1 / 5
Suunto EON Steel Black
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS050558000
Suunto EON Steel
Black
Sale price€1.079
Highly durable dive computer equipped with two algorithms, rechargeable battery and wireless mobile connection. Made in Finland.
Choose Your Color
Quantity
30-Days Return
Global Support
€1.079
Add to cart
Freedom of choice
Caves, wrecks or the blue unknown – the choice is yours. Equipped with Suunto Fused™ RGBM 2 and Bühlmann 16 with Gradient Factors dive algorithms, Suunto EON Steel Black is the ultimate dive companion for divers demanding the most. With its extremely durable design, multi-gas and CCR support, customizable features and wireless mobile connectivity with Suunto app, your diving adventure has no limits. Designed and tested by divers, for divers.
KEY FEATURES
MULTIPLE ALGORITHMS
CUSTOMIZABLE
UPDATABLE SOFTWARE
WIRELESS MOBILE CONNECTION
WIRELESS TANK PRESSURE
RECHARGEABLE BATTERY
FOR ALL DIVING
150 M WATER RESISTANT
BENEFITS
Full configurability for all diving
Suunto EON Steel Black is designed to give you the freedom to tailor your dive computer to fit your diving needs. You can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. Intuitive menus and a simple 3-button layout make Suunto EON Steel Black very easy to use despite the many options available.
Equipped with two dive algorithms; Suunto Fused™ RGBM 2 and Bühlmann 16 GF and configurable ascent profiles, you decide what is your decompression profile for today’s dive.
Designed for years to come
Suunto EON Steel Black comes with a stylish brushed stainless steel bezel and a vivid high contrast screen - easy to read even in low light conditions. The long-lasting battery endures even the toughest diving conditions, and with a full charge, provides up to 40 hours of diving.
Put to the test in the toughest diving conditions by Suunto’s internal dive team on hundreds of dives - the Steel Black is functional, accurate, and built to take a beating. The reusable storage case and user updatable software, Suunto EON Steel Black is your trusted diving companion for years to come.
Wireless connection
Transfer your dive logs easily over Bluetooth to your mobile phone. In Suunto app you can relive, and share your diving adventures, build an all-inclusive dive history by enriching your dive logs with photos, comments and dive location. Review and analyze your dive data including dive time, maximum depth, device settings, gas consumption (when using Suunto Tank POD).
Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto EON Steel Black with Suunto Tank POD before diving. You can connect up to 20 PODs.
SPECIFICATIONS
  • Weight
    347 g / 12.24 oz
  • Bezel material:
    Stainless steel
  • Glass material:
    Xensation Glass
  • Case material:
    Reinforced composite
  • Strap material:
    Elastomer, Bungee
  • What's in the box?
    Suunto EON Steel Black, USB Cable, Quick Guide, Safety and Regulatory leaflet, International warranty leaflet, Protective boot, Display scratch guard sticker, Bungee adapter and extra strap loop, Suunto sticker
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Stainless steel
  • Glass material
    Xensation Glass
  • Case material
  • Strap material
    Elastomer, Bungee
  • Weight
    347 g / 12.24 oz
  • Flip display
  • Water resistance
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Stopwatch timer
  • Language
  • Backlight
    LED
  • Configurable backlight
  • Display type
    color TFT
  • Display resolution
    320 x 240
  • Metric and imperial units
  • Battery indicator
    icon + dive hours remaining
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
COMPASS
  • Digital compass
  • Tilt compensation
    up to 45°
  • Declination correction
  • Direction scale
    degrees
  • Needle
    compass rose
  • Globally balanced
  • Compass accuracy
    +/- 15°
  • Compass resolution
CONNECTIVITY
    inductive (up to 20 Tank PODs), Bluetooth Smart
  • Compatible with Suunto app
  • Compatible with SuuntoLink
  • Compatible with DM5
  • Log transfer
    Bluetooth Smart / USB cable
  • Smartphone compatibility
    Most common models supported
OUTDOOR FUNCTIONS
WEATHER
  • Temperature
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
DIVING FUNCTIONS
BASIC
  • Altitude adjustment
  • Ascent time display
    0 - 999 min ( > after 999)
  • CNS/OTU (OLF) calculation
  • Custom displays
    4 per dive mode
  • Decompression model
    Suunto Fused™ RGBM 2 Bühlmann 16 GF
  • Decompression profile options
    continuous and stepped
  • Deep Stop
  • Dive history
    lifetime
  • Dive time
    0 to 999 min
  • Gas consumption (real-time)
  • Gas max pO2
    manual 0.5 - 1.6 / fixed 1.6
  • Gas switching
  • Gas time
  • Gases
    up to 20 gases (Oxygen 5 - 99% / Helium 0 -95%)
  • Gauge
  • Logbook bookmarks
  • Logbook memory
  • Logbook sampling rates
    10 s
    150 m
  • Nitrox (and air)
  • No fly time
  • No-decompression planner
  • Personal adjustment
    P+2, P+1, P0, P-1, P-2Gradient factors low (10-100) and high (50-100)
  • Rebreather (CCR), fixed point
  • Safety Stop
  • Surface time
    0 to 100 h
  • Timer
  • Trimix (mixed gas)
  • Visual style
    Default/Graphical/Prominent
  • Wireless gas integration
    optional (up to 20 different tanks with Suunto Tank POD)
DIVE ALARMS AND NOTIFICATIONS
  • CNS/OTU (OLF) 80% / 100%
  • Deepstop violation
  • Diluent high pO2
  • Diluent low pO2
  • Diluent switched automatically
  • Dive time
  • Gas time
  • High pO2 (hyperoxic)
  • ICD warning
  • Low pO2 (hypoxic)
  • Maximum depth
  • Tank pressure
  • Too fast ascent
REBREATHER
  • Diluents
  • Bailout
  • High/low setpoints
  • Custom setpoint
  • Manual/automatic setpoint switching
Recommended products
VIDEOS
You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
SUPPORT FOR SUUNTO EON STEEL BLACK
