SUUNTO 9 BARO titanium
Rough and tough outdoor sports watch.
Choose Your Color
Built to last – just like you!
When you have your mind set on a certain goal or adventure, you want to make sure your watch can also go the distance. With up to 7 days of continuous GPS tracking Suunto 9 is built to last – just like you!
Suunto 9 is a multisport GPS watch designed for athletes who demand the best from their sports watch. Intelligent battery life management system with smart reminders ensures your watch will last just as long as you need it to. The robust Suunto 9 is made for long, arduous training and racing and extreme adventures.
KEY FEATURES
INTELLIGENT BATTERY MODES
SAPPHIRE GLASS
WRIST HEART RATE
STRESS AND RECOVERY
WEATHER FUNCTIONS
100 M WATER RESISTANT
TOUCH SCREEN
OVER 80 SPORT MODES
SUUNTO 9 KEEPS GETTING BETTER
Update the Suunto 9 software to the latest version to receive the newest features and functionalities.
BENEFITS
NEVER WORRY ABOUT RUNNING OUT OF BATTERY
TESTED TOUGH
SUUNTO FUSEDTRACK™ FOR MORE ACCURATE TRACK AND DISTANCE
SHARE YOUR PASSION WITH SUUNTO APP
GET THE BENEFITS FROM SUUNTO PARTNER NETWORK
ХАРАКТЕРИСТИКИ
Размеры51.5 x 51.5 x 17 mm / 2.03 x 2.03 x 0.67 "
Вес76 g / 2.68 oz
Материал безеля:Titanium Grade 5
Материал стекла:Sapphire crystal
Материал корпуса:Glass fibre reinforced polyamide
Материал ремешка:Silicone
КомплектацияSuunto 9 Baro Titanium, charging cable, Quick Guide, Warranty Leaflet
Страна производстваFI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляTitanium Grade 5
Материал стеклаSapphire crystal
Материал корпусаGlass fibre reinforced polyamide
Материал ремешкаSilicone
Вес76 g / 2.68 oz
Обхват запястья130-220 mm
Ширина ремешка24 mm
Встроенный наручный пульсометр✔
Настраиваемые экраны✔
Блокировка сенсорного экранаduring exercise
Сенсорный дисплей✔
Цветной экран✔
Виброоповещение✔
Водостойкий100 m
Тип батареиrechargeable lithium-ion
Обновляемое встроенное ПО✔
Время, дата✔
Будильник✔
Время для двух часовых поясов✔
Автоматический хронометраж✔
Таймер обратного отсчета✔
Секундомер✔
ЯзыкиEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Chinese language is only available in the China edition watches.
ПодсветкаLED
Настраиваемая подсветкаbrightness / mode
Блокировка кнопокduring exercise
Размер экрана1.34"
Тип дисплеяmatrix
Разрешение дисплея320 x 300
Метрическая и британская системы измерения✔
Индикатор заряда батареиpercentage / icon
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-20° C to +55° C / -5° F to +130° F
Температура хранения-30° C to +55° C / -22° F to +130° F
Рекомендуемая температура зарядки0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Intelligent charge reminders✔
In time mode14 days
With 24/7 tracking and mobile notifications7 days
Training mode with GPS25h / 50h / 120h / 170h
КОМПАС
Цифровой компас✔
Компенсация склонения✔
Коррекция склонения✔
Шкала направленияdegrees / mils
Стрелкаnorth indicator
Точность компаса5°
Дискретность компаса1°
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Возможности подключения (между устройствами)Bluetooth
Совместимо с приложением Suunto✔
Уведомления телефона на часах✔
Управление мультимедиа на часах✔
Отправка заранее заданных ответов на входящие сообщения с часовAndroid only
Поддержка спортивных онлайн-сообществ✔
Обновление ПО часов из облака✔
Совместимость со смартфонамиMost common models supported
24/7
ОТСЛЕЖИВАНИЕ АКТИВНОСТИ
Счетчик шагов✔
Количество сожженных калорий✔
Цели активностиsteps, calories
История занятий✔
Скорость сжигания калорий и частота сердцебиения во время повседневных активностей✔
Отслеживание дневной минимальной ЧСС✔
ОТСЛЕЖИВАНИЕ СНА
Продолжительность сна✔
Время сна✔
Время бодрствования✔
Глубокий сон✔
Качество сна✔
СТРЕСС И ВОССТАНОВЛЕНИЕ
Уровень дневного ресурса✔
Стресс и восстановление✔
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
Спутниковые системыGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportL1
Simultaneous satellite systems2
Max connected satellites12
Интеллектуальные режимы работы от батареиPerformance, Endurance, Ultra, Tour, Custom
Интервал регистрации GPSBest, Good, OK, Low
Навигация по путевым точкам и визуальная навигация по маршруту✔
Масштабирование при навигации✔
Автомасштабирование в зависимости от формы маршрута✔
Построение обратного маршрута в реальном времени✔
Планирование маршрутов с профилем высот✔
Топография местности и спутниковые карты✔
Глобальные тепловые карты по 20 видам спорта✔
Планирование маршрута с тепловыми картами✔
Личная библиотека маршрутов в Интернете синхронизирована с часами✔
