Suunto Traverse Graphite
GPS outdoor watch with versatile navigation functions for hiking and trekking
      €990
        Go explore
Curiosity drives us to seek out and discover new places, but it’s the confidence of finding our way that encourages us to step off the beaten track. The integrated GPS and GLONASS navigation of Suunto Traverse help you plan your hikes and find your way in the wild. The automatic breadcrumb of your track ensures you can re-trace your steps when needed. The strong build and powerful battery of Suunto Traverse keep you exploring hour after hour.
PRODUCT HIGHLIGHTS
- Find your way with integrated GPS navigation
 - Up to 100 hours battery life, sunset/sunrise times and storm alarm
 - Made in Finland
                      Gear of the Year 2016
                SPECIFICATIONS
                  Measurements50 x 50 x 16.5 mm / 1.97 x 1.97 x 0.65 "
                  Weight80 g / 2.82 oz
                  Bezel material:Stainless steel
                  Glass material:Mineral crystal
                  Case material:Composite
                  Strap material:Silicone
                  What's in the box?Suunto Traverse Graphite, USB cable, quick guide, warranty leaflet
                  Country of manufactureFI
TECHNICAL SPECIFICATIONS
                      Bezel materialStainless steel
                      Glass materialMineral crystal
                      Case materialComposite
                      Strap materialSilicone
                      Flashlight backlight option✔
                      Vibration alert✔
                      Water resistance100 m
                      Battery typerechargeable lithium-ion
                      Firmware upgradable✔
                      Time, date✔
                      Alarm clock1 daily alarm
                      Dual time✔
                      Automatic timekeeping✔
                      Countdown timer✔
                      Stopwatch timer✔
                      LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
                      BacklightLED
                      Configurable backlightbrightness / mode
                      Button lockcustomizable
                      Invert display✔
                      Display typematrix
                      Display resolution128 x 128
                      Metric and imperial units✔
                      Automatic daylight saving time✔
                      Battery indicatorpercentage / icon
                      Memory left indicator✔
PHYSICAL SPECIFICATIONS
                      Operating temperature-20° C to +60° C / -5° F to +140° F
                      Storage temperature-30° C to +60° C / -22° F to +140° F
                      Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
                      In time mode14 days
                      Training mode with GPS10, 15, 100 h For more information www.suunto.com/software-updates
COMPASS
                      Digital compass✔
                      Tilt compensationfull
                      Declination correction✔
                      Direction scaledegrees / mils
                      Needlenorth indicator
                      Bearing lock with direction indicator✔
                      Compass accuracy5°
                      Compass resolution1°
CONNECTIVITY
                      Connectivity (between devices)Bluetooth Smart
                      Watch customizationUSB cable
                      Data transferWireless / USB cable
                      Phone notifications on the watchwith Suunto App
                      Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
                      Smartphone compatibilityMost common models supported
SUUNTO APPS
                      Compatible with Suunto Apps✔
                      Max. nr. of apps per sport mode4
                      Logging of app specific metrics✔
                      Most recommended apps by activity✔
                      Create own metrics with advanced formulas✔
                      Chrono, GPS, HR, weather and altitude data✔
                      Rich math functions, if/then-logic, sound, backlight, etc.✔
24/7
ACTIVITY TRACKING
                      Step counter✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
                      Satellite systemsGPS, GLONASS
                      GPS recording rateBest, Good, OK
                      Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
                      Waypoint and visual route navigation✔
                      Max. nr. of Points of Interest (POIs)250
                      Find back✔
                      Breadcrumb trail in real time✔
                      Route planning with altitude profilein Suunto Movescount.com
                      Route altitude profile navigation in real-time✔
                      Route points per route / POIs in watch1000 / 250
                      GPS track analysisin Suunto App
                      Track backyes, incorporated with breadcrumb trail
                      Track logging, viewing and sharingin Suunto App
                      Route planningin Suunto Movescount.com
ALTIMETER
                      Barometric altitude✔
                      Altitude graph✔
                      GPS altitude✔
                      Combined GPS and barometric altitude (FusedAlti™)✔
                      Altitude differencein log summary, and real time as an App
                      Total ascent/descentair pressure based
                      Vertical speedair pressure based
                      Automatic alti/baro profile✔
                      Log recording rate1, 10 s
                      Resolution1 m
                      Range-500 - 9999 m
WEATHER
                      Sunrise/sunset times✔
                      Storm alarm✔
                      Sea level pressure✔
                      Temperature✔
                      Temperature display range✔
                      Temperature resolution1°
                      Pressure resolution1 hPa / 0.03 inHg
                      Max weather recording lengthpast 26 hours
                      Sea level pressure graph✔
                      Tide informationyes** ** available as Suunto Apps
                      Weather trend indicator✔
TRAINING FUNCTIONS
HEART RATE
                      Heart rate in beats per minute✔
                      Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
                      Calories✔
                      Heart rate in % of max hr✔
SPEED AND DISTANCE
                      GPS speed and distanceIntegrated
                      Chrono✔
                      Distance based autolaps✔
                      Laps> 1000
                      Autopause✔
TRAINING LOAD
                      Log summary on the watch with lap details✔
                      Training analysisin Suunto App
                      Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
CYCLING
                      Cycling speedbased on GPS
                      Average speed in real timebased on GPS
RUNNING
                      Running pace✔
                      Suunto FusedSpeed™✔
                      Average pace in real time✔
                      Lap comparisons by kilometer/mile✔
SPORT MODES
                      Customizable sport modes and displays5 modes / 4 displays per mode
