1 / 13
Suunto MC-2 G Mirror Compass
SUUNTO MC-2 G Mirror Compass Orienteering Compass
1/13
Money-back guarantee
30-Days Return
Global Support
SKU: SS004252010
Suunto MC-2
G Mirror Compass
Sale price690 kr
A professional mirror compass with top-of-the-line features for direction and slope measurements for mountain adventures.
  • Fast globally balanced needle with jewel bearing
  • 20 degrees tilt margin for easier readings
  • Adjustable declination correction
  • Liquid filled capsule for stable operation
  • Mirror for sighting bearings and signaling
  • Sighting hole and notch for accurate bearings
  • Clinometer
  • Luminescent markings for working in low light
  • Metric UTM scales and inch ruler
  • Baseplate with magnifying lens
  • Detachable snap-lock lanyard with wristlock. Easy to detach for working with the map
  • Suunto limited lifetime warranty
  • Made in Finland
  • NSN: 6605-25-149-1938
Choose Your Color
Quantity
visa paypal master apple_pay diners_club american_express klarna mobilepay
30-Days Return
Global Support
690 kr
Add to cart
Made in Finland
Limited lifetime warranty
Exceptionally stable & fast needle
Luminescent markings for low light
Sighting compass for mountain adventures
When venturing out into new territory, MC-2 sighting compasses offer precision navigation with a variety of carefully engineered and dependable features for challenging conditions. Depending on the variant, MC-2 comes with Metric UTM scales and inch ruler or USGS UTM scales.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
Correct the declination between map north (North Pole) and magnetic north for trusted navigation. Read more about declination correction.
Stable operation
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
Mirror for more
The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
Accurate bearings
Sighting hole and notch in a compass facilitate precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
Integrated clinometer
The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
The lanyard with wristlock is easy to detach for working with the map.
Made in Finland
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
Sustainable design from Finland
Carbon footprint 1.3 kg CO2e
According to a category-level Life Cycle Assessment (LCA) of Suunto field compasses*, one compass in this category creates on average 1.3 kg CO₂e emissions during its whole lifespan. 1.3 kg CO₂e equals to, for example, driving a fossil fuel car for 8 kilometers.
We have fully offset the lifespan emissions of all compasses in this category with Verified Carbon Units.
*Including A-10, A-30, M-3, M-3 Global, AIM-6, AIM-30, MCB, MC-2, MC-2 Global, MB-6 and MB-6G compasses
Data source: Gov.uk, Dept for Business, Energy and Industrial Strategy, 2025
Made with 100% renewable energy
Suunto factory, where Suunto compasses are made, is located in Vantaa, Finland. Here we use 100% renewable, carbon neutral energy in all our operations. This is a key factor in enabling the Suunto compass to achieve a small carbon footprint of 1.3 kg CO₂e* over its full lifespan.
*Based on average category-level emissions for selected Suunto field compasses, including A-10, A-30, M-3, M-3 Global, AIM-6, AIM-30, MCB, MC-2, MC-2 Global, MB-6, and MB-6G.
100% carbon offset
We offset the lifetime CO₂e emissions of each sold Suunto compass* with Verified Carbon Units via Tree-Nation. The offset is done in a reforestation project in Southeast Africa that plants trees, protects biodiversity, and supports local communities in creating sustainable livelihoods.
*This applies to Suunto field compasses including A-10, A-30, M-3, M-3 Global, AIM-6, AIM-30, MCB, MC-2, MC-2 Global, MB-6, and MB-6G.
SPECIFICATIONS
  • Measurements
    65 x 101 x 18 mm / 2.56 x 3.98 x 0.71 "
  • Weight
    75 g / 2.65 oz
  • Bezel material:
    Plastic
  • What's in the box?
    Suunto MC-2 G Mirror Compass, lanyard with wristlock and declination correction tool, quick release, Quick Guide
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Plastic
  • Metric scales
    cm, 1:25 000 km UTM, 1:50 000 km UTM
  • Imperial scales
    inch
  • Declination correction
    adjustable
  • Weight
    75 g / 2.65 oz
  • Water resistance
    insensitive to water pressure
  • Battery type
    no battery required
  • Luminous markings
    bezel, orienting markings, direction of travel
  • Lanyard quick release
  • Attachment
    lanyard
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
COMPASS
  • Direction scale
    degrees
  • Needle
    Suunto global needle
  • Globally balanced
  • Liquid filled and jewel bearing
  • Compass accuracy
  • Compass resolution
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Magnifying lens
  • Mirror
  • Sighting
    mirror, notch and hole
CLINOMETER
  • Clinometer
  • Liquid filled
  • Clinometer scales
    0 ± 90°
  • Inclination accuracy
  • Inclination resolution
