1 / 3
1/3
Retour sous 30 jours
Assistance mondiale
SKU : SS050579000
Suunto Smart Heart Rate Belt
Prix de vente$106
Ceinture de fréquence cardiaque multisport précise et confortable
Choisissez votre couleur
Quantité
Assistance mondiale
Ceinture de fréquence cardiaque Suunto Smart
$106
Ajouter au panier
The Suunto Smart Heart Rate Belt provides accurate heart rate data without compromising comfort. The belt provides superior performance in sports where hand movement disturbs wrist heart rate measurements and allows measuring heartrate wearing the watch on top of the sleeve or attached to the bike handlebar or even not carrying the watch at all during the exercise.
The Suunto Smart Heart Rate Belt has an R-R memory that is used when the watch is not within reach of the Bluetooth smart radio. This is great for example in team sports where it allows recording without wearing the watch. The memory function is supported with all Bluetooth Smart enabled watches except Suunto Run, Suunto 7 and Suunto Kailash.
Biking, team sports, martial arts, climbing, swimming, water sports, triathlon, ski mountaineering, cross country skiing, skating and gym enthusiasts will see the greatest benefits from using the Suunto Smart Heart Rate Belt.
The Suunto Smart Heart Rate Belt is also a great companion for the free Sports Tracker app with Android, iOS and Watch OS devices.
The belt included in the package is black size M. You can purchase a spare Suunto Chest Strap separately available in sizes S, M and L.
Caractéristiques principales
  • Confortable, légère, peu encombrante
  • Sports multiples, notamment les sports d’hiver, le cyclisme, la natation et les sports d’équipe
  • Compatible avec les appareils intelligents Bluetooth / appareils BLE
  • Mesure de la fréquence cardiaque : Oui
  • Mesure de la variabilité de la fréquence cardiaque : Oui
  • Autonomie : 500 h
  • Changement facile de la batterie : Oui
  • Pile : CR2025
  • Module émetteur amovible : Oui
  • Sangle de poitrine remplaçable : oui
  • Poids avec ceinture taille M : 40,6 g
  • Dimensions du module Smart : 36,5 x 36,5 x 8 mm
  • Fourchette de taille pour la sangle de poitrine : S : 56-82 cm, M : 70-110 cm, L : 96-160 cm
  • Étanchéité : 30 m (adaptée à la natation)
  • Matériau du module : composite renforcé de fibres
  • Matériau du bracelet : polyamide/élasthanne avec surfaces de contact en polyuréthane
  • Compatibilité radio : Bluetooth Smart (Bluetooth Low Energy)
  • Mémoire interne : stocke et transmet 3,5 h de données de mesure à 120 bpm lorsqu'utilisée avec une montre Suunto compatible
  • Plage de température : -20…+60 °C
  • Compatible avec les vêtements Movesense : Oui
  • Instructions de lavage : rincer après chaque usage, laver en machine la sangle de poitrine sans le module smart à 30 °C après 2-3 utilisations. Ne pas utiliser d'adoucissant.
AVEZ-VOUS DES QUESTIONS OU AVEZ-VOUS BESOIN D'AIDE ?
