Suunto Traverse Slate
GPS outdoor watch with versatile navigation functions for hiking and trekking
7.700 kr
Go explore
Curiosity drives us to seek out and discover new places, but it’s the confidence of finding our way that encourages us to step off the beaten track. Topographic maps in Suunto Movescount and the integrated GPS and GLONASS navigation of Suunto Traverse help you plan your hikes and find your way in the wild. The automatic breadcrumb of your track ensures you can re-trace your steps when needed. The strong build and powerful battery of Suunto Traverse keep you exploring hour after hour.
The matte finish of the composite case and a custom dyed premium textile strap make Suunto Traverse Slate an ideal companion both for treks in the wild, as well as for everyday use. Sold exclusively in the Suunto webshop.
PRODUCT HIGHLIGHTS
- Find your way with integrated GPS navigation
- Up to 100 hours battery life, sunset/sunrise times and storm alarm
- Made in Finland
Gear of the Year 2016
SPECIFICATIONS
Measurements50 x 50 x 16.5 mm / 1.97 x 1.97 x 0.65 "
Weight80 g / 2.82 oz
Bezel material:Stainless steel
Glass material:Mineral crystal
Case material:Composite
Strap material:Textile
What's in the box?Suunto Traverse Slate, USB cable, quick guide, warranty leaflet
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialStainless steel
Glass materialMineral crystal
Case materialComposite
Strap materialTextile
Flashlight backlight option✔
Vibration alert✔
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Automatic timekeeping✔
Countdown timer✔
Stopwatch timer✔
LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
BacklightLED
Configurable backlightbrightness / mode
Button lockcustomizable
Invert display✔
Display typematrix
Display resolution128 x 128
Metric and imperial units✔
Automatic daylight saving time✔
Battery indicatorpercentage / icon
Memory left indicator✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
In time mode14 days
Training mode with GPS10, 15, 100 h For more information www.suunto.com/software-updates
COMPASS
Digital compass✔
Tilt compensationfull
Declination correction✔
Direction scaledegrees / mils
Needlenorth indicator
Bearing lock with direction indicator✔
Compass accuracy5°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)Bluetooth Smart
Watch customizationUSB cable
Data transferWireless / USB cable
Phone notifications on the watchwith Suunto App
Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
Smartphone compatibilityMost common models supported
SUUNTO APPS
Compatible with Suunto Apps✔
Max. nr. of apps per sport mode4
Logging of app specific metrics✔
Most recommended apps by activity✔
Create own metrics with advanced formulas✔
Chrono, GPS, HR, weather and altitude data✔
Rich math functions, if/then-logic, sound, backlight, etc.✔
24/7
ACTIVITY TRACKING
Step counter✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS, GLONASS
GPS recording rateBest, Good, OK
Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
Waypoint and visual route navigation✔
Max. nr. of Points of Interest (POIs)250
Find back✔
Breadcrumb trail in real time✔
Route planning with altitude profilein Suunto Movescount.com
Route altitude profile navigation in real-time✔
Route points per route / POIs in watch1000 / 250
GPS track analysisin Suunto App
Track backyes, incorporated with breadcrumb trail
Track logging, viewing and sharingin Suunto App
Route planningin Suunto Movescount.com
ALTIMETER
Barometric altitude✔
Altitude graph✔
GPS altitude✔
Combined GPS and barometric altitude (FusedAlti™)✔
Altitude differencein log summary, and real time as an App
Total ascent/descentair pressure based
Vertical speedair pressure based
Automatic alti/baro profile✔
Log recording rate1, 10 s
Resolution1 m
Range-500 - 9999 m
WEATHER
Sunrise/sunset times✔
Storm alarm✔
Sea level pressure✔
Temperature✔
Temperature display range✔
Temperature resolution1°
Pressure resolution1 hPa / 0.03 inHg
Max weather recording lengthpast 26 hours
Sea level pressure graph✔
Tide informationyes** ** available as Suunto Apps
Weather trend indicator✔
TRAINING FUNCTIONS
HEART RATE
Heart rate in beats per minute✔
Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Calories✔
Heart rate in % of max hr✔
SPEED AND DISTANCE
GPS speed and distanceIntegrated
Chrono✔
Distance based autolaps✔
Laps> 1000
Autopause✔
TRAINING LOAD
Log summary on the watch with lap details✔
Training analysisin Suunto App
Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
CYCLING
Cycling speedbased on GPS
Average speed in real timebased on GPS
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Average pace in real time✔
Lap comparisons by kilometer/mile✔
SPORT MODES
Customizable sport modes and displays5 modes / 4 displays per mode
