Alarms, warnings and notifications
Suunto D5 has color-coded alarms, warnings and notifications. They are shown prominently on the display with an audible alarm (if tones are on). Alarms are always red. Warnings may be red or yellow. Notifications are always yellow.
Suunto D5 has vibration alarm. The vibration can be turned on or off for dive alarms, notifications and warnings.
Alarms are critical events that always require immediate action. When an alarm situation comes back to normal, the alarm will stop automatically.
| Alarm |
Explanation |
Ascent speed exceeds safe speed of 10 m (33 ft) per minute for five seconds or more. |
Decompression ceiling broken by more than 0.6 m (2 ft) on a decompression dive. Immediately descend back below ceiling depth and continue to ascend normally. |
Partial pressure of oxygen exceeds safe level (>1.6). Immediately ascend or change to a gas with lower oxygen percentage. |
Warnings alert you to events that can impact your health and safety if you do not take action. Acknowledge the warning by pressing any button.
| Warning |
Explanation |
| CNS 100% |
Central Nervous System (CNS) Oxygen Toxicity level at 100% limit |
| OTU 300 |
Recommended daily limit for Oxygen Tolerance Unit/Oxygen Toxicity Unit (OTU) reached |
| Depth |
Depth exceeds your depth alarm limit |
| Dive time |
Dive time exceeds your dive time alarm limit |
| Gas time |
Gas time is below your gas time alarm limit, or tank pressure is below 35 bar (~510 psi), in which case gas time is zero. |
| Safety stop broken |
Ceiling of the voluntary safety stop broken by more than 0.6 m (2 ft) |
Tank pressure
 Tank pressure is below your tank pressure alarm limit.
There is a built in 50-bar alarm that cannot be changed. In addition to it, there is a configurable tank pressure alarm you can set to any value and your dive computer also shows an alarm when that value and 50 bar (725 psi) pressure are reached. The tank pressure number is forced onto the display and turns yellow after the value you set and it turns red after 50 bar (725 psi).
Notifications indicate events that require preventive actions. Acknowledge the notification by pressing any button.
| Notification |
Explanation |
| CNS 80% |
Central Nervous System (CNS) Oxygen Toxicity level at 80% limit |
| OTU 250 |
Approximately 80% of recommended daily limit for Oxygen Tolerance Unit/Oxygen Toxicity Unit (OTU) reached |
| Change gas |
On multi-gas dive when ascending, it is safe to switch to next available gas for optimum decompression profile |
| Battery low |
Approximately three hours of dive time left |
| Recharge needed |
Approximately two hours of battery time left; re-charging required before next dive |
| Tank POD low battery |
Tank POD battery life low; battery change required |
Algorithm lock
Breaking the decompression ceiling
When you ascend above the ceiling by more than 0.6 m (2 ft), the ceiling parameter turns red, a red arrow pointing down appears, and an audio alarm is generated.
In such event, you should descend below the ceiling level to continue the decompression. If you fail to do so within three (3) minutes, Suunto D5 locks the algorithm calculation and displays Locked instead, as shown below. Note that the ceiling value is no longer present.
Algorithm locked
Suunto Fused™ RGBM 2 algorithm is locked for 48 hours if you omit to take decompression stops for longer than three (3) minutes. When the algorithm is locked, no algorithm information is available and Locked is shown instead. Locking the algorithm is a safety feature, highlighting that the algorithm information is no longer valid.
Algorithm locked in Timer view:
Algorithm locked in No Deco view:
In this state, you significantly increase your risk of decompression sickness (DCS). Decompression information is not available for the next 48 hours after surfacing.
It is possible to dive with the device when the algorithm is locked, but instead of the decompression information, Locked is shown. Diving while the algorithm is locked resets the algorithm lock time back to 48 hours when you surface.
Altitude diving
The Altitude setting automatically adjusts the decompression calculation according to the given altitude range. You can find the setting under Dive settings » Parameters » Altitude and select from three ranges:
- 0 – 300 m (0 – 980 ft) (default)
- 300 – 1500 m (980 – 4900 ft)
- 1500 – 3000 m (4900 – 9800 ft)
As a result, the allowed no decompression stop limits are considerably reduced.
The atmospheric pressure is lower at high altitudes than at sea level. After traveling to a higher altitude, you will have additional nitrogen in your body, compared to the equilibrium situation at the original altitude. This 'additional' nitrogen is released gradually over time and equilibrium is restored. Suunto recommends that you acclimatize to a new altitude by waiting at least three hours before making a dive.
Before high-altitude diving, you need to adjust the altitude settings of your dive computer so that the calculations take into account the high altitude. The maximum partial pressures of nitrogen allowed by the mathematical model of the dive computer are reduced according to the lower ambient pressure.
WARNING:
Traveling to a higher elevation can temporarily cause a change in the equilibrium of dissolved nitrogen in the body. Suunto recommends that you acclimatize to the new altitude before diving. It is also important that you do not travel to a significantly high altitude directly after diving to minimize the risk of DCS.
WARNING:
SET THE CORRECT ALTITUDE SETTING! When diving at altitudes greater than 300 m (980 ft), the altitude setting must be correctly selected in order for the computer to calculate the decompression status. The dive computer is not intended for use at altitudes greater than 3000 m (9800 ft). Failure to select the correct altitude setting or diving above the maximum altitude limit will result in erroneous dive and planning data.
If you are doing repetitive dives at an altitude other than the previous dive altitude, change altitude setting to correspond to the next dive after the previous dive ended. This ensures more accurate tissue calculations.
