Dive safety
Suunto Ocean is a dive computer designed to be used for recreational scuba diving and freediving. The device displays essential information before, during and after the dive to enable safe decision making. Suunto Ocean can be used as a standalone product or in combination with the Suunto Tank POD, which measures the tank pressure and transmits the pressure reading information to the dive computer. The combination of Suunto Ocean and the Suunto Tank POD is categorized as Personal Protective Equipment under the EU Regulation 2016/425 and protects against risks listed under PPE Risk Category III (a): substances and mixtures which are hazardous to health.
Suunto strongly recommends that you do not engage in any diving activity type without proper training and a complete understanding and acceptance of the risks. Always follow the rules of your training agency.
Make sure you fully understand how to use your dive instrument and what its limitations are by reading all the printed documentation and the online user manual. Always remember that you are responsible for your own safety.
WARNING:
All computers experience failures. It is possible that this device may suddenly fail to provide accurate information during your dive. Always use a backup dive device and only dive with a buddy.
WARNING:
Because any decompression model is purely theoretical and does not monitor the actual body of a diver, there is always a risk of decompression illness (DCI) for any dive. An individual’s physiological makeup can vary from day to day. The dive computer cannot account for these variations. You are strongly advised to remain well within the exposure limits provided by the dive computer to minimize the risk of DCI.
WARNING:
If you suspect risk factors that tend to increase the possibility of DCI exist, Suunto recommends that you use the personal setting to make calculations more conservative and consult a physician with experience in diving medicine before you dive.
WARNING:
When diving at altitudes greater than 300 m (980 ft), the altitude setting must be correctly selected for the computer to calculate the decompression status. Failure to select the correct altitude setting or diving above the maximum altitude limit will result in erroneous dive and planning data. It is recommended that you acclimatize to the new altitude before diving. Always use the same personal and altitude adjustment settings for the actual dive and for the planning.
WARNING:
Suunto strongly recommends that the device not be used for any commercial or professional diving activities. The demands of commercial or professional diving may expose the diver to depths and conditions that tend to increase the risk of DCI.
WARNING:
Before diving, always check that your dive computer is functioning properly, the display is working, the battery level is OK, tank pressure is correct, and your settings are correct.
WARNING:
Check your dive computer regularly during a dive. If you believe or conclude that there is a problem with any computer function, abort the dive immediately and safely return to the surface. Contact Suunto customer support and return your computer to an authorized Suunto Service Center for inspection.
WARNING:
The dive computer should never be traded or shared between users while in use. Its information will not apply to someone who has not been wearing it throughout a dive, or sequence of repetitive dives. Its dive profiles must match that of the user. No dive computer can take into account dives made without the computer. Thus, any diving activity up to four days prior to initial use of the computer may cause misleading information and must be avoided.
WARNING:
For safety reasons, you should never dive alone. Dive with a designated buddy. You should also stay with others for an extended time after a dive as the onset of possible DCS may be delayed or triggered by surface activities.
WARNING:
ONLY TRAINED DIVERS SHOULD USE A DIVE COMPUTER! Insufficient training for any kind of diving, including freediving, may cause a diver to commit errors, such as incorrect use of gas mixtures or improper decompression, that may lead to serious injury or death.
WARNING:
Do not participate in freediving and scuba diving activities on the same day.
WARNING:
This device is recommended for use with compressed air. The compressed air supply must comply with the quality of compressed air specified in the EU standard EN 12021:2014 (requirements for compressed gases for breathing apparatus). This device can also be used with enriched air (nitrox) breathing gases.
WARNING:
Diving with mixed gases has dangers that are not familiar to divers diving with air. Appropriate training courses for diving with enriched air is essential prior to the use of this kind of equipment with oxygen content greater than 21%.
WARNING:
In nitrox use, the maximum operating depth and no decompression time are dependent on the oxygen content of the gas. When the oxygen limit fraction indicates that the maximum limit is reached, you must immediately take action to reduce oxygen exposure. Failure to take action to reduce oxygen exposure after a CNS%/OTU warning is given can rapidly increase the risk of oxygen toxicity, injury, or death.
WARNING:
Do not dive with gas if you have not personally verified its content and entered the analyzed value into your dive computer. Failure to verify tank contents and enter the appropriate gas values where applicable into your dive computer will result in incorrect dive planning information.
WARNING:
YOU ARE ADVISED TO AVOID FLYING ANY TIME THE COMPUTER COUNTS DOWN THE NO-FLY TIME. ALWAYS ACTIVATE THE COMPUTER TO CHECK THE REMAINING NO-FLY TIME PRIOR TO FLYING! Flying or traveling to a higher altitude within the no-fly time can greatly increase the risk of DCS. Review the recommendations given by Divers Alert Network (DAN). There can never be a flying-after-diving rule that is guaranteed to completely prevent decompression sickness!
WARNING:
If you have a pacemaker, we recommend you do not scuba dive. Scuba diving creates physical stresses on the body which may not be suitable for pacemakers.
WARNING:
You must read the printed quick guide and online user guide of your dive computer. Failure to do so may lead to improper use, serious injury or death.
Make sure your Suunto dive computer always has the latest software with updates and improvements. Check before every dive trip from suunto support , if Suunto has released a new software update for your device. When a new software update is available, you must install it before diving. Updates are made available to improve your user experience and are part of Suunto's philosophy of continuous product development and improvement.
Dive setup
Suunto Ocean has two dive modes for Scuba diving: Single gas and Multigas and one freedive mode: Freediving (depth). You can find all dive modes under the main menu by swiping down from the watch face or pressing the upper button and select the mode by pressing the middle button.
Automatic dive start
Suunto Ocean has an automatic start functionality that recognizes pressure increase and water contact. The device enters dive state from the pre-dive screen or from any other watch screen:
- When in contact with water and the absolute pressure equals to your set dive start depth (the default start depth is 1.2 m / 4 ft).
- Or if no water contact is recognizable but the absolute pressure equals to your set dive start depth (the default start depth is 1.2 m / 4 ft) + 1.8 m (5.9 ft).
Scuba dives automatically end after the set Dive end time (the default time is 5 min) and when:
- When in contact with water and the absolute pressure equals to or is less than your set dive start depth (the default start depth is 1.2 m / 4 ft).
- Or if no water contact is recognizable but the absolute pressure equals to or is less than your set dive start depth (the default start depth is 1.2 m / 4 ft) + 1.8 m (5.9 ft).
If submerged from any non-diving watch screen, Suunto Ocean automatically enters the dive mode you have last configured.
The Dive start depth can be defined under Dive settings in scuba modes and under Dive options in freedive mode.
Suunto Ocean does not enter dive state if you are already in another exercise view.
