERTIS
SIMNING
  • Simtakt och distans i bassäng
  • Simavstånd på öppet vatten
  • Simtid efter bassänglängd, mellantid, total
  • Simtagsfrekvens, antal simtag och simstil
  • Simtagseffektivitet (SWOLF)
  • Automatiska intervall
  • Varvtabell för intervaller
CYKLING
  • Cykelhastighet
  • Snitthastighet i realtid
  • Cykel-POD med stöd för hastighet/kadens
    Bluetooth Bike Pods
  • Stöd för mätare av cykeleffekt
    Bluetooth Power meters
  • Cykeleffekt (W), snitt och max (med effektsensor)
  • Cykelvarv och maximal effekt för mellantid (med effektsensor)
  • Varvtabeller i realtid med genomsnittlig puls, effekt och hastighet
  • Intervallvägledning med effekt/hastighet/puls
LÖPNING
  • Löptakt
  • Suunto FusedSpeed™
  • Löpningseffekt
  • SuuntoPlus™ Ghost runner
  • Foot POD-kalibrering
    automatic
  • Varvtabell i klocka och Suunto-app
  • Snitt, max, varvtempo i realtid
  • Intervallvägledning med takt/puls/distans för löpning
MULTISPORTER
  • Ändra sportläge under träning
  • Förkonfigurerade multisportlägen
  • Efteranalys av multisportträning anpassad efter sport
  • Träningssammanställning för multisport i klockan
SPORTLÄGEN
  • Anpassningsbara sportlägen och displayer
  • Grafisk visning i sportlägen
  • Klockans förinställda sportlägen
    > 90
  • SuuntoPlus™
DYKFUNKTIONER
FRIDYKNING
  • Djupmätare för snorkling
    10 m
Recommended Products
SUPPORT FOR SUUNTO VERTICAL 2