Ascent rate
During a dive, the bar on the left indicates ascent rate. One bar step corresponds to 2 m (6.6 ft) per minute.
The bar is also color coded:
Green indicates ascent rate is ok, less than 8 m (26 ft) per minute
Yellow indicates ascent rate is moderately high, 8-10 m (26-33 ft) per minute
Red indicates ascent rate is too high, over 10 m (33 ft) per minute
When maximum allowed ascent rate is exceeded for five seconds, an alarm is generated. Ascent rate violations result in longer safety stop times and mandatory safety stops.
WARNING:
DO NOT EXCEED THE MAXIMUM ASCENT RATE! Rapid ascents increase the risk of injury. You should always make the mandatory and recommended safety stops after you have exceeded the maximum recommended ascent rate. If this mandatory safety stop is not completed the decompression model will penalize your next dive(s).
Battery
Suunto D5 has a rechargeable lithium-ion battery. Charge the battery by connecting Suunto D5 to a power source with the included USB cable. As a power source, use a USB port of 5Vdc, 0.5A or a wall charger.
The battery icon at the bottom of the display shows the battery status.
| Icon |
Explanation |
Battery level is OK. |
Battery level is low. Less than three (3) hours left. |
Battery level is low. Less than two (2) hours left. Recharge needed. |
Battery is charging. |
For Suunto D5, the battery and charging notifications are as follows:
When you connect USB for charging and every time you press a button during charging, the following pop-up notification appears:
When charging from a wall outlet, you will see the following screen:
In watch view and dive views (when on surface and during dives), a yellow 'Battery low' pop-up appears (see below) when there is less than three hours left from battery time. If you press any button, the pop-up disappears.
When the time left decreases to two hours, a 'Recharge needed' red pop-up notification appears if you are on the surface. The red pop-up will stay on the screen on top of everything else and you cannot make it disappear until the device is charged or you change to time view. In case of scuba diving, when the charge level drops below two hours, you cannot start a dive with Suunto D5. For freediving, the limit is 30 minutes.
When the time left decreases to two hours during a dive, the red battery icon (see it in the table above) is displayed. The notification pop-up comes only on the surface so it will not cover information on the display during a dive.
Bookmark
Adding a bookmark (timestamp) to an active log is really easy in Suunto D5. See How to add bookmarks for the procedure.
Clock
You find the time and date settings of your Suunto D5 under Device settings.
You can edit time and date formats under Units & formats. For setting them, see How to set time and date.
You can activate a daily alarm under Main menu » Alarm clock. For more information, see How to set the alarm clock.
Sound and vibration are always on by default. You cannot change this setting for the alarm clock.
Compass
Short pressing the middle button repeatedly brings up the compass. First, you have to calibrate it. See Calibrating compass.
The information on the display depends on which mode you are in.
In Air/Nitrox mode, you see the following information in compass view:
In the switch window, you see the heading in numeric format.
In the General » Compass menu you can turn the bearing on or off, calibrate the compass, and set declination.
Calibrating compass
When you first start using Suunto D5, and after each charging, the compass needs to be calibrated and it is required to do so to activate it. Suunto D5 displays the calibration icon when you enter the compass view.
During the calibration process, the compass adjusts itself to the surrounding magnetic field.
Because of changes in the surrounding magnetic field, it is recommended to re-calibrate the compass before each dive.
To manually start calibration:
- Take off your Suunto D5.
- Keep the middle button pressed to enter the menu.
- Browse to General » Compass.
- Press the middle button to enter Compass.
- Scroll up or down to select Calibrate.
- Start calibrating the device by trying to move it around the xyz axes of the coordinate system (like you were drawing a small circle) so that the magnetic field is as stable as possible during the calibration. To achieve this, try to keep Suunto D5 in the same location and do not move it around using large movements.
Repeat the rotation until the compass calibration is successful.
- A sound indicates when the calibration succeeded, and the screen goes back to Compass menu.
If the calibration fails several times in a row, you may be in an area with strong sources of magnetism, such as large metal objects. Move to another location and try to calibrate the compass again.
Setting declination
You should always adjust your compass declination for the area where you are diving to get accurate heading readings. Check the local declination from a trusted source and set the value in Suunto D5.
To set declination:
- Press the middle button again to enter Declination.
- Scroll up/down to set the angle of declination: Starting from 0.0º scroll up towards East or down towards West declination. To turn declination off, set declination angle to 0.0º.
- Press middle button to save changes and go back to the Compass menu.
- Keep the middle button pressed to exit.
Locking the bearing
A bearing is the angle between north and your target. In simple terms, it is the direction you want to travel. Your heading, on the other hand, is your actual direction of travel.
You can set a bearing lock to help you orientate yourself underwater and ensure you maintain your direction of travel. For example, you can set a bearing lock for the direction to the reef before leaving the boat.
You can reset the bearing lock at any time, but you can only clear a bearing lock while at the surface.
To lock the bearing:
- Press the middle button to change to compass view.
- Hold your Suunto D5 in level in front of you, with the top pointing in the direction to your target.
Keep the lower button pressed until you see the Bearing locked notification.
After you locked the bearing, you can see yellow bars to indicate the angle where you locked the bearing:
When the bearing is at 0°, no arrows are shown beside the value, as above. When the bearing is at 180°, two yellow arrows are shown beside the value:
One yellow arrow indicates the direction you need to turn:
If you want to set a new bearing lock, just repeat the same procedure above. Each bearing lock is recorded in your dive log with a time stamp.
To clear the bearing lock from your compass view, you need to return to the surface.
To clear a bearing lock:
- While in surface state, keep the middle button pressed to enter the main menu.