WARNING:
The automatic dive start is a precaution feature. We recommend that you always start the dive by entering the selected dive mode to confirm your gas and dive settings.
Dive modes
Suunto Ocean has two scuba dive modes and a freedive mode that come with pre-defined settings to prepare for certain type of diving.
Single gas :
This dive mode is best suited for no-decompression recreational diving with only one gas, Air or Nitrox.
- One active gas, up to five disabled gases
- Air or Nitrox mixes
- Tank POD pairing to active gas
Multigas :
This dive mode is best suited for technical diving with multiple gases.
- Up to five enabled and disabled gases
- Air or Nitrox mixes, up to NX99
- Time to surface (TTS), ppO2 always on dive screen
- Tank POD pairing to multiple gases
Freedive :
This dive mode is designed for recreational freediving.
- Separate underwater and surface views
- Ascent and descent speed
- Multiple dive time and depth alarm options
Button functions during scuba diving
Your Suunto Ocean has three buttons that have different functionalities when short pressing or long pressing them during the dive.
Upper button short press: Access gas switch menu (only in Multigas mode)
Upper button long press: Adjust brightness level (Low/Medium/High)
Middle button short press: Change arch
Lower button short press: Change switch window item
Lower button long press: Lock buttons
 See Button and screen lock .
Pre-dive screen and dive options
The pre-dive screen is the same for all dive modes, but each mode has several dive mode specific options that can be adjusted to your diving needs.
A set of icons appears on the pre-dive screen, depending on what you are using with the dive mode, such as heart rate, Tank POD and GPS. The following elements can be seen on the display:
Tank POD icon if linked and active
GPS signal if enabled
Heart rate if enabled
Remaining battery time in hours
Active gas mix
Tank pressure if linked to Tank POD and active
The set maximum partial pressure limit (ppO2) for the active gas
The maximum operating depth (MOD) for the active gas
Active dive mode
GPS signal: The arrow icon (connected GPS) flashes gray while searching and turns green once a signal is found. We recommend to wait for the GPS icon to turn green before jumping into the water for accurate GPS location.
Heart rate: The heart icon (heart rate) flashes gray while searching and once a signal is found, it turns into a colored heart attached to a belt if you are using a heart rate sensor or a colored heart without the belt if you are using the optical heart rate sensor. See Pairing pods and sensors for pairing a heart rate sensor.
Tank POD: The tank icon on the left is only visible if you have a Tank POD paired to your gas and it is active.
Battery: The battery icon tells you how many hours you can dive before the battery runs out.
When scrolling up from the pre-dive screen, you can access the following settings:
Changing dive mode:
You can change the dive mode to another dive mode or any other exercise mode by tapping on the dive mode name.
Gases :
You can modify the oxygen percentage and ppO2 settings for your dive gases under Gases. See Gases .
Algorithm :
The algorithm settings provides you options for modifying your decompression algorithm for the specific dive mode. See Algorithm settings .
Alarms :
You can set alarms for reaching a certain depth, dive time or tank pressure. See Dive alarms for more information on dive related alarms.
Tank POD :
The Tank POD menu is for linking and unlinking available Tank PODs to your gas. See How to install and link a Suunto Tank POD .
Sensors :
Pair your heart rate sensor to record your diving. See Pairing pods and sensors .
Dive settings :
You can find various additional settings for your dive modes under Dive settings. See Dive settings for the available options.
Main dive view
While on the pre-dive screen, you can scroll through the different dive views by pressing the middle button. On a default dive display, you see the following information:
Decompression information
Ascent speed with color coding
Dive time
Depth
Switch window with changeable information
Arch illustrating key information: no deco limit, tank pressure, time to surface, stop time
Key information during diving
During diving, your watch displays the following information:
Decompression information:
The decompression area on the screen is fixed and shows the following data in the following situations:
Surface time: When surfacing, the decompression area is replaced with a surface timer. It shows the elapsed time between surfacing from a dive and beginning a descent for the subsequent dive. It shows the time in minutes and seconds up to one hour. Above one hour, the time is displayed in hours and minutes up to 24 hours, and after that, hours up to seven days and then only in days.
No Decompression Limit (NDL): Once a dive has started, the surface timer is replaced with the NDL time. It shows the time remaining in minutes at the current depth until mandatory decompression stops are required. If NDL time is above 99 minutes, it is displayed as >99. When the NDL time is 5 minutes or less, a mandatory alarm is triggered and the display area is highlighted until resolved or replaced with decompression information. Read more about the mandatory alarms in Mandatory dive alarms .
Deco time: If exceeding the NDL time, an alarm is triggered and the NDL time is replaced with the optimum ascent time in minutes (TTS). A Deco badge appears, the NDL arch turns to orange indicating the same TTS time, and the ceiling value appears in the switch window. The ceiling value indicates the decompression stop depth. An alarm is also triggered that can be confirmed by pressing any button. Read more about decompression diving in Decompression dives .
Stop time: If a safety stop or deco stop is required during the dive, the NDL or decompression information is replaced with a stop timer counting down the required stop time in minutes and seconds. The stop depth range will be indicated in the depth area. Once the stop is completed, Stop done is displayed in the switch window. You can adjust the safety stop time to be 3, 4 or 5 minutes (the default length is 3 minutes) in the Algorithm settings.
Ascent rate:
During a dive, the bar in the middle of the screen indicates how fast you are ascending. One bar step corresponds to 2 m (6.6 ft) per minute.
The bar is color coded to show the following:
Gray indicates ascent rate is less than 2 m (6.6 ft) per minute
Green indicates ascent rate is between 4 m (13 ft) per minute and 8 m (26 ft) per minute
Yellow indicates ascent rate is over 8 m (26 ft) per minute
Red indicates ascent rate is 10 m (33 ft) per minute
Highlighted red indicates ascent rate is over 10 m (33 ft) per minute for 5 sec or longer
WARNING:
DO NOT EXCEED THE MAXIMUM ASCENT RATE! Rapid ascents increase the risk of injury. You should always make the mandatory and recommended safety stops after you have exceeded the maximum recommended ascent rate.
Suunto Ocean comes with different arches for both Single gas and Multigas modes.
No deco : The arch shows the no deco time in a fixed range from 0 – 99. The arch is green for the range 5 – 99, and orange for the range 0 – 5. If the value is higher than 99, the indicator is stopped at the end.
Tank pressure : The arch shows the tank pressure if the watch is paired with a Suunto Tank POD. The range is determined by the Tank POD pressure reading value at the start of a dive and it can be 250 bar or 350 bar. The bars on the arch always represent 50 bar or 500 psi depending on unit settings. The colors represent certain parts of the range and they are always fixed to:
If no Tank POD is paired or the signal is lost, the arch is gray. See How to install and link a Suunto Tank POD on how to link your Tank POD.
