Suunto Race 2
Coral Orange
Ultimate performance watch for racing and training — improved
- Bright 1.5” AMOLED display
- Sleeker and lighter design
- Advanced training and everyday activity tracking
- 115+ sport modes
- Offline maps, improved navigation
- Up to 55 hours battery
Choose your Color
Designed for the driven
For athletes who train with intention, to perform when it counts.
Whether you’re chasing a summit, preparing for a race, or simply carving out time from the daily grind, Suunto Race 2 is the ultimate training and racing watch to help you achieve your personal best.
Performance that feels as good as it looks
Great design isn’t just about aesthetics, it’s about enhancing your performance. That’s why we made the AMOLED display larger and brighter — making it easier to read stats and navigate a route at a quick glance, even in low light.
The redesigned back panel enables better heart rate measurement from the wrist. The result? A seamless, powerful training experience.
Battery life that goes the distance
When you’re at the starting line of a race, the last thing you should worry about is your watch’s battery. That’s why Suunto Race 2 was built with one of the longest-lasting batteries in its class and an improved secure-snap charging interface to get you up to speed fast. Train and explore on your terms with the confidence that your watch can go the distance.
Training, continuous tracking
Up to 55 hours
Performance mode, best GPS accuracy
Up to 200 hours
Up to 16 days
Up to 22 days
For your runs and beyond
Performance is a year-round activity. With 115+ sport modes, Race 2 is your companion from trail running and ski touring to mountain biking and open water swimming.
Whatever your sport, the redesigned hardware and improved algorithms provide best possible accuracy so you can stay in the correct zone and get a more precise reading of your training load, wherever your session takes you.
A coach and watch in one
Optimize every workout and perform your best with intuitive insights from Suunto Coach. Our software analyzes trends in your training load, recovery, and progress to give you clear, actionable feedback, on your watch and Suunto App.
Experience a watch that adapts to your training, your physiology, and each season of an active life.
A watch that evolves with you
Your ambition doesn’t stand still, and neither should your watch. We designed Suunto Race 2 with faster hardware and a significant increase in memory for one key reason: to ensure it’s ready for the road ahead - full of new features and software updates.
Coupled with our growing ecosystem of partner apps, like Strava and TrainingPeaks, Race 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto app can offer you.
ESPECIFICACIONES
Medidas49 x49 x12.5 mm /1.93 x1.93 x 0.49
Peso76g
Material del bisel:Stainless steel
Material de la lente:Sapphire crystal
Material de la carcasa:Glass fibre reinforced polyamide
Material de la correa:Silicone
País de fabricaciónCN
ESPECIFICACIONES TÉCNICAS
Material de la lenteSapphire crystal
Material de la carcasaGlass fibre reinforced polyamide
Material de la correaSilicone
Peso76g
Tallas de muñeca125-175 mm
Ancho de la correa22 mm
Frecuencia cardíaca desde la muñeca integrada✔
Esferas de reloj personalizables✔
Bloqueo de pantalla táctil✔
Pantalla táctil✔
Pantalla en color✔
Alerta mediante vibración✔
Sumergibilidad100 m
Tipo de pilarechargeable lithium-ion