- Scroll to General with the upper or lower buttons and press the middle button.
- Select Clear bearing with the middle button.
Customizing dive modes with Suunto app
You can easily customize device and dive settings, such as dive modes and views with Suunto app. Create up to 10 different dive modes with up to five custom views each.
You can customize the following:
- Dive mode name
- Settings (e.g., personal setting, views, gases)
See How to customize dive modes with Suunto app for more information.
Decompression algorithm
Suunto's decompression model development originates from the 1980s when Suunto implemented Bühlmann's model based on M-values in Suunto SME. Since then research and development has been ongoing with the help of both external and internal experts.
In the late 1990s, Suunto implemented Dr. Bruce Wienke's RGBM (Reduced Gradient Bubble Model) to work with the earlier M-value based model. The first commercial products with the feature were the iconic Suunto Vyper and Suunto Stinger. With these products the improvement of diver safety was significant as they addressed a number of diving circumstances outside the range of dissolved-gas-only models by:
- Monitoring continuous multiday diving
- Computing closely spaced repetitive diving
- Reacting to a dive deeper than the previous dive
- Adapting to rapid ascents which produce high microbubble (silent-bubble) build-up
- Incorporating consistency with real physical laws for gas kinetics
The Suunto Fused™ RGBM 2 combines and improves widely respected Suunto RGBM and Suunto Fused™ RGBM decompression models developed by Suunto together with Dr. Bruce Wienke. (Suunto dive algorithms are a culmination of expertise and knowledge accumulated over decades of development, testing and thousands upon thousands of dives.)
In Suunto Fused™ RGBM 2 the tissue half-times are derived from Wienke’s FullRGBM where human body is modeled by fifteen different tissue groups. FullRGBM can utilize these additional tissues and model the on-gassing and off-gassing more accurately. The amounts of nitrogen and helium on-gassing and off-gassing in the tissues are calculated independently from each other.
The Fused™ RGBM 2 supports open-circuit and closed-circuit diving up to a depth of 150 meters. Compared to previous algorithms, Fused™ RGBM 2 is less conservative on deep air dives, allowing shorter ascent times. In addition, the algorithm no longer requires tissues to be completely free of residual gases when calculating no-fly times, thereby reducing the required time between your last dive and flying.
The advantage of Suunto Fused™ RGBM 2 is additional safety through its ability to adapt to a wide variety of situations. For recreational divers it may offer slightly longer no- deco times, depending on the chosen personal setting. For open-circuit technical divers it allows use of gas mixes with helium - on deeper and longer dives helium based gas mixes provide shorter ascent times. And finally, for rebreather divers the Suunto Fused™ RGBM 2 algorithm gives the perfect tool to be used as a non-monitoring, set point dive computer.
Suunto D5 does not have Trimix diving and CCR support.
Diver safety
Because any decompression model is purely theoretical and does not monitor the actual body of a diver, no decompression model can guarantee the absence of DCS.
CAUTION:
Always use the same personal and altitude adjustment settings for the actual dive and for the planning. Increasing the personal adjustment setting from the planned setting as well as increasing the altitude adjustment setting can lead to longer decompression times deeper and thus to larger required gas volume. You can run out of breathing gas underwater if the personal adjustment setting has been changed after dive planning.
Oxygen exposure
The oxygen exposure calculations are based on currently accepted exposure time limit tables and principles. In addition to this, the dive computer uses several methods to conservatively estimate the oxygen exposure. For example:
- The displayed oxygen exposure calculations are raised to the next higher percentage value.
- The CNS% limits up to 1.6 bar (23.2 psi) are based on 1991 NOAA Diving Manual limits.
- The OTU monitoring is based on the long-term daily tolerance level and the recovery rate is reduced.
Oxygen related information displayed by the dive computer is also designed to ensure that all warnings and displays occur at the appropriate phases of a dive. For example, the following information is provided before and during a dive when the computer is set to Air/Nitrox mode:
- The selected O2%
- CNS% and OTU
- Audible notification when CNS% reaches 80%, then warning when 100% limit is exceeded
- Notification when OTU reaches 250 and warning when 300 limit is exceeded
- Audible alarm when pO2 value exceeds the preset limit (pO2 high alarm)
WARNING:
WHEN THE OXYGEN LIMIT FRACTION INDICATES THAT THE MAXIMUM LIMIT IS REACHED, YOU MUST IMMEDIATELY TAKE ACTION TO REDUCE OXYGEN EXPOSURE. Failure to take action to reduce oxygen exposure after a CNS%/OTU warning is given can rapidly increase the risk of oxygen toxicity, injury, or death.
Decompression dives
If you exceed the no decompression limit on a dive, when no deco time reaches zero, your dive changes into a decompression dive. Therefore, you must perform one or more decompression stops on your way to the surface.
Ascent information is always presented with two values:
ceiling: depth that you should not go above
asc. time: optimum ascent time in minutes to surface with given gases
WARNING:
NEVER ASCEND ABOVE THE CEILING! You must not ascend above the ceiling during your decompression. In order to avoid doing so by accident, you should stay somewhat below the ceiling.
On a decompression dive, there can be three kinds of stops:
Safety stop: this is a recommended three-minute stop for every dive over 10 meters (33 ft).
Deepstop: this is a recommended stop when you dive deeper than 20 m (66 ft).
Decompression stop: this is a compulsory stop on your decompression dive that is for your safety, preventing decompressions sickness.