Compass : The arch shows the magnetic north (marked with a red arrow) and the four cardinal directions. See Compass use during diving .
Empty : Dive view without the arch.
In addition, there are two dynamic arches:
Stop timer : If a stop is required, the arch shows the value corresponding to the dive view window.
TTS : If exceeding the NDL time, the arch turns orange and shows the Time to surface (TTS). The TTS arch range is fixed to 0 – 50 min. If the value is higher than 50, the indicator is stopped at the end.
Press the middle button to scroll between the arches.
Switch window for scuba diving
The switch window at the bottom of the dive screen can contain different types of information that can be changed by short pressing the lower button.
| Switch window | Switch window content | Explanation |
|  | Temperature | The current temperature in degrees Celsius or Fahrenheit, depending on unit settings. |
|  | Max depth | The maximum depth reached during the current dive. |
|  | Clock | The time in a 12- or 24-hour format, based on the time format you set under Time/date settings. |
|  | Battery | The remaining battery level as percentage. See Mandatory dive alarms for battery alarms. |
|  | Tank pressure | The tank pressure in the set unit (bar or PSI) for your active gas if linked to a Tank POD. |
|  | Gas consumption (L/min or cu ft/min) | Gas consumption refers to your real-time consumption rate of gas during a dive. The actual gas consumption rate is measured in liters per minute (cubic feet per minute) and calculated for the current depth. See Gas consumption for more information. |
|  | Gas time | Gas time refers to the time you can stay at the current depth. See Gas time for more information. |
|  | Safety stop | A three (3) minute safety stop is always recommended for every dive over 10 meters (33 ft). Once exceeding 10 m (33 ft), the 3 m (9.8 ft) minimum depth of the safety stop is displayed in the switch window. Safety stops can be set to three (3), four (4), or five (5) minutes in the Algorithm settings . |
|  | Time to surface   (TTS) | The time to surface refers to the ascent time in minutes to ascend to the surface with given gases including all required decompression stops. |
|  | Actual   ppO2 | The current partial pressure of the active gas. Partial pressure is the fraction of oxygen in the gas at the current depth. The value is always in absolute atmospheres (ATA) of pressure. (1 ATA = 1.013 bar) If the ppO2 exceeds the preset limit for the gas, the switch window turns yellow and triggers an alarm. If the ppO2 exceeds the maximum partial pressure limit of 1.6, the switch window turns red until you ascend shallower than the MOD depth. |
|  | MOD | Maximum Operating Depth. MOD is the depth at which the partial pressure of oxygen (ppO2) of the gas mix exceeds a safe limit. |
|  | Average depth | The average depth of the current dive is calculated from the moment the start depth is exceeded until the dive ends. |
|  | Sunset ETA | The estimated time until sunset expressed in hours and minutes. Sunset time is determined via GPS, so your watch relies on the GPS data from the last time you used GPS. |
|  | Gradient factors | The Gradient Factor value you have defined in the Algorithm settings. See Algorithm settings and Gradient Factors for more information about the dive algorithm and Gradient Factors. |
|  | Heading | The compass feature shows heading in degrees and the cardinal and inter cardinal direction. The compass calibrates itself when in use, but if a recalibration is needed, a prompt will pop up. To calibrate the compass, turn and tilt the watch in a figure-8. |
Dynamic values
Some values are visible in the switch window by default. The values appear in the window only if they are triggered by an alarm or event.
OTU
Oxygen tolerance unit. It is used to measure the whole-body toxicity, caused by prolonged exposure to high oxygen partial pressures. Suunto Ocean alarms you when the daily recommended limit reaches 250 (caution) and 300 (warning).
CNS
Central nervous system toxicity. The CNS value is a measure of how long you have been exposed to elevated partial pressures of oxygen (ppO2), displayed as a percentage of a maximum allowable exposure. Suunto Ocean alarms you when CNS% reaches 80% (caution) and when the 100% limit (warning) is exceeded.
The oxygen exposure calculations are based on currently accepted exposure time limit tables and principles. The limits are based on the NOAA Diving Manual . The CNS percentage is calculated continuously when in diving mode, even when on the surface.
In addition to this, the dive computer uses several methods to conservatively estimate the oxygen exposure. For example:
The displayed oxygen exposure calculations are raised to the next higher percentage value.
The CNS% limits up to 1.6 bar (23.2 psi).
The OTU monitoring is based on the long-term daily tolerance level and the recovery rate is reduced.
At the surface and after the dive has ended, the CNS decreases with a half time of 90 min. For example, if the CNS is 100 after the dive, 90 min later it will be decreased to 50 and then after another 90 min to 25.
WARNING:
WHEN THE OXYGEN LIMIT FRACTION INDICATES THAT THE MAXIMUM LIMIT IS REACHED, YOU MUST IMMEDIATELY TAKE ACTION TO REDUCE OXYGEN EXPOSURE. Failure to take action to reduce oxygen exposure after a CNS%/OTU warning is given can rapidly increase the risk of oxygen toxicity, injury, or death.
Ceiling
When mandatory decompression stops are required, a ceiling value appears in the switch window. Suunto Ocean shows the ceiling value always from the deepest stop. You must not ascend above the ceiling during your ascent. Read more about decompression diving in Decompression dives .
Dive settings
For Dive settings , scroll down from the pre-dive screen.
Heart rate
Turn heart rate measurement on or off for your dive. See more about heart rate in the Heart rate , Optical heart rate and Heart rate zones topics.
GPS
To track the start and end point of your dive and to get a more accurate dive route, you need to enable GPS in the Dive settings. Make sure the GPS arrow icon turns green in the pre-dive screen before starting your dive to get an accurate location. Suunto recommends you always start your dive from the pre-dive screen.
If you start your dive from any other screen utilizing the automatic start function, the GPS signal won’t be found.
Dive route
You can track your dive route with Suunto Ocean . The underwater route tracking is based on GPS, accelerometer, gyroscope, magnetometer and pressure sensor. The algorithm has been developed by using large amount of data from real dives, data analytics and machine learning.
To track your underwater route while diving, you need to enable both the GPS and the Dive route settings. The dive route is not visible in your dive computer. It will be synced to your dive log in Suunto app when connected to your mobile phone.
Note that the dive route signal can be compromised in the following situations: overhead environments like caves or wrecks, indoor pools or with poor on nonexistent GPS signal.
To track your dive route, you need to start your dive from the pre-dive screen and ensure your GPS signal is green. See Pre-dive screen and dive options .
Syncing your dive route to Suunto app might take some time due to the large amount of data.
Dive start depth
Sets the depth threshold for starting and ending a dive. The default depth is 1.2 m (4 ft) and the maximum is 3.0 m (9.8 ft).
