Suunto Traverse Alpha Stealth
GPS/GLONASS watch with versatile outdoor functions for fishing and hunting
€990
Go explore
Traverse Alpha combines strong build quality with a full set of outdoor features. It is your guide in the wild, keeping you on track with GPS/GLONASS navigation. Specific fishing and hunting features provide useful tools for your activity, including moon phase calendar, shot detection, sunrise alert, weather trend, and red backlight for nighttime use. Plan your routes and keep a diary of your fishing and hunting trips with Suunto Movescount.com. The strap pattern in Traverse Alpha Woodland draws inspriration from the camouflage pattern used by the Finnish military.
PRODUCT HIGHLIGHTS
- Master your territory with GPS/GLONASS navigation
- Made in Finland, tested to military standards
- Dedicated functions for fishing, hunting and hiking
SPECIFICATIONS
Measurements50 x 50 x 15 mm / 1.97 x 1.97 x 0.59 "
Weight75 g / 2.65 oz
Bezel material:Stainless steel
Glass material:Sapphire crystal
Case material:Composite
Strap material:Textile
What's in the box?Suunto Traverse Alpha Stealth, USB cable, quick guide, warranty leaflet
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialStainless steel
Glass materialSapphire crystal
Case materialComposite
Strap materialTextile
Flashlight backlight option✔
Vibration alert✔
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Automatic timekeeping✔
Countdown timer✔
Stopwatch timer✔
LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
BacklightLED
Configurable backlightcolor / brightness / mode
Button lockcustomizable
Invert display✔
Display typematrix
Display resolution128 x 128
Metric and imperial units✔
Automatic daylight saving time✔
Battery indicatorpercentage / icon
Memory left indicator✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
In time mode14 days
Training mode with GPS10, 15, 100 h For more information www.suunto.com/software-updates
COMPASS
Digital compass✔
Tilt compensationfull
Declination correction✔
Direction scaledegrees / mils
Needlenorth indicator
Bearing lock with direction indicator✔
Compass accuracy5°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)Bluetooth Smart
Watch customizationUSB cable
Data transferWireless / USB cable
Phone notifications on the watchwith Suunto App
Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
Smartphone compatibilityMost common models supported
SUUNTO APPS
Compatible with Suunto Apps✔
Max. nr. of apps per sport mode4
Logging of app specific metrics✔
Most recommended apps by activity✔
Create own metrics with advanced formulas✔
Chrono, GPS, HR, weather and altitude data✔
Rich math functions, if/then-logic, sound, backlight, etc.✔
24/7
ACTIVITY TRACKING
Step counter✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS, GLONASS
GPS recording rateBest, Good, OK
Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
Waypoint and visual route navigation✔
Max. nr. of Points of Interest (POIs)250
Find back✔
Breadcrumb trail in real time✔
Route planning with altitude profilein Suunto Movescount.com
Route altitude profile navigation in real-time✔
Route points per route / POIs in watch1000 / 250
GPS track analysisin Suunto App
Track backyes, incorporated with breadcrumb trail
Track logging, viewing and sharingin Suunto App
Route planningin Suunto Movescount.com
ALTIMETER
Barometric altitude✔
Altitude graph✔
GPS altitude✔
Combined GPS and barometric altitude (FusedAlti™)✔
Altitude differencein log summary, and real time as an App
Total ascent/descentair pressure based
Vertical speedair pressure based
Automatic alti/baro profile✔
Log recording rate1, 10 s
Resolution1 m
Range-500 - 9999 m
WEATHER
Sunrise/sunset times✔
Storm alarm✔
Sea level pressure✔
Temperature✔
Temperature display range-20° C to +60° C / -4° F to +140° F
Temperature resolution1°
Pressure resolution1 hPa / 0.03 inHg
Max weather recording lengthpast 26 hours
Moon phase calendar✔
Sea level pressure graph✔
Tide informationyes** ** available as Suunto Apps
Weather trend indicator✔
TRAINING FUNCTIONS
HEART RATE
Heart rate in beats per minute✔
Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Calories✔
Heart rate in % of max hr✔
SPEED AND DISTANCE
GPS speed and distanceIntegrated
Chrono✔
Distance based autolaps✔
Laps> 1000
Autopause✔
TRAINING LOAD
Log summary on the watch with lap details✔
Training analysisin Suunto App
Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
CYCLING
Cycling speedbased on GPS
Average speed in real timebased on GPS
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Average pace in real time✔
Lap comparisons by kilometer/mile✔
HUNTING
Automatic shot detection✔
Hunting specific POI types✔
Moonrise / moonset alert✔
Moonrise and moonset times for selected date✔
Red backlight, compatible with night vision goggles✔
Sunrise / sunset alert✔
FISHING
Fishing specific POI types✔
Storm alarm✔
Temperature✔
SPORT MODES
Customizable sport modes and displays5 modes / 4 displays per mode