In Dive settings » Parameters, you can
- turn deepstop on or off (it is on by default)
- adjust the safety stop time to be 3, 4 or 5 minutes (default is 3 minutes)
- set last stop depth to 3.0 m or 6.0 m (default is 3.0 m)
The following illustration shows a decompression dive where the ceiling is at 17.7 m (58 ft):
From bottom to top you see the following in the above image:
There is a decompression window (Deco window) that is the distance between the decompression ceiling (Deco ceiling) plus 3.0 m (9.8 ft) and the decompression ceiling. So the deco window in this example is between 20.7 m (68 ft) and 17.7 m (58 ft). This is the area where decompression takes place. The closer to the ceiling you stay, the more optimal the decompression time is.
When you ascend close to the ceiling depth and enter the deco window area, two arrows appear in front of the depth value. The downward and upward pointing white arrows indicate that you are within the deco window.
If you ascend above the ceiling depth, there is still a safe margin area, equaling to ceiling depth minus 0.6 meters (2 ft). So in this example, it is between 17.7 m (58 ft) and 17.1 m (56 ft). In this safe margin area, decompression calculation still continues, but you are advised to go down below the ceiling depth. This is indicated by the ceiling depth value turning yellow with a downward pointing yellow arrow in front of the depth value.
If you go above the safe margin area, the decompression calculation is paused until you go back down below this limit. An audible alarm and a downward pointing red arrow in front of the depth value indicate unsafe decompression.
If you ignore the alarm and stay above the safe margin for three minutes, Suunto D5 locks the algorithm calculation, and decompression information will not be available anymore on the dive. See Algorithm lock.
Decompression display examples
Suunto D5 shows the ceiling value always from the deepest of these stops.
Below is a typical decompression dive view showing ascent time and the first recommended deepstop at 20.3 meters:
Below is an example of what Suunto D5 displays during an optional deepstop:
Below is an example of what Suunto D5 displays during a compulsory stop:
If the ceiling is broken for more than 3 minutes, the decompression algorithm gets locked.
With decompression stops, the ceiling is always decreasing while you are near the ceiling depth, providing continuous decompression with optimum ascent time.
It is always recommended to keep close to the decompression ceiling when ascending.
Ascent time is always the minimum time needed to reach the surface. It includes:
- Time required for deepstops
- Ascent time from depth at 10 m (33 ft) per minute
- Time needed for decompression
WARNING:
When diving with multiple gases, remember that the ascent time is always calculated with the assumption that you use all the gases found in the Gases menu. Always check that you have only the gases for your current planned dive defined before you dive. Remove the gases that are not available for the dive.
WARNING:
YOUR ACTUAL ASCENT TIME MAY BE LONGER THAN DISPLAYED BY THE DIVE COMPUTER! The ascent time will increase if you: (1) remain at depth, (2) ascend slower than 10 m/min (33 ft/min), (3) make your decompression stop deeper than at the ceiling, and/or (4) forget to change the used gas mixture. These factors might also increase the amount of breathing gas required to reach the surface.
Last stop depth
You can adjust the last stop depth for decompression dives under Dive settings » Parameters » Last stop depth. There are two options: 3 m and 6 m (9.8 ft and 19.6 ft).
By default, the last stop depth is 3 m (9.8 ft). This is the recommended last stop depth.
This setting does not affect the ceiling depth on a decompression dive. The last ceiling depth is always 3 m (9.8 ft).
Consider setting the last stop depth to 6 m (19.6 ft) when you dive in rough sea conditions and stopping at 3 m (9.8 ft) is challenging.
Device info
Information about your Suunto D5 can be found in your device. This information includes device name, serial number, device history, software and hardware versions and radio compliance information. See How to access device info.
Display
Display LED backlight is on by default.
You can significantly extend battery life by turning down the display brightness when there is ambient light available. The display is still easily readable.
For display brightness adjustment, see How to change display brightness.
Dive history
Dive history is a summary of all the dives done with your Suunto D5. The history is divided according to the dive mode used for the dive. Each dive type summary includes the number of dives, cumulative dive hours and maximum depth reached in all dives of that dive mode.
Enter History under General » About D5:
If there is more history information available than can be shown in a single screen, you can scroll through the additional information with the upper and lower buttons.
Dive modes
By default, Suunto D5 has three dive modes: Air/Nitrox, Free and Gauge (bottom timer). Select the appropriate mode for your dive under Dive settings » Mode. If you select Off mode, you can use your Suunto D5 as a regular watch. In this case, all dive functionalities are switched off.
Suunto D5 shows all dive mode names in English. You can change dive mode names via Suunto app.
Air/Nitrox mode
By default, Air/Nitrox mode is for diving with regular air and diving with oxygen enriched gas mixtures.
Diving with nitrox gas mixture allows you to increase bottom times or reduce the risk of decompression illness. Suunto D5 provides you with information to adjust your dive and stay within safe limits.
When diving with a nitrox gas mixture, both the percentage of oxygen in your tank and the oxygen partial pressure limit must be entered into Suunto D5. This ensures correct nitrogen and oxygen calculations and the correct maximum operating depth (MOD), which is based on your entered values. The default oxygen percentage (O2%) setting is 21% (air) and oxygen partial pressure (pO2) setting is 1.6 bar (23 psi).
When diving with a nitrox gas mixture, Suunto recommends changing the partial pressure to 1.4 bar (20 psi).
Air/Nitrox mode has four views:
No deco - The arch shows the no decompression time.
Compass
Tank pressure - For more information on what is shown on the display, see Tank pressure.
Timer (visible after customizing with Suunto app)
Gauge mode
Use Suunto D5 as a bottom timer with Gauge mode.
The timer in the center of the display shows dive time in minutes and seconds and activates at the start of the dive.