Dive end time
Once you are shallower than the set start depth for the dive, Suunto Ocean will start calculating the elapsed time at the surface. You can set your desired time under Dive end time. Once this time has elapsed, your dive ends automatically. If you continue diving before the set end time, the dive continues. You can define the time between 1 and 10 min. The default setting is 5 min.
Adjust the end time to longer if you are, for example, an instructor and need to communicate at the surface within the dive. Adjust it to shorter to see the dive summary more quickly.
If you surface and then dive again within the set end time, Suunto Ocean counts it as one dive.
Brightness
The brightness setting determines the overall intensity of display brightness during dive activities: Low, Medium (default) or High (default). The brightness setting is specific to the dive mode, and does not affect other dive modes, outdoor modes or the general brightness setting.
To save battery life during dive activities, the display brightness will lower after a period of inactivity. Any wrist movement, button press, or alarm trigger the full brightness mode. You can also adjust the brightness during dive by long pressing the upper button.
CAUTION:
Prolonged use of the high brightness display reduces battery life and may cause screen burn-in. Avoid using high brightness for extended period to lengthen display lifetime.
Feeling
See Feeling .
Dive alarms
Suunto Ocean has color-coded mandatory warnings. They are shown prominently on the display with an audible and vibration alarm. Warnings are always red and they are critical events that always require immediate action. You can dismiss the audio and vibration but the warning will stay red until the situation has been resolved.
With Suunto Ocean , you can also define your own alarms and set the preferred audio, vibration and appearance.
The following table shows all the mandatory warnings you may see during a dive. You can find the reason for the alarm and the solution of the issue in the table.
If multiple alarms occur simultaneously, the error with the highest priority will be displayed. Acknowledge the first alarm by pressing any button and the next one will appear.
| Alarm | Explanation | How to resolve the alarm? |
|  | Ascent speed exceeds safe speed of 10 m (33 ft) per minute for five seconds or more. | Stay within the green ascent rate indicators. Monitor for symptoms of DCS. Use extra conservatism for future dives. |
|  | Decompression ceiling broken by more than 0.6 m (2 ft) on a decompression dive. | Descend deeper than the displayed ceiling value. |
|  | Partial pressure of oxygen exceeds the maximum level (>1.6). | Immediately ascend or change to a gas with lower oxygen percentage. |
|  | Partial pressure of oxygen exceeds the set level for the gas. | Immediately ascend or change to a gas with lower oxygen percentage. |
|  | Central Nervous System (CNS) Oxygen Toxicity level at 80% or 100% limit. | Switch to a gas with a lower ppO2 or ascend shallower (within decompression ceiling). |
|  | 80% or 100% of recommended daily limit for OTU reached. | Switch to a gas with a lower ppO2 or ascend shallower (within decompression ceiling). |
|  | Tank pressure is below 50 bar (725 psi). | Change gas to a higher tank pressure or ascend to safety stop depth and terminate dive. |
|  | Depth exceeds the maximum depth (60 m) your watch should be used at. If diving beyond 60 m, the dive computer will not show accurate depth value or algorithm info. | Ascend to a shallower depth and follow computer for ascend profile. Monitor for symptoms of DCS. Use extra conservatism for future dives. |
|  | Not inside the safety stop window. | Stay within the safety stop window 3 m – 6 m. |
|  | NDL is less than 5 minutes. | Ascend shallower to avoid mandatory decompression stops. |
|  | The decompression ceiling is broken for more than 3 min and your decompression stop is missed. | Descend to the ceiling depth indicated in the switch window. |
|  | Your NDL reaches 0 min, and decompression stops are mandatory. | Perform decompression stops as directed and always stay deeper than the ceiling value. |
|  | Battery is low (<10%) or critical (<5%). | Recharge the device. |
User configurable dive alarms
In addition to the mandatory alarms, there are additional user configurable tank pressure, depth, dive time and NDL alarms. For each alarm, you can customize the audio tone to short or long or you can have all tones off. In addition to the audio option, you can also choose to have a vibration alert or if you prefer to have all tones silent, you can have only vibration on.
In addition to the audible and vibration options, you can choose between two different appearance options: Notify (cyan) or Caution (yellow). You can define a maximum of five alarms for each configurable alarm and once an alarm appears, you can clear it by pressing any button.
Tank pressure
You can set the tank pressure alarm to any value between 51–360 bar (725–5221 psi). A mandatory 50 bar (725 psi) alarm is present and it cannot be modified. Tank pressure alarms are useful to notify you when reaching your turn pressure.
Depth
You can define a depth alarm between 3.0 m and 59.0 m. Depth alarms are convenient to have especially when freediving to notify you of different phases of the freedive. You can also set a depth alarm to notify you when reaching your personal depth limit during diving.
Dive time
Dive time alarms can be defined in minutes and seconds to a maximum of 99 min.
NDL
No decompression limit (NDL) alarms can be defined to alert you of a certain NDL or when you are low on NDL time.
System errors
All computers experience failures. It is possible that this device may suddenly fail to provide accurate information during your dive. Always have a plan on how to handle failures, use a backup dive device and only dive with a buddy. In the unlikely event that the dive computer malfunctions during a dive, follow the emergency procedures provided by your certified dive training agency to immediately and safely ascend. Contact Suunto customer support if you experience a system error.
Gases
In both Single gas and Multigas modes, the default active gas is Air. In the Gases menu you can edit your active gas or create a new gas.
You cannot delete your active gas. If you want to change your active gas you need to either modify the existing gas or create a new gas and set the gas state to active. If you change the active gas, the previous gas will be disabled (Single gas mode) or enabled (Multigas mode).
In Single gas mode, you can have only one active gas. When creating a new gas, you can choose to make it your active gas or save your most used gas mixture (e.g., NX32) for easy enabling once you need it.
Edit gas
When diving with nitrox gas mixture, both the percentage of oxygen in your tank and the oxygen partial pressure limit must be entered into Suunto Ocean . This ensures correct nitrogen and oxygen calculations and the correct maximum operating depth (MOD), which is based on your entered values. The default oxygen percentage (O2%) setting is 21% (air) and the oxygen partial pressure (ppO2) setting is 1.4 bar.
You can modify the oxygen percentage and the partial pressure of the active gas in the Edit gas view by selecting the mixture.
The oxygen fraction can be modified between 21% and 100%.
The ppO2 setting limits the maximum operating depth (MOD) to which the gas mixture can be safely used. You can set the ppO2 value to 1.0, 1.1, 1.2, 1.3, 1.4, 1.5 or 1.6.
Do not change these values unless you fully understand the effect.
In the Edit gas menu you can also set your tank size. The default value is 12 liters / 80 cu ft. Make sure you set your correct tank size to ensure correct gas consumption calculations when diving with Suunto Tank POD.
