Out of Stock
1 / 12
Suunto EON Core White
1/12
Money-back guarantee
30-Days Return
Global Support
SKU: SS023081000
Suunto EON Core
White
Sale price4.850 kr
A compact dive computer with an easy to read color screen, rechargeable battery and wireless connectivity with Suunto app and Suunto Tank POD. Made in Finland.
Choose Your Color
Quantity
visa paypal master apple_pay diners_club american_express klarna mobilepay
30-Days Return
Global Support
4.850 kr
Out of Stock
Customizable
Digital compass
Wireless tank pressure
For all diving
Wireless mobile connection
Outstanding readability with great versatility
The compact Suunto EON Core is a great dive companion whether you are just beginning diving or an active diver exploring new depths. The key details of your dive are easy to read from the clear color display with large, prominent digits. This fully featured and versatile dive computer is your reliable partner no matter if you’re exploring shipwrecks or admiring the colorful marine life.
BENEFITS
Easy to read
Read all the important diving details at a glance from a clear, legible screen. Large numbers and texts with high contrast colors are easy to see even in murky waters or when diving at night time.
Grows with you
Suunto EON Core is ready out-of-the-box, but you can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. User updatable software easily via SuuntoLink makes Suunto EON Core a loyal diving partner for years to come.
Compact and comfortable
The lightweight composite case with an elastomer strap or bungee is comfortable to use both on a wrist or with a dry suit. The display's resistant mineral glass shields the screen from scratches and large buttons are easily pressed with or without gloves. Suunto EON Core comes in pure white, fresh lime or always stylish black, and is conveniently rechargeable through USB.
Connect and transfer
Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto EON Core with the Suunto Tank POD before diving. Transfer your dive logs easily over Bluetooth to your mobile phone. In Suunto app you can relive, and share your diving adventures, build an all-inclusive dive history by enriching your dive logs with photos, comments and dive location. Review and analyze all your dive data including dive time, maximum depth, device settings, gas consumption (when using Suunto Tank POD). Suunto app is available in the App Store and Google Play.
SPECIFICATIONS
  • Weight
    154 g / 5.43 oz
  • Bezel material:
    Composite
  • Glass material:
    Mineral crystal
  • Case material:
    Reinforced composite
  • Strap material:
    Elastomer, Bungee
  • What's in the box?
    Suunto EON Core White, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Composite
  • Glass material
    Mineral crystal
  • Case material
  • Strap material
    Elastomer, Bungee
  • Weight
    154 g / 5.43 oz
  • Flip display
  • Water resistance
    80 m (ISO 6425, EN 13319)
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Stopwatch timer
  • Language
  • Backlight
    LED
  • Configurable backlight
  • Display type
    color TFT
  • Display resolution
    320 x 240
  • Metric and imperial units
  • Battery indicator
    icon + dive hours remaining
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
COMPASS
  • Digital compass
  • Tilt compensation
    up to 45°
  • Declination correction
  • Direction scale
    degrees
  • Needle
    compass rose
  • Globally balanced
  • Compass accuracy
    +/- 15°
  • Compass resolution
CONNECTIVITY
    inductive (up to 20 Tank PODs), Bluetooth Smart
  • Compatible with Suunto app
  • Compatible with SuuntoLink
  • Compatible with DM5
  • Log transfer
    Bluetooth Smart / USB cable
  • Smartphone compatibility
    Most common models supported
OUTDOOR FUNCTIONS
WEATHER
  • Temperature
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
DIVING FUNCTIONS
BASIC
  • Altitude adjustment
  • Ascent time display
    0 - 999 min ( > after 999)
  • CNS/OTU (OLF) calculation
  • Custom displays
    4 per dive mode
  • Decompression model
    Suunto Fused™ RGBM 2
  • Decompression profile options
    continuous and stepped
  • Deep Stop
  • Dive history
    lifetime
  • Dive time
    0 to 999 min
  • Gas consumption (real-time)
  • Gas max pO2
    manual 0.5 - 1.6 / fixed 1.6
  • Gas switching
  • Gas time
  • Gases
    up to 10 gases (Oxygen 5 - 99% / Helium 0 -95%)
  • Gauge
  • Logbook bookmarks
  • Logbook memory
  • Logbook sampling rates
    10 s
    80m
  • Nitrox (and air)
  • No fly time
  • No-decompression planner
  • Personal adjustment
    P+2, P+1, P0, P-1, P-2
  • Rebreather (CCR), fixed point
  • Safety Stop
  • Surface time
    0 to 100 h
  • Timer
  • Trimix (mixed gas)
  • Visual style
    Classic/Graphical/Prominent
  • Wireless air integration
    optional (up to 20 different tanks with Suunto Tank POD)
DIVE ALARMS AND NOTIFICATIONS
  • CNS/OTU (OLF) 80% / 100%
  • Deepstop violation
  • Diluent high pO2
  • Diluent low pO2
  • Diluent switched automatically
  • Dive time
  • Gas time
  • High pO2 (hyperoxic)
  • ICD warning
  • Low pO2 (hypoxic)
  • Maximum depth
  • Tank pressure
  • Too fast ascent
REBREATHER
  • Diluents
    up to 10 diluents (Oxygen 5 - 99% / Helium 0 - 95%)
  • Bailout
  • High/low setpoints
  • Custom setpoint
  • Manual/automatic setpoint switching
Recommended products
Videos
You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
How to adjust basic settings on your Suunto EoN Core dive computer.
How to get started with your Suunto EON Core dive computer.
How to connect a Tank POD to your Suunto EON Core.
How to attach the Bungee Adapter Kit on your Suunto EON Core.
How to activate alarms on your Suunto EON Core dive computer.
How to set gasses on your Suunto EON Core dive computer.
How to use the dive planner on your Suunto EON Core dive computer.
Support for Suunto EON Core
