Suunto Race 2
Feather Gray
Ultimate performance watch for racing and training — improved
- Bright 1.5” AMOLED display
- Sleeker and lighter design
- Advanced training and everyday activity tracking
- 115+ sport modes
- Offline maps, improved navigation
- Up to 55 hours battery
Choose your Color
Designed for the driven
For athletes who train with intention, to perform when it counts.
Whether you’re chasing a summit, preparing for a race, or simply carving out time from the daily grind, Suunto Race 2 is the ultimate training and racing watch to help you achieve your personal best.
Performance that feels as good as it looks
Great design isn’t just about aesthetics, it’s about enhancing your performance. That’s why we made the AMOLED display larger and brighter — making it easier to read stats and navigate a route at a quick glance, even in low light.
The redesigned back panel enables better heart rate measurement from the wrist. The result? A seamless, powerful training experience.
Battery life that goes the distance
When you’re at the starting line of a race, the last thing you should worry about is your watch’s battery. That’s why Suunto Race 2 was built with one of the longest-lasting batteries in its class and an improved secure-snap charging interface to get you up to speed fast. Train and explore on your terms with the confidence that your watch can go the distance.
Training, continuous tracking
Up to 55 hours
Performance mode, best GPS accuracy
Up to 200 hours
Up to 16 days
Up to 22 days
For your runs and beyond
Performance is a year-round activity. With 115+ sport modes, Race 2 is your companion from trail running and ski touring to mountain biking and open water swimming.
Whatever your sport, the redesigned hardware and improved algorithms provide best possible accuracy so you can stay in the correct zone and get a more precise reading of your training load, wherever your session takes you.
A coach and watch in one
Optimize every workout and perform your best with intuitive insights from Suunto Coach. Our software analyzes trends in your training load, recovery, and progress to give you clear, actionable feedback, on your watch and Suunto App.
Experience a watch that adapts to your training, your physiology, and each season of an active life.
A watch that evolves with you
Your ambition doesn’t stand still, and neither should your watch. We designed Suunto Race 2 with faster hardware and a significant increase in memory for one key reason: to ensure it’s ready for the road ahead - full of new features and software updates.
Coupled with our growing ecosystem of partner apps, like Strava and TrainingPeaks, Race 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto app can offer you.
SPÉCIFICATIONS
Mesures49 x49 x12.5 mm /1.93 x1.93 x 0.49
Poids76g
Matériau de la lunetteStainless steel
Matériau du verreSapphire crystal
Matériau du boîtierGlass fibre reinforced polyamide
Matériau du braceletSilicone
Pays de fabricationCN
TECHNICAL SPECIFICATIONS
GÉNÉRAL
Poids76g
Tailles de poignet125-175 mm
Largeur du bracelet22 mm
Fréquence cardiaque au poignet intégrée✔
Cadrans personnalisables✔
Verrouillage de l’écran tactile✔
Écran tactile✔
Écran couleur✔
Alerte par vibration✔
Résistance à l’eau100 m
Type de batterierechargeable lithium-ion
Mise à jour du firmware✔
Heure, date✔
Réveil✔
Double fuseau horaire✔
Horodatage automatique✔
Minuteur✔
Chronomètre✔
LangueCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