From the Edit gas menu you can also pair your Suunto Tank POD. See How to install and link a Suunto Tank POD for information about the wireless tank pressure pairing.
Diving with multiple gases
When diving with Multigas mode, Suunto Ocean allows gas changes between the enabled gases in the Gases menu. You can have maximum five gases in the gas list, enabled or disabled.
The decompression algorithm assumes all the enabled gases are planned to use for the dive and will calculate any decompression stops, decompression time and time to surface according to the available gases. Make sure to disable any gases you are not carrying with you.
When ascending, you are always notified to change gas when a better gas is available.
For example, you may have the following gases when diving to 40 m (131.2 ft):
- Nitrox 26% (1.4 ppO 2 ) (for bottom)
- Nitrox 50% (1.6 ppO 2 ) (decompression gas)
- Nitrox 99% (1.6 ppO 2 ) (decompression gas)
While ascending, you are notified to change gas at 22 m (72 ft) and 6 m (20 ft) according to the maximum operating depth (MOD) of the gas. Gas switch notification will be in the switch window and pressing any button will open a gas list with the recommended gas first. Confirm the new gas by pressing the middle button. If you don’t want to perform the suggested gas switch, you can dismiss the gas switch recommendation. This will ignore the suggested gas until the next possible MOD of an enabled gas. Once the dive has ended, the gas with the lowest O 2 value will be your active gas for the next dive.
Wireless tank pressure support
Suunto Ocean can be used together with Suunto Tank POD for wireless transmission of tank pressure and gas consumption to the dive computer. Suunto Ocean is only compatible with Suunto Tank POD transmitters. Suunto Tank POD transmits data using 123 kHz band. The communication from the Tank POD to the dive computer is one-way, meaning the dive computer does not send anything to the Tank POD.
Enabled features when Suunto Ocean is paired to Suunto Tank POD:
Tank pressure from up to 5 gas cylinders
Actual gas consumption for the active gas (L/min or cu ft/min)
Remaining gas time for the active gas
Configurable tank pressure alarms
Logging of start, end and the used pressure
Logging of average gas consumption for every gas with Tank POD
Units in bar or PSI
 To install and link a Suunto Tank POD :
Install the Tank POD as described in the Tank POD quick guide or in the Tank POD user guide .
To ensure the most accurate tank pressure readings, Suunto recommends that you install Suunto Tank POD so it is on the same side as you wear your Suunto Ocean .
- After installing the Tank POD and opening the valve, wait for the green LED on the Tank POD to flash.
- Go to the Tank POD menu under Dive options . If your Tank POD is active and in range you see the Tank POD serial number listed.
- Select the correct Tank POD and check its battery status and the tank pressure.
- Select the correct gas from the list to link with your Suunto Tank POD (if diving with multiple gases).
- Make sure the tank size is correct to enable correct gas consumption metering.
Go Back to the main menu and you will see your Tank POD serial number listed under the Tank POD menu.
  Alternatively, you can link the Suunto Tank POD(s) from the Gases menu  :
- In the Gases menu, select the gas you want your Tank POD to link with.
- Go to the Edit gas view and scroll to the Tank POD setting.
Make sure the Tank POD has been activated and that it is within range. Select your Tank POD serial number from the list.
If you have linked the same Tank POD to several gases, remember to check before your dive that you have the right active gas and that you have your Tank POD linked. In the dive main views, only one tank pressure is shown and corresponds to the active gas.
WARNING:
If there are several divers using Tank PODs, always check before you dive that the POD number of your selected gas corresponds to the serial number on your POD.
You can find the serial number on the metal base and also on the cover of the Tank POD.
Repeat the procedure above for additional Tank PODs and select different gases for each POD.
  To unlink and remove your Tank POD from a specific gas:
Select the gas you want to remove the Tank POD from in the Gases menu.
De-select the Tank POD you want to remove (check the serial number).
Your Tank POD is removed from the selected gas list.
You can also unlink the Tank POD from the Tank POD menu.
You can only unlink your Tank POD once it is active and transmitting.
Always use a backup analog submersible pressure gauge as a redundant source of gas pressure information.
For Suunto Tank POD related information, please see the instructions provided with the product.
Tank pressure
Once your Suunto Ocean is linked to a Suunto Tank POD, you can follow the tank pressure both in the switch window and on the arch in the tank pressure view. See Key information during diving on how tank pressure is shown on the arch.
The following examples show different tank pressures:
Tank pressure is 125 bar:
Tank pressure is 50 bar:
An extra tank pressure alarm is set to 100 bar:
If you have not paired a Suunto Tank POD, the switch window tank pressure will read No Tank Pod. If A Tank POD is paired but no data is being received, the field shows - -. This may be because the POD is not in range, the tank is closed, or the POD battery is low.
LED lights may interfere with the Tank pressure signal.
Gas consumption
You can follow your actual gas pressure during your dive from the switch window on the watch screen. You can also see the average gas consumption from the dive in the dive summary in the device and in Suunto app.
The Gas consumption data on the screen refers to your real-time consumption rate of gas during a dive at the depth you are at. To calculate your personal breathing rate, Suunto Ocean uses respiratory minute volume (RMV) which is the volume of gas your lungs experience per minute, measured in L/min or cu ft/min. For accurate gas consumption, you need to define the correct tank size for the gas in the Edit gas menu. See Edit gas . The default tank size is always 12 L (80 cu ft) .
The RMV formula used in Suunto Ocean to calculate the gas consumption during the dive is the following:
The calculation is based on actual depth and the average used gas volume (in atmospheric pressure) calculated within in a varying 50 – 170-second window.
| V gas (liters) | Gas volume in atmospheric pressure |
| RMV liters/minute | Depth compensated SAC |
| T 1 | Time at the beginning of the window |
| T 2 | Time at the end of the window |
| Depth (T) | Depth |
| V T1 | V gas (liters) at the beginning of the window |
| V T2 | V gas (liters) at the end of the window |
| D average | Average depth in time window |
To calculate gas volume, Suunto Ocean uses the following formula:
You can see your average gas consumption after the dive in the dive summary. The value shows the average gas consumption value, calculated from all the gas consumption values during the dive.
Since the real-time consumption values are based on data collected within a time window, the gas consumption value might not be populated immediately at the beginning of the dive. The values might also be higher due to using low pressure hose to control buoyancy in BCD or exposure suit.
The gas calculations also take into consideration the gas compressibility and temperature variations to provide more accurate values.
Gas time
The Gas time value in the switch window indicates the maximum time (in minutes) you can stay at the current depth and ascend to the surface (at an ascent rate of 10 m/min) with and end pressure of 35 bar (508 psi). The time is based on the tank pressure value, tank size and your current breathing rate and depth.
Gas time is calculated using the following formula:
Safety stops and decompression stops are not included in the Gas time calculations.