Gauge mode is a bottom timer only. It does not use any decompression algorithm, thus it does not include decompression information or calculations.
Gauge mode has three views:
After diving in Gauge mode, decompression calculation is locked for 48 hours. If during this time you dive again in Air/Nitrox or Free mode, there is no decompression calculation available and Locked is shown in decompression information fields.
Locked time is set back to 48 hours if you start a new dive while your device is locked.
Freedive mode
With Free mode, Suunto D5 can be used as a freediving instrument.
Go to Main menu » Dive settings » Mode to activate Free mode. Suunto D5 will restart to change mode. When you activate Free mode, the display shows you data in white color. Depth is indicated in the unit you set (see How to set language and unit), dive time in minutes and seconds in the center of the display. Temperature information is at the bottom of the display. With the lower button you can change the window at the bottom of the display.
The freedive starts at 1.2 m (4 ft) with water contact or 3.0 m (10 ft) without water contact and ends when your depth is less than 0.9 m (3 ft) with water contact or 3.0 m (10 ft) without water contact. For more information on the water contact sensor, see Water contacts.
Freedive mode has three views by default:
A fourth view is available after customization in the Suunto app:
You can change the views with short pressing the middle button.
Time
Before dives:
During dives:
Depth
It is the default view. The white arrow on the left side of the arch moves according to the depth. The yellow arch shows the depth between the max depth (defined by Depth notify 5) and the next deepest active depth notification.
Before dives:
During dives:
Compass
Before dives:
During dives:
Timer
This view is available only after customization in Suunto app.
Before dives:
During dives:
On the surface after freediving
When you are on the surface after freediving, the data on the display turns green. You can see your last depth, the time of your last dive, and the number of dives you have done (white number with a hashtag).
Surface notify
In Timer view the surface interval time is being counted in minutes and seconds at the bottom of the display in a green field until the value you set in Main menu » Dive settings » NOTIFICATIONS » Surface notify.
If Surface notify is off, the surface interval counter runs for 4 hours, after that, or after the previously set surface interval time has passed, the counter disappears from the display. Your Suunto D5 will show the following data:
Under the surface time icon
, the time spent on the surface is shown in hours and minutes in white color.
For setting depth notifications, see How to set depth notifications (freedive only).
Surface timer
While freediving, you can use the surface timer to help you prepare yourself for your next dive. Suunto D5 starts the counter as soon as you reach 0.9 m (3 ft).
Dive planner
The dive planner in Suunto D5 helps you to quickly plan your next dive. The planner displays available no decompression time and gas times for your dive based on depth, tank size and gas consumption set.
The dive planner can also help you plan dives in series, taking into account the residual nitrogen from your previous dive(s) based on the planned surface time you enter.
It is important to adjust tank size, tank pressure and personal gas consumption to get the gas calculations right.
See How to plan a dive using the Dive planner for details on planning your dives.
Gas consumption
Gas consumption refers to your real-time consumption rate of gas during a dive. In other words, it is the amount of gas a diver would use in one minute on the surface. This is commonly known as your surface air consumption or SAC rate.
Gas consumption rate is measured in liters per minute (cubic feet per minute). This is an optional field and needs to be added to your custom dive mode views in Suunto app.
For enabling gas consumption metering, see How to enable gas consumption metering.
Gas mixtures
By default, Suunto D5 has only one gas (air) available. The default oxygen percentage (O2%) setting is 21% (air) and oxygen partial pressure (pO2) setting is 1.6 bar (23 psi). You can modify O2 percentage and pO2 settings in Gases menu.
If you are diving with only one gas, ensure you have only that one gas in the Gases menu. Otherwise, Suunto D5 expects you to use all gases in the list and notifies you to change gases during the dive.
If you need more than one gas, activate multi-gas option in your device. Go to Dive settings » Parameters and turn on Multiple gases option.
You need to define all gas mixtures intended to use during the dive in the Gases menu because during your dive the decompression algorithm calculates ascent time using all gases available in the Gases menu.
If you want to use trimix gas mixtures (with helium activated), you need to turn helium on under Dive settings » Parameters. When this is done, you can change helium percentage (He%) for the selected gas in the Gases menu.
You can activate multi-gas diving and helium, configure dive modes and change gas settings using Suunto app, too.
Changing gas during a dive
It is important to understand how your Suunto D5 device works when you dive with multiple gases. For example, you may have the following gases when diving to 40 m (131.2 ft):
- Nitrox 26% (1.4 pO2) (for bottom)
- Nitrox 50% (1.6 pO2) (decompression gas)
- Nitrox 99% (1.6 pO2) (decompression gas)
While ascending, you are notified to change gas at 22 m (72 ft) and 6 m (20 ft) according to the maximum operating depth (MOD) of the gas.
To take a better gas into use, you need to change gas manually by completing the following steps:
- Press any button to acknowledge the gas change notification.
- Long press the middle button to see gas options.
- Scroll with the upper or lower button to the desired gas.
- Press the middle button to confirm gas selection.
If you press any button while Change gas notification is visible on the device screen, the notification disappears. By pressing a button, you only confirm the notification, but gas is not changed automatically. You should always change gas manually. To change gas, you must follow the above listed steps.
Modifying gases during a dive
Modifying gases is for emergency cases only. For example, due to unforeseen events, you might lose a gas mixture, in which case you could adjust to the situation by deleting that gas mixture from the gas list of Suunto D5. This allows you to continue diving and get correct decompression information calculated by the dive computer.
In another case, if for some reason you run out of gas and need to use a gas mixture from a dive buddy, it is possible to adapt Suunto D5 to the situation by adding the new gas mixture to the list. Suunto D5 re-calculates decompression and shows the correct information.
