Suunto EON Steel
The fully customizable dive computer with a bright color screen, extremely durable construction and mobile connectivity. Made in Finland.
Extreme durability with full customization
The robust Suunto EON Steel is designed for divers who demand the most of their dive computer. With the extremely durable construction, wide-angle BrightSee™ color screen and multiple gas support, this dive computer is ideal for advanced diving. Customizable features and views add a new dimension to your diving when exploring the blue unknown. Tested in the toughest diving conditions, Suunto EON Steel is your reliable partner in all conditions.
Bühlmann 16 with Gradient Factors is now available!
Suunto EON Steel can now be upgraded to include an additional algorithm for added diving possibilities.
HIGHLIGHTS
- Fully customizable
- Superior viewing
- Robust construction
- Wireless connectivity
ХАРАКТЕРИСТИКИ
Размеры104.6 x 60.5 x 23.1 mm / 4.12 x 2.38 x 0.91 "
Вес347 g / 12.24 oz
Материал безеля:Stainless steel
Материал стекла:Xensation Glass
Материал корпуса:Composite
Материал ремешка:Elastomer
КомплектацияSuunto EON Steel, USB Cable, Quick Guide, Legal leaflet, Protective boot, Display scratch guard sticker, Bungee adapter and cord
Страна производстваFI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляStainless steel
Материал стеклаXensation Glass
Материал корпусаComposite
Материал ремешкаElastomer
Вес347 g / 12.24 oz
Поворот дисплея✔
Водостойкий150 m (ISO 6425, EN 13319)
Тип батареиrechargeable lithium-ion
Обновляемое встроенное ПО✔
Время, дата✔
Секундомер✔
ЯзыкиEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
ПодсветкаLED
Настраиваемая подсветка✔
Тип дисплеяcolor TFT
Разрешение дисплея320 x 240
Метрическая и британская системы измерения✔
Индикатор заряда батареиicon + dive hours remaining
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура0° C to +40° C / +32° F to +104° F
Температура хранения-20 ° C to +50 ° C / -4° F to +122° F
Рекомендуемая температура зарядки0° C to +35° C / +32° F to +95° F
BATTERY LIFE
In time mode2 months
КОМПАС
Цифровой компас✔
Компенсация склоненияup to 45°
Коррекция склонения✔
Шкала направленияdegrees
Стрелкаcompass rose
Фиксация азимута с индикатором направления✔
Глобальная балансировка✔
Точность компаса+/- 15°
Дискретность компаса1°
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Возможности подключения (между устройствами)inductive (Tank POD), Bluetooth Smart
Совместимо с приложением Suunto✔
Совместимость с DM5✔
Передача журналаBluetooth Smart / USB cable
Совместимость со смартфонамиMost common models supported
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
ПОГОДА
Термометр✔
Диапазон отображения температуры-20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
Дискретность температуры1° C / 1.5° F
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
БАЗОВЫЕ ВОЗМОЖНОСТИ
Поправка по высоте0 - 300 m / 300 -1500 m / 1500 - 3000 m
Отображение времени всплытия0 - 999 min ( > after 999)
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения)✔
Custom disНастраиваемые экраны4 per dive mode
Модель декомпрессииSuunto Fused™ RGBM
Декомпрессионная остановка✔
Журнал погруженийlifetime
Время погружения0 to 999 min
Потребление газовой смеси (в реальном времени)✔
Максимальное парциальное давление кислорода (pO2) в дыхательной смесиmanual 0.5 - 1.6 / fixed 1.6
Переключение дыхательных смесей✔
Время по газовой смеси✔
Газовые смесиup to 10 gases (Oxygen 5 - 99% / Helium 0 -95%)
Gauge (Датчик)✔
Создание ярлыков журнала✔
Память для журнала измерений200 h
Изменение интервалов регистрации данных в журнале10 s
Максимальная глубина погружения (EN 13319)80m
Кислородно-азотная смесь (и воздух)✔
Время запрета полетов✔
Планировщик бездекомпрессионного предела✔
Персональная настройкаP+2, P+1, P0, P-1, P-2
Ребризер замкнутого цикла (CCR), фиксированная концентрация кислорода✔
Остановка безопасности✔
Время на поверхности0 to 100 h
Таймер✔
Поддержка КАГС (газовая смесь)✔
Визуальный стильClassic/Graphical/Prominent
Беспроводное подключение к системе подачи воздухаoptional (up to 20 different tanks with Suunto Tank POD)
СИГНАЛЫ И УВЕДОМЛЕНИЯ ПРИ ПОГРУЖЕНИИ
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения) 80% / 100%✔
Выход за верхний декомпрессионный предел✔
Выход за точку глубокой остановки✔
Высокое значение pO2 разжижителя✔
Низкое значение pO2 разжижителя✔
Автоматическое переключение разжижителя✔
Время погружения✔
Высокое парциальное давление pO2 (гипероксия)✔
Предупреждение об ИКД✔
Низкое парциальное давление pO2 (гипоксия)✔
Максимальная глубина✔
Переключение газовой смеси (на более подходящую, если имеется)✔
Давление в баллоне✔
Слишком быстрое всплытие✔
РЕБРИЗЕР
Разжижителиup to 10 diluents (Oxygen 5 - 99% / Helium 0 - 95%)
Отработка аварийных случаев✔
Верхние/нижние пределы✔
Пользовательские пределы✔
Ручное/автоматическое переключение пределов✔