Algorithm settings
Suunto's decompression model development originates from the 1980s when Suunto implemented Bühlmann's model based on M-values in Suunto SME. Since then, research and development has been ongoing with the help of both external and internal experts.
Bühlmann 16 GF algorithm
The Bühlmann decompression algorithm was developed by Swiss physician Dr. Albert A. Bühlmann, who researched into decompression theory starting from 1959. The Bühlmann decompression algorithm is a theoretical mathematical model describing the way in which inert gases enter and leave the human body as the ambient pressure changes. Several versions of the Bühlmann algorithm have been developed over the years and adopted by many dive computer manufacturers. Suunto Ocean is using Suunto’s Bühlmann 16 GF dive algorithm that is based on the Bühlmann ZHL-16C model that we have implemented our own code for. The algorithm can be modified by using gradient factors to set the level of conservatism.
Because any decompression model is purely theoretical and does not monitor the actual body of a diver, no decompression model can guarantee the absence of DCS. Always take your personal factors, the planned dive, and your dive training into consideration when choosing the appropriate gradient factors for your dive.
Gradient Factors
Gradient Factor (GF) is a parameter to create various levels of conservatism. GFs are divided into two separate parameters, Gradient Factor Low and Gradient Factor High.
By using GF with the Bühlmann algorithm, you can set your safety margin for the dive by adding conservatism to control when different tissue compartments reach their acceptable M‑value. A Gradient Factor is defined as percentage of the M-value Gradient and defined from 0% to 100%.
A commonly used combination is GF Low 30% and GF High 70%. (Also written as GF 30/70.) This setting means that the first stop would take place once the leading tissue reaches 30% of its M-value. The lower the first number is, the less supersaturation is allowed. As a result, the first stop is required when you are deeper. A Gradient Factor of 0% represents the ambient pressure line and a Gradient Factor of 100% represents the M-value line.
In the following illustration, GF Low is set to 30% and the leading tissue compartments react to the 30% limit of the M-value. At this depth the first decompression stop takes place.
When the ascent continues, the GF moves from 30% to 70%. GF 70 indicates the amount of supersaturation allowed when you get to the surface. The lower the GF High value is, the longer shallow stop is needed to off-gas before surfacing. In the following illustration, GF High is set to 70% and the leading tissue compartments react to the 70% limit of M-value.
At this point you can come back to the surface and finish your dive.
GF Low % effect on dive profile is illustrated in the following picture. It shows how GF Low % determines the depth where the ascent starts slowing down and the depth of the first decompression stops. The illustration shows how the different GF Low % values change the depth of the first stop. The higher the GF Low % value is, the shallower the first stop occurs.
If GF Low % value is too low, some tissues may still on-gas when the first stop occurs.
GF High % effect on the dive profile is illustrated in the following picture. It shows how GF High % determines the decompression time spent in the shallow phase of the dive. The higher the GF High % value is, the shorter the total dive time is, and the less time the diver spends in shallow water. If GF High % is set to a lower value, the diver spends more time in shallow water and the total dive time gets longer.
You can adjust the gradient factors. The default conservatism setting in the Suunto Ocean dive computer is set to medium (40/85). You can adjust the setting to more aggressive or more conservative than the default value. Select from the preset levels or set your own custom level.
The preset values are the following:
Low: 45/95
Medium: 40/85 (default)
High: 35/75
For recreational dives, a high conservatism setting (35/75) gives you more buffer to avoid decompression requirements. Low conservatism setting (45/95) gives you more NDL time but also a lower buffer so it is a more aggressive setting.
There are several risk factors that can affect your susceptibility to DCS, such as your personal health and behavior. Such risk factors vary between divers, as well as from one day to another.
The personal risk factors which tend to increase the possibility of DCS include the following:
- exposure to low temperature – water temperature less than 20 °C (68 °F)
- below average physical fitness level
- age, particularly over the age of 50
- fatigue (from over exercising, lack of sleep, exhausting travel)
- dehydration (affects circulation and may slows down off-gassing)
- stress
- tight fitting equipment (may slows down off-gassing)
- obesity (BMI that is considered obese)
- patent foramen ovale (PFO)
- exercise before or after dive
- strenuous activity during a dive (increases bloodflow and brings additional gas to tissues)
WARNING:
Do not edit Gradient Factor values until you understand the effects. Some Gradient Factor settings can cause a high risk of DCS or other personal injury.
Deco profile
Deco profile can be selected in Dive options > Algorithm > Deco profile .
Continuous decompression profile
Traditionally, since Haldane’s 1908 tables, decompression stops have always been deployed in fixed steps such as 15 m, 12 m, 9 m, 6 m and 3 m. This practical method was introduced before the advent of dive computers. However, when ascending, a diver actually decompresses in a series of more gradual ministeps, effectively creating a smooth decompression curve. The advent of microprocessors has allowed Suunto to more accurately model the actual decompression behavior. During any ascent involving decompression stops, Suunto dive computers calculate the point at which the control compartment crosses the ambient pressure line (that is the point at which the tissue’s pressure is greater than the ambient pressure), and off-gassing starts. This is referred to as the decompression floor. Above this floor depth and below the ceiling depth is the decompression window. The range of the decompression window is dependent on the dive profile.
The optimal decompression occurs in the decompression window, which is displayed by both upward and downward arrows next to the depth value. If the ceiling depth is violated, a downward pointing arrow and an audible alarm will prompt the diver to descend back to the decompression window.
Off-gassing in the leading fast tissues will be slow at or near the floor because the outward gradient is small. Slower tissues may be still on-gassing and given enough time, the decompression obligation may increase, in which case the ceiling may move down and the floor may move up. The decompression floor represents the point at which the algorithm is seeking to maximize bubble compression, while the decompression ceiling is maximizing off-gassing.
The added advantage of having a decompression ceiling and floor is that it recognizes that in rough water, it might be difficult to maintain the exact depth to optimize decompression. By maintaining a depth below the ceiling but above the floor, the diver is still decompressing, although slower than optimal, and provides an additional buffer to minimize the risk that waves will lift the diver above the ceiling. Also, the continuous decompression curve used by Suunto provides a much smoother and a more natural decompression profile than the traditional “step” decompression.
Stepped decompression profile
In this decompression profile, the ascent has been divided into traditional 3 m (10 ft) steps or stages.
In this model the diver decompresses at traditional fixed depths. The ceiling value in the switch window will show the depth of the next step and once the diver reaches the decompression window, a timer starts showing the needed length of the decompression stop.
See Example - Multigas mode for an example decompression dive.
