Refurbished Suunto Core Alpha
Stealth
The traditional outdoor watch for off-grid adventures with military-grade durability.
Choose your Color
SUUNTO CORE ALPHA
Suunto Core Alpha packs the key outdoor features in robust construction with a comfortable yet durable textile strap. Combining an altimeter, barometer and compass with weather information, it will bring out the explorer in you. The night vision goggle friendly red backlight helps you stay unnoticed when hunting.
Suunto Core Alpha is designed and made in Finland with the quality that Suunto is known for. Tested to military standards (MIL-STD-810), the watch will make sure your journey is safe and successful even in the toughest and most demanding conditions. Suunto Core Alpha has passed 9 tests, including pressure, heat/cold, shock, drop, freeze/thaw, rain, humidity and dust.
Key features
Barometer
Compass
Altimeter
Red backlight
Weather functions
Sunrise and sunset times
30 m water resistant
Benefits
- Altimeter
- Barometer
- Compass, adjustable declination
- Temperature
- Storm alarm
- Sunset/sunrise times
- Tested to military standards
- Made in Finland
- Red backlight, night vision goggle friendly
- Textile strap (Berry amendment compliant)
- User replaceable battery (CR2032), battery life ~12 months
- Multiple watch, date and time functions
- 30 m / 100 ft water resistance
- Depth meter for snorkeling (10 meters)
- Metric and imperial units
- Multilingual menu: EN, DE, ES, FR
ХАРАКТЕРИСТИКИ
Размеры49.5 x 49.5 x 15.1 mm / 1.95 x 1.95 x 0.59 "
Вес67 g / 2.36 oz
Материал безеля:Aluminum
Материал стекла:Mineral crystal
Материал корпуса:Composite
Материал ремешка:Textile
КомплектацияSuunto Core Alpha Stealth and Quick Guide
Страна производстваCN
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляAluminum
Материал стеклаMineral crystal
Материал корпусаComposite
Материал ремешкаTextile
Вес67 g / 2.36 oz
Обхват запястья140-240 mm
Водостойкий30 m
Тип батареиCR2032
Сменная батарея✔
Время, дата✔
Будильник1 daily alarm
Время для двух часовых поясов✔
Таймер обратного отсчета✔
Секундомер✔
ЯзыкиEN, DE, ES, FR
ПодсветкаLED
Настраиваемая подсветкаactivation: 1 button, all buttons
Блокировка кнопок✔
Тип дисплеяmatrix
Метрическая и британская системы измерения✔
Индикатор заряда батареиlow battery indicator
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-20° C to +60° C / -5° F to +140° F
Температура хранения-30° C to +60° C / -22° F to +140° F
BATTERY LIFE
In time mode12 months
КОМПАС
Цифровой компас✔
Шкала направленияdegrees
Стрелкаnorth indicator
Фиксация курса с индикатором ориентирования✔
Точность компаса5°
Дискретность компаса1°
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
АЛЬТИМЕТР
Барометрический альтиметр✔
График высот над уровнем моря✔
Перепад высот над уровнем моря✔
Общий подъем/спускair pressure based
Автопереключение профиля высотомера и барометра✔
Интервал регистрации в журнале1, 5, 10, 30, 60 s
Дискретность1 m
Диапазон-500 - 9000 m
ПОГОДА
Время восхода/захода солнца✔
Штормовое предупреждение✔
Атмосферное давление✔
Термометр✔
Диапазон отображения температуры✔
Дискретность температуры1°
Дискретность давления1 hPa / 0.03 inHg
Макс. продолжительность регистрации погоды7 days
График изменения атмосферного давления✔
Индикатор прогноза погоды✔
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ОХОТА
Красная подсветка, не слепящая приборы ночного видения✔
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
ФРИДАЙВИНГ
Глубиномер для подводного плавания с трубкой10 m