Firmware actualizable✔
Hora, fecha✔
Despertador✔
Hora dual✔
Control de hora automático✔
Temporizador de cuenta atrás✔
Cronómetro✔
IdiomasCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
Luz de fondoLTPO AMOLED
Luz de fondo configurableautomatic brightness
Bloqueo de botonesduring exercise
Tamaño de pantalla1,5"
Tipo de pantallamatrix
Resolución de pantalla466 x 466
Unidades métricas e imperiales✔
Indicador de bateríapercentage / icon
Oxígeno en sangre✔
Pantalla siempre activa✔
ESPECIFICACIONES FÍSICAS
Temperatura de funcionamiento-20° C to +55° C / -5° F to +130° F
Temperatura de almacenamiento-20° C to +55° C / -5° F to +130° F
Temperatura de carga recomendada0° C to +35° C / +32° F to +95° F
DURACIÓN DE LA BATERÍA
Recordatorios de carga inteligentes✔
Uso diario: modo smartwatchup to 18 days
Uso diario: solo modo de esperaup to 30 days
Entrenamiento: modo GNSS de todos los sistemas + multibandaup to 55h (AOD 50)
Entrenamiento: modo GNSS de todos los sistemas + banda únicaup to 65h (AOD 60)
Entrenamiento: promesas de batería para todos los modos55h / 65h / 90h / 200h
Entrenamiento: modos GNSS de ahorro de energíaup to 200h
BRÚJULA
Brújula digital✔
Compensación de inclinación✔
Corrección de la declinación✔
Escala de direccióndegrees / mils
Agujanorth indicator
Exactitud de la brújula5°
Resolución de brújula1°
CONECTIVIDAD
Conectividad (entre dispositivos)Bluetooth
Compatible con la Suunto app✔
Notificaciones del teléfono en el reloj✔
Controles multimedia en el reloj✔
Envía desde el reloj respuestas predefinidas a los mensajes entrantesAndroid only
Compatible con las comunidades deportivas en líneaStrava, TrainingPeaks and more
Actualizaciones del software del reloj desde la nube✔
Actualizaciones de software inalámbricas automáticas✔
Compatibilidad con smartphoneMost common models supported, check here for detailed compatibility list
24/7
SEGUIMIENTO DE LA ACTIVIDAD
Contador de pasos✔
CClorías quemadas✔
Objetivos de actividadsteps, calories
Historial de actividad✔
Calorías quemadas y frecuencia cardíaca durante las actividades diarias✔
Seguimiento de la frecuencia cardíaca diaria mínima✔
SEGUIMIENTO DEL SUEÑO
Duración del sueño✔
Horas de acostarse✔
Tiempo despierto✔
Sueño profundo✔
Frecuencia cardíaca media y mínima durante el sueño✔
Sueño ligero✔
REM✔
VFC durante el sueño✔
Calidad del sueño✔
ESTRÉS Y RECUPERACIÓN
Nivel de recursos diario✔
Estado de estrés y recuperación✔
Medición de la VFC✔
FUNCIONES PARA AIRE LIBRE
Mapas sin conexión en el reloj✔
Sistemas de satéliteGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Sistemas de satélite simultáneos4
Máximos satélites conectados32
Modos de batería inteligentePerformance, Endurance, Ultra, Tour
Frecuencia de grabación GPSBest, Good, OK, Low
Navegación por puntos de referencia y rutas visuales✔
Niveles de zoom en navegación✔
Auto zoom basado en la forma de la ruta✔
Sendero de navegación en tiempo real✔
Planificación de ruta con perfil de altitud✔
Mapas de terreno y de satélite para aire libre✔
Mapas de calor globales para 20 deportes✔
Planificación de rutas con mapas térmicos✔
Librería de rutas personales sincronizadas con el reloj✔
Ajuste de ruta✔
Navegación de puntos de interés (PDI)✔
Análisis de rutas de GPS✔
Registro, visualización e intercambio de rutas✔
Hora de llegada estimada (ETA)✔
ALTÍMETRO
Altitud barométrica✔
Altitud de GPS✔
Altitud combinada GPS y barométrica (FusedAlti™)✔