Altitude setting
The Altitude setting automatically adjusts the decompression calculation according to the given altitude range. You can find the setting under Dive options » Algorithm » Altitude and select from three ranges:
- 0 – 300 m (0 – 980 ft) (default)
- 300 – 1500 m (980 – 4900 ft)
- 1500 – 3000 m (4900 – 9800 ft)
As a result, the allowed no decompression stop limits are considerably reduced.
The atmospheric pressure is lower at high altitudes than at sea level. After traveling to a higher altitude, you will have additional nitrogen in your body, compared to the equilibrium situation at the original altitude. This 'additional' nitrogen is released gradually over time and equilibrium is restored. Suunto recommends that you acclimatize to a new altitude by waiting at least three hours before making a dive.
Before high-altitude diving, you need to adjust the altitude setting of your dive computer so that the calculations take into account the high altitude. The maximum partial pressures of nitrogen allowed by the mathematical model of the dive computer are reduced according to the lower ambient pressure.
WARNING:
Traveling to a higher elevation can temporarily cause a change in the equilibrium of dissolved nitrogen in the body. Suunto recommends that you acclimatize to the new altitude before diving. It is also important that you do not travel to a significantly high altitude directly after diving to minimize the risk of DCS.
WARNING:
SET THE CORRECT ALTITUDE SETTING! When diving at altitudes greater than 300 m (980 ft), the altitude setting must be correctly selected in order for the computer to calculate the decompression status. The dive computer is not intended for use at altitudes greater than 3000 m (9800 ft). Failure to select the correct altitude setting or diving above the maximum altitude limit will result in erroneous dive and planning data.
If you are doing repetitive dives at an altitude other than the previous dive altitude, change altitude setting to correspond to the next dive after the previous dive ended. This ensures more accurate tissue calculations.
Safety stop time
A safety stop is always recommended for every dive over 10 meters (33 ft). You can adjust the safety stop settings as follows:
3 min: The safety stop is always a 3-minute stop, even after the last decompression stop. The safety stop time is not included in TTS (time to surface).
4 min: The safety stop is always a 4-minute stop, even after the last decompression stop. The safety stop time is not included in TTS (time to surface).
5 min: The safety stop is always a 5-minute stop, even after the last decompression stop. The safety stop time is not included in TTS (time to surface).
Always OFF: No safety stop is shown during the dive.
Adjusted: A 3-minute safety stop is added after decompression, but the duration of the stop is adjusted based on the dive profile. This means that it can be shorter if the time is spent in the shallow. The predicted time is included in TTS (time to surface).
Ascent speed violation during dive does not make the safety stop time longer.
See Safety stops .
Last stop depth
You can adjust the last stop depth for decompression dives under Dive options » Algorithm » Last deco stop . There are two options: 3 m and 6 m (9.8 ft and 19.6 ft).
By default, the last stop depth is 3 m (9.8 ft).
This setting does not affect the ceiling depth on a decompression dive. The last ceiling depth is always 3 m (9.8 ft).
Consider setting the last stop depth to 6 m (19.6 ft) when you dive in rough sea conditions and stopping at 3 m (9.8 ft) is challenging.
Diving with Suunto Ocean
Safety stops
A three (3) minute Safety stop is always recommended for every dive over 10 meters (33 ft). When a safety stop is required, the minimum ceiling value (3 m) appears in the switch window.
The time for a safety stop is calculated when you are between 2.4 and 6 m (7.9 and 20 ft).
This is presented with up and down arrows on the left side of the stop depth value. Safety stop time is shown in minutes and seconds. The preferred safety stop time can be set in the Algorithm menu under Dive options .
There are two types of safety stops: voluntary and mandatory. Safety stop is mandatory if exceeding the suggested maximum ascent speed during the dive. If the stop is mandatory, ascending shallower than 2.4 m will trigger red arrows in the window indicator. If the stop is non-mandatory, only the yellow arrow is used.
If the depth goes below 6 m (20 ft), the safety stop timer will stop and resume counting once you are again inside the safety stop window. Once the timer shows zero, the stop is done and you can ascend to the surface.
If you ignore the safety stop, there will be no penalty. However, Suunto always recommends that you perform a safety stop for every dive to minimize the risk of DCI.
If you set the safety stop setting to off, there will be no safety stop indications when you arrive to the safety stop window.
Decompression dives
When you exceed the no-decompression limit, Suunto Ocean provides the decompression information required for ascending. Ascent information is always presented with two values:
- Decompression time (also referred to as Time to surface): optimum ascent time in minutes to surface with given gases
- Ceiling: depth that you should not go above
WARNING:
NEVER ASCEND ABOVE THE CEILING! You must not ascend above the ceiling during your decompression. In order to avoid doing so by accident, you should stay somewhat below the ceiling.
Once the No deco time is at 0 min, the display area will change to show the Deco time , the ceiling value will be displayed in the switch window and the arch will turn to orange indicating the same deco time. An alarm is also triggered that can be confirmed with any button press.
Deco time is referring to the recommended ascent time in minutes to the surface (TTS).
WARNING:
YOUR ACTUAL ASCENT TIME MAY BE LONGER THAN DISPLAYED BY THE DIVE COMPUTER! The ascent time will increase if you: (1) remain at depth, (2) ascend slower than 10 m/min (33 ft/min), (3) make your decompression stop deeper than at the ceiling, and/or (4) forget to change the used gas mixture. These factors might also increase the amount of breathing gas required to reach the surface.
Diving with multiple gases and dismissing a gas switch prompt will provide you with inaccurate Time to surface values and longer decompression stops than predicted.
The ceiling value indicates the first decompression stop depth.
You can set the last stop depth to 3.0 m or 6.0 m (the default depth is 3.0 m) in the Algorithm settings. See Last stop depth .
On a decompression dive, different stop types can be present:
Decompression stop : A compulsory stop if diving with a Stepped decompression profile (see Deco profile ). Decompression stops occur at fixed 3 m (10 ft) intervals.
Safety stop : If safety stop time has been set, you will have an extra safety stop after the last decompression stop. Safety stop is always non mandatory for decompression dives.
There is a decompression window at 3 m (9,8 ft) between the decompression floor and decompression ceiling. The closer to the ceiling you stay, the more optimal the decompression time is.
When you ascend close to the ceiling depth and enter the decompression window area, two arrows appear next to the depth number.
If diving with a Stepped deco profile, a timer will start the countdown when entering the decompression window and the ceiling is the same for a specific time and then moves upwards 3 m (9.8 ft) at a time.
Inside the decompression window (Stepped profile):
In the Continuous ascent mode, the ceiling is constantly decreasing while you are near the ceiling depth, providing continuous decompression with optimum ascent time.
Inside the decompression window (Continuous profile):
If you ascend above the ceiling depth, there is still a safe margin area, equalling to the ceiling depth minus 0.6 meters (2 ft). In this safe margin area, decompression calculation still continues, but you are advised to go down below the ceiling depth. This is indicated with a downward pointing yellow arrow next to the depth value.
