Karoo 2 Cycling Computer
Suunto compatible cycling computer that brings the power of advanced navigation, Suunto heatmaps, and intuitive software to your handlebars, all on a stunning, smartphone-like display.
See the adventure ahead
Karoo 2 is a Suunto compatible cycling computer that brings the power of advanced navigation and intuitive software to your handlebars, all on a stunning, smartphone-like display. When connected with Suunto app, Suunto heatmaps show the most popular rides right on Karoo 2 screen. With Suunto app you can create new routes for your Karoo 2 even on the go.
Afterwards all your rides are available for further analyses in Suunto app – along with the runs, swims, strength sessions and other exercise you have tracked with your Suunto watch. The long-term analyses in Suunto app are powered by TrainingPeaks. Suunto app also helps you monitor your daily activity and sleep to keep your life in balance.
Key features
BENEFITS
Software
External hardware
Internal hardware
ХАРАКТЕРИСТИКИ
Размеры60.8 x 100.6 x 19.3 mm / 2.39 x 3.96 x 0.76 "
Вес131 g / 4.62 oz
Материал стекла:Dragontrail™ with anti-glare etching
Материал корпуса:Glass-filled high-impact polycarbonate chassis with interlocking protective shells and weather-resistant gaskets
КомплектацияHammerhead Karoo 2, Hammerhead Mounting System, Quarter-turn Mounting Adapter, 2.5mm allen key, USB-A to USB-C Cable, Lanyard, Getting Started Guide
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал стеклаDragontrail™ with anti-glare etching
Материал корпусаGlass-filled high-impact polycarbonate chassis with interlocking protective shells and weather-resistant gaskets
Вес131 g / 4.62 oz
Блокировка сенсорного экрана✔
Сенсорный дисплей✔
Цветной экран✔
ВодостойкийIP67
Тип батареиrechargeable lithium-ion
Обновляемое встроенное ПО✔
Время, дата✔
ЯзыкиEnglish only
Подсветкаuser-adjustable
Размер экрана3.2" diagonal
Тип дисплеяTFT LCD
Разрешение дисплея480 x 800
Метрическая и британская системы измерения✔
Автоматические беспроводное обновление прошивки✔
Индикатор заряда батареиpercentage / icon
Internal storage32 GB
Customized displays in device✔
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-15° C to +55° C / +5° F to +130° F
Температура хранения-15° C to +55° C / +5° F to +130° F
BATTERY LIFE
Battery life12 hours of ride time
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
Совместимо с приложением Suunto✔
Поддержка спортивных онлайн-сообществ✔
Автоматическое обновление программного обеспечения по беспроводной сети✔
Live tracking✔
USB-C✔
Software updates from cloudOver-the-air via WiFi
Phone notifications✔
Mobile network (via optional SIM card)2G/3G/4G
BluetoothSensor and audio
ANT+✔
WiFi✔
Совместимость со смартфонамиMost common models supported
ONBOARD SENSORS
Temperature✔
Altimeter✔
3-axis gyroscope✔
3-axis magnetometer✔
3-axis accelerometer✔
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
Спутниковые системыGPS, GLONASS, QZSS, BEIDOU
Интервал регистрации GPS1s
Навигация по путевым точкам и визуальная навигация по маршруту✔
Масштабирование при навигации✔
Построение обратного маршрута в реальном времени✔
Планирование маршрутов с профилем высотvia Suunto app & Hammerhead.io
Топография местности и спутниковые картыvia Suunto app & Hammerhead.io
Навигация по интересующим пунктам (POI)✔
Анализ маршрута по данным GPSvia Dashboard
ETA (расчетное время прибытия)✔
Upcoming elevation graphs✔
Historic elevation graphs✔
Beeper notification for navigation✔
Map on device✔
Auto route sync✔
Wireless route import✔
Personal route library synced to Karoo 2✔
Offline navigation to route start✔
Auto-detect upcoming climbs✔
Rerouting speedunder 5 seconds
Routing customization✔
Pin-drop route creation✔
АЛЬТИМЕТР
Барометрический альтиметр✔
Высота по данным GPS✔
Вертикальная скорость✔
Автопереключение профиля высотомера и барометра✔
Интервал регистрации в журнале1 s
Дискретность1 m
Диапазон-500 - 9000 m
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ЧАСТОТА СЕРДЦЕБИЕНИЯ
Частота сердцебиения в удаках в минуту✔
Личные пульсовые зоны✔
Совместимость с датчиками сердечного ритма✔
СКОРОСТЬ И РАССТОЯНИЕ
Скорость и расстояние по данным GPS✔
Хронографvia GPS/Speed Sensor
Автоэтапы✔
Ручной отсчет этапов✔
Анализ темпа, графики скорости и маршруты на картеvia 3rd parties such as Strava
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ЕЗДА НА ВЕЛОСИПЕДЕ
Скорость езды✔
Средняя скорость в режиме реального времени✔
Таблица этапов в реальном времени со средними показателями: частота сердцебиения, мощность и скорость✔
Подсказки для интервальных тренировок с мощностью, скоростью и пульсом✔
Bike lap and Lap Maximum Power✔
Мощность езды на велосипеде за 3 с, 10 с, 30 с (с датчиком мощности)✔
Электронная смена передачwith SRAM eTap, SRAM AXS, Shimano Di2, Campagnolo EPS and FSA K-Force
Задний радарwith ANT+ radar devices
СПОРТИВНЫЕ РЕЖИМЫ
Подходит для спортаcycling, indoor cycling, mountain biking