RétroéclairageLTPO AMOLED
Rétroéclairage configurableautomatic brightness
Verrouillage des boutonsduring exercise
Taille de l’écran1,5"
Type d’écranmatrix
Résolution de l’écran466 x 466
Unités métriques et impériales✔
Heure d’été automatique✔
Indicateur de batteriepercentage / icon
Oxygène sanguin✔
Affichage permanent✔
CARACTÉRISTIQUES PHYSIQUES
Température de fonctionnement-20° C to +55° C / -5° F to +130° F
Température de stockage-20° C to +55° C / -5° F to +130° F
Température de mise en charge recommandée0° C to +35° C / +32° F to +95° F
AUTONOMIE
Rappels de charge intelligents✔
Utilisation quotidienne : mode montre connectéeup to 18 days
Utilisation quotidienne : Mode veille uniquementup to 30 days
Entraînement : Mode GNSS tous systèmes + Multi-Bandup to 55h (AOD 50)
Entraînement : Mode GNSS tous systèmes + Single-Bandup to 65h (AOD 60)
Entraînement : Promesses de batterie pour tous les modes55h / 65h / 90h / 200h
Entraînement : modes GNSS d'économie d'énergieup to 200h
BOUSSOLE
Boussole numérique✔
Compensation de l'inclinaison✔
Correction de déclinaison✔
Échelle de directiondegrees / mils
Aiguillenorth indicator
Précision de la boussole5°
Résolution de la boussole1°
CONNECTIVITÉ
Connectivité (entre appareils)Bluetooth
Compatible avec l'application Suunto✔
Affichage des notifications du téléphone sur la montre✔
Contrôle des médias depuis la montre✔
Envoi de réponses prédéfinies aux messages entrants depuis la montreAndroid only
Compatible avec les différentes communautés sportives en ligneStrava, TrainingPeaks and more
Mises à jour logicielles de la montre depuis le cloud✔
Mises à jour logicielles sans fil automatiques✔
Compatibilité avec les smartphonesMost common models supported, check here for detailed compatibility list
24/7
SUIVI D'ACTIVITÉ
Compteur de pas✔
Calories brûlées✔
Objectifs d'activité physiquesteps, calories
Historique des activités✔
TCalories dépensées et fréquence cardiaque au cours des activités quotidiennes✔
Suivi de la fréquence cardiaque journalière minimale✔
SUIVI DU SOMMEIL
Durée du sommeil✔
Heures de coucher✔
Temps éveillé✔
Sommeil profond✔
Fréquence cardiaque moyenne et minimum pendant le sommeil✔
Sommeil léger✔
REM✔
VFC du sommeil✔
Qualité du sommeil✔
STRESS ET RÉCUPÉRATION
Niveau des ressources journalières✔
État de stress et récupération✔
Mesure de la VFC✔
SUIVI GPS & NAVIGATION
Cartes hors ligne sur la montre✔
Systèmes par satelliteGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Systèmes satellites simultanés4
Nombre maximum de satellites connectés32
Modes batterie intelligentsPerformance, Endurance, Ultra, Tour
Fréquence d'enregistrement GPSBest, Good, OK, Low
Navigation par points de passage et itinéraire visuel✔
Niveaux de zoom dans la navigation✔
Zoom auto basé sur la forme de l'itinéraire✔
Création de trace en temps réel (« Petit Poucet »)✔
Planification d'itinéraire avec profil d'altitude✔
Cartes topographiques et cartes satellite✔
Cartes de fréquentation du monde entier pour 20 sports✔
Planification d'itinéraire avec les cartes de chaleur✔
Bibliothèque personnelle d'itinéraires sur le Web synchronisée avec la montre✔
Passer à l'itinéraire✔
Navigation vers un point d'intérêt (POI)✔
Analyse de trace GPS✔
Enregistrement, visualisation et partage des itinéraires✔
HAE (heure d'arrivée estimée)✔
ALTIMÈTRE
Altitude barométrique✔
Altitude GPS✔
Altitude GPS et barométrique combinée (FusedAlti™)✔
Altitude en mode quotidien✔
Acclimatation à l'altitude avec l'oxygène sanguin✔