This feature is not enabled by default, it must be activated and creates an additional step to the gas menu during the dive. It is only available if multiple gases are selected for the dive mode.
To enable modifying gases, turn the feature on in the settings menu under Dive settings » Parameters » Modify gases.
When enabled, during a multi-gas dive, you can add a new gas as well as select an existing gas from the gas list to remove it.
You cannot modify or remove the gas currently in use (active gas).
When Modify gases is turned on, you can remove gases which are not in use from the gas list, add new gases to the list, and modify parameters (O2, pO2) of nonactive gases.
Gas time
Gas time refers to remaining air (gas) left with current gas mixture, measured in minutes. The time is based on the tank pressure value and your current breathing rate.
Gas time is also highly dependent on your current depth. For example, all other factors being the same, including breathing rate, tank pressure and tank size, depth affects gas time as follows:
- At 10 m (33 ft, surrounding pressure 2 bar), gas time is 40 minutes.
- At 30 m (99 ft, surrounding pressure 4 bar), gas time is 20 minutes.
- At 70 m (230 ft, surrounding pressure 8 bar), gas time is 10 minutes.
Gas time can be viewed at the bottom of the dive mode screens. If you have not paired a Suunto Tank POD, the gas time field shows N/A. If you have paired a POD but there is no data being received, the field shows - -. This may be because the POD is not in range, the tank is closed, or the POD battery is low.
It is important to adjust tank size, tank pressure and personal gas consumption to get the gas calculations right. Find these options under Dive planner in the device menu.
Idle and deep sleep
Idle and deep sleep are functions that are designed to prolong battery life.
Idle
When you press any button on your Suunto D5, it goes to active mode and the display backlight is activated (if turned on) and the seconds become visible on the watch face (red rectangle moving). After two minutes, the device goes to idle mode: the number of colors is reduced to save power and moving elements are turned off.
Deep sleep
Deep sleep is a function that prolongs battery life when Suunto D5 has not been used for some time. Deep sleep is activated when one day has passed since:
- No buttons have been pressed
- Dive calculation has ended
Suunto D5 wakes up when it is connected to a PC/charger, when a button is pressed, or when the water contact gets wet.
When not used, your Suunto D5 goes from active mode to idle mode and finally to deep sleep.
Wake up your Suunto D5 by pressing any button, or connecting to a computer / charger, or activating the water contact by immersing the device in water.
If your Suunto D5 runs out of battery when in deep sleep, you can only wake up your device by connecting to a charger or a computer with a USB cable of 5Vdc.
Language and unit system
You can change the device language and unit system at any time. Suunto D5 refreshes immediately to reflect the changes.
To set these values, see How to set language and unit.
Logbook
Dive logs can be found under Logs. They are listed by date and time, and each entry listing shows the max. depth and dive time of the log.
Dive log details and profile can be browsed by scrolling through the logs with the upper or the lower button and selecting a log with the middle button.
Each dive log contains data samples with fixed 10-second intervals. Freedive sample rate is 1 second.
For more detailed log analyses, upload the dive(s) to the Suunto app (Suunto app).
In the image below, you can see information on the:
- start and stop times (14:36, 15:11)
- depth profile
- surface time (0:07)
- max depth and temperature at max depth (33.0 m, 19 °C)
As an example, the logbook info display gives you the following information on your logged Nitrox dive:
When the logbook memory gets full, the oldest dives are deleted to make space for new ones.
If you surface and then dive again within five minutes, Suunto D5 counts it as one dive.
Mobile notifications
If you have paired your watch with the Suunto app on your smartphone, you can receive notifications such as incoming calls and text messages on your watch.
Messages received from some apps used for communication might not be compatible with Suunto D5.
When you pair your watch with the app, notifications are on by default. You can turn them off under General » Connectivity.
Text and call notifications
When a text notification arrives, a pop-up appears on the screen. You can see the message for 10 seconds, during which period current time is visible on the top of the watch face.
If the message is too long to fit on the screen, you can scroll through the full text by pressing the lower button.
If you get a call on your phone, you see a notification of an incoming call on your watch.
If you want to mute your device and stop vibration, press the lower button. You cannot answer or dismiss a call on your Suunto D5.
In case you missed a call, its sign is visible on the watch face for 2 seconds, while your watch is vibrating.
Tones and vibration can be turned on and off under General » Device settings.
Notification history
You can find unread notifications and missed calls in the notification history on your watch.
After entering the main menu, scroll to General » Notifications. There you see the 10 most recent notifications. Data on the top of the screen shows when you received the text or the call.
If you want to delete the notifications, choose Clear all.
Oxygen calculations
During a dive, Suunto D5 calculates partial pressure of oxygen (pO2), central nervous system toxicity (CNS%) and pulmonary oxygen toxicity, tracked by oxygen toxicity units (OTU). The oxygen calculations are based on currently accepted exposure time limit tables and principles.
By default in Air/Nitrox dive mode, CNS% and OTU values are not displayed until they reach 80% of their recommended limits. When either value reaches 80%, Suunto D5 notifies you and the value stays in the view.
You can customize views to always show CNS% and OTU.
Personal setting
Suunto Fused™ RGBM 2 algorithm provides 5 personal setting options (+2, +1, 0, -1, -2). These options refer to decompression models. +2 and +1 can be considered conservative, while -2 and -1 can be considered aggressive. 0 is the default setting and is neutral, for ideal conditions. Generally speaking, conservative means safer. In practice it means that a dive at a given depth is shorter due to the decompression obligation (the no decompression time is short).