Контроль маршрута✔
Навигация по интересующим пунктам (POI)✔
Анализ маршрута по данным GPS✔
Параметры, просмотр и экспорт маршрутов✔
ETA (расчетное время прибытия)✔
Bearing navigation✔
Карты местности: спутниковые, физические и топографические от Mapbox, Google Maps и Android✔
АЛЬТИМЕТР
Барометрический альтиметр✔
Высота по данным GPS✔
Объединение данных GPS с данными барометрического альтиметра (FusedAltiTM)✔
Высота в повседневном режиме✔
Общий подъем/спуск✔
Вертикальная скорость✔
Автопереключение профиля высотомера и барометра✔
Интервал регистрации в журнале1 s
Дискретность1 m
Диапазон-500 - 9999 m
ПОГОДА
Время восхода/захода солнца✔
Штормовое предупреждение✔
Атмосферное давление✔
Термометр✔
Диапазон отображения температуры-20° C to +55° C / -5° F to +130° F
Дискретность температуры1° C / 1.5° F
Дискретность давления1 hPa
Отображение графика высоты в общих сведениях о тренировке✔
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ИНТЕРВАЛЬНАЯ ТРЕНИРОВКА
Настройка интервалов✔
Подсказки в ходе интервальной тренировки✔
ЧАСТОТА СЕРДЦЕБИЕНИЯ
Измерение пульса на запястье✔
Совместимость с поясами-кардиодатчикамиBluetooth Smart belts
Интервал RRwith Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Частота сердцебиения в удаках в минуту✔
Запись сердечного ритма при плавании✔
График частоты сердцебиения в режиме реального времени✔
Информация о средней частоте сердцебиения в режиме реального времени✔
Калории✔
Максимальная эффективность тренировки✔
Личные пульсовые зоны✔
Уровень подготовки (макс. VO2)✔
Время восстановления✔
СКОРОСТЬ И РАССТОЯНИЕ
Измерение скорости и расстояния по данным датчика каденса✔
Скорость и расстояние по данным GPS✔
Хронограф✔
Поддержка Foot PODBluetooth Smart
Автоэтапы✔
Ручной отсчет этапов✔
Анализ темпа, графики скорости и маршруты на карте✔
ВОССТАНОВЛЕНИЕ ПОСЛЕ ТРЕНИРОВОК
Сохранение ощущения после тренировки на часы✔
Время восстановления в зависимости от тренировок✔
НАГРУЗКА ПРИ ТРЕНИРОВКЕ
Журнал с подробностями тренировок✔
Общие сведения о тренировке с подробностями этапов✔
Журнал тренировок для обзора длительных периодов✔
Итоговая тренировочная нагрузка по видам спорта✔
ДЕЛИТЕСЬ И ПЕРЕЖИВАЙТЕ ЗАНОВО
Публикация тренировок в соцсетях✔
Комментарии и оценки к тренировкам✔
Подписывайтесь на других участников и читайте комментарии через ленту активностей✔
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ПЛАВАНИЕ
Темп и расстояние заплыва в бассейне✔
Дистанция плавания в открытой воде✔
Время плавания: длина дорожки, этап, общее✔
Частота гребков, количество и тип✔
Эффективность гребков (SWOLF)✔
Автоматические интервалы✔
Таблица этапов для интервальной тренировки✔
ЕЗДА НА ВЕЛОСИПЕДЕ
Скорость езды✔
Средняя скорость в режиме реального времени✔
Bike POD с поддержкой скорости/частоты вращения педалейBluetooth Smart
Поддержка датчика мощности при езде на велосипедеBluetooth Smart
Мощность езды на велосипеде (Вт), средняя и максимальная (с датчиком мощности)Bluetooth Smart
Bike Lap and Lap Maximum Power (с датчиком мощности)✔
Таблица этапов в реальном времени со средними показателями: частота сердцебиения, мощность и скорость✔
Подсказки для интервальных тренировок с мощностью, скоростью и пульсом✔
БЕГ
Темп бега✔
Suunto FusedSpeed™✔
Контроль маршрута✔
Мощность бегаwith Stryd sensor
SuuntoPlus™ Ghost runner✔
Калибровка Foot PODautomatic
Таблица данных кругового хронографа в часах и приложении Suunto✔
Темп: средний, максимальный, этапа — в режиме реального времени✔
Подсказки для интервальных тренировок с темпом бега, пульсом и расстоянием✔
ТРЕНИРОВКИ С НЕСКОЛЬКИМИ ВИДАМИ СПОРТА
Изменение спортивного режима во время тренировки✔
Настроенные режимы для тренировок с несколькими видами спорта✔
Пост-анализ многоборья по видам спорта✔
Общие сведения о тренировке с несколькими видами спорта на часах✔
СПОРТИВНЫЕ РЕЖИМЫ
Настройка спортивных режимов и дисплеев✔
Графические дисплеи в спортивных режимахheart rate, speed and altitude
Предустановленные спортивные режимы в часах> 80
SuuntoPlus™✔
Recommended products
Videos
*Your actual battery life may vary depending on usage and conditions. If you enable the Ultra battery mode it will increase battery life, but deactivate wrist heart rate tracking. Tour battery mode gives you the longest battery life with lower GPS quality. In Endurance battery mode, battery life is 40 hours with wrist heart rate and 50 hours with HR belt. Touch is disabled during exercise, but you can activate it in your custom mode.
Learn more about the best practices for measuring heart rate from wrist.