The following is displayed using the Stepped decompression profile:
The following is displayed using the Continuous decompression profile:
If you go above the safe margin area, the decompression calculation is paused until you go back down below this limit. An audible alarm and a downward pointing red arrow in front of the ceiling depth value indicate unsafe decompression. If you ignore the alarm and stay above the safe margin for three minutes, the stop is considered missed and an algorithm violation notification will appear.
Suunto Ocean does not lock after you confirm the algorithm deviation trigger alert. Suunto Ocean continues showing the original decompression plan even if the decompression stop is violated. A red warning will appear in the window and it will stay in the diving window until the required decompression stops are cleared or after 48 hours.
Algorithm violation can also occur in the following situations:
In all of the cases, the algorithm deviation icon will appear in the dive window, but the algorithm will function as normal. If an algorithm deviation has occurred during the dive, you will also see a header in the dive log and in Suunto app.
WARNING:
Only perform decompression diving if you have received proper training to do so.
Surface and no-fly time
After a dive, Suunto Ocean displays surface time since the previous dive and a countdown time for recommended no-fly time in the watch face and in the dive stats widgets. You will see a red airplane icon and a red arch on the watch face as long as the no-fly time is present. The arch shows the estimated time for when the no-fly time will end.
The following screen shows that 5 hours and 5 minutes have passed since the last scuba dive, and the no-fly time will end at 2.30:
The following screen shows that the no-fly time has ended.
No-fly time is the minimum surface time after a dive which is recommended to wait before entering and flying with an airplane. It is always at least 12 hours and equals desaturation time when it is more than 12 hours. For desaturation times shorter than 75 minutes, no-fly time is not displayed.
If an algorithm deviation has occurred during the dive, the no-fly time is always 48 hours.
WARNING:
The Suunto Ocean device has a gyro-assisted compass that allows you to orient yourself in relation to magnetic north. While diving, you can access the compass by pressing the middle button (compass seen on arch) or see the heading in degrees with cardinal and inter cardinal direction in the bottom switch window by pressing the lower button.
You can set the bearing by long pressing middle button. Once the bearing is set, a notification is displayed and the bearing pointer appears on the compass arch to indicate the set heading. When the bearing is set, the bearing pointer is locked on the compass arch to indicate the set heading. The orange slot located on the opposite side of the pointer is to indicate the reciprocal direction (180 degrees).
The bearing can be cleared at any time by long pressing the middle button again.
The heading value is available in the switch window and can be used independently without the compass arch. If the heading value visible in the switch window and the set heading are aligned, the switch window value turns yellow or orange (reciprocal direction).
The margin of the switch window color change is +/-5° compared to the set value so that the state is visible.
The compass calibrates itself when in use, but if a recalibration is needed, a prompt pops up in the switch window. To calibrate the compass, turn and tilt the watch in a figure-8.
Example - Single gas mode
The following example shows a no-decompression dive in Single gas mode with Air and a Suunto Tank POD.
Pre-dive screen:
 Always start your dive from the pre-dive screen to ensure you’ll have a GPS signal, enough battery and tank pressure (if linked to Suunto Tank POD), diving with the right gas and you understand the MOD of the active gas. If the Suunto Tank pod battery is low or you have forgotten to change tanks and the tank pressure is low, you’ll see warnings on the pre-dive screen.
Once descending over 10 m, a safety stop indication will appear in the switch window, indicating a safety stop ceiling of 3 m. No deco time shows > 99, meaning the maximum time you can spend at this depth is greater than 99 min.
 Once you continue the descent, the No deco time will show a smaller value. No deco time is always in minutes.
If your No deco time reaches 5 min, a yellow caution alarm will be triggered. When ascending and the No deco value is increased, the alarm will be resolved. You can also mute the alarm with any button press. Continuing to stay at deeper depths despite the No deco alarm can cause decompression obligation. Do not dive decompression dives unless you’ve sufficient training.
You can set your own tank pressure alarms to help you keep track of critical limits, like turn pressure. If set, Suunto Ocean alerts you when reaching 100 bar (1450 psi).
You can follow the ascent speed from the Ascent speed indicator. If passing the suggested maximum of 10 m/min, the indicator will turn red and trigger an audible and vibration alarm. This can be acknowledged by pressing any button.
When you are between 2.4 and 6 m (7.9 and 20 ft), a safety stop timer will appear and count down until the suggested stop. Once the stop is performed, a Stop done notification will appear.
The following example shows a decompression dive to 40 m in Multigas mode and with the following gases: NX28 (main gas), NX99 decompression gas.
Pre dive screen – showing the active gas (NX28), set ppO2 and MOD.
NDL alarm at 5 min.
NDL reaches 0 and decompression is needed. The gauge changes to orange indicating Deco time. The NDL area shows the TTS value including deco stops and safety stop. The ceiling value is displayed in the switch window.
The ceiling value is 9 m so you can ascend to this depth within the ascent speed limits. Once arriving close to the ceiling depth and entering the decompression window area, two arrows appear next to the depth number and a timer appears in the Deco field indicating a deco stop of 1 min. Once the countdown is 0, the TTS value is displayed again and the ceiling value has changed 3 m shallower, to 6 m.
Gas change at 6 m. The decompression time is always calculated with the assumption that you use all the gases found in the Gas list. Once ascending to 6 m, a gas change to NX99 will be suggested. Once switch is made, the information of the current gas appears. If you decide to dismiss the gas change, the decompression information will not be accurate.
Arriving at the last stop. Once the decompression time is cleared, the deco badge disappears and the stop turns into a safety stop. In this example, the safety stop is set to Adjusted, so the countdown starts at 1'30 due to longer time at 6 m.
If you ascend above the decompression or safety stop window, an arrow and a warning will be triggered and prompt you to descend back to the window.
Once all stops are done, the Stop done info will appear in the switch window and it is then safe to ascend to surface.
Dive planner
The dive planner helps you quickly plan your next dive. The planner displays the available no decompression time for your dive based on depth, algorithm settings and current surface time.
How to plan a dive
Before you start planning your next dive in the Planner menu, set the following:
The planner displays the active gas defined for the dive mode. You can modify the gas settings under the Gases menu (see Gases ).
The surface interval is calculated automatically from the end of the previous dive. Use the upper and lower buttons to adjust the value in 10-minute increments to reflect the planned surface interval. The maximum value is 48 hours.
Use the upper and lower buttons to adjust the planned depth. You can see the NDL time for the specific depth at the bottom of the screen.
Press the upper button to return to the pre-dive menu or press the middle button to return to the beginning of the planner.
The NDL planner can only be used for planning dives without the need for decompression stops.