Conservative also means that the time the diver needs to spend on decompression is longer. For recreational divers, a conservative model means less time in the water in order to avoid decompression requirements. For technical divers, however, conservative means more time in the water because of the longer decompression requirements imposed during ascent.
Aggressive models, on the other hand, increase the potential health risks of a dive. For recreational divers, an aggressive model allows more time at depth, but may significantly increase the risk of decompression sickness (DCS).
The default setting for the Suunto Fused™ RGBM and Fused™ RGBM 2 is to use a compromise (0 setting) between conservative and aggressive. With the personal setting, you can select gradually more conservative or more aggressive calculations.
There are several risk factors that can affect your susceptibility to DCS like your personal health and behavior. Such risk factors vary between divers, as well as from one day to another.
The personal risk factors which tend to increase the possibility of DCS include:
- exposure to low temperature – water temperature less than 20 °C (68 °F)
- below average physical fitness level
- age, particularly over the age of 50
- fatigue (from over exercising, lack of sleep, exhausting travel)
- dehydration (affects circulation and may slow down off-gassing)
- stress
- tight fitting equipment (may slow down off-gassing)
- obesity (BMI that is considered obese)
- patent foramen ovale (PFO)
- exercise before or after dive
- strenuous activity during a dive (increases bloodflow and brings additional gas to tissues)
WARNING:
SET THE CORRECT PERSONAL SETTING! Whenever it is believed that risk factors that tend to increase the possibility of DCS exist, it is recommended that you use this option to make the calculations more conservative. Failure to select the correct personal setting will result in erroneous dive and planning data.
The five-step personal setting can be used to adjust the algorithm conservatism to fit your DCS susceptibility. You can find the setting under Dive settings » Parameters » Personal.
| Personal level |
Explanation |
| More aggressive (-2) |
Ideal conditions, excellent physical fitness, highly experienced with a lot of dives in the near past |
| Aggressive (-1) |
Ideal conditions, good physical fitness, well experienced with dives in the near past |
| Default (0) |
Ideal conditions (default value) |
| Conservative (+1) |
Some risk factors or conditions exist |
| More conservative (+2) |
Several risk factors or conditions exist |
WARNING:
Personal adjustment setting 0, -1 or -2 causes a high risk of DCS, or other personal injury, and death.
Safety stops and deepstops
Safety stop and deepstop ceilings are always at constant depth when you are at the stop. Safety stop and deepstop times are counted down in minutes and seconds.
Safety stop
There are two types of safety stops: voluntary and mandatory. Safety stop is mandatory if ascent speed violation happened during the dive. Mandatory safety stop is shown in red, while voluntary safety stop is indicated with yellow.
A three (3) minute safety stop is always recommended for every dive over 10 meters (33 ft).
The time for a safety stop is calculated when you are between 2.4 and 6 m (7.9 and 19.6 ft). This is presented with up/down arrows on the left side of the depth value. Safety stop time is shown in minutes and seconds. The time may exceed three (3) minutes if you ascend too fast during dive. Ascent speed violation increases safety stop time with minimum 30 seconds. If violations happened several times, the additional stop time is longer. Safety stops can be set to three (3), four (4), or five (5) minutes.
Voluntary safety stop is shown in yellow:
Mandatory safety stop is shown in red:
Deepstop
The deepstop gets activated only when you dive deeper than 20 m (66 ft). During ascend, deepstops activate when you are halfway up from your maximum depth. The deepstop is presented like a safety stop. You are in the deepstop area when there are up/down arrows on the left of the depth value and deepstop time is running. The deepstop window is +/- 1.5 m (4.9 ft). Calculation starts at deepstop target depth plus 0.5 m (1.6 ft). Calculation ends - 3 m (- 9.8 ft) away from deepstop depth.
There can be more than one deepstop during ascend. For example, if you dive to 42 m (137.8 ft), the first deepstop is prompted at 21 m (68.9 ft) and the second is at 10.5 m (34.4 ft) The second deepstop is 2 minutes long.
In the following example the diver dives down to maximum 30.4 m (99.7 ft) and has a deepstop at 15.2 m (49.9 ft):
Below 20.0 m (66 ft), the deepstop gets activated. In this case, as the diver ascends, the deepstop is necessary at halfway of the maximum depth, so at 15.2 m (49.9 ft).
If the deepstop depth is 15.2 m (49.9 ft), the calculation starts at 15.7 m (51.5 ft) and stops at 12.2 m (40.0 ft). The deepstop window is +/- 1.5 m (4.9 ft) and when the diver is within the deepstop window, it is indicated with two white arrows pointing at each other on the display.
When the diver ascends above the deepstop window ceiling - in this case above 14.2 m (46.5 ft) - a downward pointing yellow arrow signals that the depth is not optimal, it is recommended to descend. The deepstop target depth number also turns yellow.
If the diver keeps ascending, after 0.5 m (1.6 ft), a downward pointing red arrow and an alarm notify the diver to descend immediately. The deepstop calculation keeps running for another 1.5 m (4.9 ft) up but stops after that. In the above example it stops at 12.2 m (40.0 ft).
Sample rate
Suunto D5 uses a fixed sample rate of 10 seconds for all log recordings except in Free mode. Free mode uses a sample rate of 1 second.
Surface and no-fly time
After a dive, Suunto D5 displays surface time since the previous dive and a countdown time for the recommended no-fly time. During the no-fly time you should avoid flying or traveling to higher altitude.
No-fly time is the minimum surface time after a dive which is recommended to wait before entering and flying with an airplane. It is always at least 12 hours and equals desaturation time when it is more than 12 hours. For desaturation times shorter than 75 minutes, no-fly time is not displayed.