Totaux des ascensions/descentes✔
Vitesse verticale✔
Profil altimètre/baromètre automatique✔
Fréquence d'enregistrement du journal1 s
Résolution1 m
Portée-500 - 9999 m
MÉTÉO
Heures de lever/coucher du soleil✔
Alarme d'orage✔
Pression au niveau de la mer✔
Température✔
Plage d'affichage de température-20° C to +55° C / -5° F to +130° F
Résolution de température1° C / 1.5° F
Résolution de pression1 hPa
ENTRAÎNEMENT FRACTIONNÉ
Configuration d'intervalles✔
Assistance pour l'entraînement fractionné pendant la séance✔
Intervalles structurés✔
FRÉQUENCE CARDIAQUE
Fréquence cardiaque mesurée à partir du poignet✔
Compatibilité ceinture de fréquence cardiaqueBluetooth HR belts
Intervalle RRwith Suunto Smart Sensor
Fréquence cardiaque en battements par minute✔
Enregistre la fréquence cardiaque pendant la natation✔
Graphique de fréquence cardiaque en temps réel✔
Fréquence cardiaque moyenne en temps réel✔
Calories✔
Pic d'effet d'entraînement✔
Zones de fréquence cardiaque personnelles✔
Niveau de forme (VO2max)✔
Détection du seuil de lactate✔
Temps de récupération✔
VITESSE ET DISTANCE
Vitesse et distance basées sur la cadence✔
Vitesse et distance GPS✔
Chrono✔
Compatible avec le capteur de fouléeBluetooth Foot Pods
Tours automatiques✔
Tours manuels✔
Analyse de l'allure, graphiques de vitesse et traces sur la carte✔
RÉCUPÉRATION DE L'ENTRAÎNEMENT
Sentiment enregistré après l'entraînement sur la montre✔
Temps de récupération selon l'entraînement✔
CHARGE D'ENTRAÎNEMENT
Journal avec détails des exercices✔
Charge d'entraînement avec totaux par sport✔
Journal d'entraînement pour les vues d'ensemble sur le long terme✔
Récapitulatif des exercices avec détails des tours✔
PARTAGER ET REVIVREZ
Partage de l'exercice sur les réseaux sociaux✔
Évaluation et commentaire des exercices✔
Suivez les autres membres et recevez des avis via le flux des activités✔
L'EXPERTISE DU SPORT
NATATION
Rythme de nage en bassin et distance✔
Distance de nage en eau libre✔
Temps de nage par longueur de bassin, tours, total✔
Cadence et type de nage et nombre de mouvements✔
Efficacité des mouvements (SWOLF)✔
Intervalles automatiques✔
Tableau de tours en fractionné✔
CYCLISME
Vitesse cycliste✔
Vitesse moyenne en temps réel✔
Bike POD avec prise en charge de la vitesse et de la cadenceBluetooth Bike Pods
Prise en charge des appareils de mesure de puissance cyclisteBluetooth Power meters
Puissance cycliste (W), moyenne et maximum (avec capteur de puissance)Bluetooth Power meters
Tours en vélo et puissance maximum par tour (avec capteur de puissance)✔
Tableau de tours en temps réel avec FC moyenne, puissance moyenne et vitesse moyenne✔
Assistance pour l'entraînement fractionné avec puissance/vitesse/fréquence cardiaque✔
COURSE
Rythme de course✔
Suunto FusedSpeed™✔
Puissance de course à pied✔
SuuntoPlus™ Ghost runner✔
Étalonnage de capteur de fouléeautomatic
Tableau des tours dans la montre et l'appli Suunto✔
Cadence moyenne, maxi., au tour en temps réel✔
Assistance pour l'entraînement fractionné avec allure de course/fréquence cardiaque/distance✔
MULTISPORTS
Changer de mode sportif pendant l'exercice✔
Modes multisports préconfigurés✔
Analyse post-exercice multisport par sport✔
Résumé de l'exercice multisport sur la montre✔
MODES SPORTIFS
Modes sportifs et affichages personnalisables✔
Affichages graphiques dans les modes sportifs✔
Modes sportifs préinstallés sur la montre> 90
SuuntoPlus™✔
FONCTIONS DE PLONGÉE
APNÉE
Profondimètre pour le snorkeling10 m
