1 / 4
Suunto Tank Pod
1/4
Money-back guarantee
30-Days Return
Global Support
SKU: SS020306000
Suunto Tank POD
Sale price€294,02
Wireless tank pressure transmitter for Suunto Ocean, Suunto D5, Suunto EON Steel, EON Steel Black and EON Core.
  • High quality
  • Easy pairing
  • Cleaned for oxygen service
  • Set your own gas alerts
  • Accurate pressure reading
Quantity
30-Days Return
Global Support
Suunto Tank Pod
€294,02
Add to cart
Suunto Tank POD
The Suunto Tank POD is a wireless tank pressure transmitter that allows you to view current tank pressure with just a glance at your wrist. The Suunto Tank POD is cleaned for oxygen service for added safety when diving with enriched air.
The pairing procedure is very intuitive; just pressurize the system, hold your Suunto D5Suunto EON SteelSuunto EON Steel Black or Suunto EON Core close to the Tank POD and after a few seconds a menu pops up on the screen showing the serial number, battery status and the tank pressure.
Product highlights
  • Easy pairing
BENEFITS
Easily read key dive details on your wrist
Enjoy increased comfort and safety during the dive and use your Suunto D5, Suunto EON Core, Suunto EON Steel or Suunto EON Steel Black together with Suunto Tank POD.
Paired with Suunto Tank POD, simply check the dive computer on your wrist for
  • accurate gas pressure reading
  • remaining gas time
  • clear color-coding indicating gas level
  • low in gas warning, so you will have enough time for a safe ascend
  • setting your own gas alarms
The pairing procedure is very intuitive; just pressurize the system and hold your Suunto D5, Suunto EON Steel, Suunto EON Steel Black or Suunto EON Core close to the Tank POD.
High quality and tested tough
Suunto Tank POD has a safe and robust construction according to the most stringent European safety standards and the built-in Suunto quality. The Suunto Tank POD comes cleaned for oxygen service to provide that extra added safety when diving with higher oxygen concentrated gases like Nitrox. With the built-in gas alarms Suunto Tank POD along with your Suunto dive computer will never let you down.
Follow your development as a diver
After diving, transfer your dive logs easily over Bluetooth to your mobile. In Suunto app you can analyze your gas consumption and follow how it develops the more dive experience you gain.
With Suunto app on your mobile, share your underwater adventures with friends and be the first to know of software updates bringing new features to your dive computer.
