Technical specifications
Dimensions and weight:
- Max. diameter: 40 mm / 1.57 in
- Length: 80 mm / 3.15 in
- Weight: 95 g / 3.4 oz
- Threading: 7/16” - 20UNF
- Hex base size: 19 mm
Operating conditions
- Maximum depth of operation: 150 m / 492 ft (complying with EN 13319)
- Operating temperature: 0 °C to 40 °C / 32 °F to 104 °F
Diving in freezing conditions may damage the dive computer. Make sure the device does not freeze when wet.
- Storage temperature: -20 °C to +50 °C / -4 °F to +122 °F
Store in a dry place at room temperature.
WARNING:
Do not expose the device to temperatures above or below the given limits, otherwise it might get damaged or you might be exposed to safety risk.
Pressure measurements
- Rated working pressure: 300 bar / 4351 psi
Battery
- Type: 3.6 V 1/2 AA Primary lithium-thionyl chloride (Li-SOCl2)
Low temperature or an internal oxidation of the battery may activate the battery warning even though the battery has enough capacity. In this case, the warning usually disappears when the dive mode is activated again.
Do not try to replace the battery by yourself! It should always be replaced by an authorized Suunto Service Center.
Radio transceiver
- Frequency band: single channel 123 kHz
- Maximum output power: 360 mW
See the appropriate product user guides for information on range.
Manufacturer
Suunto Oy
Tammiston kauppatie 7 A
FI-01510 Vantaa FINLAND
Compliance
For compliance related information, see “Product Safety and Regulatory Information” delivered together with your   Suunto Tank POD   or available at    SuuntoTankPodSafety  .
Trademark
Suunto Tank POD , its logos, and other Suunto brand trademarks and made names are registered or unregistered trademarks of Suunto Oy. All rights are reserved.
Patent notice
This product is protected by pending patent applications and their corresponding national rights: US 13/803,795, US 13/832,081, US 13/833,054, US 14/040,808, US 7,349,805, and US 86608266.
Additional patent applications may be filed.
International Limited Warranty
Warranty Period
The Warranty Period is two (2) years for Watches, Smart Watches, Dive Computers, Heart Rate Transmitters, Dive Transmitters, Dive Mechanical Instruments, and Mechanical Precision Instruments unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to Suunto chest straps, watch straps, chargers, cables, rechargeable batteries, bracelets and hoses.
The Warranty Period is five (5) years for failures attributable to the depth measurement (pressure) sensor on Suunto Dive Computers.
Exclusions and Limitations
- normal wear and tear such as scratches, abrasions, or alteration of the color and/or material of non-metallic straps, b) defects caused by rough handling, or c) defects or damage resulting from use contrary to intended or recommended use, improper care, negligence, and accidents such as dropping or crushing;
- printed materials and packaging;
- defects or alleged defects caused by use with any product, accessory, software and/or service not manufactured or supplied by Suunto;
- non-rechargeable batteries.
- has been opened beyond intended use;
- has been repaired using unauthorized spare parts; modified or repaired by unauthorized Service Center;
- serial number has been removed, altered or made illegible in any way, as determined at the sole discretion of Suunto; or
- has been exposed to chemicals including but not limited to sunscreen and mosquito repellents.
You must provide proof of purchase to access Suunto warranty service. You must also register your product online at     apac.suunto.com/register     to receive international warranty services globally. For instructions on how to obtain warranty service, visit   apac.suunto.com/warranty   , contact your local Suunto retailer, or contact Suunto support at   apac.suunto.com/support   .
Limitation of Liability