If decompression is omitted during a dive and the dive algorithm is locked for 48 hours (see Algorithm lock), the no-fly time is always 48 hours. Similarly, if dive is done in gauge mode (bottom timer), the no-fly time is 48 hours.
With Suunto Fused™ RGBM 2, the selected personal setting parameter (-2, -1, 0, +1, +2) is affecting no-fly time. The more conservative personal setting you have, the longer no-fly time values you will see. More aggressive personal setting will result in shorter no-fly time values.
Once the no-fly time calculated by your Suunto D5 with Suunto Fused™ RGBM 2 has ended, you can enter and fly with a normal airplane which is pressurized up to 3000 m.
WARNING:
YOU ARE ADVISED TO AVOID FLYING ANY TIME THE COMPUTER COUNTS DOWN THE NO-FLY TIME. ALWAYS ACTIVATE THE COMPUTER TO CHECK THE REMAINING NO-FLY TIME PRIOR TO FLYING! Flying or traveling to a higher altitude within the no-fly time can greatly increase the risk of DCS. Review the recommendations given by Divers Alert Network (DAN). There can never be a flying-after-diving rule that is guaranteed to completely prevent decompression sickness!
Suunto app
With the Suunto app, you can easily customize device and dive settings. See Customizing dive modes with Suunto app and How to customize dive modes with Suunto app.
You can also transfer your dive logs wirelessly to the app where you can follow and share your diving adventures.
To pair with Suunto app on iOS:
- Download and install Suunto app on your compatible Apple device from the App Store. The app description includes the latest compatibility information.
- Start Suunto app and turn on Bluetooth if it is not on already. Leave the app running in the foreground.
- If you have not yet set up your Suunto D5, do so now (see Getting started).
- Tap the watch icon in the upper left corner of the screen and tap on the ' + ' icon to add a new device.
- Select your dive computer from the list of found devices, tap PAIR.
- Enter the passkey shown on your dive computer display into the pairing request field on your mobile device.
- Tap PAIR at the bottom of the request field.
To pair with Suunto app on Android:
- Download and install Suunto app on your compatible Android device from Google Play. The app description includes the latest compatibility information.
- Tap the watch icon in the upper right corner of the screen.
- Select your dive computer from the list of found devices and tap PAIR.
You cannot pair any device if airplane mode is on. Turn off airplane mode before pairing.
Synchronizing logs and settings
To be able to synchronize logs and settings, first you need to install Suunto app.
To download logs from your Suunto D5 and sync settings:
- Connect Suunto D5 to your mobile device via Bluetooth.
- Start Suunto app.
- Wait for the syncing to complete.
New dive logs appear in your activity history, sorted by date and time.
SuuntoLink
Use SuuntoLink to update the software of your Suunto D5. Download and install SuuntoLink on your PC or Mac.
We strongly recommend updating your device when a new software release is available. If an update is available, you are notified via SuuntoLink and in the Suunto app.
Visit www.suunto.com/SuuntoLink for further information.
To update your dive computer software:
- Plug your Suunto D5 into the computer with the supplied USB cable.
- Start SuuntoLink if it is not already running.
- Click the update button in SuuntoLink.
To sync your dives, connect the device to Suunto app before the software update.
Tank pressure
Your Suunto D5 can be used with the total number of three Suunto Tank PODs for wireless tank pressure transmission.
To install and pair a Suunto Tank POD, see How to install and pair a Suunto Tank POD.
In tank pressure view, you can see the below screens.
In the switch window, the actual tank pressure is shown in a blue field by default. This is also shown with a blue arrow in the arch. The blue part of the arch indicates the range between the value you set for the tank pressure alarm and the actual tank pressure:
The following example has the tank pressure alarm set to 100 bars. The tank pressure is 75 bars as indicated in the switch window at the bottom.
When the tank pressure alarm is turned on and the value is between the value you set and 50 bars, the tank pressure value is indicated in a yellow field in the switch window and the range is also shown in the arch with yellow:
When the tank pressure drops below 50 bars (so within the red area in the arch) the actual tank pressure value is indicated in a red field in the switch window and a mandatory alarm is triggered:
Timer
Suunto D5 has a timer that can be used for timing specific actions during surface or dive. The timer is shown at the bottom of the screen as a scrollable item.
 To use the timer:
- Press the upper button to start the timer.
- Press the upper button again to pause the timer.
- Keep the upper button pressed to reset the timer.
Timer start and stop actions are saved in the dive log.
Water contacts
Suunto D5 has water contact functionality that recognizes when the device is in contact with water. When submerged, the water contact poles are connected by the conductivity of the water.
Suunto D5 switches to dive state when water is detected. Dive starts
- when the water contact is on, at 1.2 m (4 ft), or
- when the water contact is not on, at 3.0 m (9.8 ft)
and ends
- when the water contact is on and your depth is less than 0.9 m (2.9 ft) in case of freedive, and 1.2 m (3.9 ft) in case of scuba dive, or
- when the water contact is not on and your depth is at 3.0 m (9.8 ft).
A wave icon appears on the left, above the ascend indicator when the device is under water. See Display - modes, views, and states for an overview of dive screen icons.
Water contact icon:
Water contact icon in Free mode Depth view:
CAUTION:
If you see a question mark in a yellow square, that means the device is functioning abnormally. E.g., it can signal that the water contact is not working as expected. Start using your backup instrument, abort the dive immediately and safely ascend to the surface. Call Suunto Customer Support and return your computer to an authorized Suunto Service Center for inspection.