Altitud en modo diario✔
Aclimatación a la altitud con oxígeno en sangre✔
Ascenso/descenso total✔
Velocidad vertical✔
Perfil automático alti/baro✔
Frecuencia de grabación de registros1 s
Resolución1 m
Intervalo-500 - 9999 m
METEOROLOGÍA
Hora de amanecer/puesta de sol✔
Alarma de tormenta✔
Presión a nivel del mar✔
Temperatura✔
Intervalo de indicación de temperatura-20° C to +55° C / -5° F to +130° F
Resolución de temperatura1° C / 1.5° F
Resolución de presión1 hPa
FUNCIONES DE ENTRENAMIENTO
ENTRENAMIENTO CON INTERVALOS
Establecer intervalos✔
Guía de intervalos durante el entrenamiento✔
Intervalos estructurados✔
FRECUENCIA CARDÍACA
Medición de frecuencia cardíaca desde la muñeca✔
Compatibilidad con cinturón de frecuencia cardíacaBluetooth HR belts
Intervalo RRwith Suunto Smart Sensor
Frecuencia cardíaca en latidos por minuto✔
Registra la frecuencia cardíaca al nadar✔
Gráfica de frecuencia cardíaca en tiempo real✔
Frecuencia cardíaca media en tiempo real✔
Calorías✔
Peak Training Effect✔
Zonas personales de frecuencia cardíaca✔
Nivel de forma física (VO2máx)✔
Detección del umbral de lactato✔
Tiempo de recuperación✔
VELOCIDAD Y DISTANCIA
Velocidad y distancia basadas en cadencia✔
Velocidad y distancia de GPS✔
Cronómetro✔
Compatible con Foot PODBluetooth Foot Pods
Autolaps✔
Vueltas manuales✔
Análisis de ritmo, gráficos de velocidad y senderos en el mapa✔
RECUPERACIÓN DE ENTRENAMIENTO
Tras el entrenamiento, el reloj guarda información sobre cómo te has sentido✔
Tiempo de recuperación según entrenamiento✔
CARGA DE ENTRENAMIENTO
Diario con datos de los ejercicios✔
Carga de entrenamiento con totales por deporte✔
Diario de entrenamiento para resúmenes a largo plazo✔
Resumen de ejercicios con datos de vueltas✔
COMPARTE Y REVIVE
Puntuación y comentarios de los ejercicios✔
Sigue a otros miembros y obtén feedback mediante streaming de actividades✔
CAPACIDADES PARA DEPORTE
NATACIÓN
Ritmo y distancia de natación en piscina✔
Distancia de natación en aguas abiertas✔
Tiempo de natación por largo de piscina, vueltas, total✔
Frecuencia de brazada en natación, cuenta y tipo✔
Eficiencia de brazada (SWOLF)✔
Intervalos automáticos✔
Tabla de vueltas de intervalos✔
CICLISMO
Velocidad de ciclismo✔
Velocidad media en tiempo real✔
Bike POD con soporte de velocidad/cadenciaBluetooth Bike Pods
Soporte de medición de Bike PowerBluetooth Power meters
Potencia de bicicleta (W), media y máxima (con sensor de potencia)Bluetooth Power meters
Vuelta de bicicleta y potencia máxima de vuelta (con sensor de potencia)✔
Tabla de vueltas en tiempo real con FC media, potencia media y velocidad media✔
Guía de intervalos con potencia/velocidad/frecuencia cardíaca✔
CARRERA
Ritmo de carrera✔
Suunto FusedSpeed™✔
Ajuste de ruta✔
Potencia de carrera✔
SuuntoPlus™ Ghost runner✔
Calibración de Foot PODautomatic
Tabla de vueltas en el reloj y en la app Suunto✔
Cadencia de carrera✔
Guía de intervalos con ritmo/frecuencia cardíaca/distancia en carrera✔
MULTIDISCIPLINARIOS
Cambio de modo de deporte durante el ejercicio✔
Modos multidisciplinarios preconfigurados✔
Análisis posterior de ejercicio multidisciplinario por deportes✔
Resumen de ejercicios multidisciplinarios en el reloj✔
MODOS DE DEPORTE
Modos de deporte y pantallas personalizables✔
Pantallas gráficas en modos de deporte✔
Modos de deporte preinstalados en el reloj> 90
SuuntoPlus™✔
FUNCIONES DE BUCEO
INMERSIÓN EN APNEA
Profundímetro para inmersión con snorkel10 m
