Suunto Nautic
Elastic Textile Strap
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Explore more with the Suunto app
ХАРАКТЕРИСТИКИ
Размеры101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
Вес227g (with bungee strap) , 232g (with elastic textile strap)
Материал безеля:Fiber reinforced polymer
Материал стекла:Panda glass (PANDA-MN228 high alumina silicon glass)
Материал корпуса:Glass fibre reinforced polyamide
Материал ремешка:Bungee cord / Elastic textile
Страна производстваFI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляFiber reinforced polymer
Материал стеклаPanda glass (PANDA-MN228 high alumina silicon glass)
Материал корпусаGlass fibre reinforced polyamide
Материал ремешкаBungee cord / Elastic textile
Цветной экран✔
Виброоповещение✔
Водостойкий200 m
Тип батареиrechargeable lithium-ion
Обновляемое встроенное ПО✔
Время, дата✔
Секундомер✔
ЯзыкиCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
ПодсветкаAMOLED
Настраиваемая подсветкаautomatic brightness
Блокировка кнопок✔
Размер экрана3,26"
Тип дисплеяmatrix
Разрешение дисплея720x382
Метрическая и британская системы измерения✔
Автоматический хронометраж✔
Индикатор заряда батареиpercentage / icon
Дисплей всегда вкл.✔
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-20° C to +55° C / -5° F to +130° F
Рабочая температура в режиме погружения0° C to +40° C / +32° F to +104° F
Температура хранения-20° C to +55° C / -5° F to +130° F
Рекомендуемая температура зарядки0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Intelligent charge reminders✔
Battery life (dive)80-190h
КОМПАС
Цифровой компас✔
Цифровой компас во время дайвинга✔
Компенсация склонения✔
Коррекция склонения✔
Шкала направления✔
Стрелка✔
Точность компаса5°
Дискретность компаса1°
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Возможности подключения (между устройствами)Bluetooth
Совместимо с приложением Suunto✔
Обновление ПО часов из облака✔
Автоматическое обновление программного обеспечения по беспроводной сети✔
Совместимость со смартфонамиMost common models supported, check here for detailed compatibility list
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
Offline maps on watch✔
Спутниковые системыGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Offline map storage size32 GB
Simultaneous satellite systems4
Max connected satellites32
Интервал регистрации GPSBest, Good, OK, Low
Масштабирование при навигации✔
Построение обратного маршрута в реальном времени✔
Топография местности и спутниковые карты✔
Глобальные тепловые карты по 20 видам спорта✔
Навигация по интересующим пунктам (POI)✔
Анализ маршрута по данным GPS✔
Параметры, просмотр и экспорт маршрутов✔
ПОГОДА
Время восхода/захода солнца✔
Термометр✔
Диапазон отображения температуры-20° C to +55° C / -5° F to +130° F
Дискретность температуры1° C / 1.5° F
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ЧАСТОТА СЕРДЦЕБИЕНИЯ
Совместимость с поясами-кардиодатчикамиBluetooth HR belts
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
СПОРТИВНЫЕ РЕЖИМЫ
Настройка спортивных режимов и дисплеевCustomizable dive
Графические дисплеи в спортивных режимахIn dive
Предустановленные спортивные режимы в часахDive modes
Подходит для спортаScubadive
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
БАЗОВЫЕ ВОЗМОЖНОСТИ
Поправка по высоте0 - 300 m / 300 -1500 m / 1500 - 3000 m
Отображение времени всплытия✔
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения)✔
Настраиваемые режимы погружения и дисплеи✔
Модель декомпрессииSuunto Bühlmann 16 GF
Параметры профиля декомпрессииcontinuous and stepped
Журнал погруженийlifetime
Время погружения✔
Потребление газовой смеси (в реальном времени)✔
Максимальное парциальное давление кислорода (pO2) в дыхательной смесиmanual 1.0 - 1.6
Переключение дыхательных смесей✔
Время по газовой смеси✔
Газовые смесиup to 5 gases (Oxygen 21 - 100%)
Gauge (Датчик)✔
Максимальная глубина погружения (EN 13319)200m
Кислородно-азотная смесь (и воздух)✔
Время запрета полетов✔
Планировщик бездекомпрессионного предела✔
Персональная настройкаGradient factors low (10-100) and high (50-100)
Остановка безопасности✔
Время на поверхности✔
Таймер✔
Беспроводное подключение к системе подачи воздуха✔
Беспроводная интеграция с баллоном✔
Deco planner✔
Helium✔
СИГНАЛЫ И УВЕДОМЛЕНИЯ ПРИ ПОГРУЖЕНИИ
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения) 80% / 100%✔
Выход за верхний декомпрессионный предел✔
Время погружения✔
Высокое парциальное давление pO2 (гипероксия)✔
Низкое парциальное давление pO2 (гипоксия)✔
Максимальная глубина✔
NDL✔
Переключение газовой смеси (на более подходящую, если имеется)✔
Давление в баллоне✔
Слишком быстрое всплытие✔
ФРИДАЙВИНГ
Оповещение о глубине✔
Уведомление о времени на поверхности✔
